Возможно хотелка странная для 21-го века, но..
Как бы вот этот мусор -
tcpdump -nn -i fxp0 ip6
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on fxp0, link-type EN10MB (Ethernet), capture size 96 bytes
23:00:37.886793 IP6 fe80::c102:c40a:8078:1357.59660 > ff02::c.1900: UDP, length 146
23:00:40.886747 IP6 fe80::c102:c40a:8078:1357.59660 > ff02::c.1900: UDP, length 146
23:00:41.759772 IP6 fe80::c102:c40a:8078:1357.546 > ff02::1:2.547: dhcp6 solicit
23:00:43.886882 IP6 fe80::c102:c40a:8078:1357.59660 > ff02::c.1900: UDP, length 146
23:00:47.887190 IP6 fe80::c102:c40a:8078:1357.59660 > ff02::c.1900: UDP, length 146
23:00:50.887141 IP6 fe80::c102:c40a:8078:1357.59660 > ff02::c.1900: UDP, length 146
23:00:51.739685 IP6 fe80::5504:253d:70a7:c9ca.546 > ff02::1:2.547: dhcp6 solicit
23:00:52.753023 IP6 fe80::5504:253d:70a7:c9ca.546 > ff02::1:2.547: dhcp6 solicit
23:00:53.887276 IP6 fe80::c102:c40a:8078:1357.59660 > ff02::c.1900: UDP, length 146
23:00:54.765806 IP6 fe80::5504:253d:70a7:c9ca.546 > ff02::1:2.547: dhcp6 solicit
23:00:57.887565 IP6 fe80::c102:c40a:8078:1357.59660 > ff02::c.1900: UDP, length 146
23:00:58.774256 IP6 fe80::5504:253d:70a7:c9ca.546 > ff02::1:2.547: dhcp6 solicit
23:01:00.887544 IP6 fe80::c102:c40a:8078:1357.59660 > ff02::c.1900: UDP, length 146
23:01:03.887665 IP6 fe80::c102:c40a:8078:1357.59660 > ff02::c.1900: UDP, length 146
23:01:04.758976 IP6 fe80::c102:c40a:8078:1357.59080 > ff02::1:3.5355: UDP, length 33
23:01:04.858599 IP6 fe80::c102:c40a:8078:1357.59080 > ff02::1:3.5355: UDP, length 33
23:01:05.070304 IP6 fe80::c102:c40a:8078:1357.65468 > ff02::1:3.5355: UDP, length 33
23:01:05.169633 IP6 fe80::c102:c40a:8078:1357.65468 > ff02::1:3.5355: UDP, length 33
23:01:05.384695 IP6 fe80::c102:c40a:8078:1357.63810 > ff02::1:3.5355: UDP, length 33
23:01:05.484632 IP6 fe80::c102:c40a:8078:1357.63810 > ff02::1:3.5355: UDP, length 33
23:01:05.698726 IP6 fe80::c102:c40a:8078:1357.54882 > ff02::1:3.5355: UDP, length 33
23:01:05.798651 IP6 fe80::c102:c40a:8078:1357.54882 > ff02::1:3.5355: UDP, length 33p
пристрелить непосредственно на доступе?
Пока не особо достаёт, но есть один небольшой удалённый сегмент сети, подключенный к ядру по WIFI, вот оттуда очень хочется вычистить ipv6 мусор.
Существует ли вообще такой функционал на D-Link DES-3200? Хотелось бы реализовать с помощью PCF ACL-ей.
отключать поддержку ipv6 пробовали на доступе ?
Не нашел такой буквы в этом слове(свитче).
зафильтровать трафик по ethertype 0x86DD
А вот это скорее всего самое тО, даже подходящий профиль в ACL уже есть.
create access_profile packet_content_mask destination_mac FF-FF-FF-FF-FF-FF  offset1 l2 0 0xFFFF  profile_id 3
config access_profile profile_id 3 add access_id 1 packet_content destination_mac FF-FF-FF-FF-FF-FF offset1 0x0806 port 1-10 permit
Добавлю в него правило
config access_profile profile_id 3 add access_id 2 packet_content destination_mac FF-FF-FF-FF-FF-FF offset1 0x86dd port 1-10 deny
Проверил - не работает..
10:16:49.891674 f4:6d:04:2f:e5:c7 > 33:33:00:00:00:0c, ethertype IPv6 (0x86dd), length 208: (hlim 1, next-header UDP (17) payload length: 154) fe80::c102:c40
a:8078:1357.51015 > ff02::c.1900: UDP, length 146
       0x0000:  3333 0000 000c f46d 042f e5c7 86dd 6000  33.....m./....`.
