Есть маршрутизатор Cisco 7401ASR
абонентам интернет раздаёт а на самом инета нет, в чём дело?
вот конфиг:
Router#sh run
Building configuration...
Current configuration : 3896 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname Router
boot-start-marker
boot system disk0:c7400-ik9o3s-mz.124-12.bin
boot-end-marker
no logging console
aaa new-model
aaa session-mib disconnect
aaa authentication login default local
aaa authentication ppp default group radius
aaa authorization network default group radius
aaa accounting delay-start
aaa accounting update periodic 5
aaa accounting network default start-stop group radius
aaa session-id common
clock timezone MSK 0
ip nbar pdlm disk0:bittorrent.pdlm
ip nbar pdlm disk0:directconnect.pdlm
ip nbar pdlm disk0:eDonkey.pdlm
ip cef
ip name-server 217.9.147.42
ip name-server 8.8.8.8
ip name-server 217.9.148.4
ip name-server 10.0.0.1
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.0 192.168.0.100
ip dhcp pool LOCAL
network 192.168.0.0 255.255.252.0
dns-server 10.0.0.1
default-router 192.168.0.1
no ip pxf
virtual-template 1 pre-clone 500
username хххххх privilege 15 secret 5 хххххххххххх
archive
log config
logging enable
hidekeys
class-map match-any p2p
match protocol bittorrent
match protocol directconnect
match protocol edonkey
policy-map limit-torrents
class p2p
police 2560000 480000 960000 conform-action transmit exceed-action drop violate-action drop
bba-group pppoe global
virtual-template 1
sessions max limit 8000
ac name nas1
sessions per-mac limit 1
sessions per-vlan limit 500
sessions auto cleanup
interface GigabitEthernet0/0
description BILLING
ip address 10.0.0.2 255.255.255.0
ip virtual-reassembly
duplex full
speed auto
media-type rj45
interface GigabitEthernet0/1
description LOCAL
ip address 192.168.0.1 255.255.252.0
duplex full
speed auto
media-type rj45
vlan-range dot1q 1 4048
pppoe enable group global
exit-vlan-config
no cdp enable
interface FastEthernet1/0
description INTERNET
ip address хх.хх.40.210 255.255.255.252
ip nbar protocol-discovery
ip nat outside
duplex full
service-policy input limit-torrents
service-policy output limit-torrents
interface Virtual-Template1
mtu 1492
ip unnumbered GigabitEthernet0/0
ip flow ingress
ip flow egress
autodetect encapsulation ppp
peer default ip address pool PPPoE
ppp max-bad-auth 3
ppp authentication chap
ppp timeout retry 3
ppp timeout authentication 45
ppp timeout idle 3600
ip route 0.0.0.0 0.0.0.0 хх.хх.40.209
ip flow-export source Virtual-Template1
ip flow-export version 5
ip flow-export destination 10.0.0.1 9996
no ip http server
no ip http secure-server
ip nat inside source static 10.0.0.1 interface FastEthernet1/0
ip access-list standard RW3
access-list 10 permit 192.168.0.2
access-list 10 deny any log
access-list 114 remark ** Remix DAY-Time ACL
access-list 114 permit ip any any time-range DAY-REMIX
access-list 115 remark ** NIGHT-Time ACL
access-list 115 permit ip any any time-range NIGHT-REMIX
snmp-server community public RO
snmp-server community private RW
radius-server attribute 8 include-in-access-req
radius-server attribute nas-port format e UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
radius-server attribute 31 mac format unformatted
radius-server host 10.0.0.1 auth-port 1812 acct-port 1813
radius-server retransmit 5
radius-server timeout 30
radius-server deadtime 1
radius-server key 7 03175E08140A35
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
access-class 10 in
privilege level 15
ntp clock-period 17180149
ntp server 62.117.76.142
periodic daily 8:00 to 23:59
periodic daily 0:00 to 7:59
end
Edited by phrozen
есть соединение
на нашей стороне интерфейс на 7401
на другом конце вышестоящий пров.
с интерфейсом хх.хх.40.209
я не могу пинговать хх.хх.40.209
но через это соединение проходит интернет абонентам и всё работает!
а также не пингуется нет с 7401
Ммм... Даже пароли выложили. :) Дело за малым, перебрать первых два октета телнетом :)
Help is on the way!
Edited by tartila
+ 1 о томже подумал (помоему автор из города киров или гдето рядом :D)
а может хост провайдера не отвечает на пинги :D
Edited by mukca
Вот эту фразу не понял: "а также не пингуется нет с 7401".
То, что не пингуется IP провайдера, не страшно. Там может быть запрет.
Вас так тонко троллят.
Люди здесь на форуме обитают опытные. Они все специалисты, и некоторые даже готовы делиться знаниями. Для этого, правда, необходимо внятно объяснить ситуацию и суть вопроса.
phrozen, шучу, конечно.
Просто хотел сказать, что нужно просто сделать пинг с сорс адреса, который смотрит в интернет.
Когда делаете пинг без указания сорс, циска берет первый (могу быть не прав), в Вашем случае GigabitEthernet0/0
В общем, ping 8.8.8.8 source хх.хх.40.210 должен показать "наличие интернета".
нет инета всё равно!
циска время с ntp server не получает из за этого
достаточно CCNA книги купить и почитать... ИМХО
Сильно зависит от человека, учитывая что такие проблемы самостоятельно решаются долго и с помощью форума, лучше курсы
