Решил перейти со встроеного радиуса на freeradius.
Погуглил, пояндексил, покопипастил, поправил, и вот, что получилось:
sql_user_name = "%{User-Name}"
authorize_check_query="\
SELECT ip_groups.ip_group_id, ip_groups.uname,'Cleartext-Password', ip_groups.upass,':=' FROM UTM5.ip_groups, \
UTM5.iptraffic_service_links, UTM5.service_links, UTM5.accounts WHERE ip_groups.uname = '%{SQL-User-Name}' AND \
ip_groups.is_deleted='0' AND iptraffic_service_links.is_deleted='0' AND service_links.is_deleted='0' AND accounts.is_deleted='0' \
AND accounts.is_blocked='0' AND ip_groups.ip_group_id=iptraffic_service_links.ip_group_id \
AND iptraffic_service_links.id=service_links.id AND service_links.account_id=accounts.id \
UNION SELECT ip_groups.ip_group_id, ip_groups.uname,'Simultaneous-Use','1',':=' FROM UTM5.ip_groups, \
UTM5.iptraffic_service_links, UTM5.service_links, UTM5.accounts WHERE ip_groups.uname = '%{SQL-User-Name}' \
AND ip_groups.is_deleted='0' AND iptraffic_service_links.is_deleted='0' AND service_links.is_deleted='0' \
AND accounts.is_deleted='0' AND accounts.is_blocked='0' AND ip_groups.ip_group_id=iptraffic_service_links.ip_group_id \
authorize_reply_query="\
SELECT ip_group_id, uname, 'Framed-IP-Address', inet_ntoa(ip_groups.ip & 0xFFFFFFFF) AS a, ':=' FROM UTM5.ip_groups \
WHERE uname='%{SQL-User-Name}' AND is_deleted='0' \
UNION SELECT ip_group_id, uname, 'Auth-Type', 'Reject' as a, ':=' \
FROM ip_groups WHERE uname='%{SQL-User-Name}' AND is_deleted='0' \
## probably not needed
#postauth_query="\
#INSERT INTO dhs_access_log (recv_date,User_Name,Service_Type,Framed_Protocol,NAS_IP_Address,NAS_Id,is_success) \
#VALUES(UNIX_TIMESTAMP('%S'),'%{SQL-User-name}','0','2','0','%{NAS-Identifier}','1') \
#LOCK TABLES ip_groups WRITE, iptraffic_service_links WRITE, service_links WRITE;                               \
#UNLOCK TABLES;        \
accounting_start_query = "\
SET @ipgid = (select ip_group_id from ip_groups where uname = '%{SQL-User-Name}' and is_deleted <> '1' limit 1);\
SET @slid = (select id from iptraffic_service_links where is_deleted <> '1' and ip_group_id = @ipgid limit 1);  \
SET @accid = (select account_id from service_links where id = @slid limit 1);                                   \
SET @framed_ip = (INET_ATON(CONCAT_WS('.',SUBSTRING_INDEX('%{Framed-IP-Address}','.',-1),                       \
                                    SUBSTRING_INDEX(SUBSTRING_INDEX('%{Framed-IP-Address}','.',-2),'.',1),     \
                                    SUBSTRING_INDEX(SUBSTRING_INDEX('%{Framed-IP-Address}','.',2),'.',-1),     \
                                    SUBSTRING_INDEX('%{Framed-IP-Address}','.',1))));                          \
SET @framed_ip = (IF(@framed_ip > 268435455,CAST(@framed_ip-0x100000000 AS SIGNED),@framed_ip));                \
SET @nas_ip = (INET_ATON(CONCAT_WS('.',SUBSTRING_INDEX('%{%{NAS-IP-Address}:-%{Client-IP-Address}}','.',-1),    \
            SUBSTRING_INDEX(SUBSTRING_INDEX('%{%{NAS-IP-Address}:-%{Client-IP-Address}}','.',-2),'.',1),       \
            SUBSTRING_INDEX(SUBSTRING_INDEX('%{%{NAS-IP-Address}:-%{Client-IP-Address}}','.',2),'.',-1),       \
            SUBSTRING_INDEX('%{%{NAS-IP-Address}:-%{Client-IP-Address}}','.',1))));                            \
SET @nas_ip = (IF(@nas_ip > 268435455,CAST(@nas_ip-0x100000000 AS SIGNED),@nas_ip));                            \
SET @inbytes = (IF(%{%{Acct-Input-Octets}:-0} < 0,                                                              \
                   (4294967296 * %{%{Acct-Input-Gigawords}:-0}) + 2147483648 - %{%{Acct-Input-Octets}:-0},     \
