Привет админам! Помогите решить проблему. После установки и настройки апача по инструкции http://www.celteh.com/dokumentatsiya/mikbill-freebsd.html перестало подключатся РРРоЕ к провайдеру. Сам апач не запускается. Прикладываю настройки и логи.
/usr/local/etc/mpd5/mpd.conf
startup:
set user login parol admin
set console self 127.0.0.1 5005
default:
load pppoe_client
pppoe_client:
create bundle static B1
set iface route default
set ipcp ranges 0.0.0.0/0 0.0.0.0/0
set ipcp enable req-pri-dns
set ipcp enable req-sec-dns
create link static L1 pppoe
set link action bundle B1
set auth authname name
set auth password pass
set link max-redial 0
set link mtu 1460
set link keep-alive 20 75
set pppoe iface rl1
set pppoe service ""
open
/etc/rc.conf
gateway_enable="YES"
inetd_enable="YES"
keymap="ru.koi8-r"
sshd_enable="YES"
ifconfig_rl1="DHCP"
ifconfig_rl0="DHCP"
ifconfig_ng0="DHCP"
hostname="server"
mpd_enable="YES"
webmin_enable="YES"
mysql_enable="YES"
apache22_enable="YES"
Лог MPD:
Mar 12 15:32:15 server mpd: caught fatal signal term
Mar 12 15:32:15 server mpd: [b1] IFACE: Close event
Mar 12 15:32:15 server mpd: [b1] IPCP: Close event
Mar 12 15:32:17 server mpd: [b1] Bundle: Shutdown
Mar 12 15:32:17 server mpd: [L1] Link: Shutdown
Mar 12 15:32:17 server mpd: process 892 terminated
Mar 12 15:33:35 server mpd: Multi-link PPP daemon for FreeBSD
Mar 12 15:33:35 server mpd: process 888 started, version 5.6 (root@server 12:21 10-Mar-2012)
Mar 12 15:33:36 server mpd: [b1] Bundle: Interface ng0 created
Mar 12 15:33:36 server mpd: [L1] Link: OPEN event
Mar 12 15:33:36 server mpd: [L1] LCP: Open event
Mar 12 15:33:36 server mpd: [L1] LCP: state change Initial --> Starting
Mar 12 15:33:36 server mpd: [L1] LCP: LayerStart
Mar 12 15:33:36 server mpd: [L1] PPPoE: Connecting to ''
Mar 12 15:33:36 server mpd: PPPoE: rec'd ACNAME "bb-core.slav.dn.ua"
Mar 12 15:33:36 server mpd: [L1] PPPoE: connection successful
Mar 12 15:33:36 server mpd: [L1] Link: UP event
Mar 12 15:33:36 server mpd: [L1] LCP: Up event
Mar 12 15:33:36 server mpd: [L1] LCP: state change Starting --> Req-Sent
Mar 12 15:33:36 server mpd: [L1] LCP: SendConfigReq #1
Mar 12 15:33:36 server mpd: [L1] PROTOCOMP
Mar 12 15:33:36 server mpd: [L1] MRU 1492
Mar 12 15:33:36 server mpd: [L1] MAGICNUM 88786370
Mar 12 15:33:36 server mpd: [L1] LCP: rec'd Configure Request #1 (Req-Sent)
Mar 12 15:33:36 server mpd: [L1] AUTHPROTO CHAP MD5
Mar 12 15:33:36 server mpd: [L1] MAGICNUM 94dc7307
Mar 12 15:33:36 server mpd: [L1] LCP: SendConfigAck #1
Mar 12 15:33:36 server mpd: [L1] LCP: state change Req-Sent --> Ack-Sent
Mar 12 15:33:38 server mpd: [L1] LCP: SendConfigReq #2
Mar 12 15:33:38 server mpd: [L1] PROTOCOMP
Mar 12 15:33:38 server mpd: [L1] MRU 1492
Mar 12 15:33:38 server mpd: [L1] MAGICNUM 88786370
Mar 12 15:33:38 server mpd: [L1] LCP: rec'd Configure Reject #2 (Ack-Sent)
Mar 12 15:33:38 server mpd: [L1] LCP: SendConfigReq #3
Mar 12 15:33:38 server mpd: [L1] LCP: rec'd Configure Ack #3 (Ack-Sent)
Mar 12 15:33:38 server mpd: [L1] LCP: state change Ack-Sent --> Opened
Mar 12 15:33:38 server mpd: [L1] LCP: auth: peer wants CHAP, I want nothing
Mar 12 15:33:38 server mpd: [L1] LCP: LayerUp
Mar 12 15:33:38 server mpd: [L1] CHAP: rec'd CHALLENGE #214 len: 39
Mar 12 15:33:38 server mpd: [L1] Name: "bb-core.slav.dn.ua"
Mar 12 15:33:38 server mpd: [L1] CHAP: Using authname "semen-wifi"
Mar 12 15:33:38 server mpd: [L1] CHAP: sending RESPONSE #214 len: 31
Mar 12 15:33:42 server last message repeated 2 times
Mar 12 15:33:42 server mpd: [L1] CHAP: rec'd SUCCESS #214 len: 12
Mar 12 15:33:42 server mpd: [L1] MESG: Login OK
Mar 12 15:33:42 server mpd: [L1] LCP: authorization successful
Mar 12 15:33:42 server mpd: [L1] Link: Matched action 'bundle "B1" ""'
Mar 12 15:33:42 server mpd: [L1] Link: Join bundle "B1"
Mar 12 15:33:42 server mpd: [b1] Bundle: Status update: up 1 link, total bandwidth 64000 bps
Mar 12 15:33:42 server mpd: [b1] IPCP: Open event
