Замечено, что при создании саб-интерфейса иногда возникают проблемы.
May  4 10:56:41.698: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Unknown state
May  4 10:56:41.698: %ASR1000_RP_ALARM-6-INFO: ASSERT CRITICAL module R0 No Working ESP
May  4 10:57:00.808: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0 desc:CPP Client process failed: cpp_cp det:HA class:CLIENT_SW sev:FATAL id:1 cppstate:RUNNING res:UNKNOWN flags:0x0 cdmflags:0x0
May  4 10:57:00.809: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP MDM while client(s) still connected
May  4 10:57:00.831: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_cp_svr has been helddown (rc 134)
May  4 10:57:00.844: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_ha_top_level_server has been helddown (rc 69)
May  4 10:57:04.818: %CPPOSLIB-3-ERROR_NOTIFY: F0: /tmp/sw/fp/0/0/fpx86/mount/usr/cpp/bin/cpp_driver[6519]:  cpp_driver-0 encountered an error -Traceback= 1#a00f6e53e69011fd6ce8a24064a6fc2c   errmsg:7FB3FBBB6000+1175 cpp_common_os:7FB3FEB61000+D1E5 cpp_common_os:7FB3FEB61000+D12E cpp_common_os:7FB3FEB61000+18FEE :400000+104C0 cpp_drv_cmn:7FB3FF9EF000+B98A4 cpp_drv_cmn:7FB3FF9EF000+AED19 evlib:7FB3FD76D000+B379 evlib:7FB3FD76D000+DCD0 :400000+8121 :400000+77C8 c:7FB3F73DB000+1E514 :400000+72B9
May  4 10:57:16.328: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Unknown state
May  4 10:57:16.328: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Disabled
May  4 10:58:01.318: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Disabled
May  4 10:58:01.318: %ASR1000_RP_ALARM-6-INFO: ASSERT MAJOR module F0 Boot state
May  4 10:59:06.787: %CPPHA-7-START: F0: cpp_ha:  CPP 0 preparing image /tmp/sw/fp/0/0/fpx86/mount/usr/cpp/bin/qfp-ucode-esp40
May  4 10:59:07.293: %CPPHA-7-START: F0: cpp_ha:  CPP 0 startup init image /tmp/sw/fp/0/0/fpx86/mount/usr/cpp/bin/qfp-ucode-esp40
May  4 10:59:09.234: %ASR1000_OIR-6-ONLINECARD: Card (fp) online in slot F0
May  4 10:59:09.234: %ASR1000_RP_ALARM-6-INFO: CLEAR CRITICAL module R0 No Working ESP
May  4 10:59:09.234: %ASR1000_RP_ALARM-6-INFO: CLEAR MAJOR module F0 Boot state
May  4 10:59:13.052: %CPPHA-7-START: F0: cpp_ha:  CPP 0 running init image /tmp/sw/fp/0/0/fpx86/mount/usr/cpp/bin/qfp-ucode-esp40
May  4 10:59:13.656: %CPPHA-7-READY: F0: cpp_ha:  CPP 0 loading and initialization complete
May  4 10:59:13.852: %IOSXE-6-PLATFORM: F0: cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-ADVIPSERVICES-M), Version 15.1(3)S, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 22:44 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2011 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
ASR-1004 uptime is 2 weeks, 3 days, 3 hours, 0 minutes
Uptime for this control processor is 2 weeks, 3 days, 3 hours, 2 minutes
System returned to ROM by reload at 08:07:02 UTC Thu Sep 15 2011
System restarted at 11:16:49 Moscow Thu Apr 19 2012
System image file is "bootflash:asr1000rp2-advipservices.03.04.00.S.151-3.S.bin"
Last reload reason: Reload Command
cisco ASR1004 (RP2) processor with 4282135K/6147K bytes of memory.
4 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1925119K bytes of eUSB flash at bootflash:.
78085207K bytes of SATA hard disk at harddisk:.
Configuration register is 0x2102
Кто-нибудь сталкивался с данной проблемой? Можете что-нибудь посоветовать?
Edited by detx
на asr1000rp1-advipservices.03.05.00.S.152-1.S.bin таких проблем не замечено, думаю и на Вашем rp2 тоже всё будет работать корректно, рутрекер в помощь)
