jahon55564 Posted July 13, 2012 Posted July 13, 2012 Всем доброго дня! Сегодня приобрели SCE 1000 , но не новый. Он грузится в Recover mode, каждый раз предупреждает NOTE: System is in Recover mode !!! . Как заставит его грузится в нормальном режиме? Вставить ник Quote
Helios Posted July 13, 2012 Posted July 13, 2012 Как вариант перезагрузить один раз нормально, командой reload, а не выдергивать из нее шнурок питания, SCE такого не любят. Вставить ник Quote
jahon55564 Posted July 14, 2012 Author Posted July 14, 2012 сделал как вы сказали , но не получается ! SCE1000#reload Are you sure? y ошибки при подключению по aux порту ! /SYSTEM/BACKUP/FAIL.DFL Allocation error, size adjusted ERRORS FOUND !!! 595 lost allocation units in 1 chains 4874240 bytes disk space would be freed. All lost chains have been made available Corrections have been written to disk. total disk space (bytes) : 394,166,272 bytes in each allocation unit : 8,192 total allocation units on disk : 48,116 bad allocation units : 0 available bytes on disk : 185,262,080 available clusters on disk : 22,615 maximum available contiguous chain (bytes) : 130,056,192 available space fragmentation (%) : 30 clusters allocated : 25,501 Done Checking Disk. Finished boot. TimeStamp:83. ***************************************************************** * * Welcome to SCE1000 Version 3.5.0 Build 407. * * * * Recovery mode detected, loaded with minimal hardware interaction. * * This might result from various reasons (HW problem, explicit user request, et c.) * Use the 'show system operation-status' to verify the exact reason * * You should be able to telnet to the box and install a package file * using the 'debug package extract system <package name>' * CLI command. * Using the logger for Dbg interpretation is possible as well. * * Usage of any other commands might be risky, as they might * cause the box to get stuck ! * * Good Luck! ***************************************************************** CALLING LIC WD FOR THE FIRST TIME AT TIME = 105236 Before HWSRV_NIC_Basic::SyncWithLic() SYNC WITH LIC DONE AT TIME = 105243 SCE1000->ERROR: RucClient::syncRpcClientToSlave(rpcIf=RiRucLoader) about to retu rn FAIL for cpu 0, rpcStatus=2, halting boot. SCE1000->ERROR: RucClient::syncMultiRpcClientToAllSlaves(rpcIf=RiRucLoader) abou t to return FAIL, halting boot. Registering RuC RPC client RDB_PartyContext. RDB_PartyContext::initRpcClients(): Running. ERROR: RucClient::syncRpcClientToControl(rpcIf=RiPartyTpToControl) about to retu rn FAIL, rpcStatus=2, halting boot. ERROR: RDB_PartyContext::initRpcClients() failed. Registering RuC RPC client SipAtckDtctIntrfcReal. Registering RuC RPC client AttackFilterIntReal. AttackFilterIntReal::initRpcClients(): Running. Вставить ник Quote
Tosha Posted July 16, 2012 Posted July 16, 2012 (edited) Надо конфиг чистить, думаю Edited July 16, 2012 by Tosha Вставить ник Quote
jahon55564 Posted July 26, 2012 Author Posted July 26, 2012 Надо конфиг чистить, думаю спосибо всем решили проблему ! Вставить ник Quote