Mar 12 15:33:42 server mpd: [b1] IPCP: state change Initial --> Starting
Mar 12 15:33:42 server mpd: [b1] IPCP: LayerStart
Mar 12 15:33:42 server mpd: [b1] IPCP: Up event
Mar 12 15:33:42 server mpd: [b1] IPCP: state change Starting --> Req-Sent
Mar 12 15:33:42 server mpd: [b1] IPCP: SendConfigReq #1
Mar 12 15:33:42 server mpd: [b1] IPADDR 0.0.0.0
Mar 12 15:33:42 server mpd: [b1] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid
Mar 12 15:33:42 server mpd: [b1] IPCP: rec'd Configure Reject #1 (Req-Sent)
Mar 12 15:33:42 server mpd: [b1] IPCP: SendConfigReq #2
Mar 12 15:33:42 server mpd: [b1] IPCP: rec'd Configure Nak #2 (Req-Sent)
Mar 12 15:33:42 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:33:42 server mpd: [b1] 188.239.193.21 is OK
Mar 12 15:33:42 server mpd: [b1] IPCP: SendConfigReq #3
Mar 12 15:33:42 server mpd: [b1] IPCP: rec'd Configure Ack #3 (Req-Sent)
Mar 12 15:33:42 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 12 15:33:44 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 12 15:33:44 server mpd: [b1] IPCP: SendConfigReq #4
Mar 12 15:33:44 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:33:44 server mpd: [b1] IPCP: rec'd Configure Ack #4 (Req-Sent)
Mar 12 15:33:44 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 12 15:33:46 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 12 15:33:46 server mpd: [b1] IPCP: SendConfigReq #5
Mar 12 15:33:46 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:33:46 server mpd: [b1] IPCP: rec'd Configure Ack #5 (Req-Sent)
Mar 12 15:33:46 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 12 15:33:48 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 12 15:33:48 server mpd: [b1] IPCP: SendConfigReq #6
Mar 12 15:33:48 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:33:48 server mpd: [b1] IPCP: rec'd Configure Ack #6 (Req-Sent)
Mar 12 15:33:48 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 12 15:33:50 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 12 15:33:50 server mpd: [b1] IPCP: SendConfigReq #7
Mar 12 15:33:50 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:33:50 server mpd: [b1] IPCP: rec'd Configure Ack #7 (Req-Sent)
Mar 12 15:33:50 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 12 15:33:52 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 12 15:33:52 server mpd: [b1] IPCP: SendConfigReq #8
Mar 12 15:33:52 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:33:52 server mpd: [b1] IPCP: rec'd Configure Ack #8 (Req-Sent)
Mar 12 15:33:52 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 12 15:33:54 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 12 15:33:54 server mpd: [b1] IPCP: SendConfigReq #9
Mar 12 15:33:54 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:33:54 server mpd: [b1] IPCP: rec'd Configure Ack #9 (Req-Sent)
Mar 12 15:33:54 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 12 15:33:56 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 12 15:33:56 server mpd: [b1] IPCP: SendConfigReq #10
Mar 12 15:33:56 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:33:56 server mpd: [b1] IPCP: rec'd Configure Ack #10 (Req-Sent)
Mar 12 15:33:56 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 12 15:33:58 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 12 15:33:58 server mpd: [b1] IPCP: SendConfigReq #11
Mar 12 15:33:58 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:33:58 server mpd: [b1] IPCP: rec'd Configure Ack #11 (Req-Sent)
Mar 12 15:33:58 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 12 15:34:00 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 12 15:34:00 server mpd: [b1] IPCP: SendConfigReq #12
Mar 12 15:34:00 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:02 server mpd: [b1] IPCP: SendConfigReq #13
Mar 12 15:34:02 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:02 server mpd: [b1] IPCP: rec'd Configure Ack #13 (Req-Sent)
