кусок конфига
aaa authentication login local local
aaa authentication enable default enable
username Antares password 0 ********
enable password 0 ********* level 15
не пускает в web, не проходит авторизация
вот выдержка из мануала к 2970-24S
Http uses enable as the access password. You need to set the password enable if you
want to perform authentication for http access. The password  enable is set in global
configuration mode using the following command:
Enable password {0|7} line
  • 1 month later...
  • 4 weeks later...
