здравствуйте всем. тут такая проблема, не работает нат, точнее работает только на icmp, на остальное нет.
в чём может быть проблема?
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service compress-config
service sequence-numbers
hostname warland
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 warnings
no logging console
no aaa new-model
resource policy
clock timezone Karachi 5
ip subnet-zero
no ip source-route
ip tcp synwait-time 10
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
no ip bootp server
ip domain name edu.uz
ip name-server x.x.x.x
ip name-server y.y.y.y
interface Null0
no ip unreachables
interface Loopback0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
no snmp trap link-status
interface FastEthernet0/0
no ip address
no ip proxy-arp
duplex auto
speed auto
interface FastEthernet0/0.200
no cdp enable
interface FastEthernet0/0.202
encapsulation dot1Q 202
ip address 10.0.0.2 255.255.255.252
no cdp enable
interface FastEthernet0/0.203
description Link to Corporate Network vlanid 203
encapsulation dot1Q 203
ip address 10.20.26.2 255.255.255.0
ip nat outside
ip virtual-reassembly
no cdp enable
interface FastEthernet0/1
description Link to Local
no ip address
no ip proxy-arp
duplex auto
speed auto
interface FastEthernet0/1.200
encapsulation dot1Q 200
ip address z.z.z.z a.a.a.a
ip flow ingress
ip flow egress
no cdp enable
interface FastEthernet0/1.201
description Link to Local Subnet 192.168.1.0/24 vlanid 201
encapsulation dot1Q 201
ip address 192.168.1.253 255.255.255.0
ip nat inside
no cdp enable
interface Content-Engine1/0
no ip address
shutdown
router ospf 30
router-id 10.20.26.2
log-adjacency-changes
redistribute static
network 10.20.26.2 0.0.0.0 area 0.0.0.30
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip flow-export version 5
ip flow-export destination 10.20.55.10 9995
no ip http server
no ip http secure-server
ip nat pool corporate 10.20.26.2 10.20.26.2 netmask 255.255.255.0
ip nat inside source list 110 pool corporate overload
ip access-list standard telnet
permit 10.20.55.10
access-list 100 permit ip host 192.168.1.243 any
access-list 100 deny   ip any any
access-list 110 permit ip 192.168.1.0 0.0.0.255 10.20.0.0 0.0.127.255
snmp-server community xxxx RO telnet
no cdp run
control-plane
alias exec bw show int fast 0
alias exec sr show running-config
alias exec ct configure terminal
alias exec cpu show proc cpu hist
line con 0
login local
transport output telnet
line aux 0
login local
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output all
line vty 0 4
access-class telnet in
exec-timeout 0 0
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 100 in
exec-timeout 0 0
privilege level 15
login local
scheduler allocate 20000 1000
end
заранее спасибо
вы бы хоть топологию набросали, непонятно же ничего...
а чего тут непонятного? один inside, один outside, с адресами
show ip route ospf покажите.
show ip route ospf
    10.0.0.0/8 is variably subnetted, 299 subnets, 4 masks
O IA    10.20.30.0/24 [110/5] via 10.20.26.1, 5d20h, FastEthernet0/0.203
O IA    10.10.0.0/24 [110/14] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.20.31.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O       10.10.1.0/24 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.10.0.1/32 [110/14] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.246.2.252/30 [110/1] via 10.20.26.1, 05:02:38, FastEthernet0/0.203
O IA    10.20.28.0/24 [110/5] via 10.20.26.1, 1w2d, FastEthernet0/0.203
O       10.10.2.0/24 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.10.3.0/24 [110/5] via 10.20.26.1, 2d06h, FastEthernet0/0.203
O IA    10.10.4.0/24 [110/5] via 10.20.26.1, 3d18h, FastEthernet0/0.203
O IA    10.20.27.0/24 [110/5] via 10.20.26.1, 1w1d, FastEthernet0/0.203
O IA    10.10.5.0/24 [110/5] via 10.20.26.1, 05:02:43, FastEthernet0/0.203
O IA    10.10.6.0/24 [110/5] via 10.20.26.1, 1w4d, FastEthernet0/0.203
O IA    10.20.25.0/24 [110/5] via 10.20.26.1, 1d07h, FastEthernet0/0.203
O IA    10.10.7.0/24 [110/5] via 10.20.26.1, 6d07h, FastEthernet0/0.203
O IA    10.20.22.0/24 [110/5] via 10.20.26.1, 1w2d, FastEthernet0/0.203
O IA    10.10.8.0/24 [110/5] via 10.20.26.1, 6d06h, FastEthernet0/0.203
O IA    10.20.23.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.10.9.0/24 [110/5] via 10.20.26.1, 1d20h, FastEthernet0/0.203
O IA    10.20.20.0/24 [110/5] via 10.20.26.1, 3d15h, FastEthernet0/0.203
O IA    10.10.10.0/24 [110/5] via 10.20.26.1, 1w3d, FastEthernet0/0.203
O IA    10.20.21.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.10.11.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.20.18.0/24 [110/5] via 10.20.26.1, 19:55:44, FastEthernet0/0.203
O IA    10.10.12.0/24 [110/5] via 10.20.26.1, 2d16h, FastEthernet0/0.203
O IA    10.10.13.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.20.16.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.20.17.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.10.15.0/24 [110/5] via 10.20.26.1, 1w2d, FastEthernet0/0.203
O IA    10.10.16.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.10.17.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.20.12.0/24 [110/5] via 10.20.26.1, 2d16h, FastEthernet0/0.203
O IA    10.10.18.0/24 [110/5] via 10.20.26.1, 19:55:44, FastEthernet0/0.203
O IA    10.20.13.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.20.10.0/24 [110/5] via 10.20.26.1, 1w3d, FastEthernet0/0.203
O IA    10.10.20.0/24 [110/5] via 10.20.26.1, 3d15h, FastEthernet0/0.203
O IA    10.20.11.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.10.21.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.20.8.0/24 [110/5] via 10.20.26.1, 6d06h, FastEthernet0/0.203
O IA    10.20.9.0/24 [110/5] via 10.20.26.1, 1d20h, FastEthernet0/0.203
