Имеем freeBSD 5.2, mpd 3.18.
mpd.conf
default:
   load pppoe0
pppoe0:
   new -i ng0 pppoe0 pppoe0
   set ipcp ranges 172.18.1.1/32 172.18.1.2/32
   load pppoe_standart
pppoe_standart
   set iface disable on-demand
   set bundle disable multilink
   set link yes acfcomp protocomp
   set link no pap chap
   set link enable chap
   set link mtu 1492
   set iface route default
   set iface idle 0
   set bundle authname MyLogin
   set link no acfcomp protocomp
   set link keep-alive 10 60
   set ipcp yes vjcomp
mpd.links
pppoe0:
   set link type pppoe
   set pppoe iface tx0
   set pppoe service "*"
   set pppoe enable incoming
   set pppoe disable originate
При попытки соединения из windows 98/XP пишет линия занята.
По сети передается 3 пакета
1. PADI Есть ли pppoe сервер
2. PADO Да есть
3. PADR Подключится к нему
4. Ответа так и нет!!!
В лог mpd пишет
Jul 22 16:27:28 SERVER mpd: mpd: pid 662, version 3.18 (root@freebsd.org 13:20  1-Jul-2004)
Jul 22 16:27:28 SERVER mpd: [pppoe0] ppp node is "mpd662-pppoe0"
Jul 22 16:27:28 SERVER mpd: [pppoe0] exec: /sbin/ifconfig tx0 up
Jul 22 16:27:28 SERVER mpd: [pppoe0] using interface ng0
Jul 22 16:27:28 SERVER mpd: [pppoe0] PPPoE server listening on tx0: for service "*"
-----Это после подключения-----
Jul 22 16:28:19 SERVER mpd: Incoming PPPoE connection request via tx0: for service "*" from 00:10:60:f6:10:10
Jul 22 16:28:19 SERVER mpd: [pppoe0] Accepting PPPoE connection
Jul 22 16:28:19 SERVER mpd: [pppoe0] PPPoE response sent
Jul 22 16:28:19 SERVER mpd: [pppoe0] IPCP: Open event
Jul 22 16:28:19 SERVER mpd: [pppoe0] IPCP: state change Initial --> Starting
Jul 22 16:28:19 SERVER mpd: [pppoe0] IPCP: LayerStart
Jul 22 16:28:19 SERVER mpd: [pppoe0] bundle: OPEN event in state CLOSED
Jul 22 16:28:19 SERVER mpd: [pppoe0] opening link "pppoe0"...
Jul 22 16:28:19 SERVER mpd: [pppoe0] link: OPEN event
Jul 22 16:28:19 SERVER mpd: [pppoe0] LCP: Open event
Jul 22 16:28:19 SERVER mpd: [pppoe0] LCP: state change Initial --> Starting
Jul 22 16:28:19 SERVER mpd: [pppoe0] LCP: LayerStart
Jul 22 16:28:19 SERVER mpd: [pppoe0] device: OPEN event in state DOWN
Jul 22 16:28:19 SERVER mpd: [pppoe0] PppoeOpen() on incoming call
Jul 22 16:28:19 SERVER mpd: [pppoe0] device is now in state OPENING
Jul 22 16:28:19 SERVER mpd: [pppoe0] PPPoE connection closed
Jul 22 16:28:19 SERVER mpd: [pppoe0] device: DOWN event in state OPENING
Jul 22 16:28:19 SERVER mpd: [pppoe0] device is now in state DOWN
Jul 22 16:28:19 SERVER mpd: [pppoe0] link: DOWN event
Jul 22 16:28:19 SERVER mpd: [pppoe0] LCP: Down event
Jul 22 16:28:19 SERVER mpd: [pppoe0] pausing 6 seconds before open
Jul 22 16:28:25 SERVER mpd: [pppoe0] device: OPEN event in state DOWN
Jul 22 16:28:25 SERVER mpd: [pppoe0] PPPoE originate option is not enabled
Jul 22 16:28:25 SERVER mpd: [pppoe0] device is now in state OPENING
Jul 22 16:28:25 SERVER mpd: [pppoe0] device: DOWN event in state OPENING
Jul 22 16:28:25 SERVER mpd: [pppoe0] device is now in state DOWN
Jul 22 16:28:25 SERVER mpd: [pppoe0] link: DOWN event
Jul 22 16:28:25 SERVER mpd: [pppoe0] LCP: Down event
Jul 22 16:28:25 SERVER mpd: [pppoe0] pausing 6 seconds before open
Jul 22 16:28:31 SERVER mpd: [pppoe0] device: OPEN event in state DOWN
Jul 22 16:28:31 SERVER mpd: [pppoe0] PPPoE originate option is not enabled
Jul 22 16:28:31 SERVER mpd: [pppoe0] device is now in state OPENING
Jul 22 16:28:31 SERVER mpd: [pppoe0] device: DOWN event in state OPENING
Jul 22 16:28:31 SERVER mpd: [pppoe0] device is now in state DOWN
Jul 22 16:28:31 SERVER mpd: [pppoe0] link: DOWN event
Jul 22 16:28:31 SERVER mpd: [pppoe0] LCP: Down event
и дальше продолжается пока не остановишь.
Вчем может быть ошибка?
