Есть 2й SUP на нем набито порядка 2000+ маршрутов типа:
ip route 10.100.17.4 255.255.255.255 Vlan72
ip route 10.100.17.5 255.255.255.255 Vlan73
ip route 10.100.17.6 255.255.255.255 Vlan74
ip route 10.100.17.7 255.255.255.255 Vlan75
ip route 10.100.17.8 255.255.255.255 Vlan76
ip route 10.100.17.9 255.255.255.255 Vlan77
ip route 10.100.17.10 255.255.255.255 Vlan78
В какой то момент обратил внимание что пропадают маршруты которые уже ранее вбивал, чему сильно удивился
c6509#show ip route summary
IP routing table name is Default-IP-Routing-Table(0)
Route Source    Networks    Subnets     Overhead    Memory (bytes)
connected       2           7           576         1440
static          2           2051        131456      328480
internal        8                                   9440
Total           12          2058        132032      339360
проходит скокато времени и ( 8-0 ) :
static          2           2041        130816      326880
internal        8                                   9440
Total           12          2048        131392      337760
Ну и собственно вопрос: это вообще как понимать ? :)
c6509#show ip cef summary
IP Distributed CEF with switching (Table Version 4298), flags=0x0
 2088 routes, 0 reresolve, 0 unresolved (0 old, 0 new), peak 20
 20 instant recursive resolutions, 0 used background process
 2088 leaves, 53 nodes, 347500 bytes, 2228 inserts, 140 invalidations
 1 load sharing elements, 336 bytes, 1 references
 universal per-destination load sharing algorithm, id 0048A28A
 3(0) CEF resets, 1 revisions of existing leaves
 Resolution Timer: Exponential (currently 1s, peak 1s)
 0 in-place/0 aborted modifications
 refcounts:  17947 leaf, 13824 node
 Table epoch: 0 (2088 entries at this epoch)
Adjacency Table has 70 adjacencies
c6509#sh platform hardware capacity
System Resources
  PFC operating mode: unknown
  Supervisor redundancy mode: administratively rpr-plus, operationally rpr-plus
  Switching resources: Module   Part number               Series      CEF mode
                       1        WS-X6K-S2U-MSFC2      supervisor           CEF
                       2        WS-X6516-GBIC             CEF256           CEF
                       3        WS-X6516-GBIC             CEF256           CEF
                       4        WS-X6516-GBIC             CEF256           CEF
                       6        WS-X6516-GBIC             CEF256           CEF
                       7        WS-X6516-GBIC             CEF256           CEF
                       9        WS-X6516-GE-TX            CEF256           CEF
Power Resources
  Power supply redundancy mode: administratively redundant
                                operationally redundant
  System power: 2331W, 0W (0%) inline, 1001W (43%) total allocated
  Powered devices: 0 total, 0 Class3, 0 Class2, 0 Class1, 0 Class0, 0 Cisco
Flash/NVRAM Resources
  Usage: Module Device               Bytes:      Total          Used     %Used
         1  RP  bootflash:                    15204352      13022168       86%
         1  SP  disk0:                       127913984     101847040       80%
         1  SP  sup-bootflash:                31981569      31981568      100%
         1  SP  const_nvram:                    129004         22344       17%
         1  SP  nvram:                          391160        175244       45%
CPU Resources
  CPU utilization: Module             5 seconds       1 minute       5 minutes
                   1  RP               3% /  1%             4%              6%
                   1  SP               3% /  0%             5%              5%
  Processor memory: Module   Bytes:       Total           Used           %Used
                    1  RP             405972480      104325776             26%
                    1  SP             167784456       50644184             30%
  I/O memory: Module         Bytes:       Total           Used           %Used
              1  RP                    67108864       10353328             15%
              1  SP                    35651584        9616816             27%
EOBC Resources
  Module                     Packets/sec     Total packets     Dropped packets
  1  RP      Rx:                      71           1368652                   0
             Tx:                      60           1236548                   0
  1  SP      Rx:                      39            990935                   0
             Tx:                      49           1115782                   0
VLAN Resources
  VLANs: 4094 total, 368 VTP, 12 extended, 11 internal, 3703 free
QoS Policer Resources
  Aggregate policers: Module                      Total         Used     %Used
                      1                            1024            1        1%
  Microflow policer configurations: Module        Total         Used     %Used
                                    1                64            1        1%
Switch Fabric Resources
  Bus utilization: current: 10%, peak was 15% at 12:58:21 Yekater Tue Apr 17 2012  Fabric utilization: no fabric
  Switching mode: no fabric
Interface Resources
  Interface drops:
    Module    Total drops:    Tx            Rx      Highest drop port:  Tx  Rx
         no modules reported drops
  Interface buffer sizes:
    Module                            Bytes:     Tx buffer           Rx buffer
    1                                               442368               81920
    2                                               442368               81920
    3                                               442368               81920
    4                                               442368               81920
    6                                               442368               81920
    7                                               442368               81920
    9                                               901120              147456
SPAN Resources
  Source sessions: 2 maximum, 0 used
    Type                                    Used
    Local                                      0
    RSPAN source (max   1)                     0
    Service module                             0
  Destination sessions: 64 maximum, 0 used
    Type                                    Used
    RSPAN destination                          0
WS-X6K-S2U-MSFC2
s222-adventerprisek9_wan-mz.122-18.SXF3.bin
Edited by Dushes
Если вы делаете маршруты старческие делайте их с ключом permanent что бы они не удалялись если падает интерфес.