O IA    10.10.23.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.20.6.0/24 [110/5] via 10.20.26.1, 1w4d, FastEthernet0/0.203
O IA    10.20.7.0/24 [110/5] via 10.20.26.1, 6d07h, FastEthernet0/0.203
O IA    10.10.25.0/24 [110/5] via 10.20.26.1, 1d07h, FastEthernet0/0.203
O IA    10.20.4.0/24 [110/5] via 10.20.26.1, 3d18h, FastEthernet0/0.203
O       10.10.26.0/24 [110/2] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.20.5.0/24 [110/5] via 10.20.26.1, 05:02:58, FastEthernet0/0.203
O IA    10.10.27.0/24 [110/5] via 10.20.26.1, 1w1d, FastEthernet0/0.203
O       10.20.2.0/24 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.10.28.0/24 [110/5] via 10.20.26.1, 1w2d, FastEthernet0/0.203
O IA    10.20.3.0/24 [110/5] via 10.20.26.1, 2d06h, FastEthernet0/0.203
O IA    10.10.30.0/24 [110/5] via 10.20.26.1, 5d20h, FastEthernet0/0.203
O       10.20.1.0/24 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.10.31.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.10.32.0/24 [110/5] via 10.20.26.1, 1d16h, FastEthernet0/0.203
O       10.10.33.0/24 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.10.34.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.20.61.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.10.35.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.100.74.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.10.36.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.20.59.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.100.72.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.10.38.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.10.39.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.10.40.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.20.55.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.10.41.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.10.42.0/24 [110/1] via 10.20.26.1, 00:06:25, FastEthernet0/0.203
O E2    10.100.69.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.20.53.0/24 [110/1] via 10.20.26.1, 05:03:08, FastEthernet0/0.203
O E2    10.100.66.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.50.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.10.44.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.100.67.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.51.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.10.45.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.10.46.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.49.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.46.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.10.48.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.10.49.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.44.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.10.50.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.45.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.10.51.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.42.0/24 [110/1] via 10.20.26.1, 00:06:34, FastEthernet0/0.203
O E2    10.10.53.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.40.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.41.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.10.55.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.38.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.39.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.20.36.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O E2    10.10.59.0/24 [110/1] via 10.20.26.1, 05:03:18, FastEthernet0/0.203
O IA    10.20.34.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.10.60.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.20.35.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.10.61.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.100.80.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O IA    10.20.32.0/24 [110/5] via 10.20.26.1, 1d16h, FastEthernet0/0.203
O       10.20.33.0/24 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.100.46.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.246.10.180/30 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.100.44.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.10.66.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.100.45.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.10.67.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.100.42.0/24 [110/1] via 10.20.26.1, 00:06:42, FastEthernet0/0.203
O E2    10.10.69.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.246.10.176/30 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.100.40.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.10.70.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.100.41.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.100.38.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.10.72.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.100.39.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.100.36.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O E2    10.10.74.0/24 [110/1] via 10.20.26.1, 05:03:26, FastEthernet0/0.203
O IA    10.100.34.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.100.35.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O IA    10.100.32.0/24 [110/5] via 10.20.26.1, 1d16h, FastEthernet0/0.203