Mar 12 15:34:02 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 12 15:34:04 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 12 15:34:04 server mpd: [b1] IPCP: SendConfigReq #14
Mar 12 15:34:04 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:06 server mpd: [b1] IPCP: SendConfigReq #15
Mar 12 15:34:06 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:06 server mpd: [b1] IPCP: rec'd Configure Ack #15 (Req-Sent)
Mar 12 15:34:06 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 12 15:34:08 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 12 15:34:08 server mpd: [b1] IPCP: SendConfigReq #16
Mar 12 15:34:08 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:10 server mpd: [b1] IPCP: SendConfigReq #17
Mar 12 15:34:10 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:12 server mpd: [b1] IPCP: SendConfigReq #18
Mar 12 15:34:12 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:14 server mpd: [b1] IPCP: SendConfigReq #19
Mar 12 15:34:14 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:16 server mpd: [b1] IPCP: SendConfigReq #20
Mar 12 15:34:16 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:18 server mpd: [b1] IPCP: SendConfigReq #21
Mar 12 15:34:18 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:20 server mpd: [b1] IPCP: SendConfigReq #22
Mar 12 15:34:20 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:22 server mpd: [b1] IPCP: SendConfigReq #23
Mar 12 15:34:22 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:24 server mpd: [b1] IPCP: SendConfigReq #24
Mar 12 15:34:24 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:26 server mpd: [b1] IPCP: SendConfigReq #25
Mar 12 15:34:26 server mpd: [b1] IPADDR 188.239.193.21
Mar 12 15:34:28 server mpd: [b1] IPCP: parameter negotiation failed
Mar 12 15:34:28 server mpd: [b1] IPCP: state change Req-Sent --> Stopped
Mar 12 15:34:28 server mpd: [b1] IPCP: LayerFinish
Mar 12 15:34:28 server mpd: [b1] Bundle: No NCPs left. Closing links...
Mar 12 15:34:28 server mpd: [b1] Bundle: closing link "L1"...
Mar 12 15:34:28 server mpd: [L1] Link: CLOSE event
Mar 12 15:34:28 server mpd: [L1] LCP: Close event
Mar 12 15:34:28 server mpd: [L1] LCP: state change Opened --> Closing
Mar 12 15:34:28 server mpd: [L1] Link: Leave bundle "B1"
Mar 12 15:34:28 server mpd: [b1] Bundle: Status update: up 0 links, total bandwidth 9600 bps
Mar 12 15:34:28 server mpd: [b1] IPCP: Close event
Mar 12 15:34:28 server mpd: [b1] IPCP: state change Stopped --> Closed
Mar 12 15:34:28 server mpd: [b1] IPCP: Down event
Mar 12 15:34:28 server mpd: [b1] IPCP: state change Closed --> Initial
Mar 12 15:34:28 server mpd: [L1] LCP: SendTerminateReq #4
Mar 12 15:34:28 server mpd: [L1] LCP: LayerDown
Mar 12 15:34:30 server mpd: [L1] LCP: SendTerminateReq #5
Mar 12 15:34:32 server mpd: [L1] LCP: state change Closing --> Closed
Mar 12 15:34:32 server mpd: [L1] LCP: LayerFinish
Mar 12 15:34:32 server mpd: [L1] Link: DOWN event
Mar 12 15:34:32 server mpd: [L1] LCP: Down event
Mar 12 15:34:32 server mpd: [L1] LCP: state change Closed --> Initial
ifconfig:
rl0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
       options=3808<VLAN_MTU,WOL_UCAST,WOL_MCAST,WOL_MAGIC>
       ether 00:15:58:01:47:91
       inet 192.168.100.200 netmask 0xffffff00 broadcast 192.168.100.255
       media: Ethernet autoselect (100baseTX <full-duplex>)
       status: active
rl1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
       ether 00:e0:1c:3c:cd:0f
       inet 172.26.112.91 netmask 0xffffff80 broadcast 172.26.112.127
       status: active
plip0: flags=8810<POINTOPOINT,SIMPLEX,MULTICAST> metric 0 mtu 1500
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
       options=3<RXCSUM,TXCSUM>
       inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
       inet6 ::1 prefixlen 128
       inet 127.0.0.1 netmask 0xff000000
       nd6 options=3<PERFORMNUD,ACCEPT_RTADV>
ng0: flags=8890<POINTOPOINT,NOARP,SIMPLEX,MULTICAST> metric 0 mtu 1500
Это для старта mpd как сетевой сервис, чтоб апач раньше не стартанул.
