Всем добрый день.
Предоставилась возможность поиграться с L3 коммутатором Cisco 3550-12T, пытаюсь настроить на нем Inter-VLAN маршрутизацию:
ip subnet-zero
ip routing
interface GigabitEthernet0/1
description UPLINK
no switchport
ip address 10.1.1.250 255.255.255.0
interface GigabitEthernet0/2
description CLIENT
no switchport
ip address 10.20.10.1 255.255.255.252
ip route 0.0.0.0 0.0.0.0 10.1.1.253
TESTED#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.1.1.253 to network 0.0.0.0
10.0.0.0/24 is subnetted, 2 subnets
C 10.20.10.0 is directly connected, GigabitEthernet0/2
C 10.1.1.0 is directly connected, GigabitEthernet0/1
S* 0.0.0.0/0 [1/0] via 10.1.1.253
TESTED#sh ver
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
Copyright © 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Mar-09 20:28 by gereddy
Image text-base: 0x00003000, data-base: 0x012A99FC
ROM: Bootstrap program is C3550 boot loader
TESTED uptime is 14 minutes
System returned to ROM by power-on
System image file is "flash:/c3550-ipservicesk9-mz.122-44.SE6/c3550-ipservicesk9-mz.122-44.SE6.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco WS-C3550-12T (PowerPC) processor (revision U0) with 65526K/8192K bytes of memory.
Processor board ID CAT0917X1AU
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 2 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 7 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 8 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 9 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 10 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 11 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 12 has 1 Gigabit Ethernet/IEEE 802.3 interface
12 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:14:1C:13:A5:80
Motherboard assembly number: 73-5527-17
Power supply part number: 34-0967-03
Motherboard serial number: CAT09180TDV
Power supply serial number: DTH08295ZZW
Model revision number: U0
Motherboard revision number: A0
Model number: WS-C3550-12T
System serial number: CAT0917X1AU
Configuration register is 0x10F
TESTED#sh sdm prefer
The current template is the default extended-match template.
The selected template optimizes the resources in
the switch to support this level of features for
16 routed interfaces and 1K VLANs.
number of unicast mac addresses: 6K
number of igmp groups: 6K
number of qos aces: 2K
number of security aces: 2K
number of unicast routes: 6K
number of multicast routes: 6K
sdm extended-match template выбрал только потому, что в дальнейшем хотелось бы еще реализовать на коммутаторе policy routing
IP адрес клиентского компьютера, подключенного к gi0/2 - 10.20.10.2.
Шлюз 10.1.1.253 имеет выход в интернет, но клиентский компьютер сей шлюз не пингует.
Подскажите пожалуйста, в чем может быть проблема?)
Коммутатор пингует и 10.1.1.253, и 10.20.10.2
Клиентский комп - помимо 10.20.10.1 пингует 10.1.1.250
Собственно никакого интер-влан тут и нет, IP-интерфейсы прямо на физических портах.
А шлюз (10.1.1.253) знает про эту подсеть:
description CLIENT
no switchport
имхо адрес на порт не понравилось. лучше адрес на int vlan.
работает "само по себе". если коммутатор L3 1 то rip и ospf не надо.
угу
сделайте на шлюзе (10.1.1.253) трейсроут до 10.20.10.2
скорее всего ваш шлюз (10.1.1.253) не знает что в сеть 10.20.10.0/30 надо ходить через 10.1.1.250
угу
а разве не это указывает куда посылать все пакеты ?
по моему тут прелести ип на порт - с 10.1.1.253 обратный маршрут на 10.1.1.250 обязательно.
если ип на инт влан - то и без него взлетит.
Пользуясь случаем, поинтересуюсь у вас еще кое о чем)
Собсна, предыстория, с чего все началось, и почему я решил поиграться с cisco3550.
На данный момент наша сеть работает по схеме, изображенной ниже.
Перестала устраивать система блокировки пользователя, после того как установили в сеть новой ядро - core2. На данный момент блокировка на обоих ядрах работает, но на втором ядре через раз... Сейчас пытаемся копать в сторону билинга, думаем что косяки за ним. Возникли идеи повесить ACL на бордер, либо на коммутатор ядра (cisco3550), который встанет между бордером и ядрами. Плюс повесить на него policy routing для редиректа заблокированных юзеров на информирующую веб страничку. Но, поигравшись с сим коммутаторм понял, что придется бордер и ядра разделить по своим подсетям. Соответственно встает проблема с ospf.. И второе - cisco3550 не поддерживает Dynamic ACL, что тоже не есть гуд.
Насколько правильно будет повесить ACL на бордер, и как это скажется на загрузке процессора (сейчас загрузка при 80Mb/s - ~40%)?
Именно загрузка бордера обработкой ACL родила идею повесить листы на коммутатор.
Может кто поделится, у кого как организована блокировка? Жду советов от знающих людей. Буду очень признателен! =)
Edited by valeriy_sd
  • 2 weeks later...
Работаем по похожей схеме. Имеется 5 NAS терминирующих PPPOE. Ограничение скорости rate-limit (сейчас переходим на policy), ограничение доступа через ACL на NAS. Так вот после установки Cisco 7206VXR-NPE-G2 загрузка CPU составила почти 80% при 300 сессиях и трафике чуть более 100Мбит/с. Очень огорчило и насторожило. После анализа было решено убрать ACL с NAS и перенести на бордер. 2 ACL (на вход и выход) содержат порядка по 2000 правил (на абонента 1 правило), т.е. сумарно 4000 правил. Предположения действительно подтвердились, именно ACL дико грузит CPU. После переноса ACL на бордер получили, все на той же Cisco 7206VXR-NPE-G2, при 800 сессиях и суммарном трафике в почти 500Мбит/с загрузка cpu в 40%. При этом загрузка теперь не зависит от количества пользователей, а лишь от проходящего трафика.
В качестве бордера используем Ericsson SE100. Так как роутер, в большей части, аппаратный, то загруженные ACL практически не повлияли на загрузку cpu - всего 0.4% при всех прочих его функциях (BGP, OSPF и др.). При этом получили еще и оптимизацию за счет переноса ACL на бордер - управление доступом только в одном месте, а не как раньше на 5 NAS.