O E2    10.20.80.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O       10.100.33.0/24 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.10.80.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.246.10.164/30 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.100.60.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.100.61.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.20.74.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.100.59.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.246.10.160/30 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.20.72.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.100.55.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.246.10.172/30 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.100.53.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.20.69.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.100.50.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.20.66.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.100.51.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.20.67.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.246.10.168/30 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.100.48.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O E2    10.100.49.0/24 [110/1] via 10.20.26.1, 05:03:33, FastEthernet0/0.203
O IA    10.100.15.0/24 [110/5] via 10.20.26.1, 1w2d, FastEthernet0/0.203
O E2    10.246.10.148/30 [110/1] via 10.20.26.1, 05:03:41, FastEthernet0/0.203
O IA    10.100.12.0/24 [110/5] via 10.20.26.1, 2d16h, FastEthernet0/0.203
O IA    10.100.13.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.110.0.0/16 [110/2] via 10.20.26.1, 05:03:41, FastEthernet0/0.203
O IA    10.100.10.0/24 [110/5] via 10.20.26.1, 1w3d, FastEthernet0/0.203
O IA    10.100.11.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.246.10.144/30 [110/1] via 10.20.26.1, 05:03:41, FastEthernet0/0.203
O IA    10.100.8.0/24 [110/5] via 10.20.26.1, 6d06h, FastEthernet0/0.203
O IA    10.100.9.0/24 [110/5] via 10.20.26.1, 1d20h, FastEthernet0/0.203
O IA    10.100.6.0/24 [110/5] via 10.20.26.1, 1w4d, FastEthernet0/0.203
O IA    10.100.7.0/24 [110/5] via 10.20.26.1, 6d07h, FastEthernet0/0.203
O E2    10.246.10.156/30 [110/1] via 10.20.26.1, 05:03:41, FastEthernet0/0.203
O IA    10.100.4.0/24 [110/5] via 10.20.26.1, 3d18h, FastEthernet0/0.203
O IA    10.100.5.0/24 [110/5] via 10.20.26.1, 05:03:46, FastEthernet0/0.203
O       10.100.2.0/24 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.100.3.0/24 [110/5] via 10.20.26.1, 2d06h, FastEthernet0/0.203
O E2    10.246.10.152/30 [110/1] via 10.20.26.1, 05:03:41, FastEthernet0/0.203
O IA    10.100.0.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O       10.100.1.0/24 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.100.30.0/24 [110/5] via 10.20.26.1, 5d20h, FastEthernet0/0.203
O IA    10.100.31.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.246.10.132/30 [110/1] via 10.20.26.1, 05:03:41, FastEthernet0/0.203
O IA    10.100.28.0/24 [110/5] via 10.20.26.1, 1w2d, FastEthernet0/0.203
O       10.100.26.0/24 [110/2] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.100.27.0/24 [110/5] via 10.20.26.1, 1w1d, FastEthernet0/0.203
O E2    10.246.10.128/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O IA    10.100.25.0/24 [110/5] via 10.20.26.1, 1d07h, FastEthernet0/0.203
O IA    10.100.23.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.246.10.140/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O E2    10.246.2.132/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O IA    10.100.20.0/24 [110/5] via 10.20.26.1, 3d15h, FastEthernet0/0.203
O IA    10.100.21.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.100.18.0/24 [110/5] via 10.20.26.1, 19:56:40, FastEthernet0/0.203
O E2    10.246.10.136/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O       10.246.2.128/30 [110/3] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.100.16.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.100.17.0/24 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.246.10.116/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O E2    10.246.2.124/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O E2    10.246.10.112/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O E2    10.246.2.120/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O E2    10.246.10.124/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O E2    10.246.2.116/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O E2    10.246.10.120/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O E2    10.246.10.100/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O E2    10.246.2.108/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O E2    10.246.10.96/30 [110/1] via 10.20.26.1, 05:03:49, FastEthernet0/0.203
O E2    10.246.2.104/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.10.108/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O       10.246.2.100/30 [110/2] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.246.10.104/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.2.96/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.10.84/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.10.80/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.2.88/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.10.92/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.2.84/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.1.80/32 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.10.88/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.2.80/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.10.68/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.2.76/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.1.72/32 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.10.64/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.1.74/32 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.1.69/32 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.10.76/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.2.68/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.10.72/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.2.64/30 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.1.67/32 [110/1] via 10.20.26.1, 05:03:55, FastEthernet0/0.203