правите /etc/rc.d/NETWORKING
Добавляете туда
# REQUIRE: mpd
Убедиться что в /usr/local/etc/rc.d/mpd5 присутствует строка:
# PROVIDE: mpd
в /usr/local/etc/rc.d/apache22
в строчку # REQUIRE добавить NETWORKING
Edited by vlad11
Добавьте еще строки в mpd.conf
        set iface enable tcpmssfix
       set iface up-script   /usr/local/etc/mpd5/stream-up.sh
       set iface down-script /usr/local/etc/mpd5/stream-down.sh
stream-up.sh
#!/bin/sh
/sbin/ifconfig ng0 descr STREAM
/bin/sleep 10
/etc/rc.d/named restart
/usr/bin/dig @A.ROOT-SERVERS.NET . ns
stream-down.sh
#!/bin/sh
/sbin/route delete default
потом сделайте исполняемыми эти скрипты chmod +x <script>
Edited by vlad11
# REQUIRE: mpd
# PROVIDE: mpd
Это добавлять именно так? С комментарием? Потому что в /usr/local/etc/rc.d/mpd5 она закоментирована. И тоже самое в /usr/local/etc/rc.d/apache22 строка # REQUIRE
Не получилось. Настроил как сказали. Вот лог:
Mar 14 13:31:45 server mpd: Multi-link PPP daemon for FreeBSD
Mar 14 13:31:45 server mpd: process 1345 started, version 5.6 (root@server 17:09 12-Mar-2012)
Mar 14 13:31:45 server mpd: [b1] Bundle: Interface ng0 created
Mar 14 13:31:45 server mpd: [L1] Link: OPEN event
Mar 14 13:31:45 server mpd: [L1] LCP: Open event
Mar 14 13:31:45 server mpd: [L1] LCP: state change Initial --> Starting
Mar 14 13:31:45 server mpd: [L1] LCP: LayerStart
Mar 14 13:31:45 server mpd: [L1] PPPoE: Connecting to ''
Mar 14 13:31:45 server mpd: PPPoE: rec'd ACNAME "bb-core.slav.dn.ua"
Mar 14 13:31:45 server mpd: [L1] PPPoE: connection successful
Mar 14 13:31:45 server mpd: [L1] Link: UP event
Mar 14 13:31:45 server mpd: [L1] LCP: Up event
Mar 14 13:31:45 server mpd: [L1] LCP: state change Starting --> Req-Sent
Mar 14 13:31:45 server mpd: [L1] LCP: SendConfigReq #1
Mar 14 13:31:45 server mpd: [L1]   PROTOCOMP
Mar 14 13:31:45 server mpd: [L1]   MRU 1492
Mar 14 13:31:45 server mpd: [L1]   MAGICNUM 3c077381
Mar 14 13:31:45 server mpd: [L1] LCP: rec'd Configure Request #1 (Req-Sent)
Mar 14 13:31:45 server mpd: [L1]   AUTHPROTO CHAP MD5
Mar 14 13:31:45 server mpd: [L1]   MAGICNUM e37ddb75
Mar 14 13:31:45 server mpd: [L1] LCP: SendConfigAck #1
Mar 14 13:31:45 server mpd: [L1] LCP: state change Req-Sent --> Ack-Sent
Mar 14 13:31:45 server mpd: [L1] LCP: rec'd Configure Reject #1 (Ack-Sent)
Mar 14 13:31:45 server mpd: [L1] LCP: SendConfigReq #2
Mar 14 13:31:45 server mpd: [L1] LCP: rec'd Configure Ack #2 (Ack-Sent)
Mar 14 13:31:45 server mpd: [L1] LCP: state change Ack-Sent --> Opened
Mar 14 13:31:45 server mpd: [L1] LCP: auth: peer wants CHAP, I want nothing
Mar 14 13:31:45 server mpd: [L1] LCP: LayerUp
Mar 14 13:31:45 server mpd: [L1] CHAP: rec'd CHALLENGE #254 len: 40
Mar 14 13:31:45 server mpd: [L1]   Name: "bb-core.slav.dn.ua"
Mar 14 13:31:45 server mpd: [L1] CHAP: Using authname "semen-wifi"
Mar 14 13:31:45 server mpd: [L1] CHAP: sending RESPONSE #254 len: 31
Mar 14 13:31:47 server mpd: [L1] CHAP: sending RESPONSE #254 len: 31
Mar 14 13:31:47 server mpd: [L1] CHAP: rec'd SUCCESS #254 len: 12
Mar 14 13:31:47 server mpd: [L1]   MESG: Login OK
Mar 14 13:31:47 server mpd: [L1] LCP: authorization successful
Mar 14 13:31:47 server mpd: [L1] Link: Matched action 'bundle "B1" ""'
Mar 14 13:31:47 server mpd: [L1] Link: Join bundle "B1"
Mar 14 13:31:47 server mpd: [b1] Bundle: Status update: up 1 link, total bandwidth 64000 bps
Mar 14 13:31:47 server mpd: [b1] IPCP: Open event
Mar 14 13:31:47 server mpd: [b1] IPCP: state change Initial --> Starting
Mar 14 13:31:47 server mpd: [b1] IPCP: LayerStart
Mar 14 13:31:47 server mpd: [b1] IPCP: Up event
Mar 14 13:31:47 server mpd: [b1] IPCP: state change Starting --> Req-Sent
Mar 14 13:31:47 server mpd: [b1] IPCP: SendConfigReq #1
