Zarin Posted June 18, 2012 Posted June 18, 2012 (edited) Такая проблема. При ip subscriber routed и initator dhcp не приходит акаунтинг, если включен accounting delay-start all (или для vrf в котором висит интерфейс) Стоит выключить delay-start, аккаунтинг начинает приходит, но старт-пакет не содержит атрибута Framed-IP-Address. Апдейт пакеты приходят уже с атрибутом Framed-IP-Address. IOS: asr1000rp1-adventerprisek9.03.04.02.S.151-3.S2.bin Является ли это глюком. Или так и должно работать ? =================================================================== aaa authentication login default local group aaa-manage aaa authentication login INET-ISG group aaa-inet aaa authentication enable default enable line group aaa-manage aaa authentication ppp INET-L2TP group aaa-billing aaa authorization network INET-L2TP group aaa-billing aaa authorization network INET-ISG group aaa-inet aaa authorization subscriber-service default local group aaa-inet aaa authorization subscriber-service INET-ISG group aaa-inet aaa accounting delay-start vrf <l2tp_vrf_name> aaa accounting update periodic 20 aaa accounting network INET-L2TP start-stop group aaa-billing aaa accounting network INET-ISG start-stop group aaa-inet ========================================================================= policy-map type control ISG-INTERFACE-POLICY class type control always event session-start 10 authorize aaa list INET-ISG password 123 identifier remote-id plus circuit-id plus mac-address ! class type control always event session-restart 10 authorize aaa list INET-ISG password 123 identifier remote-id plus circuit-id plus mac-address ! ========================================================================= interface Port-channel2.171 encapsulation dot1Q 171 vrf forwarding <ipoe_vrf_name> ip dhcp relay information check-reply none ip address <ip> <mask> ip helper-address <dhcp_host> service-policy type control ISG-INTERFACE-POLICY ip subscriber routed initiator dhcp Спасибо. Edited June 18, 2012 by Zarin Вставить ник Quote