O E2    10.246.1.66/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.61/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.60/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.10.52/30 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.2.60/30 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.10.48/30 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.2.56/30 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.59/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.53/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.10.60/30 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.2.52/30 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.55/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.49/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.48/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.10.56/30 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.2.48/30 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.51/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.50/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.45/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.44/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.10.36/30 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.2.44/30 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.46/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.41/32 [110/1] via 10.20.26.1, 05:04:02, FastEthernet0/0.203
O E2    10.246.1.40/32 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O E2    10.246.10.32/30 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O E2    10.246.2.40/30 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O E2    10.246.1.42/32 [110/1] via 10.20.26.1, 00:07:25, FastEthernet0/0.203
O E2    10.246.1.36/32 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O E2    10.246.10.44/30 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O E2    10.246.2.36/30 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O E2    10.246.1.39/32 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O E2    10.246.1.38/32 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O       10.246.1.33/32 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.32/32 [110/5] via 10.20.26.1, 1d16h, FastEthernet0/0.203
O E2    10.246.10.40/30 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O E2    10.246.2.32/30 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O E2    10.246.1.35/32 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O IA    10.246.1.34/32 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.28/32 [110/5] via 10.20.26.1, 1w2d, FastEthernet0/0.203
O E2    10.246.10.20/30 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O E2    10.246.2.28/30 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O IA    10.246.1.31/32 [110/5] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.30/32 [110/5] via 10.20.26.1, 5d20h, FastEthernet0/0.203
O IA    10.246.1.25/32 [110/4] via 10.20.26.1, 1d07h, FastEthernet0/0.203
O E2    10.246.10.16/30 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O E2    10.246.2.24/30 [110/1] via 10.20.26.1, 05:04:09, FastEthernet0/0.203
O IA    10.246.1.27/32 [110/4] via 10.20.26.1, 1w1d, FastEthernet0/0.203
O       10.246.1.26/32 [110/1] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.21/32 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.20/32 [110/4] via 10.20.26.1, 3d15h, FastEthernet0/0.203
O E2    10.246.10.28/30 [110/1] via 10.20.26.1, 05:04:14, FastEthernet0/0.203
O E2    10.246.2.20/30 [110/1] via 10.20.26.1, 05:04:14, FastEthernet0/0.203
O IA    10.246.1.23/32 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.22/32 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.17/32 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.16/32 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.246.10.24/30 [110/1] via 10.20.26.1, 05:04:14, FastEthernet0/0.203
O E2    10.246.2.16/30 [110/1] via 10.20.26.1, 05:04:14, FastEthernet0/0.203
O IA    10.246.1.18/32 [110/4] via 10.20.26.1, 19:57:05, FastEthernet0/0.203
O IA    10.246.1.13/32 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.12/32 [110/4] via 10.20.26.1, 2d16h, FastEthernet0/0.203
O E2    10.246.10.4/30 [110/1] via 10.20.26.1, 05:04:14, FastEthernet0/0.203
O E2    10.246.2.12/30 [110/1] via 10.20.26.1, 05:04:14, FastEthernet0/0.203
O IA    10.246.1.15/32 [110/4] via 10.20.26.1, 1w2d, FastEthernet0/0.203
O IA    10.246.1.9/32 [110/4] via 10.20.26.1, 1d20h, FastEthernet0/0.203
O IA    10.246.1.8/32 [110/4] via 10.20.26.1, 6d07h, FastEthernet0/0.203
O E2    10.246.10.0/30 [110/1] via 10.20.26.1, 05:04:14, FastEthernet0/0.203
O E2    10.246.2.8/30 [110/1] via 10.20.26.1, 05:04:14, FastEthernet0/0.203
O IA    10.246.1.11/32 [110/4] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.10/32 [110/4] via 10.20.26.1, 1w3d, FastEthernet0/0.203
O IA    10.246.1.5/32 [110/4] via 10.20.26.1, 05:04:20, FastEthernet0/0.203
O IA    10.246.1.4/32 [110/4] via 10.20.26.1, 3d18h, FastEthernet0/0.203
O E2    10.246.10.12/30 [110/1] via 10.20.26.1, 05:04:21, FastEthernet0/0.203
O       10.246.2.4/30 [110/3] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.7/32 [110/4] via 10.20.26.1, 6d08h, FastEthernet0/0.203
O IA    10.246.1.6/32 [110/4] via 10.20.26.1, 1w4d, FastEthernet0/0.203
O       10.246.1.1/32 [110/3] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O E2    10.246.10.8/30 [110/1] via 10.20.26.1, 05:04:21, FastEthernet0/0.203
O       10.246.2.0/30 [110/3] via 10.20.26.1, 1w6d, FastEthernet0/0.203
O IA    10.246.1.3/32 [110/4] via 10.20.26.1, 2d06h, FastEthernet0/0.203
O       10.246.1.2/32 [110/3] via 10.20.26.1, 1w6d, FastEthernet0/0.203
Edited by elyor
проверял только на 10.20.55.0/24.
