SUMMARY:
This article describes the process involved in configuring IP Monitoring on SRX-Series gateways.
PROBLEM OR GOAL:
How to configure IP Monitoring on SRX-Series gateways.
Supported Platforms:
SRX3400
SRX3600
SRX5600
SRX5800
SOLUTION:
Introduction:
This feature is used to track the coverage of a set of configured IP addresses.
It impacts the failover of redundancy groups based on the coverage of the IP addresses.
ICMP echo messages are sent at regular intervals to the configured addresses.
If no replies are received after a configurable interval, the IP address is marked as unreachable.
Configuration:
IP monitoring is configured on a per-redundancy group basis.
It can be configured either as a 'global configuration' (impacts all the IP addresses configured under the RG), or as a 'per-IP configuration' (impacts only that IP address).
[edit chassis cluster]
redundancy-group 1 {
interface-monitor {
ge-0/1/9 weight 100;
ip-monitoring {
global-weight 230;
global-threshold 70;
retry-interval 6;
retry-count 7;
family {
inet {
1.1.1.5 {
weight 30;
interface reth0.10 secondary-ip-address 1.1.1.3;
1.2.3.4 {
weight 100;
2.3.4.5 {
weight 10;
10.254.5.44 {
weight 30;
Troubleshooting:
The following command is used to view the status of all the configured IP addresses:
cli>show chassis cluster ip-monitoring status
node0:
Redundancy group: 1
IP address Status Failure count Reason
10.254.5.44 reachable 1 n/a
2.2.2.1 reachable 0 n/a
1.1.1.5 reachable 0 n/a
1.1.1.4 reachable 0 n/a
1.1.1.1 reachable 1 n/a
node1:
Redundancy group: 1
10.254.5.44 reachable 0 n/a
1.1.1.1 reachable 0 n/a
PURPOSE:
Configuration
Implementation
