Megas Posted July 2, 2012 Posted July 2, 2012 Есть колечко. root стоит на dgs3120 в кольце юзается rstp, клинеты des3200-10, hp2626 Периодами, пару раз за день начинается такое: Jul 2 15:44:28 192.168.2.61 ports: port 9 is now on-lineJul 2 14:45:40 192.168.2.102 INFO: Port 5 link down Jul 2 14:50:47 192.168.2.103 INFO: Port 7 link down Jul 2 15:52:28 192.168.2.65 ports: port 1 is now off-line Jul 2 15:52:27 192.168.3.16 ports: port 1 is now off-line Jul 2 15:52:27 192.168.3.16 vlan: VLAN2131 virtual LAN disabled Jul 2 14:53:19 192.168.2.24 INFO: Port 5 link down Jul 2 14:53:23 192.168.2.24 INFO: Port 5 link up, 100Mbps FULL duplex Jul 2 14:53:38 192.168.2.28 INFO: Port 3 link down Jul 2 14:54:46 192.168.2.28 INFO: Port 3 link up, 100Mbps FULL duplex Jul 2 15:56:10 192.168.2.65 ports: port 4 is now off-line Jul 2 15:56:16 192.168.3.3 ports: port 17 is Blocked by STP Jul 2 15:56:45 192.168.3.3 ports: port 17 is now on-line Jul 2 15:56:44 192.168.3.10 NOTICE: Topology changed (Instance:0, Port:1:22,MAC:84-C9-B2-8F-F0-C0) Jul 2 14:56:46 192.168.2.25 INFO: Topology changed (Instance:0 port:9) Jul 2 14:56:45 192.168.2.29 INFO: Topology changed (Instance:0 port:9) Jul 2 14:56:46 192.168.2.35 INFO: Topology changed (Instance:0 port:9) Jul 2 15:56:44 192.168.2.4 NOTICE: Topology changed (Instance:0, Port:1:22,MAC:84-C9-B2-8F-F0-C0) Jul 2 14:56:46 192.168.2.27 INFO: Topology changed (Instance:0 port:9) Jul 2 15:56:45 192.168.3.10 NOTICE: Topology changed (Instance:0, Port:1:22,MAC:84-C9-B2-8F-F0-C0) Jul 2 14:56:48 192.168.2.28 INFO: Topology changed (Instance:0 port:9) Jul 2 15:56:46 192.168.2.4 NOTICE: Topology changed (Instance:0, Port:1:22,MAC:84-C9-B2-8F-F0-C0) Jul 2 14:56:49 192.168.2.25 INFO: Topology changed (Instance:0 port:9) Jul 2 14:56:48 192.168.2.29 INFO: Topology changed (Instance:0 port:9) Jul 2 14:56:49 192.168.2.35 INFO: Topology changed (Instance:0 port:9) Jul 2 14:56:49 192.168.2.27 INFO: Topology changed (Instance:0 port:9) Jul 2 15:56:47 192.168.3.10 NOTICE: Topology changed (Instance:0, Port:1:22,MAC:84-C9-B2-8F-F0-C0) Jul 2 15:56:47 192.168.2.4 NOTICE: Topology changed (Instance:0, Port:1:22,MAC:84-C9-B2-8F-F0-C0) Jul 2 14:56:51 192.168.2.28 INFO: Topology changed (Instance:0 port:9) Jul 2 15:56:49 192.168.2.4 NOTICE: Topology changed (Instance:0, Port:1:22,MAC:84-C9-B2-8F-F0-C0) Jul 2 16:02:07 192.168.2.62 ports: port 2 is now on-line Jul 2 16:02:14 192.168.2.62 ports: port 2 is now off-line Jul 2 16:02:17 192.168.2.62 ports: port 2 is now on-line Jul 2 16:02:31 192.168.2.62 ports: port 2 is now off-line Jul 2 16:02:33 192.168.2.62 ports: port 2 is now on-line Jul 2 15:03:38 192.168.2.33 INFO: Port 3 link up, 100Mbps FULL duplex Jul 2 15:03:55 192.168.2.33 INFO: Port 3 link down Jul 2 15:03:58 192.168.2.33 INFO: Port 3 link up, 100Mbps FULL duplex Jul 2 15:05:01 192.168.2.31 INFO: Port 2 link up, 100Mbps FULL duplex Jul 2 16:06:34 192.168.2.4 INFO: Port 1:6 link down Jul 2 15:15:23 192.168.2.34 INFO: Port 2 link down Jul 2 15:16:06 192.168.2.34 INFO: Port 2 link up, 100Mbps FULL duplex Jul 2 16:17:59 192.168.2.63 ports: port 1 is Blocked by STP Jul 2 16:17:59 192.168.2.63 ports: port 1 is now on-line Это выхлоп из глобального журнала, куда сливается вся инфа, не пойму что приводит к перестройке кольца. Магистральные порты не видно чтобы падали, но тем не менее начинается. Что посоветуете? Вставить ник Quote
pliskinsad Posted July 2, 2012 Posted July 2, 2012 Отключить stp там где оно не нужно, и искать кольца. Вставить ник Quote
Megas Posted July 2, 2012 Author Posted July 2, 2012 вопрос такой. может не много нубский. должно ли быть stp на тех свичах которые есть в кольце, но от них малу толку? Вставить ник Quote
ichthyandr Posted July 3, 2012 Posted July 3, 2012 вопрос такой. может не много нубский. должно ли быть stp на тех свичах которые есть в кольце, но от них малу толку? Там где у вас кольцевая топология ®stp нужен. Настраивайте также правильно аплинки на кольцевых свичах и edge порты, на edge портах stp нужно отключить, на апликах - включить. На некольцевых свичах stp и bpdu forwarding нужно выключить. В новых и бета прошивках у dlinka для dgs3120, dgs3200, des3200 есть bpdu фильтры, их тоже правильно настраивайте. Как показывает практика, клиентские мыльницы-маршрутизаторы сорят bpdu, лечится обновлением прошивки. Вставить ник Quote