везде прописал, не помогло :(
c6509#show running-config | include ip route
ip route 0.0.0.0 0.0.0.0 10.254.254.1 name to_BGP_Router
ip route 10.0.0.0 255.255.255.0 195.191.221.11 name to_NAS
ip route 10.100.0.0 255.255.255.0 195.191.221.11 name to_NAS
ip route 10.100.0.47 255.255.255.255 Vlan536 permanent
ip route 10.100.1.0 255.255.255.0 195.191.221.11 name to_NAS
ip route 10.100.1.252 255.255.255.252 10.254.254.1
ip route 10.100.17.1 255.255.255.255 Vlan69 permanent
ip route 10.100.17.2 255.255.255.255 Vlan70 permanent
ip route 10.100.17.3 255.255.255.255 Vlan71 permanent
ip route 10.100.17.4 255.255.255.255 Vlan72 permanent
ip route 10.100.17.5 255.255.255.255 Vlan73 permanent
ip route 10.100.17.6 255.255.255.255 Vlan74 permanent
ip route 10.100.17.7 255.255.255.255 Vlan75 permanent
ip route 10.100.17.8 255.255.255.255 Vlan76 permanent
ip route 10.100.17.9 255.255.255.255 Vlan77 permanent
static          2           2051        131456      330520
internal        8                                   9440
Total           12          2058        132032      341400
static          2           2050        131392      330360
internal        8                                   9440
Total           12          2057        131968      341240
и как понять кто это удаляет маршрут ???
11:13:15: IP-ST: if_list try 2087
11:13:15: IP-ST: gw_list total 21, try 21, completed list TRUE
11:13:15: IP-Static: all_list, time elapsed 24 ms
11:13:18: Periodic IP routing statistics collection
11:13:23: Periodic IP routing statistics collection
11:13:28: Periodic IP routing statistics collection
11:13:33: Periodic IP routing statistics collection
11:13:38: Periodic IP routing statistics collection
11:13:43: Periodic IP routing statistics collection
11:13:48: Periodic IP routing statistics collection
11:13:53: Periodic IP routing statistics collection
11:13:58: Periodic IP routing statistics collection
11:14:03: Periodic IP routing statistics collection
11:14:08: Periodic IP routing statistics collection
11:14:08: RT: del 10.100.18.225/32 via 0.0.0.0, static metric [1/0]
11:14:08: RT: delete subnet route to 10.100.18.225/32
11:14:13: Periodic IP routing statistics collection
11:14:15: IP-ST: if_list try 2086
11:14:15: IP-ST: gw_list total 21, try 21, completed list TRUE
11:14:15: IP-Static: all_list, time elapsed 28 ms
11:14:18: Periodic IP routing statistics collection
s.lobanov
удаляются из running-config
config
да так и пропадают
12:18:16: IP-ST: gw_list total 21, try 21, completed list TRUE
12:18:16: IP-Static: all_list, time elapsed 24 ms
12:18:36: RT: add 10.100.18.86/32 via 0.0.0.0, static metric [1/0]
12:18:53: RT: del 10.100.19.179/32 via 0.0.0.0, static metric [1/0]
12:18:53: RT: delete subnet route to 10.100.19.179/32
12:19:16: IP-ST: if_list try 2064
12:19:16: IP-ST: gw_list total 21, try 21, completed list TRUE
12:19:16: IP-Static: all_list, time elapsed 24 ms
12:19:59: RT: del 10.100.19.69/32 via 0.0.0.0, static metric [1/0]
12:19:59: RT: delete subnet route to 10.100.19.69/32
12:20:16: IP-ST: if_list try 2063
12:20:16: IP-ST: gw_list total 21, try 21, completed list TRUE
12:20:16: IP-Static: all_list, time elapsed 24 ms
вот тут прочитал следущее:
CISCO помнит статические маршруты, до тех пор, пока вы не удаляете их (используя в режиме глобальной конфигурации команду no ip route prefix mask ). Однако, если Вы определяете параметр administrative distance, Вы ослабеваете(flagging) статический маршрут, который может быть отменен (overridden) динамической информацией.
