имеем Catalyst 3560G на ядре сети (OSPF, PIM, MSDP и тд тп) (C3560-ADVIPSERVICESK9-M), Version 12.2(44)SE1, RELEASE SOFTWARE (fc1))
неожиданно перестал отвечать на пинг запросы, предварительно посыпались сообщения в syslog:
Aug 30 16:19:18 10.16.0.7 5761: Aug 30 16:16:04.486: %OSPF-5-ADJCHG: Process 1, Nbr 10.15.10.2 on Vlan460 from FULL to DOWN, Neighbor Down: Dead timer expi
Aug 30 16:19:18 10.16.0.7 5762: Aug 30 16:16:04.528: %OSPF-5-ADJCHG: Process 1, Nbr 10.15.6.2 on Vlan506 from FULL to DOWN, Neighbor Down: Dead timer expir
Aug 30 16:19:19 10.16.0.7 5763: Aug 30 16:16:05.577: %OSPF-5-ADJCHG: Process 1, Nbr 10.15.36.2 on Vlan335 from 2WAY to DOWN, Neighbor Down: Dead timer expi
Aug 30 16:19:19 10.16.0.7 5764: Aug 30 16:16:06.583: %OSPF-5-ADJCHG: Process 1, Nbr 10.15.35.18 on Vlan345 from FULL to DOWN, Neighbor Down: Dead timer exp
Aug 30 16:19:19 10.16.0.7 5765: Aug 30 16:16:06.583: %OSPF-5-ADJCHG: Process 1, Nbr 10.15.35.18 on Vlan335 from 2WAY to DOWN, Neighbor Down: Dead timer exp
Aug 30 16:19:20 10.16.0.7 5766: Aug 30 16:16:06.835: %OSPF-5-ADJCHG: Process 1, Nbr 10.16.0.5 on Vlan505 from FULL to DOWN, Neighbor Down: Dead timer expir
Aug 30 16:19:20 10.16.0.7 5767: Aug 30 16:16:07.548: %OSPF-5-ADJCHG: Process 1, Nbr 10.16.20.2 on Vlan462 from FULL to DOWN, Neighbor Down: Dead timer expi
Aug 30 16:19:20 10.16.0.7 5768: Aug 30 16:16:07.850: %OSPF-5-ADJCHG: Process 1, Nbr 10.15.35.2 on Vlan335 from 2WAY to DOWN, Neighbor Down: Dead timer expi
Aug 30 16:19:22 10.16.0.7 5769: Aug 30 16:16:08.530: %OSPF-5-ADJCHG: Process 1, Nbr 10.15.6.2 on Vlan446 from FULL to DOWN, Neighbor Down: Dead timer expir
Aug 30 16:19:39 10.16.0.7 5770: Aug 30 16:16:25.651: %OSPF-5-ADJCHG: Process 1, Nbr 10.15.36.2 on Vlan350 from FULL to DOWN, Neighbor Down: Dead timer expi
Aug 30 16:20:03 10.16.0.7 5771: Aug 30 16:16:49.835: %PIM-5-NBRCHG: neighbor 10.15.4.2 DOWN on interface Vlan443 DR
Aug 30 16:20:03 10.16.0.7 5772: Aug 30 16:16:49.835: %PIM-5-DRCHG: DR change from neighbor 10.15.4.2 to 10.15.4.1 on interface Vlan443
Aug 30 16:20:05 10.16.0.7 5773: Aug 30 16:16:51.991: %PIM-5-NBRCHG: neighbor 10.15.6.2 DOWN on interface Vlan446 DR
Aug 30 16:20:05 10.16.0.7 5774: Aug 30 16:16:51.991: %PIM-5-DRCHG: DR change from neighbor 10.15.6.2 to 10.15.6.1 on interface Vlan446
Aug 30 16:20:05 10.16.0.7 5775: Aug 30 16:16:52.008: %PIM-5-NBRCHG: neighbor 10.15.11.2 DOWN on interface Vlan702 DR
Aug 30 16:20:05 10.16.0.7 5776: Aug 30 16:16:52.008: %PIM-5-DRCHG: DR change from neighbor 10.15.11.2 to 10.15.11.1 on interface Vlan702
Aug 30 16:20:09 10.16.0.7 5777: Aug 30 16:16:56.093: %OSPF-5-ADJCHG: Process 1, Nbr 10.15.4.5 on Vlan514 from FULL to DOWN, Neighbor Down: Dead timer expir
