Добрый день!
Нужен бордер(2 full view) + bras.
Выбрал asr1001.
Не могу найти в гайдах описание какое количество маршрутов поддерживает asr1001 с 4 Гб оперативы.
Киньте ссылку на мануал где такое написано.
ASR1002#show ip bgp summary
BGP router identifier 127.0.0.1, local AS number 65536
BGP table version is 22988969, main routing table version 22988969
115998 network entries using 17167704 bytes of memory
346916 path entries using 22202624 bytes of memory
48042/24123 BGP path/bestpath attribute entries using 6533712 bytes of memory
43868 BGP AS-PATH entries using 1859974 bytes of memory
187 BGP community entries using 5502 bytes of memory
1 BGP extended community entries using 24 bytes of memory
159 BGP route-map cache entries using 5724 bytes of memory
128 BGP filter-list cache entries using 2048 bytes of memory
BGP using 47777312 total bytes of memory
BGP activity 1005383/889385 prefixes, 35865671/35518755 paths, scan interval 60 secs
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
1.1.1.1         4        65500   25747   25738 22988834    0    0 2w2d           83
2.2.2.2         4        65500 3527692   25739 22988834    0    0 2w2d       115715
3.3.3.3         4        65500 3181523   45676 22988834    0    0 4w0d       115721
4.4.4.4         4        65001       0       0        1    0    0 6w4d     Idle (Admin)
5.5.5.5         4        65002 12687110  135162 22988834    0    0 12w1d      115379
ASR1002#show subscriber memory
 Allocator-Name                  In-use/Allocated            Count
 SSS SSF group m           :     303048/352776     ( 85%) [   8418] Chunk
 SSS SSF seg chu           :     600532/655956     ( 91%) [   5177] Chunk
 SSS SSF message           :          0/16592      (  0%) [      0] Chunk
 SSS SSF mgr mes           :          0/4304       (  0%) [      0] Chunk
 SSS SSF cfgsb c           :         44/1732       (  2%) [      1] Chunk
 SSS SSF dp sess           :     114240/136180     ( 83%) [   3570] Chunk
 SSS SSF HA segm           :      78540/130976     ( 59%) [   1785] Chunk
 SSS SSF HA sess           :     114240/131176     ( 87%) [   1785] Chunk
 SSS SSF HA flow           :      85680/130976     ( 65%) [   1785] Chunk
 SSS LTERM sessi           :     121380/140720     ( 86%) [   1785] Chunk
 SSS LTERM switc           :      57120/67416      ( 84%) [   1785] Chunk
 SSS LTERM reque           :          0/32820      (  0%) [      0] Chunk
 SSS PM context            :    3741012/3804712    ( 98%) [   6633] Chunk
 SSS PM profdb c           :      57440/78164      ( 73%) [   1795] Chunk
 SSS PM prof chu           :      43080/52980      ( 81%) [   1795] Chunk
 SSS PM config c           :     275352/333932     ( 82%) [  11473] Chunk
 SSS PM elem rec           :     149940/189860     ( 78%) [   1785] Chunk
 SSS PM list rec           :      35700/58736      ( 60%) [   1785] Chunk
 SSS PM service            :     193920/218364     ( 88%) [   4848] Chunk
 SSS SM chunk              :     278460/327940     ( 84%) [   1785] Chunk
 SSS SM flow chu           :     257792/327940     ( 78%) [   3392] Chunk
 SSS SM SIP chun           :          0/65488      (  0%) [      0] Chunk
 SSS SM PM chunk           :      92820/130976     ( 70%) [   1785] Chunk
 SSS FM CCM ENTITY         :       1344/2956       ( 45%) [     31]
 SSS HANDLE IDs            :      66560/66716      ( 99%) [      3]
 SSS LTERM CCM ISSU client :        100/152        ( 65%) [      1]
 SSS LTERM CCM ISSU client :        292/760        ( 38%) [      9]
 SSS LTERM CCM ISSU client :        164/216        ( 75%) [      1]
 SSS LTERM request         :          0/32820      (  0%) [      0] Chunk
 SSS LTERM sessions        :     121380/140720     ( 86%) [   1785] Chunk
 SSS LTERM switching       :      57120/67416      ( 84%) [   1785] Chunk
 SSS Mgr target handle has :          0/168        (  0%) [      0] Chunk
 SSS PM Auto service chunk :          0/16592      (  0%) [      0] Chunk
 SSS PM CCM ENTITY         :        572/1248       ( 45%) [     13]
 SSS PM HA CTX Chunk       :     114240/126692     ( 90%) [   1785] Chunk
 SSS PM HA ELEM Chunk      :     875556/930024     ( 94%) [   6633] Chunk
 SSS PM HA HANDLE ID table :      33792/33896      ( 99%) [      2]
 SSS PM HA Timer chunk     :      57120/69500      ( 82%) [   1785] Chunk
 SSS PM Infotype chunk     :     345644/392928     ( 87%) [   6647] Chunk
 SSS PM Per-User Info      :      64260/82304      ( 78%) [   1785] Chunk