                   (4294967296 * %{%{Acct-Input-Gigawords}:-0}) + %{%{Acct-Input-Octets}:-0}));                \
SET @outbytes = (IF(%{%{Acct-Output-Octets}:-0} < 0,                                                            \
                   (4294967296 * %{%{Acct-Output-Gigawords}:-0}) + 2147483648 - %{%{Acct-Output-Octets}:-0},   \
                   (4294967296 * %{%{Acct-Output-Gigawords}:-0}) + %{%{Acct-Output-Octets}:-0}));              \
INSERT INTO dhs_sessions_log                    \
(account_id, slink_id, recv_date,last_update_date,Framed_IP_Address, NAS_Port, Acct_Delay_Time, Acct_Session_Id,\
NAS_Port_Type, User_Name, Service_Type, Framed_Protocol, NAS_IP_Address, NAS_Id, Acct_Status_Type,              \
Acct_Input_Packets, Acct_Input_Octets, Acct_Output_Packets, Acct_Output_Octets, Acct_Session_Time,              \
Called_Station_Id, Calling_Station_Id)          \
VALUES                                          \
(@accid, @slid, '%l', UNIX_TIMESTAMP('%S'), @framed_ip, '%{NAS-Port}', '%{Acct-Delay-Time}', '%{Acct-Unique-Session-ID}', \
'0', '%{SQL-User-name}', '2', '1', @nas_ip, '%{NAS-Identifier}', '1',                                           \
'%{%{Acct-Input-Packets}:-0}', @inbytes, '%{%{Acct-Output-Packets}:-0}', @outbytes, '%{%{Acct-Session-Time}:-0}', \
'%{Called-Station-Id}','%i' );                  \
accounting_update_query = "\
UPDATE dhs_sessions_log SET last_update_date=UNIX_TIMESTAMP('%S'), Acct_Status_Type='3',\
Acct_Input_Packets ='%{%{Acct-Input-Packets}:-0}', Acct_Input_Octets = @inbytes,        \
Acct_Output_Packets ='%{%{Acct-Output-Packets}:-0}', Acct_Output_Octets = @outbytes,    \
Acct_Session_Time ='%{Acct-Session-Time}'                                               \
WHERE Acct_Session_Id = '%{Acct-Unique-Session-ID}' AND NAS_Port = '%{NAS-Port}' AND User_Name = '%{SQL-User-Name}' \
accounting_stop_query = "\
UPDATE dhs_sessions_log SET last_update_date=UNIX_TIMESTAMP('%S'), Acct_Status_Type='2',\
simul_count_query  = "SELECT COUNT(*) FROM dhs_sessions_log WHERE User_Name='%{SQL-User-Name}' \
AND (Acct_Status_Type = '3' OR Acct_Status_Type = '1') \
simul_verify_query = "SELECT COUNT(*) FROM dhs_sessions_log WHERE User_Name='%{SQL-User-Name}' \
Ядро биллинга у меня старое, 5.1.10-017, и переходить на новое пока не возжелал - оно и так нормально работает.
Соответственно, если кто захочет заюзать мою версию запросов - придется добавить пару полей, которые добавились в 5.2.1-xxx, а может и так работать будет.
Я не силен в SQL, но старался избегать лишних (и медленных) запросов.
Корректно ли я оформил запросы?
Что правильнее: использовать Acct-Output-Gigawords и Acct-Output-Octets, или Acct-Output-Octets-64?
Правильно ли выводить всего одну запись (limit 1), или есть ситуации, когда к одному юзеру в UTM привязано больше одной сервисной связки?
Нужно ли делать WRITE LOCK на таблицы при авторизации? UTM5 не использует механизм LOCKS, и вообще единолично общается с БД, не поплохеет ли ему от заблокированой таблицы? кто пробовал?
Edited by [anp/hsw]
Не надо блочить таблицу при авторизации - смысла в этом нет, скорее всего с биллингом не сможете работать, т.к. таблица будет вечно заблочена.
' timestamp='1331735316' post=698322]
Если работает - значит корректно, хотя authorize_check_query мне не понравился.
нет, я не имею ввиду полную блокировку, а только блокировку на время вычисления путя от логина до сервисной связки:
UNLOCK TABLES;        \
А что именно не понравилось в authorize_check_query? Он сделан дампингом mysql-запроса ядра при авторизации.
Предложите ваш вариант, если не сложно.