       0x0010:  0000 009a 1101 fe80 0000 0000 0000 c102  ................
       0x0020:  c40a 8078 1357 ff02 0000 0000 0000 0000  ...x.W..........
       0x0030:  0000 0000 000c c747 076c 009a b73a 4d2d  .......G.l...:M-
       0x0040:  5345 4152 4348 202a 2048 5454 502f 312e  SEARCH.*.HTTP/1.
       0x0050:  310d 0a48 6f73 743a 5b46 4630 323a 3a43  1..Host:[FF02::C
10:16:53.891980 f4:6d:04:2f:e5:c7 > 33:33:00:00:00:0c, ethertype IPv6 (0x86dd), length 208: (hlim 1, next-header UDP (17) payload length: 154) fe80::c102:c40
10:16:56.891968 f4:6d:04:2f:e5:c7 > 33:33:00:00:00:0c, ethertype IPv6 (0x86dd), length 208: (hlim 1, next-header UDP (17) payload length: 154) fe80::c102:c40
10:16:59.892079 f4:6d:04:2f:e5:c7 > 33:33:00:00:00:0c, ethertype IPv6 (0x86dd), length 208: (hlim 1, next-header UDP (17) payload length: 154) fe80::c102:c40
10:17:00.148097 50:e5:49:29:82:09 > 33:33:00:01:00:02, ethertype IPv6 (0x86dd), length 152: (hlim 1, next-header UDP (17) payload length: 98) fe80::21ca:b230
:d3f2:f138.546 > ff02::1:2.547: dhcp6 solicit (xid=459255 (elapsed time 0) (client ID hwaddr/time type 1 time 380318533 50e549298209)[|dhcp6ext])
       0x0000:  3333 0001 0002 50e5 4929 8209 86dd 6000  33....P.I)....`.
       0x0010:  0000 0062 1101 fe80 0000 0000 0000 21ca  ...b..........!.
       0x0020:  b230 d3f2 f138 ff02 0000 0000 0000 0000  .0...8..........
       0x0030:  0000 0001 0002 0222 0223 0062 ce7f 0145  .......".#.b...E
       0x0040:  9255 0008 0002 0000 0001 000e 0001 0001  .U..............
       0x0050:  16ab 3345 50e5 4929 8209 0003 000c 1450  ..3EP.I).......P
10:17:01.148159 50:e5:49:29:82:09 > 33:33:00:01:00:02, ethertype IPv6 (0x86dd), length 152: (hlim 1, next-header UDP (17) payload length: 98) fe80::21ca:b230
:d3f2:f138.546 > ff02::1:2.547: dhcp6 solicit (xid=459255 (elapsed time 100) (client ID hwaddr/time type 1 time 380318533 50e549298209)[|dhcp6ext])
       0x0030:  0000 0001 0002 0222 0223 0062 ce1b 0145  .......".#.b...E
       0x0040:  9255 0008 0002 0064 0001 000e 0001 0001  .U.....d........
10:17:03.148315 50:e5:49:29:82:09 > 33:33:00:01:00:02, ethertype IPv6 (0x86dd), length 152: (hlim 1, next-header UDP (17) payload length: 98) fe80::21ca:b230
:d3f2:f138.546 > ff02::1:2.547: dhcp6 solicit (xid=459255 (elapsed time 300) (client ID hwaddr/time type 1 time 380318533 50e549298209)[|dhcp6ext])
       0x0030:  0000 0001 0002 0222 0223 0062 cd53 0145  .......".#.b.S.E
       0x0040:  9255 0008 0002 012c 0001 000e 0001 0001  .U.....,........
10:17:03.892362 f4:6d:04:2f:e5:c7 > 33:33:00:00:00:0c, ethertype IPv6 (0x86dd), length 208: (hlim 1, next-header UDP (17) payload length: 154) fe80::c102:c40
10:17:06.177548 00:24:21:03:9c:20 > 33:33:ff:ff:ff:fe, ethertype IPv6 (0x86dd), length 86: (hlim 255, next-header ICMPv6 (58) payload length: 32) fe80::8d78:
b42a:794c:2ce3 > ff02::1:ffff:fffe: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has fe80::ffff:ffff:fffe
         source link-address option (1), length 8 (1): 00:24:21:03:9c:20
       0x0000:  3333 ffff fffe 0024 2103 9c20 86dd 6000  33.....$!.....`.
       0x0010:  0000 0020 3aff fe80 0000 0000 0000 8d78  ....:..........x
       0x0020:  b42a 794c 2ce3 ff02 0000 0000 0000 0000  .*yL,...........
