коллеги возник вопрос при работе с ip unnumbered:
используем L3-коммутатор Cisco
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(55)SE4, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Sep-11 06:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x0160376C
d1-test-3550#sh ip dhcp binding
Bindings from all pools not associated with VRF:
IP address          Client-ID/              Lease expiration        Type
                   Hardware address/
                   User name
10.2.1.10           000e.0829.8ea3          May 14 2012 09:37 AM    Relay
10.2.1.100          0021.8548.67be          May 14 2012 09:37 AM    Relay
10.2.1.101          0800.2772.de03          May 14 2012 09:40 AM    Relay
d1-test-3550#sh run int lo3
interface Loopback3
description vlan1
ip address 10.2.1.1 255.255.255.0 secondary
ip address 22.33.44.225 255.255.255.240
no ip redirects
end
d1-test-3550#sh run int vlan 11
interface Vlan11
ip dhcp relay information trusted
ip unnumbered Loopback3
ip helper-address 10.60.1.2
end
вроде бы все работает, но dhcp-сессии срываются. одной из возможных причин считаю, что при dhcp-relay cisco не отвечает на unicast renew
15:38:45.462602 IP (tos 0x0, ttl 128, id 19773, offset 0, flags [none], proto UDP (17), length 328)
   10.2.1.101.68 > 22.33.44.225.67: BOOTP/DHCP, Request from 08:00:27:72:de:03, length 300, xid 0x82b7770b, secs 1024, Flags [none]
         Client-IP 10.2.1.101
         Client-Ethernet-Address 08:00:27:72:de:03
         Vendor-rfc1048 Extensions
           Magic Cookie 0x63825363
           DHCP-Message Option 53, length 1: Request
           Client-ID Option 61, length 7: ether 08:00:27:72:de:03
           Hostname Option 12, length 5: "winxp"
           FQDN Option 81, length 9: "winxp."
           Vendor-Class Option 60, length 8: "MSFT 5.0"
           Parameter-Request Option 55, length 11:
             Subnet-Mask, Domain-Name, Default-Gateway, Domain-Name-Server
             Netbios-Name-Server, Netbios-Node, Netbios-Scope, Router-Discovery
             Static-Route, Classless-Static-Route-Microsoft, Vendor-Option
обрабатываются только broadcast DHCP Request, которые dhcp-клиент отправляет, если несколько раз безуспешно пытался сделать unicast-запрос.
ACL не включены, ip dhcp server не используется. в которую сторону копать?
  • 4 weeks later...
попробуй
no ip dhcp relay information check
но лучше сказать debug ip dhcp server events и debug ip dhcp server packet и посмотреть, почему renew не пропускает.
кстати, у меня вопрос: поделитесь кому не жалко "правильным" отлаженным ACL на 3550 L3 relay...
  • 3 years later...
Хоть тема и старая, но тоже с таким столкнулись - юникастовые запросы не попадали под relay.
У себя проблему решили тем, что начали в dhcp option 54 (server-identifier) передавать ip адрес циски. И проблема исчезла :)
можно на dhcp сервере подкрутить таймеры, чтобы клиент сразу по broadcast делал renew. У нас, когда были 3550, все работало без opt54. Сессии не падали. Причем время сессии было 5 или 10 минут. Еще не хватает proxy arp на vlan
сомнительно, ренью всегда юникастом идёт, тк адрес у клиента ещё есть и адрес сервера он знает.
Наверно, клиентам всё-таки вообще лучше не знать ip адрес настоящего DHCP сервера.
У меня какая-то часть клиентов, как и в Странность в DHCP REQUEST (unicast), слала юникаст запросы напрямую на сервер с broadcast флагом.А dhcp сервер тупо броадкастом так и отвечал в своём влане. В итоге - лишний мусор в логах и ненужный броадкаст в влане с серверами.
Надо крутить таймеры T1 и T2. Делать их близкими друг к другу или равными.
https://www.ietf.org/rfc/rfc2131.txt
If no DHCPACK arrives before time T2, the client moves to REBINDING
state and sends (via broadcast) a DHCPREQUEST message to extend its
lease. The client sets the 'ciaddr' field in the DHCPREQUEST to its
current network address. The client MUST NOT include a 'server
identifier' in the DHCPREQUEST message.
Times T1 and T2 are configurable by the server through options. T1
defaults to (0.5 * duration_of_lease). T2 defaults to (0.875 *
duration_of_lease). Times T1 and T2 SHOULD be chosen with some
random "fuzz" around a fixed value, to avoid synchronization of
client reacquisition.
