Уважаемые господа! Помогите настроить связку e1-as5350-asterisk, проблема в следующем:
исходящие звонки из астериска уходят в е1 без проблем, но входящие.... понимаю что проблема в написании dial-peer'ов и translation-rule.
три дня голову ломаю, все не как.
формат аона 495ХХХХХХХ
мой конфиг (сильно не ругайте)
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname m9-2
no boot startup-test
enable secret 5 $1$iWS9$AQ9ebdhGVhiBtFdOE1.NO/
resource-pool disable
spe default-firmware spe-firmware-1
aaa new-model
aaa authentication login default group tacacs+ local enable
aaa authentication login CONSOLE none
aaa authentication ppp default if-needed group tacacs+
aaa session-id common
ip subnet-zero
ip cef
isdn switch-type primary-net5
voice call send-alert
no voice call carrier capacity active
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
sip
voice class codec 2
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 5 g723r53
codec preference 6 g723ar53
codec preference 7 g723r63
no voice hpi capture buffer
no voice hpi capture destination
controller E1 3/0
framing NO-CRC4
pri-group timeslots 1-31
description Beeline
controller E1 3/1
interface FastEthernet0/0
ip address XXX.XXX.22.88 255.255.255.0
ip access-group stopvoip1 in
duplex full
speed 100
interface FastEthernet0/1
description ipass(m9-cat-2:fa11,18,30)-255
ip address XXX.XX.241.140 255.255.255.248
duplex full
speed 100
interface Serial0/0
no ip address
shutdown
clockrate 2000000
interface Serial0/1
no ip address
shutdown
clockrate 2000000
interface Serial3/0:15
no ip address
isdn overlap-receiving
isdn network-failure-cause 17
isdn incoming-voice modem
isdn map address . plan isdn type subscriber
isdn send-alerting
isdn negotiate-bchan
isdn sending-complete
no cdp enable
interface Async1/00
no ip address
interface Async1/01
no ip address
interface Async1/02
no ip address
interface Async1/03
no ip address
interface Async1/04
no ip address
interface Async1/05
no ip address
interface Async1/06
no ip address
interface Async1/07
no ip address
interface Async1/08
no ip address
interface Async1/09
no ip address
interface Async1/10
no ip address
interface Async1/11
no ip address
interface Async1/12
no ip address
interface Async1/13
no ip address
interface Async1/14
no ip address
interface Async1/15
no ip address
interface Async1/16
no ip address
interface Async1/17
no ip address
interface Async1/18
no ip address
interface Async1/19
no ip address
interface Async1/20
no ip address
interface Async1/21
no ip address
interface Async1/22
no ip address
interface Async1/23
no ip address
interface Async1/24
no ip address
interface Async1/25
no ip address
interface Async1/26
no ip address
interface Async1/27
no ip address
interface Async1/28
no ip address
interface Async1/29
no ip address
interface Async1/30
no ip address
interface Async1/31
no ip address
interface Async1/32
no ip address
interface Async1/33
no ip address
interface Async1/34
no ip address
interface Async1/35
no ip address
interface Async1/36
no ip address
interface Async1/37
no ip address
interface Async1/38
no ip address
interface Async1/39
no ip address
interface Async1/40
no ip address
interface Async1/41
no ip address
interface Async1/42
no ip address
interface Async1/43
no ip address
interface Async1/44
no ip address
interface Async1/45
no ip address
interface Async1/46
no ip address
interface Async1/47
no ip address
interface Async1/48
no ip address
interface Async1/49
no ip address
interface Async1/50
no ip address
interface Async1/51
no ip address
interface Async1/52
no ip address
interface Async1/53
no ip address
interface Async1/54
no ip address
interface Async1/55
no ip address
interface Async1/56
no ip address
interface Async1/57
no ip address
interface Async1/58
no ip address
interface Async1/59
no ip address
interface Group-Async0
no ip address
no group-range
ip classless
ip route 0.0.0.0 0.0.0.0 XXX.XXX.22.254 250
no ip http server
access-list 99 permit XXX.XXX.23.0 0.0.0.255
access-list 99 permit XXX.XXX.254.0 0.0.0.255
access-list 99 deny any
tacacs-server host XXX.XXX.23.4
tacacs-server directed-request
tacacs-server key 7 DBDB7KNNCVB897676VV
radius-server authorization permit missing Service-Type
voice-port 3/0:D
disc_pi_off
echo-cancel coverage 32
no non-linear
no vad
no comfort-noise
cptone RU
timeouts call-disconnect 3
bearer-cap Speech
dial-peer voice 156 pots
dial-peer voice 1 pots
description Trunk_2_POTS
destination-pattern T