       0x0030:  0001 ffff fffe 8700 d685 0000 0000 fe80  ................
       0x0040:  0000 0000 0000 0000 ffff ffff fffe 0101  ................
       0x0050:  0024 2103 9c20                           .$!...
10:17:06.892302 f4:6d:04:2f:e5:c7 > 33:33:00:00:00:0c, ethertype IPv6 (0x86dd), length 208: (hlim 1, next-header UDP (17) payload length: 154) fe80::c102:c40
10:17:06.893208 00:24:21:03:9c:20 > 33:33:ff:ff:ff:fe, ethertype IPv6 (0x86dd), length 86: (hlim 255, next-header ICMPv6 (58) payload length: 32) fe80::8d78:
10:17:07.148512 50:e5:49:29:82:09 > 33:33:00:01:00:02, ethertype IPv6 (0x86dd), length 152: (hlim 1, next-header UDP (17) payload length: 98) fe80::21ca:b230
:d3f2:f138.546 > ff02::1:2.547: dhcp6 solicit (xid=459255 (elapsed time 700) (client ID hwaddr/time type 1 time 380318533 50e549298209)[|dhcp6ext])
       0x0030:  0000 0001 0002 0222 0223 0062 cbc3 0145  .......".#.b...E
       0x0040:  9255 0008 0002 02bc 0001 000e 0001 0001  .U..............
10:17:07.893002 00:24:21:03:9c:20 > 33:33:ff:ff:ff:fe, ethertype IPv6 (0x86dd), length 86: (hlim 255, next-header ICMPv6 (58) payload length: 32) fe80::8d78:
10:17:09.178152 00:24:21:03:9c:20 > 33:33:ff:ff:ff:fe, ethertype IPv6 (0x86dd), length 86: (hlim 255, next-header ICMPv6 (58) payload length: 32) fe80::8d78:
10:17:09.892444 f4:6d:04:2f:e5:c7 > 33:33:00:00:00:0c, ethertype IPv6 (0x86dd), length 208: (hlim 1, next-header UDP (17) payload length: 154) fe80::c102:c40
10:17:09.892904 00:24:21:03:9c:20 > 33:33:ff:ff:ff:fe, ethertype IPv6 (0x86dd), length 86: (hlim 255, next-header ICMPv6 (58) payload length: 32) fe80::8d78:
10:17:10.892904 00:24:21:03:9c:20 > 33:33:ff:ff:ff:fe, ethertype IPv6 (0x86dd), length 86: (hlim 255, next-header ICMPv6 (58) payload length: 32) fe80::8d78:
10:17:11.155389 00:24:21:03:9c:20 > 33:33:ff:cd:b4:20, ethertype IPv6 (0x86dd), length 86: (hlim 255, next-header ICMPv6 (58) payload length: 32) fe80::8d78:
b42a:794c:2ce3 > ff02::1:ffcd:b420: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has fe80::fd8b:d9f:1fcd:b420
       0x0000:  3333 ffcd b420 0024 2103 9c20 86dd 6000  33.....$!.....`.
       0x0030:  0001 ffcd b420 8700 437c 0000 0000 fe80  ........C|......
       0x0040:  0000 0000 0000 fd8b 0d9f 1fcd b420 0101  ................
Похоже я погорячился насчет того, что профиль 3 подходит для этой задачи.. Или накосячил в самом правиле (с destination_mac).
Попробую вот так:
config access_profile profile_id 3 add access_id 2 packet_content destination_mac 00-00-00-00-00-00 mask 00-00-00-00-00-00 offset1 0x86dd port 1-10 deny
P.S. Кстати, destination МАС в пакетах какой-то странный..
UPD: Переписал правило, все ок - tcpdump молчит..
P.P.S. Ну теперь можно смело идти праздновать. :)
Всех с Днем Победы!!
Edited by AlKov
А зачем dest_mac ?
Так не проще ли?
create access_profile  packet_content_mask   offset1 l2 0 0xFFFF  profile_id 3
config access_profile profile_id 3  add access_id 1  packet_content   offset1 0x86dd   mask 0xffff port 1-10 deny
а к нам хомячьё бегает, как так они чужие компы в сетевом окружении видят
ipv6 это очень опасно, когда к компьютеру настроенному среднестатистическим юзером, есть доступ из любой точки мира
так вот откуда это полезло... спасибо за наводку
Видят - их проблемы. Им дали дырку с интернетом, а дальше пущай сами себе админят или зовут мастеров за "пиво".
PS: было смешнее когда америкосовские компы с гос органов так были видны - ихние админы тогда ещё были не в курсе всяких тередо и прочих туннелинговых автотехнологий в новых виндах.