отсюда вопрос может ли статик маршрут удалятся из-а того что появляется Connected маршрут у которого Distance 0 ?
Arp, предмет для разговора.
Возможно в тот момент когда появляется запись ARP для этого адреса , это в принципе тот же маршрут, только с метрикой 0 .
Edited by config
новые странности :)
c6509#show running-config | include 10.100.20.181
ip route 10.100.20.181 255.255.255.255 Vlan528 permanent
c6509#show ip route | include 10.100.20.181
S       10.100.20.181/32 is directly connected, Vlan597
не понял, dhcp отключен, только dhcp relay откуда эти маршруты ?
c6509#show ip route dhcp
S    10.100.22.123/32 is directly connected, Vlan571
S    10.100.23.118/32 is directly connected, Vlan570
S    10.100.23.111/32 is directly connected, Vlan570
S    10.100.24.105/32 is directly connected, Vlan604
S    10.100.21.89/32 is directly connected, Vlan606
S    10.100.20.82/32 is directly connected, Vlan558
S    10.100.18.86/32 is directly connected, Vlan574
S    10.100.18.82/32 is directly connected, Vlan574
S    10.100.20.75/32 is directly connected, Vlan558
S    10.100.18.78/32 is directly connected, Vlan574
S    10.100.19.70/32 is directly connected, Vlan575
S    10.100.21.50/32 is directly connected, Vlan589
S    10.100.21.54/32 is directly connected, Vlan589
S    10.100.22.41/32 is directly connected, Vlan565
Получается так что включена фича по умолачнию и работает так что если интерфейс ip unnumbered + ip helper address то маршрут добавляется. Может надo ip helper address делать не на ip unnumbered а на основноми нтерфейсе ?
даже если записи permanent - начинается путаница при флапании интерфйсов или добавлении одного и тогоже маршрута дважды или трижды, причем может скрипт добавить уже существующий маршрут на другой интерфейс. Проверяй скрипт добавления маршрутов, кстати, а при добавления маршрута он удаляется с циски ?? ))
s.lobanov - правильно сказал - зачем скриптом добавлять маршруты если это релей делает сам ??
martini
ну я могу ошибается, но я в этом удивил 2 причины:
1) исключить ошибки настройки последней мили
2) абоненты при желании не смогут у себя на интерфейсе прописать адрес статикой, в случии каких либо проблем работы dhcp
Взял коммутатор (один VLAN на все клиентские порты ) настроил на обеих портах dhcp snooping + port protection
Эксперимент 1:
первым компьютером как полагается получил адрес по dhcp
вторым компьютером прописал этот же адрес вручную на интерфейсе
итог: 1 компьютер потерял связь, у второго всё работало :(
Эксперимент 2:
после на этот же компьютере ip задал вручную .. всё продолжало работать, уже как 30 минут, ожидаю далее
вопрос: а на какой срок 6509 держит маршрут, как его сменить ?
параметр dhcp lease - на дхцп сервере выдает на сколько выдается маршрут.
В эксперименте 1 у тебя все правильно происходит, у тебя ведь на циске на влане поднят ИП интерфейс, соответственно работает АРП протокол.
Если оставить только ДХЦП - будет все в шакаладе )
