Прописал следующие правила:
/ip firewall mangle
add action=mark-packet chain=postrouting comment="Link-critical traffic (DHCP)" disabled=no dst-port=67 new-packet-mark=link_critical out-interface=ether1 passthrough=no protocol=udp src-port=68
add action=mark-packet chain=postrouting comment="VPN TCP" disabled=no new-packet-mark=link_critical out-interface= ether1 passthrough=no port=443,1723 protocol=tcp
add action=mark-packet chain=postrouting comment="VPN GRE" disabled=no new-packet-mark=link_critical out-interface= ether1 passthrough=no protocol=gre
add action=mark-packet chain=postrouting comment="VPN UDP" disabled=no new-packet-mark=link_critical out-interface= ether1 passthrough=no port=4500,500,1701 protocol=udp
add action=mark-packet chain=postrouting comment="VPN ESP" disabled=no new-packet-mark=link_critical out-interface= ether1 passthrough=no protocol=ipsec-esp
add action=mark-packet chain=postrouting comment="Time-critical traffic (DNS, TCP control packets, certain ACK packets, new connections)" disabled=no dst-port=53 new-packet-mark=time_critical out-interface= ether1 passthrough=no protocol=udp
add action=mark-packet chain=postrouting comment="" disabled=no new-packet-mark=time_critical out-interface= ether1 passthrough=no protocol=tcp tcp-flags=fin,syn,rst
add action=mark-packet chain=postrouting comment="" disabled=no new-packet-mark=time_critical out-interface= ether1 packet-size=40-89 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=postrouting comment="" connection-state=new disabled=no new-packet-mark=time_critical out-interface= ether1 passthrough=no protocol=tcp
add action=mark-packet chain=postrouting comment="Critical traffic (just some ACK packets)" disabled=no new-packet-mark=critical out-interface= ether1 packet-size=90-159 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=postrouting comment="High-priority interactive traffic (SSH, WinBox, certain ACK packets)" disabled=no new-packet-mark=high_pri_interactive out-interface= ether1 passthrough=no port=22,2200 protocol=tcp
add action=mark-packet chain=postrouting comment="" disabled=no new-packet-mark=high_pri_interactive out-interface= ether1 passthrough=no port=8291 protocol=tcp
add action=mark-packet chain=postrouting comment="" disabled=no new-packet-mark=high_pri_interactive out-interface= ether1 packet-size=160-249 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=postrouting comment="Low-priority interactive traffic (HTTP, HTTPS)" disabled=no new-packet-mark=low_pri_interactive out-interface= ether1 passthrough=no port=80 protocol=tcp
add action=mark-packet chain=postrouting comment="" disabled=no new-packet-mark=low_pri_interactive out-interface= ether1 packet-size=250-359 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=postrouting comment="High-priority non-interactive traffic (FTP)" connection-type=ftp disabled=no new-packet-mark=high_pri_non_interactive out-interface= ether1 passthrough=no protocol=tcp
add action=mark-packet chain=postrouting comment="" disabled=no new-packet-mark=high_pri_non_interactive out-interface= ether1 packet-size=360-489 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=postrouting comment="Low-priority non-interactive traffic (POP, SMTP)" disabled=no new-packet-mark=low_pri_non_interactive out-interface= ether1 passthrough=no port=25,110 protocol=tcp
add action=mark-packet chain=postrouting comment="" disabled=no new-packet-mark=low_pri_non_interactive out-interface= ether1 packet-size=490-639 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=postrouting comment="Non-critical traffic (P2P)" disabled=no new-packet-mark=non_critical out-interface= ether1 packet-size=640-809 passthrough=no protocol=tcp tcp-flags=ack
add action=mark-packet chain=postrouting comment="" disabled=no new-packet-mark=non_critical out-interface= ether1 passthrough=no protocol=tcp
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=9M name="Outgoing queue" packet-mark="" parent=ether1 priority=8
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=9M name="Low-pri non-interactive" packet-mark=low_pri_non_interactive parent="Outgoing queue" priority=7 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=9M name=Non-critical packet-mark=non_critical parent="Outgoing queue" priority=8 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=9M name=Link-critical packet-mark=link_critical parent="Outgoing queue" priority=1 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=9M name=Time-critical packet-mark=time_critical parent="Outgoing queue" priority=2 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=9M name=Critical packet-mark=critical parent="Outgoing queue" priority=3 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=9M name="High-pri interactive" packet-mark=high_pri_interactive parent="Outgoing queue" priority=4 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=9M name="Low-pri interactive" packet-mark=low_pri_interactive parent="Outgoing queue" priority=5 queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=9M name="High-pri non-interactive" packet-mark=high_pri_non_interactive parent="Outgoing queue" priority=6 queue=default
Интерфейс провайдера ether1. Настроен NAT
Скорость канала 10Мбит.
