Локальная сторона:
 MikroTik RouterOS 5.13 (c) 1999-2012
[admin@bridge1] > system routerboard p
      routerboard: yes
            model: 1100AH
    serial-number: *
 current-firmware: 2.38
 upgrade-firmware: 2.39
[admin@bridge1] > ip add p
Flags: X - disabled, I - invalid, D - dynamic
#   ADDRESS            NETWORK         INTERFACE
0   192.168.10.80/23   192.168.10.0    ether13
1   192.168.8.1/30     192.168.8.0     bonding1
[admin@bridge1] > int bo p
Flags: X - disabled, R - running
0  R name="bonding1" mtu=1500 mac-address=D4:CA:6D:20:0B:53 arp=enabled slaves=ether1,ether3 mode=balance-rr primary=none link-monitoring=arp arp-interval=1s
     arp-ip-targets=192.168.8.2 mii-interval=1s down-delay=0ms up-delay=1s lacp-rate=30secs transmit-hash-policy=layer-2
[admin@bridge1] > int eth m ether1,ether3
             status: link-ok no-link
   auto-negotiation: done    done
               rate: 100Mbps 10Mbps
        full-duplex: yes     no
[admin@bridge1] > int br po p
Flags: X - disabled, I - inactive, D - dynamic
#    INTERFACE                                                           BRIDGE                                                          PRIORITY  PATH-COST    HORIZON
0    ether6                                                              bridge1                                                             0x80         10       none
1    bonding1                                                            bridge1                                                             0x80         10       none
2    ether2                                                              bridge1                                                             0x80         10       none
[admin@bridge1] > int mo ether1,ether2
   rx-packets-per-second:      496     495
     rx-drops-per-second:        0       0
    rx-errors-per-second:        0       0
      rx-bits-per-second:  2.5Mbps 2.6Mbps
   tx-packets-per-second:      594     612
     tx-drops-per-second:        0       0
    tx-errors-per-second:        0       0
      tx-bits-per-second:  4.2Mbps 4.1Mbps
[admin@bridge1] > int pr where name=ether1
Flags: D - dynamic, X - disabled, R - running, S - slave
#     NAME        TYPE               MTU L2MTU  MAX-L2MTU
0  R  ;;; Ubiquiti Rocket M5 (trunk25)
      ether1        ether             1500  1598       9498
[admin@bridge1] > int pr where name=ether2
1  R  ;;; Ubiquiti Rocket M5 (trunk22)
      ether2        ether             1500  1598       9498
[admin@bridge1] > int pr where name=ether6
2  R  ;;; D-Link DES-3200-10 (trunk)
      ether6        ether             1500  1598       9498
Удаленная сторона:
 MikroTik RouterOS 5.14 (c) 1999-2012
[admin@bridge2] > system routerboard p
      routerboard: yes
            model: 1200
    serial-number: *
 current-firmware: 2.33
 upgrade-firmware: 2.38
[admin@bridge2] > ip add p
0   192.168.8.2/30     192.168.8.0     bonding1
1   192.168.10.81/23   192.168.10.0    bonding1
[admin@bridge2] > int bo p
0  R name="bonding1" mtu=1500 mac-address=00:0C:42:D2:AF:4F arp=enabled slaves=ether1,ether2 mode=balance-rr primary=none link-monitoring=arp arp-interval=1s
     arp-ip-targets=192.168.8.1 mii-interval=1s down-delay=0ms up-delay=1s lacp-rate=30secs transmit-hash-policy=layer-2
[admin@bridge2] > int eth m ether1,ether2
             status: link-ok link-ok
               rate: 100Mbps 100Mbps
        full-duplex: yes     yes
[admin@bridge2] > int br po p
0    ether3                                                              bridge1                                                             0x80         10       none
1    ether4                                                              bridge1                                                             0x80         10       none
2    ether5                                                              bridge1                                                             0x80         10       none
3    ether6                                                              bridge1                                                             0x80         10       none
4 I  ether7                                                              bridge1                                                             0x80         10       none
5 I  ether8                                                              bridge1                                                             0x80         10       none
6 I  ether9                                                              bridge1                                                             0x80         10       none
7 I  ether10                                                             bridge1                                                             0x80         10       none
8    bonding1                                                            bridge1                                                             0x80         10       none
[admin@bridge2] > int mo ether1,ether2
   rx-packets-per-second:      719     787
      rx-bits-per-second:  5.3Mbps 5.8Mbps
   tx-packets-per-second:      655     655
      tx-bits-per-second:  2.6Mbps 2.5Mbps
[admin@bridge2] > int pr where name=ether1
0  R  ;;; Ubiquiti Rocket M5 (trunk?)
      ether1        ether             1500  1598       4078
[admin@bridge2] > int pr where name=ether2
1  R  ;;; Ubiquiti Rocket M5 (trunk?)
      ether2
А теперь словами. На локальной стороне интерфейс бондинг собран только с одним работающим портом, второй добавлен в бридж. На бондинге настроен arp-мониторинг, адрес для мониторинга висит только на бондинг интерфейсе. Тоесть поскольку с этой стороны бондинг только на одном рабочем порту (а адрес для мониторинга висит на бондинге), то с той стороны роутерос должна бы выключить порт через который не приходят arp-ответы. И все бы хорошо, но при этом трафик делится между портами ровно пополам, хотя по логике должен был идти только через один порт. Второй момент, если собрать бондинг с локальный стороны правильно то работает логично и до точек появляется 50% потери пакетов. А в текущей ситуации нет потерь до точек, но трафик все равно делится ровно.
