СЕРВЕРА
1. Сервер Sun Netra 210 1U 10тыс.р.
1x2 CPU UltraSparc IIIi (1.3GHz), 2x512Mb 32max PC2700 ECC, 1x2 72 GB 10k SAS Hot-Swap, Qlogic QLA2342 QLA 2342 2-Gbps Fibre Fiber Channel HBA Card, DVD-RW, 4x10/100/1000 Base-T Ethernet, 1x10 Base-T Ethernet, 1xTIA/EIA-232-F (RJ45) port 1xTIA/EIA-232-F asynchronous (DB9) port, SCSI/USB: 1xUltra160 SCSI multimode (SE/LVD). 2xOHCI 1.0-compliant interfaces, Supporting dual speeds of 1.2- and 1.5-Mbits/sec. each, 1xinternal PCI 2.2-compliant expansion slot: 1x64-bit, 33/66-MHz 3.3 V full-length, ONC, NFS, TCP/IP, SunLink, OSI, MHS, IPX/SPX
2. Сервер IBM x3350 (4193K1G) 15тыс.р.
IBM System x3350; Однопроцессорный сервер, 1U; Intel Xeon 2.66 GHz 3075 Dual Core L2 Cache 4MB FSB 1333MHz; RAM 4x512 MB PC2-5300E DDR2 SDRAM ECC; 1x250Gb 2 Bays 3.5" Hot-swap; Integrated SATA/SAS Controller; 2xPower 450Вт; Multiburner; no FDD; Dual GB Ethernet, Rack 1U
3. Сервер IBM x3650 25тыс.р.
1x2 Xeon Quad Core E5405 80W 2.0GHz/1333MHz/12MB L2, 2x1GB PC5300F DDR2 SDRAM 12max, 2x8 73,4Gb 15k 2.5” HS SAS, Streamer Quantum CD72SH, PCI-E Riser Card, ServeRAID-8k, 2хGbEth, Ultrabay Enhanced DVD-ROM/CD-RW, 2x835W p/s
4. Сервер IBM x3650 (7979KPG) 25 тыс.р.
1x2 Xeon Quad Core E5405 80W 2.0GHz/1333MHz/12MB L2, 2x1GB PC5300F DDR2 SDRAM 12max, 2x6 3.5” 146,8 SAS 10K HS, PCI-E Riser Card, , ServeRAID-8k, 2хGbEth, Ultrabay Enhanced DVD-ROM/CD-RW Combo Drive, 2x835W p/s
5. Сервер IBM x3650 25 тыс.р.
IBM x3650, 2U, 1x2 Xeon Quad Core X5405 80W 2.0GHz/1333MHz/12MB L2, 2x1GB PC5300F DDR2 667Mhz 12max, 2x8 2.5” 146,8 SAS 10K HS, PCI-E Riser Card, Ultrabay Enhanced DVD-ROM/CD-RW Combo Drive, 2x835W p/s
6. Сервер IBM x3650 (7979KPG) 30 тыс.р.
2x2 Xeon Quad Core L5410 80W 2.0GHz/1333MHz/12MB L2, 2x1GB PC5300F DDR2 667Mhz 12max, 2x8 2.5” 146,8 SAS 10K HS, PCI-E Riser Card, , ServeRAID-8k, 2хGbEth, Ultrabay Enhanced DVD-ROM/CD-RW Combo Drive, 2x835W p/s
7. Сервер IBM x3850 (71414RG) 100 тыс.р.
IBM x3850 M2, 4U, 4xXeon Quad Core X7350 130W 2.93GHz/1066MHz/8MB L2, 8x1GB PC2-5300F Hot Swap 32max(256Gb), 4x73,4 15k/Bay HS 2.5in SAS, UltraSlim Enhanced Super Multi, 2x1440W p/s
8. Сервер Dell PowerEdge R900 85 тыс.р.
Rack 4U, 2xXeon Quad Core X7350 130W 2.93GHz/1066MHz/8MB L2, 8x1GB PC2-5300F Hot Swap 32max(256Gb), 8x73,4 15k/Bay HS 2.5” SAS, DVD CD-RW, 2x1570W p/s
+ к ним
Консоль IBM 1U 17" Flat Panel Monitor Console 17231RX with Keyboard Со всеми шнурами и салазками 15тыс.р.
KVM коммутатор IBM Global 2x16 Console Manager 17352GX, в комплекте 13 шт. KVM Conversion Cable (UCO) 39M2911 40тыс.р.
Aten CS9138 Переключатель электрон. KVM 1 user PS2+VGA кабель в комплекте 3 тыс.р.
Cisco 675W Redundant Power Supply 5 тыс.р.
IBM ISS Proventia M30E 5 тыс.р.
Система контроля и мониторинга Rittal СМС-ТС в комплекте (Процессорный блок PU II RITTAL 7320100 3шт., Сенсорный блок ввода/вывода для PU II 4 порта RJ-12 для 4х датчиков RITTAL 7320210 - 6шт., Датчик дыма RITTAL 7320560 2шт, Датчик температуры RITTAL 7320500 - 3шт., Датчик утечки Rittal 7320630 -6шт.) 40тыс.р.
и Avaya G650 с IP медиапроцессором и платами TN2312BP IPSI -1шт., TN799DP C-Lan-4шт., TN2464CP-3шт., TN793CP, TN771DP, TN744E. 200тыс.р.
IP-телефоны Avaya 1616 по 1,5 тыс.р.
IP-телефоны LinkSys SPA 922,941 1-1,5 тыс.р.
Все оборудование в рабочем и очень хорошем состоянии.
тел. 8(905)541-3959 Дмитрий