Вижу, что HTTP, HTTPS трафик не маркируется.
Не могу понять почему.
Edited by edc
HTTPS обычно идёт по 443/TCP порту, а в правиле указан только 80/TCP.
И ещё меня смущает пробел после "out-interface=".
Edited by bel
Попробуйте использовать Forward и Output, если интернет раздает ваш же маршрутизатор, а не перенаправляет пакеты далее на другой.
Поставил parent=global-out - заработало.
Но почему-то трафик ipsec туннелей никак не маркируется.
Туннели настроены на этом же маршрутизаторе и используют ether1 интерфейс.
Если поставить output, то очень мало трафика маркируется.
Больше всего, когда стоит postrouting.
Можно как-то остальной трафик, кроме того, что указан в правилах, тоже маркировать и поставить низкий приоритет.
Сейчас, как я понял, весь немаркированный трафик идет первым приоритетом.
Так вы одним правилом один трафик маркируйте, другим - другой. Отдельно входящий и отдельно исходящий. Если вы какой-то трафик не помаркировали, то он вообще идет помимо приоритетов. Поэтому нужно сделать правило маркировки, куда попадает весь трафик и пойдет по минимальному приоритету, у него галочку Passthrough не ставите. А все те, что маркируют конкретный трафик, делаете с этой галочкой. Тогда можно делать рабочие приоритеты без "утечек".
В конечном итоге так и сделал.
Но если указать parent interface на downdload global-out, а на upload - global-in или global-total, то объем маркированных данных примерно одинаковый.
Хотя в данный момент соотношение download/upload около порядка.
Использую схему с dscp, маркировка в postrouting, правило примерно такого вида:
add action=mark-packet chain=postrouting dscp=1 dst-address-list=local-net\
new-packet-mark=dscp_1 passthrough=no src-address-list=!local-net
Если надо определенный трафик приоретизировать, то делаю так:
add action=change-dscp chain=prerouting comment=p2p disabled=no new-dscp=0 p2p=all-p2p passthrough=yes
В дереве очередей первое правило:
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=12M name=IN parent=global-out priority=8
И вешаем на него:
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=dscp0 packet-mark=dscp_0 parent=IN priority=8 queue=pcq-in
А есть у кого-то пример маркировки пакетов для протоколов H.323 и SIP ?
Вы можете маркировать их по портам, но лучше по TOS. А дальше в стандартном дереве поставите им первый приоритет.
Ребят, не могу понять, почему трафик при такой конфигурации почти одинаковый на вход и выход
Edited by edc
  • 6 months later...
А вот как этот злополучный tos определить? Снял трафик tools/packet sniffer а затем загружаю его в wireshark
А дальше "темнота" .....
или есть метод попроще?
  • 1 year later...
Поискать в гугле стандартные метки телефонии, далее в манглах попробовать вводить их и смотреть попадают под него пакеты или нет. Если времени свободного много, можно в экселе накопировать правил, увеличивая значение на 1, после чего вставить в микротик, так сможете тоже найти.
