Macro Posted March 23, 2012 Posted March 23, 2012 RHEL 6.0 Сервер с 15 винтами. Стояли по 1ТБ, но в ходе работы и ломки винтов меняем на 2ТБ. Поверх mdX массива накручен ЛВМ. Проблема: Volume Group не показывает весь размер массива. [root@ftp ~]# fdisk -l /dev/sd[abcdefghijklmno] | grep GB Disk /dev/sda: 999.0 GB, 998999326720 bytes Disk /dev/sdb: 1999.0 GB, 1998998994944 bytes Disk /dev/sdc: 1999.0 GB, 1998998994944 bytes Disk /dev/sdd: 999.0 GB, 998999326720 bytes Disk /dev/sde: 1999.0 GB, 1998998994944 bytes Disk /dev/sdf: 999.0 GB, 998999326720 bytes Disk /dev/sdg: 999.0 GB, 998999326720 bytes Disk /dev/sdh: 999.0 GB, 998999326720 bytes Disk /dev/sdi: 999.0 GB, 998999326720 bytes Disk /dev/sdj: 999.0 GB, 998999326720 bytes Disk /dev/sdk: 999.0 GB, 998999326720 bytes Disk /dev/sdl: 999.0 GB, 998999326720 bytes Disk /dev/sdm: 999.0 GB, 998999326720 bytes Disk /dev/sdn: 1999.0 GB, 1998998994944 bytes Disk /dev/sdo: 1999.0 GB, 1998998994944 bytes Собран linux-raid6 массив. [root@ftp ~]# mdadm -D /dev/md127 /dev/md127: Version : 0.90 Creation Time : Fri Mar 11 18:35:05 2011 Raid Level : raid6 Array Size : 10731370496 (10234.23 GiB 10988.92 GB) Used Dev Size : 975579136 (930.38 GiB 998.99 GB) Raid Devices : 13 Total Devices : 15 Preferred Minor : 127 Persistence : Superblock is persistent Update Time : Fri Mar 23 13:50:24 2012 State : active Active Devices : 13 Working Devices : 15 Failed Devices : 0 Spare Devices : 2 Layout : left-symmetric Chunk Size : 256K UUID : 4457978d:b4a935a1:a7ed4e92:af442a01 Events : 0.2092485 Number Major Minor RaidDevice State 0 8 161 0 active sync /dev/sdk1 1 8 193 1 active sync /dev/sdm1 2 8 17 2 active sync /dev/sdb1 3 8 49 3 active sync /dev/sdd1 4 8 145 4 active sync /dev/sdj1 5 8 81 5 active sync /dev/sdf1 6 8 97 6 active sync /dev/sdg1 7 8 113 7 active sync /dev/sdh1 8 8 129 8 active sync /dev/sdi1 9 8 1 9 active sync /dev/sda1 10 8 177 10 active sync /dev/sdl1 11 8 225 11 active sync /dev/sdo1 12 8 209 12 active sync /dev/sdn1 13 8 65 - spare /dev/sde1 14 8 33 - spare /dev/sdc1 Сам Volume Group: --- Volume group --- VG Name vg00 System ID Format lvm2 Metadata Areas 1 Metadata Sequence No 11 VG Access read/write VG Status resizable MAX LV 0 Cur LV 3 Open LV 3 Max PV 0 Cur PV 1 Act PV 1 VG Size 9.99 TiB PE Size 32.00 MiB Total PE 327495 Alloc PE / Size 327495 / 9.99 TiB Free PE / Size 0 / 0 VG UUID QhUx59-SJKG-NaOu-28Jh-ThiP-CRqk-iaUnAp mdadm показывает район 11 ТБ, а vg уперся в 9.99TБ И чем отличается GiB от GB? Вставить ник Quote
s.lobanov Posted March 23, 2012 Posted March 23, 2012 Создаёте pv из остатков(если они есть) и вводите его в vg Вставить ник Quote
vitalyb Posted March 23, 2012 Posted March 23, 2012 чем отличается GiB от GB? http://physics.nist.gov/cuu/Units/binary.html Массив, а за ним и VG, сможете увеличить только когда поменяете все диски. Как вариант, еще можно из "хвостов" 2Т дисков собрать еще один массив если очень сильно нужно место. Вставить ник Quote
f13 Posted March 23, 2012 Posted March 23, 2012 что-то я не понял где у вас pv? если на диске без партиций то pvresize без заморочек, если у вас партиции то всё хуже, надо грохнуть pv партицию (естественно загрузившись c лайв сд) и создать новую, начальный блок должен совпадать со старым значение, конечный больше старого, а затем опять же pvresize если у вас второй вариант, действуйте очень аккуратно и про бекап не забывайте Вставить ник Quote
Macro Posted March 23, 2012 Author Posted March 23, 2012 PV /dev/md127 VG vg00 lvm2 [9.99 TiB / 0 free] Вставить ник Quote
f13 Posted March 23, 2012 Posted March 23, 2012 т.е. партиций нет, тогда pvresize /dev/md127 ну на всякий случай с маном ознакомьтесь Вставить ник Quote
Macro Posted March 23, 2012 Author Posted March 23, 2012 (edited) [root@ftp ~]# pvresize /dev/md127 Physical volume "/dev/md127" changed 1 physical volume(s) resized / 0 physical volume(s) not resized [root@ftp ~]# pvscan PV /dev/md127 VG vg00 lvm2 [9.99 TiB / 0 free] размер такой же OS: RHEL 6.0 64bit Edited March 23, 2012 by Macro Вставить ник Quote
Macro Posted March 23, 2012 Author Posted March 23, 2012 [root@ftp ~]# pvdisplay /dev/md127 --- Physical volume --- PV Name /dev/md127 VG Name vg00 PV Size 9.99 TiB / not usable 13.81 MiB Allocatable yes (but full) PE Size 32.00 MiB Total PE 327495 Free PE 0 Allocated PE 327495 PV UUID 5pf78U-ZzY0-Kdqa-JxLF-MRv0-BVCc-pweiIg Вставить ник Quote
f13 Posted March 23, 2012 Posted March 23, 2012 может ему что не травиться, попробуйте pvresize -v /dev/md127 ругани никакой нет? Вставить ник Quote
Macro Posted March 23, 2012 Author Posted March 23, 2012 [root@ftp ~]# pvresize -v /dev/md127 Using physical volume(s) on command line Archiving volume group "vg00" metadata (seqno 14). No change to size of physical volume /dev/md127. Resizing volume "/dev/md127" to 21462740608 sectors. Updating physical volume "/dev/md127" Creating volume group backup "/etc/lvm/backup/vg00" (seqno 15). Physical volume "/dev/md127" changed 1 physical volume(s) resized / 0 physical volume(s) not resized Вставить ник Quote
f13 Posted March 23, 2012 Posted March 23, 2012 стоп!!! 10234.23/1024=9.99436523437500000000~9.99 TiB нет там места Вставить ник Quote
nicolnx Posted March 23, 2012 Posted March 23, 2012 mdadm --grow /dev/md127 -n 15 сначала сделайте, а потом уже тяните PV Вставить ник Quote
Macro Posted March 23, 2012 Author Posted March 23, 2012 стоп!!! 10234.23/1024=9.99436523437500000000~9.99 TiB нет там места Спасибо, сорри, ступил с самого начала. Вставить ник Quote
martin74 Posted March 23, 2012 Posted March 23, 2012 vgdisplay выведет много полезной инфы, в том числе и размер свободного места в группе А вообще вам надо поменять все винты, потом расширить рейд на свободное место, потом расширить группу, потом расширить том, а потом - файловую систему. Вот. Вставить ник Quote