 SSS PM cond block         :         44/96         ( 45%) [      1]
 SSS PM cond block name    :         68/120        ( 56%) [      1]
 SSS PM cond line          :        168/272        ( 61%) [      2]
 SSS PM config chunk       :     275352/333932     ( 82%) [  11473] Chunk
 SSS PM context chunk      :    3741012/3804712    ( 98%) [   6633] Chunk
 SSS PM prof chunk         :      43080/52980      ( 81%) [   1795] Chunk
 SSS PM profdb chunk       :      57440/78164      ( 73%) [   1795] Chunk
 SSS PM rule               :         84/240        ( 35%) [      3]
 SSS PM rule action        :       1920/2960       ( 64%) [     20]
 SSS PM rule cond          :         48/100        ( 48%) [      1]
 SSS PM rule name          :        108/264        ( 40%) [      3]
 SSS PM service chunk      :     193920/218364     ( 88%) [   4848] Chunk
 SSS PM svc rule           :        308/412        ( 74%) [      2]
 SSS PM svc rule subblock  :         48/152        ( 31%) [      2]
 SSS Relay Context Handle  :        400/452        ( 88%) [      1]
 SSS SERVICE_NAME          :     210176/462064     ( 45%) [   4844]
 SSS SM AIE chunk          :      28560/63644      ( 44%) [   1785] Chunk
 SSS SM AIE table          :      32768/32820      ( 99%) [      1]
 SSS SM SB chunk           :          0/8436       (  0%) [      0] Chunk
 SSS SM SIP chunk          :          0/65488      (  0%) [      0] Chunk
 SSS SM flow chunk         :     257792/327940     ( 78%) [   3392] Chunk
 SSS SM hash table         :      32768/32820      ( 99%) [      1]
 SSS SSF HA flow chunk     :      85680/130976     ( 65%) [   1785] Chunk
 SSS SSF HA segment chunk  :      78540/130976     ( 59%) [   1785] Chunk
 SSS SSF HA session chunk  :     114240/131176     ( 87%) [   1785] Chunk
 SSS SSF L2HW context chun :      49980/63904      ( 78%) [   1785] Chunk
 SSS SSF L2HW feature map  :     149464/180300     ( 82%) [   5338] Chunk
 SSS SSF cfgsb chunk       :         44/1732       (  2%) [      1] Chunk
 SSS SSF dp session chunk  :     114240/136180     ( 83%) [   3570] Chunk
 SSS SSF group map chunk   :     303048/352776     ( 85%) [   8418] Chunk
 SSS SSF message chunk     :          0/16592      (  0%) [      0] Chunk
 SSS SSF mgr message chunk :          0/4304       (  0%) [      0] Chunk
 SSS SSF seg chunk         :     600532/655956     ( 91%) [   5177] Chunk
 SSS SVM ENTITY            :        792/1780       ( 44%) [     19]
 SSS SVM ID table          :      33792/33896      ( 99%) [      2]
 SSS SVM dload             :          0/1732       (  0%) [      0] Chunk
 SSS SVM finfo             :          0/1552       (  0%) [      0] Chunk
 SSS SVM head              :        896/10052      (  8%) [     14] Chunk
 SSS SVM info              :       2016/5052       ( 39%) [     14] Chunk
 SSS Switch Handle         :       1024/1076       ( 95%) [      1]
 SSS info element chunk    :     624384/787168     ( 79%) [  39024] Chunk
 SSS info list chunk       :     302904/393020     ( 77%) [   8414] Chunk
 SSS msg chunk             :          0/65488      (  0%) [      0] Chunk
 SSS policy-profile--name  :      76316/169656     ( 44%) [   1795]
 SSS rule-map-condition    :        880/1660       ( 53%) [     15]
 SSS subscriber-service-na :         48/152        ( 31%) [      2]
 SSS switch information    :         76/128        ( 59%) [      1]
 SSS SSF L2HW fe           :     149464/180300     ( 82%) [   5338] Chunk
 SSS SSF L2HW co           :      49980/63904      ( 78%) [   1785] Chunk
 nFM                       :         32/3052       (  1%) [      1] Chunk
 iFM                       :      57024/68324      ( 83%) [   1782] Chunk
 oFM                       :      56992/69464      ( 82%) [   1781] Chunk
 CCA CCB chunks            :     368604/432068     ( 85%) [  10239] Chunk
 CCA CLL chunks            :      50988/64796      ( 78%) [   1821] Chunk
 SSS PM Per-User           :      64260/82304      ( 78%) [   1785] Chunk
 SSS info elemen           :     624384/787168     ( 79%) [  39024] Chunk
 SSS info list c           :     302904/393020     ( 77%) [   8414] Chunk
 SSS SM AIE chun           :      28560/63644      ( 44%) [   1785] Chunk
 SSS Mgr target            :          0/168        (  0%) [      0] Chunk
 SSS Mgr target handle has :      32768/32820      ( 99%) [      1]
 Total allocated: 20.242 Mb, 20728 Kb, 21226036 bytes
Считайте. )))