Mar 14 13:31:47 server mpd: [b1]   IPADDR 192.168.100.200
Mar 14 13:31:47 server mpd: [b1]   COMPPROTO VJCOMP, 16 comp. channels, no comp-cid
Mar 14 13:31:47 server mpd: [b1] IPCP: rec'd Configure Reject #1 (Req-Sent)
Mar 14 13:31:47 server mpd: [b1] IPCP: SendConfigReq #2
Mar 14 13:31:47 server mpd: [b1] IPCP: rec'd Configure Nak #2 (Req-Sent)
Mar 14 13:31:47 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:31:47 server mpd: [b1]     188.239.193.21 is OK
Mar 14 13:31:47 server mpd: [b1] IPCP: SendConfigReq #3
Mar 14 13:31:47 server mpd: [b1] IPCP: rec'd Configure Ack #3 (Req-Sent)
Mar 14 13:31:47 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:31:49 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:31:49 server mpd: [b1] IPCP: SendConfigReq #4
Mar 14 13:31:49 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:31:49 server mpd: [b1] IPCP: rec'd Configure Ack #4 (Req-Sent)
Mar 14 13:31:49 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:31:51 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:31:51 server mpd: [b1] IPCP: SendConfigReq #5
Mar 14 13:31:51 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:31:53 server mpd: [b1] IPCP: SendConfigReq #6
Mar 14 13:31:53 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:31:53 server mpd: [b1] IPCP: rec'd Configure Ack #6 (Req-Sent)
Mar 14 13:31:53 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:31:55 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:31:55 server mpd: [b1] IPCP: SendConfigReq #7
Mar 14 13:31:55 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:31:55 server mpd: [b1] IPCP: rec'd Configure Ack #7 (Req-Sent)
Mar 14 13:31:55 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:31:57 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:31:57 server mpd: [b1] IPCP: SendConfigReq #8
Mar 14 13:31:57 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:31:57 server mpd: [b1] IPCP: rec'd Configure Ack #8 (Req-Sent)
Mar 14 13:31:57 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:31:59 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:31:59 server mpd: [b1] IPCP: SendConfigReq #9
Mar 14 13:31:59 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:31:59 server mpd: [b1] IPCP: rec'd Configure Ack #9 (Req-Sent)
Mar 14 13:31:59 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:32:01 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:32:01 server mpd: [b1] IPCP: SendConfigReq #10
Mar 14 13:32:01 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:01 server mpd: [b1] IPCP: rec'd Configure Ack #10 (Req-Sent)
Mar 14 13:32:01 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:32:03 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:32:03 server mpd: [b1] IPCP: SendConfigReq #11
Mar 14 13:32:03 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:03 server mpd: [b1] IPCP: rec'd Configure Ack #11 (Req-Sent)
Mar 14 13:32:03 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:32:05 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:32:05 server mpd: [b1] IPCP: SendConfigReq #12
Mar 14 13:32:05 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:05 server mpd: [b1] IPCP: rec'd Configure Ack #12 (Req-Sent)
Mar 14 13:32:05 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:32:07 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:32:07 server mpd: [b1] IPCP: SendConfigReq #13
Mar 14 13:32:07 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:07 server mpd: [b1] IPCP: rec'd Configure Ack #13 (Req-Sent)
Mar 14 13:32:07 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:32:09 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:32:09 server mpd: [b1] IPCP: SendConfigReq #14