Aug 30 16:20:12 10.16.0.7 5778: Aug 30 16:16:58.828: %OSPF-5-ADJCHG: Process 1, Nbr 10.15.35.18 on Vlan356 from FULL to DOWN, Neighbor Down: Dead timer exp
Aug 30 16:20:12 10.16.0.7 5779: Aug 30 16:16:58.995: %PIM-5-NBRCHG: neighbor 10.15.5.2 DOWN on interface Vlan445 DR
Aug 30 16:20:12 10.16.0.7 5780: Aug 30 16:16:58.995: %PIM-5-DRCHG: DR change from neighbor 10.15.5.2 to 10.15.5.1 on interface Vlan445
Aug 30 16:20:16 10.16.0.7 5781: Aug 30 16:17:02.460: %PIM-5-NBRCHG: neighbor x.x.x.x DOWN on interface Vlan597 non DR
Aug 30 16:20:16 10.16.0.7 5782: Aug 30 16:17:02.779: %PIM-5-NBRCHG: neighbor 10.15.36.26 DOWN on interface Vlan356 DR
Aug 30 16:20:16 10.16.0.7 5783: Aug 30 16:17:02.779: %PIM-5-DRCHG: DR change from neighbor 10.15.36.26 to 10.15.36.25 on interface Vlan356
Aug 30 16:20:17 10.16.0.7 5784: Aug 30 16:17:04.113: %PIM-5-NBRCHG: neighbor 10.15.9.2 DOWN on interface Vlan449 DR
Aug 30 16:20:17 10.16.0.7 5785: Aug 30 16:17:04.113: %PIM-5-DRCHG: DR change from neighbor 10.15.9.2 to 10.15.9.1 on interface Vlan449
Aug 30 16:20:17 10.16.0.7 5786: Aug 30 16:17:05.010: %PIM-5-NBRCHG: neighbor 10.15.7.2 DOWN on interface Vlan447 DR
Aug 30 16:20:17 10.16.0.7 5787: Aug 30 16:17:05.010: %PIM-5-DRCHG: DR change from neighbor 10.15.7.2 to 10.15.7.1 on interface Vlan447
Aug 30 16:20:22 10.16.0.7 5788: Aug 30 16:17:09.162: %PIM-5-NBRCHG: neighbor 10.15.8.2 DOWN on interface Vlan448 DR
Aug 30 16:20:22 10.16.0.7 5789: Aug 30 16:17:09.162: %PIM-5-DRCHG: DR change from neighbor 10.15.8.2 to 10.15.8.1 on interface Vlan448
Aug 30 16:20:22 10.16.0.7 5790: Aug 30 16:17:09.590: %PIM-5-NBRCHG: neighbor 10.15.36.2 DOWN on interface Vlan350 DR
L3, L2 функции стали недоступны
после ребута по питанию не грузился (моргала лампа SYST), после второго ребута - загрузился проработал 3 минуты и опять стал сбрасывать OSPF, PIM сессии.
цепляю консоль: в логах ничего другого кроме neighbor down нету, делаю reload вижу следующее:
Reload command.
Base ethernet MAC Address: 00:1f:26:fc:c4:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 458 files, 6 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 19496448
flashfs[0]: Bytes available: 13017600
flashfs[0]: flashfs fsck took 8 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "c3560-advipservicesk9-mz.122-44.SE1.bin"...c3560-advipservicesk9-mz.122-44.SE1.bin: no such device
Error loading "c3560-advipservicesk9-mz.122-44.SE1.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c3560-advipservicesk9-mz.122-44.SE1.bin"...@@@@@@@@@@@@@@@@@@@@@@@@
с 3-го ребута, все нормально загрузилось и заработало. тьфу тьфу тьфу.