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 3/0:D
dial-peer voice 3 voip
description Default_VoIP_peer
incoming called-number .T
voice-class codec 2
session protocol sipv2
session transport udp
dtmf-relay rtp-nte
fax protocol none
no vad
dial-peer voice 5 voip
description 495 728
voice-class codec 2
session target ipv4:XXX.XXX.23.214
dtmf-relay rtp-nte
fax protocol none
dial-peer voice 7 pots
description test
huntstop
preference 10
direct-inward-dial
no register e164
line con 0
password 7 CHJHGFTREFGL
line aux 0
line vty 0 4
access-class 99 in
exec-timeout 40 0
line 1/00 1/59
no flush-at-activation
modem InOut
scheduler allocate 10000 400
end
debug isdn q931
*May 3 17:41:17.583: ISDN Se3/0:15 Q931: RX <- SETUP pd = 8 callref = 0x01C9
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18391
Preferred, Channel 17
Calling Party Number i = 0x2183, '9655291119'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '4957284005'
*May 3 17:41:17.587: ISDN Se3/0:15 Q931: isdn_parser_map_lkup: overriding plan/type for 9651291109, isdn/national to isdn/subscriber
*May 3 17:41:17.587: ISDN Se3/0:15 Q931: isdn_parser_map_lkup: overriding plan/type for 4957284005, isdn/national to isdn/subscriber
*May 3 17:41:17.591: ISDN Se3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0010
Sending Complete
Standard = CCITT
Channel ID i = 0xA1839F
Preferred, Channel 31
Calling Party Number i = 0x4183, '9655291119'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0xC1, '4957284005'
*May 3 17:41:17.591: ISDN Se3/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x81C9
*May 3 17:41:17.639: ISDN Se3/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8010
Channel ID i = 0xA9839F
Exclusive, Channel 31
*May 3 17:41:17.723: ISDN Se3/0:15 Q931: RX <- SETUP pd = 8 callref = 0x01CB
Sending Complete
Standard = CCITT
Channel ID i = 0xA18392
Preferred, Channel 18
Calling Party Number i = 0x2180, '9655291119'
debug voice translation
*May 3 17:44:22.099: regxrule_get_profile_from_trunkgroup: Voice port 0x63D4D600 does not belong to any trunk group
*May 3 17:44:22.099: regxrule_stack_pop_RegXruleNumInfo: stack=0x642E01F0; count=1
*May 3 17:44:22.103: regxrule_stack_push_RegXruleNumInfo: stack=0x642E01F0; count=0
*May 3 17:44:22.103: regxrule_profile_translate: Error: invalid input; callinfo=0x642F1490 profilep=0x0 rtype=calling
*May 3 17:44:22.103: regxrule_profile_translate: Error: invalid input; callinfo=0x642F1490 profilep=0x0 rtype=redirect-called
*May 3 17:44:22.103: regxrule_profile_translate: Error: invalid input; callinfo=0x642F1490 profilep=0x0 rtype=called
*May 3 17:44:22.103: regxrule_stack_push_RegXruleNumInfo: stack=0x642E01F0; count=1
*May 3 17:44:22.103: regxrule_dp_translate: No profile found in peer 1 for outgoing direction
*May 3 17:44:22.103: regxrule_dp_translate: calling_number=9655291119 calling_octet=0x21
called_number=4957284005 called_octet=0xA1
redirect_number= redirect_type=4294967295 redirect_plan=4294967295
*May 3 17:44:22.103: regxrule_vp_translate: No profile found in voice port or trunk group for outgoing direction
*May 3 17:44:22.103: regxrule_vp_translate: calling_number=9655291119 calling_octet=0x21
*May 3 17:44:22.219: regxrule_get_profile_from_trunkgroup: Voice port 0x63D4D600 does not belong to any trunk group
*May 3 17:44:22.219: regxrule_stack_pop_RegXruleNumInfo: stack=0x64281080; count=1
*May 3 17:44:22.219: regxrule_stack_push_RegXruleNumInfo: stack=0x64281080; count=0
*May 3 17:44:22.219: regxrule_profile_translate: Error: invalid input; callinfo=0x642E6D3C profilep=0x0 rtype=calling
*May 3 17:44:22.223: regxrule_profile_translate: Error: invalid input; callinfo=0x642E6D3C profilep=0x0 rtype=redirect-called
*May 3 17:44:22.223: regxrule_profile_translate: Error: invalid input; callinfo=0x642E6D3C profilep=0x0 rtype=called
*May 3 17:44:22.223: regxrule_stack_push_RegXruleNumInfo: stack=0x64281080; count=1
*May 3 17:44:22.223: regxrule_dp_translate: No profile found in peer 1 for outgoing direction
*May 3 17:44:22.223: regxrule_dp_translate: calling_number=9655291119 calling_octet=0x21
*May 3 17:44:22.223: regxrule_vp_translate: No profile found in voice port or trunk group for outgoing direction
*May 3 17:44:22.223: regxrule_vp_translate: calling_number=9655291119 calling_octet=0x21
а зачем трансляция? Нет воип диалпира с destination-pattern
СПАСИБО ОГРОМНОЕ!!!
все, вызовы пошли в обе стороны.
есть правда одна БЕДА, нет кпв при звонке со стороны е1