Mar 14 13:32:09 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:09 server mpd: [b1] IPCP: rec'd Configure Ack #14 (Req-Sent)
Mar 14 13:32:09 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:32:11 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:32:11 server mpd: [b1] IPCP: SendConfigReq #15
Mar 14 13:32:11 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:11 server mpd: [b1] IPCP: rec'd Configure Ack #15 (Req-Sent)
Mar 14 13:32:11 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:32:13 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:32:13 server mpd: [b1] IPCP: SendConfigReq #16
Mar 14 13:32:13 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:13 server mpd: [b1] IPCP: rec'd Configure Ack #16 (Req-Sent)
Mar 14 13:32:13 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:32:15 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:32:15 server mpd: [b1] IPCP: SendConfigReq #17
Mar 14 13:32:15 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:15 server mpd: [b1] IPCP: rec'd Configure Ack #17 (Req-Sent)
Mar 14 13:32:15 server mpd: [b1] IPCP: state change Req-Sent --> Ack-Rcvd
Mar 14 13:32:17 server mpd: [b1] IPCP: state change Ack-Rcvd --> Req-Sent
Mar 14 13:32:17 server mpd: [b1] IPCP: SendConfigReq #18
Mar 14 13:32:17 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:19 server mpd: [b1] IPCP: SendConfigReq #19
Mar 14 13:32:19 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:21 server mpd: [b1] IPCP: SendConfigReq #20
Mar 14 13:32:21 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:23 server mpd: [b1] IPCP: SendConfigReq #21
Mar 14 13:32:23 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:25 server mpd: [b1] IPCP: SendConfigReq #22
Mar 14 13:32:25 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:27 server mpd: [b1] IPCP: SendConfigReq #23
Mar 14 13:32:27 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:29 server mpd: [b1] IPCP: SendConfigReq #24
Mar 14 13:32:29 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:31 server mpd: [b1] IPCP: SendConfigReq #25
Mar 14 13:32:31 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:33 server mpd: [b1] IPCP: SendConfigReq #26
Mar 14 13:32:33 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:35 server mpd: [b1] IPCP: SendConfigReq #27
Mar 14 13:32:35 server mpd: [b1]   IPADDR 188.239.193.21
Mar 14 13:32:37 server mpd: [b1] IPCP: parameter negotiation failed
Mar 14 13:32:37 server mpd: [b1] IPCP: state change Req-Sent --> Stopped
Mar 14 13:32:37 server mpd: [b1] IPCP: LayerFinish
Mar 14 13:32:37 server mpd: [b1] Bundle: No NCPs left. Closing links...
Mar 14 13:32:37 server mpd: [b1] Bundle: closing link "L1"...
Mar 14 13:32:37 server mpd: [L1] Link: CLOSE event
Mar 14 13:32:37 server mpd: [L1] LCP: Close event
Mar 14 13:32:37 server mpd: [L1] LCP: state change Opened --> Closing
Mar 14 13:32:37 server mpd: [L1] Link: Leave bundle "B1"
Mar 14 13:32:37 server mpd: [b1] Bundle: Status update: up 0 links, total bandwidth 9600 bps
Mar 14 13:32:37 server mpd: [b1] IPCP: Close event
Mar 14 13:32:37 server mpd: [b1] IPCP: state change Stopped --> Closed
Mar 14 13:32:37 server mpd: [b1] IPCP: Down event
Mar 14 13:32:37 server mpd: [b1] IPCP: state change Closed --> Initial
Mar 14 13:32:37 server mpd: [L1] LCP: SendTerminateReq #3
Mar 14 13:32:37 server mpd: [L1] LCP: LayerDown
Mar 14 13:32:39 server mpd: [L1] LCP: SendTerminateReq #4
Mar 14 13:32:41 server mpd: [L1] LCP: state change Closing --> Closed
Mar 14 13:32:41 server mpd: [L1] LCP: LayerFinish
Mar 14 13:32:41 server mpd: [L1] Link: DOWN event
Mar 14 13:32:41 server mpd: [L1] LCP: Down event
Mar 14 13:32:41 server mpd: [L1] LCP: state change Closed --> Initial