понимаю что поздно цепанул консоль, поспешил с ребутом.
но может есть идеи о причинах такой аварии?
P.S.
Проработал без ребута 2-3 года.
Edited by dbask
У вас в boot указано c3560-advipservicesk9-mz.122-44.SE1.bin
Нужно указывать вместе с директорией: flash:/c3560-advipservicesk9-mz.122-44.SE1.bin
Ругнулось что нет такого файла и цепануло автоматом то что лежало на флеше. Все нормально и правильно.
Оспф падает ибо Dead timer expired. Проверяйте конфиги, если все верно - включайте дебаг и смотрите.
Pim падает вдогонку.
какая то фигня с ospf все соседи отваливаются.. (естественно сраз теряется маршрутизация и до циски достучаться не можете..)
возможно проблема и не в этой циске.. а с соседями.. там где нибуть штормик или еще чего, загружается проц на 100% и перестает коммутатор обрабатывать l3 (все что идет на cpu)
абсолютно нормальное поведение если при обновлении прошивки не указали в конфиге какую прошивку грузить (или указали не существующую или неправильный путь указали)
на сайте циски мона почитать как железка себя ведет и в каком порядке и в какой памяти ищет прошивку и по какому алгоритму..
Edited by mukca
  • 4 months later...
ребят есть вопросик примерно такого же плана у меня C3560-48TS.. ничего не предвещало беды но тут я захотел в ги01 вставить сфп модуль.. ну вставил... все клево, но тут захотелось мне расшатить его и посмотреть поднялась ли оптика на порту, и бац! недоступен был секунд на 10!!!
ну и в логах вот такое чудо
0, changed state to up
066763: Jan 23 07:46:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan130
8, changed state to up
066764: Jan 23 07:46:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan131
066765: Jan 23 07:46:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan154
6, changed state to up
066766: Jan 23 07:46:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan222
2, changed state to up
066767: Jan 23 07:46:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan300
066768: Jan 23 07:46:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan301
1, changed state to up
но аптайм неизменился!)
так тут и нет ничего, что было бы даун, пишет только что состояние изменилось на ап, надо больше логов
Syslog logging: enabled (3562 messages dropped, 0 messages rate-limited, 51 flus
hes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 63173 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
Trap logging: level debugging, 63633 message lines logged
Log Buffer (8192 bytes):
col on Interface Vlan721, changed state to up
066715: Jan 23 07:46:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan725
066716: Jan 23 07:46:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan735
066717: Jan 23 07:46:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan751
066718: Jan 23 07:46:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan767
066719: Jan 23 07:46:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan769
066720: Jan 23 07:46:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan773
066721: Jan 23 07:46:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan780
066722: Jan 23 07:46:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan781
066723: Jan 23 07:46:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan782
066724: Jan 23 07:46:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan801
066725: Jan 23 07:46:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan802
066768: Jan 23 07:46:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan3051
066769: Jan 23 07:46:27: %OSPF-5-ADJCHG: Process 2118, Nbr 192.168.5.210 on Vlan
2470 from LOADING to FULL, Loading Done
066770: Jan 23 07:55:40: %SYS-5-CONFIG_I: Configured from console by fominyh on
vty5 (77.221.200.10)
066771: Jan 23 08:54:55: %PLATFORM_UCAST-6-PREFIX: One or more, more specific p
refixes could not be programmed into TCAM and are being covered by a less specif
ic prefix
066772: Jan 23 09:03:46: %PLATFORM_UCAST-6-PREFIX: One or more, more specific p
ic prefix
066773: Jan 23 09:06:44: %PLATFORM_UCAST-6-PREFIX: One or more, more specific p
ic prefix
066774: Jan 23 09:22:08: %PLATFORM_UCAST-6-PREFIX: One or more, more specific p
ic prefix
это все что было!)
Edited by fenikssss
