В общем решил просто поглядеть. На сервер поднял vlan, ничего такого и сел на него tcpdump.
Вижу такое:
0 max 20 hello 2 fdelay 15
15:57:05.708808 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:06.244028 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:06.708848 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:07.243942 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:07.300316 00:1b:21:af:e5:6d > 01:80:c2:00:00:00, 802.3, length 52: LLC, dsap STP (0x42), ssap STP (0x42), cmd 0x03: 802.1d config 8000.00:1b:21:af:e5:6d.8011 root 8000.00:1b:21:af:e5:6d pathcost 0 age 0 max 20 hello 2 fdelay 15
15:57:07.708816 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:08.170368 54:04:a6:c8:43:90 > Broadcast, ethertype ARP (0x0806), length 60: arp who-has 192.168.0.254 (Broadcast) tell 192.168.0.121
15:57:08.243914 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:08.358784 14:d6:4d:a7:db:aa > 01:00:5e:40:00:00, ethertype IPv4 (0x0800), length 157: 192.168.0.43.plysrv-https > 239.192.0.0.plysrv-https: UDP, length 115
15:57:08.358975 14:d6:4d:a7:db:aa > 01:00:5e:40:00:00, ethertype IPv4 (0x0800), length 157: 192.168.0.43.plysrv-https > 239.192.0.0.plysrv-https: UDP, length 115
15:57:08.359087 14:d6:4d:a7:db:aa > 01:00:5e:40:00:00, ethertype IPv4 (0x0800), length 157: 192.168.0.43.plysrv-https > 239.192.0.0.plysrv-https: UDP, length 115
15:57:08.717799 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:09.243918 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:09.299894 00:1b:21:af:e5:6d > 01:80:c2:00:00:00, 802.3, length 52: LLC, dsap STP (0x42), ssap STP (0x42), cmd 0x03: 802.1d config 8000.00:1b:21:af:e5:6d.8011 root 8000.00:1b:21:af:e5:6d pathcost 0 age 0 max 20 hello 2 fdelay 15
15:57:09.717746 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:10.244004 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:10.717775 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:11.244019 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:11.299611 00:1b:21:af:e5:6d > 01:80:c2:00:00:00, 802.3, length 52: LLC, dsap STP (0x42), ssap STP (0x42), cmd 0x03: 802.1d config 8000.00:1b:21:af:e5:6d.8011 root 8000.00:1b:21:af:e5:6d pathcost 0 age 0 max 20 hello 2 fdelay 15
15:57:11.388816 14:d6:4d:a7:db:aa > 01:00:5e:40:00:00, ethertype IPv4 (0x0800), length 157: 192.168.0.43.plysrv-https > 239.192.0.0.plysrv-https: UDP, length 115
15:57:11.389001 14:d6:4d:a7:db:aa > 01:00:5e:40:00:00, ethertype IPv4 (0x0800), length 157: 192.168.0.43.plysrv-https > 239.192.0.0.plysrv-https: UDP, length 115
15:57:11.717827 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:11.733988 b0:48:7a:dd:b5:d9 > Broadcast, ethertype ARP (0x0806), length 60: arp who-has 192.168.0.93 tell 192.168.0.93
15:57:12.243993 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:12.717788 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:12.833708 00:0a:48:08:87:b3 > Broadcast, ethertype ARP (0x0806), length 60: arp who-has 192.168.0.101 tell 192.168.0.101
15:57:13.243987 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:13.299643 00:1b:21:af:e5:6d > 01:80:c2:00:00:00, 802.3, length 52: LLC, dsap STP (0x42), ssap STP (0x42), cmd 0x03: 802.1d config 8000.00:1b:21:af:e5:6d.8011 root 8000.00:1b:21:af:e5:6d pathcost 0 age 0 max 20 hello 2 fdelay 15
15:57:13.717857 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:14.245113 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:14.371462 14:d6:4d:a7:db:aa > 01:00:5e:40:00:00, ethertype IPv4 (0x0800), length 157: 192.168.0.43.plysrv-https > 239.192.0.0.plysrv-https: UDP, length 115
15:57:14.717862 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:15.245074 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:15.299430 00:1b:21:af:e5:6d > 01:80:c2:00:00:00, 802.3, length 52: LLC, dsap STP (0x42), ssap STP (0x42), cmd 0x03: 802.1d config 8000.00:1b:21:af:e5:6d.8011 root 8000.00:1b:21:af:e5:6d pathcost 0 age 0 max 20 hello 2 fdelay 15
15:57:15.378202 14:d6:4d:a7:db:aa > 01:00:5e:40:00:00, ethertype IPv4 (0x0800), length 157: 192.168.0.43.plysrv-https > 239.192.0.0.plysrv-https: UDP, length 115
15:57:15.717789 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:16.245054 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:16.383249 14:d6:4d:a7:db:aa > 01:00:5e:40:00:00, ethertype IPv4 (0x0800), length 157: 192.168.0.43.plysrv-https > 239.192.0.0.plysrv-https: UDP, length 115
15:57:16.717782 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:17.245079 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:17.300032 00:1b:21:af:e5:6d > 01:80:c2:00:00:00, 802.3, length 52: LLC, dsap STP (0x42), ssap STP (0x42), cmd 0x03: 802.1d config 8000.00:1b:21:af:e5:6d.8011 root 8000.00:1b:21:af:e5:6d pathcost 0 age 0 max 20 hello 2 fdelay 15
15:57:17.717781 14:d6:4d:a7:db:aa > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.43.54953 > 255.255.255.255.7533: UDP, length 26
15:57:18.178445 54:04:a6:c8:43:90 > Broadcast, ethertype ARP (0x0806), length 60: arp who-has 192.168.0.254 (Broadcast) tell 192.168.0.121
15:57:18.245116 00:25:22:b9:d5:e2 > Broadcast, ethertype IPv4 (0x0800), length 68: 192.168.0.31.megaregsvrport > 255.255.255.255.7533: UDP, length 26
15:57:18.602880 00:1f:e2:06:14:94 > 01:00:5e:40:00:00, ethertype IPv4 (0x0800), length 157: 192.168.0.112.plysrv-https > 239.192.0.0.plysrv-https: UDP, length 115
Не пойму, чего тут делает STP?
DGS-3120-24SC:admin#show stp ports 8
Command: show stp ports 1:8
MSTP Port Information
Port Index : 1:8 , Hello Time: 2 /2 , Port STP : Disabled ,
External PathCost : Auto/20000 , Edge Port : False/No , P2P : Auto /No
Port RestrictedRole : False, Port RestrictedTCN : False
Port Forward BPDU : Disabled
MSTI Designated Bridge Internal PathCost Prio Status Role
0 N/A 20000 128 Forwarding NonStp
Да и как можно подрезать все лишнее? напрягает этот шастающий мусор, серв на лине.
Абонент брудкастит, забейте на него, если проблем не возникает.
На всякий случае клиентов лучше изолировать друг от друга.
Ну и edge true на клиентских портах, если конечно используете STP
Если клиент отдан с DGS-3120-24SC то используйте ACL - они в Dlink на удивление очень даже хороши. В результате можно запретить все кроме arp запросов 0x0806 ( в принципе единственный полезный broadcast запрос - если кроме доступа в Internet клиент ничего получать не должен ). Тут на форуме полно примеров как настраивать длинковские ACL.
Удачи :)
