Есть циска 4900m c 10gb модулем x2-10gb-sr и asr1002 с модулем 10gb-mm-sr. порт не поднимается, не могу понять почему, может какая то не совместимость ?
TenGigabitEthernet1/2 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet Port, address is 0007.7dbd.9781 (bia 0007.7dbd.9781)
Description: ADSLROUTER
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 10Gb/s, link type is auto, media type is 10GBase-SR
input flow-control is off, output flow-control is off
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output never, output hang never
Last clearing of "show interface" counters never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
Router_ADSL#show interfaces tenGigabitEthernet 0/1/0
TenGigabitEthernet0/1/0 is down, line protocol is down
Hardware is SPA-1X10GE-L-V2, address is a493.4c48.7f10 (bia a493.4c48.7f10)
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive not supported
Full Duplex, 10000Mbps, link type is force-up, media type is 10GBase-SR/SW
output flow-control is on, input flow-control is on
Last input 00:11:43, output 00:11:43, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
20 packets input, 1280 bytes, 0 no buffer
Received 20 broadcasts (0 IP multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
20 packets output, 1280 bytes, 0 underruns
0 output errors, 0 collisions, 8 interface resets
0 unknown protocol drops
Может дело в патчкорде? Например волокна местами поменять?
Дело и в правду было в патчкордах, только не из за волокон, а из за того что я использовал одномодные патчкорды а нужно двухмодные.
ну слово двухмодные конечно не совсем корректно, но видя что модули SR (это и есть многомодовый интерфейс) могли-бы вы и сразу догадатся ))))