В общем, так и отболтались, мы предоставляем коннективити, а дальше проблемы юзера, почему он не пользуется фаерволом, но ведь проще один раз запретить, чем сто раз объяснить
tcp/139 и tcp/445 им закройте
Неправда ваша. К компьютеру с Win7, настроенному среднестатистическим юзером, нет доступа из любой точки мира. Если конечно этот юзер специально не отключил фаервол, или если не перевёл фаервол в режим Home network (супротив дефолтной Public network), или если чего ещё хуже не поставил какую-нибудь сборку ZverCD. Но тогда этот юзверь уже не среднестатистический.
Edited by dr Tr0jan
Новейшие разработки от MS такие как HomeGroup использует другие номера портов, а еще она использует ipv6
только win7 при подключении спрашивает к какой сети она подключена, и что должен выбрать юзер если комп стоит у него дома? а если у него будет домашняя сеть за роутером и все на ipv6 - какой профиль выберет юзер? параноидальный или тот, где домашние компы смогут друг с другом взаимодействовать?
Edited by zi_rus
zi_rus, HomeGroup защищена паролем. Не зная пароля, не увидишь в своей сети чужие машины.
Если у юзверя сеть за роутером, то среднестатистично - это NAT (а если не NAT, то проблема провайдера); если NAT, то и по ipv6 юзверь из другой сети никого не увидит при любых настройках фаерволла. Проблемы "хомячьё бегает, как так они чужие компы в сетевом окружении видят" возникают из-за multihomed компов (с несколькими сетевухами: одна - инет, вторая - домашняя локалка) с кривонастроенным фаерволом (Home network на интернетовском интерфейсе).
2 dr Tr0jan Эээ ipv6 как бы и придумывался чтобы не было бедных НАТа. Все домашние устройства будут доступны из внешнего мира. Спасет только настроенный фаервол. Другой вопрос что 10 домашних устройств в его /64 не найдут перебором (ну или очень не скоро).. Ну так найдут по активности. есть много мест где логи светятся в мир, достаточно туда разок зайти.
зы. В винде фаервол научили фильтровать v6 ? Некоторое время назад оно этого не делало (как минимум по умолчанию).
про видят чужие компы, это я не в тему ляпнул, к ipv6 отношения не имеет, просто почему-то в голове всплыл случай, нам даже пытались нарушение конфиденциальности приплести
я вот homegroup не тестировал и не знаю что он сам по себе может показать без ipv4 примочек старых времен. пароль-то есть, но что мы видим пока пароль еще не введен?
мы четко обрисовали свою позицию и фильтровать что-либо отказались, мне кажется это правильно
st_re, я ошибся, ниже расскажу почему.
В win7 всегда фильтровало v6. По умолчанию не фильтровало в winxp, но там и v6 по умолчанию не было вообще.
Ага, и меня что-то понесло. В win7 по умолчанию в Home network (он же Firewall Private profile) SMB/CIFS фильтруется по localsubnet. Т.е. супостаты из интернета не пройдут в любом случае. st_re, т.е. можно не париться и спокойно ставить Home профиль хоть с роутером, хоть без него.
Ничего не видим. Вас просто не пустят в группу без пароля. Точнее вы даже найти её без пароля не сможете.
Edited by dr Tr0jan
уу.. если в конце шарки поставить $ то ее не видно... ага. В эксплорере. В остальных местах видно однако. Если на фай фай рутере поставить не анонсировать ssid то его не видно.. Но находится она на раз-два. Тут также ?
вот это не верно
http://www.techdays.ru/videos/1404.html
видео с момента 14:00 рассказывается как идет работа с хоумгруп
в двух словах, как только кто-то в локальной сети кто-то создаст группу, другие машины автоматически ее обнаруживают и они уже не могут ничего создать, а могут только присоединиться к созданной и для того чтобы узнать, что в сети создана группа, не надо знать пароля
Edited by zi_rus
st_re, нет, речь идёт о другой технологии - о Homegroup, а не Network Neighbors.
zi_rus, забавно, пришли к тому, что сеть надо либо сегментировать по L2, либо резать Homegroup.
Я и спрашиваю "не видно" реализовано так же, как в примерах выше ? а пароль поди в 90% случаем qwerty или подобный? достаточно чтобы было видно саму группу, пароль подберут не к 1-й так к 3-й найденной сети, ибо человек ленив.
st_re, там есть кнопка "распечатать на принтере", а если нет принтера, советуют написать на бумажке.
Там и другие протоколы используются, найти не проблема.
И заплатки постоянно выходят для дыр как с прошедшими проверку так и не прошедшими -левыми юзерами.