на хосте 10.20.55.10 icmp видны дампером, а остальные протоколы нет (http, ftp, ssh, dns)
насколько я понял, циска трафик вообще не пропускает, так как когда nat выключаю, пакеты доходят до меня с адресами 192.168.1.0/24, а когда включаю, то вообще ничего не видно, ни с 10.20.26.2, ни с 192.168.1.0/24.
ip nat inside source list 110 interface FastEthernet0/0.203 overload
то же самое, без изменений.
я это уже проверял перед тем, как сюда писать :)
У вас адрес nat pool попадает в acl описывающий трафик для ната
Для проверки попробуйте привести 110 лист к виду:
access-list 110 permit ip 192.168.1.0 0.0.0.255 10.20.55.0 0.0.0.255
так, то, что пакеты не походят, это оказывается из-за inside хостов.
с ними справился, теперь такая проблема:
icmp - натится
http - натится
dns - не натится
ftp - не натится
вывод show ip nat tr
Pro Inside global      Inside local       Outside local      Outside global
icmp 10.20.26.2:1      192.168.1.77:1     10.20.55.10:1      10.20.55.10:1
tcp 10.20.26.2:52825   192.168.1.77:52825 10.20.55.10:21     10.20.55.10:21
tcp 10.20.26.2:52899   192.168.1.77:52899 10.20.55.10:80     10.20.55.10:80
tcp 10.20.26.2:52900   192.168.1.77:52900 10.20.55.10:80     10.20.55.10:80
tcp 10.20.26.2:52915   192.168.1.77:52915 10.20.55.10:21     10.20.55.10:21
tcp 10.20.26.2:52936   192.168.1.77:52936 10.20.55.10:21     10.20.55.10:21
udp 10.20.26.2:63761   192.168.1.77:63761 10.20.55.10:53     10.20.55.10:53
udp 10.20.26.2:64912   192.168.1.77:64912 10.20.55.10:53     10.20.55.10:53
udp 10.20.26.2:64913   192.168.1.77:64913 10.20.55.10:53     10.20.55.10:53
udp 10.20.26.2:64914   192.168.1.77:64914 10.20.55.10:53     10.20.55.10:53
до хоста 10.20.55.10 dns и ftp доходят с ip 192.168.1.77
p.s. access-list исправил.
я тут ещё debug включил на нат (debug ip nat det)
080270: *Jul 20 12:35:08.529 Karachi: NAT: Allocated Port for 192.168.1.77 -> 10.20.26.2: wanted 50279 got 50279
080271: *Jul 20 12:35:10.537 Karachi: NAT: Allocated Port for 192.168.1.77 -> 10.20.26.2: wanted 50280 got 50280
080272: *Jul 20 12:35:12.537 Karachi: NAT: Allocated Port for 192.168.1.77 -> 10.20.26.2: wanted 50281 got 50281
080273: *Jul 20 12:35:14.537 Karachi: NAT: Allocated Port for 192.168.1.77 -> 10.20.26.2: wanted 50282 got 50282
080274: *Jul 20 12:35:16.541 Karachi: NAT: Allocated Port for 192.168.1.77 -> 10.20.26.2: wanted 50283 got 50283
это на dns
и ещё он говорит что
080279: *Jul 20 12:36:09.005 Karachi: NAT: expiring 10.20.26.2 (192.168.1.77) udp 50279 (50279)
080280: *Jul 20 12:36:10.541 Karachi: NAT: expiring 10.20.26.2 (192.168.1.77) udp 50280 (50280)
080281: *Jul 20 12:36:12.589 Karachi: NAT: expiring 10.20.26.2 (192.168.1.77) udp 50281 (50281)
080282: *Jul 20 12:36:14.637 Karachi: NAT: expiring 10.20.26.2 (192.168.1.77) udp 50282 (50282)
080283: *Jul 20 12:36:16.685 Karachi: NAT: expiring 10.20.26.2 (192.168.1.77) udp 50283 (50283)
хотя никакого ната не было (т.е. на 10.20.55.10 source был 192.168.1.77, а не 10.20.26.2)
что мне с ним делать? ))
