Народ выручайте, есть роутер на х86 Mikrotik 3.22 надо одну подсеть отправить на 1 wlan а вторую на 2 wlan, что сделано
vlan-ы сидят на интерфейсе inet
ip address print
0   172.17.31.100/24   172.17.31.0     172.17.31.255   lan 1
1   92.***.***.41/30   92.***.***.40   92.***.***.43   vlan_318_inet
2   172.16.140.57/30   172.16.140.56   172.16.140.59   vlan_303_inet
3   192.168.100.1/24   192.168.100.0   192.168.100.255 lan 2
interface print
0  R  lan 1           ether            1500
1  R  inet            ether            1500
2  R  lan 2           ether            1500
3  R  vlan_318_inet   vlan             1500
4  R  vlan_303_inet   vlan             1500
ip firewall mangle print detail
0   chain=forward action=mark-connection new-connection-mark=isp_318 passthrough=yes in-interface=vlan_318_inet
1   chain=forward action=mark-connection new-connection-mark=isp_303 passthrough=yes in-interface=vlan_303_inet
2   chain=forward action=mark-connection new-connection-mark=isp_318 passthrough=yes in-interface=lan 1
3   chain=forward action=mark-connection new-connection-mark=isp_303 passthrough=yes in-interface=lan 2
4   chain=prerouting action=mark-routing new-routing-mark=route_318 passthrough=yes connection-mark=isp_318
5   chain=prerouting action=mark-routing new-routing-mark=route_303 passthrough=yes connection-mark=isp_303
ip firewall nat print detail
0 chain=srcnat action=masquerade out-interface=vlan_318_inet connection-mark=isp_318
1 chain=srcnat action=masquerade out-interface=vlan_303_inet connection-mark=isp_303
ip route print detail
0 A S  dst-address=0.0.0.0/0 gateway=92.***.***.42 interface=vlan_318_inet gateway-state=reachable distance=1 scope=255 target-scope=10 routing-mark=main
1 A S  dst-address=0.0.0.0/0 gateway=92.***.***.42 interface=vlan_318_inet gateway-state=reachable distance=1 scope=30 target-scope=10 routing-mark=route_318
2 A S  dst-address=0.0.0.0/0 gateway=172.16.140.58 interface=vlan_303_inet gateway-state=reachable distance=1 scope=30 target-scope=10 routing-mark=route_303
3 ADC  dst-address=92.***.***.40/30 pref-src=92.***.***.41 interface=vlan_318_inet distance=0 scope=10
4 ADC  dst-address=172.16.140.56/30 pref-src=172.16.140.57 interface=vlan_303_inet distance=0 scope=10
5 ADC  dst-address=172. 17. 31.0/24 pref-src=172.17.31.100 interface=lan 1 distance=0 scope=10
6 ADC  dst-address=192.168.100.0/24 pref-src=192.168.100.1 interface=lan 2 distance=0 scope=10
при таком конфиге маршрутизит в инет только подсеть 172.17.31.0/24 а сеть 192.168.100.0/24 не маршрутизится
перевожу в route 0 строку в disable встаёт все.
где мой косяк?
правильно ли я понимаю, что переписать правила маскарадинга нужно на эти ??
ip firewall address-list print detail
0   list=local_net_1 address=172.17.31.0/24
1   list=local_net_2 address=192.168.100.0/24
0 chain=srcnat action=masquerade src-address-list=local_net_1 out-interface=vlan_318_inet connection-mark=isp_318
1 chain=srcnat action=masquerade src-address-list=local_net_2 out-interface=vlan_303_inet connection-mark=isp_303
Косяк в том, что у вас маскардинг работает для всего подряд, нужно в правиле четко указать src.address.
вы сдулись в том, что пытаетесь NATом резать\блокировать трафик, NAT это всего лишь NAT а не Firewall.
что то я не вижу тут где вы метите пакеты одной сети и пакеты для другой сети для направления на нужный интерфейс?
вообщем как то так, метим пакеты от сетей и потом в рутах направляем их (метки) на нужные интерфейсы:
chain=prerouting action=mark-routing src-address=172.17.31.0/24 new-routing-mark=route_318 passthrough=yes
chain=prerouting action=mark-routing src-address=192.168.100.0/24 new-routing-mark=route_303 passthrough=yes
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=vlan_318_inet routing-mark=route_318 scope=30 target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=vlan_303_inet routing-mark=route_303 scope=30 target-scope=10
