Люди помогите!!!!
Имеем 2 провайдера, свою AS и пул адресов.
Надо разделить пользователей по каналам.
Конфиг zebra.conf
! Zebra configuration saved from vty
! 2010/08/19 21:29:23
hostname Какое-то имя
password password
enable password password
log file /var/log/quagga/zebra.log
!debug zebra events
!debug zebra packet
interface eth8
ip address xxx.xxx.x40.110/30
ipv6 nd suppress-ra
interface eth6
ip address yyy.yyy.yy1.47/31
ipv6 nd suppress-ra
interface br0
ip address 192.168.1.201/24
ip address 172.16.0.3/16
ip address 172.24.0.3/16
ip address 172.25.0.3/24
ipv6 nd suppress-ra
interface lo
interface lo:1
ip address xxx.xxx.xxx.1/24
ipv6 nd suppress-ra
ip route 0.0.0.0/0 xxx.xxx.xxx.109 15
ip route 0.0.0.0/0 yyy.yyy.yyy.46 25
ip route 10.0.0.0/8 Null0 254
ip route 172.16.0.0/16 Null0 254
ip route 172.24.0.0/16 Null0 254
ip route 172.25.0.0/16 Null0 254
ip route 192.168.0.0/16 Null0 254
ip route xxx.xxx.xxx.0/24 Null0 254
ip route xxx.xxx.xxx.0/25 xxx.xxx.xxx.72
ip route xxx.xxx.xxx.128/25 yyy.yyy.yyy.46
ip forwarding
line vty
exec-timeout 0 0
конфиг bgpd.conf
hostname OURAS
password pass
!debug bgp events
!debug bgp filters
!debug bgp fsm
!debug bgp keepalives
!debug bgp updates
bgp multiple-instance
bgp config-type cisco
log file /var/log/quagga/bgpd.log
log stdout
router bgp OURAS
no synchronization
bgp router-id xxx.xxx.xxx.1
bgp log-neighbor-changes
network xxx.xxx.xxx.0/24
neighbor xxx.xxx.xxx.72 remote-as ASISP1
neighbor xxx.xxx.xxx.72 description ISP1
neighbor xxx.xxx.xxx.72 update-source xxx.xxx.xxx.110
neighbor xxx.xxx.xxx.72 ebgp-multihop 255
neighbor xxx.xxx.xxx.72 weight 4000
neighbor xxx.xxx.xxx.72 soft-reconfiguration inbound
neighbor xxx.xxx.xxx.72 route-map ISP1-in in
neighbor xxx.xxx.xxx.72 route-map ISP1-out out
neighbor yyy.yyy.yyy.46 remote-as ASISP2
neighbor yyy.yyy.yyy.46 description ISP2
neighbor yyy.yyy.yyy.46 update-source yyy.yyy.yyy.47
neighbor yyy.yyy.yyy.46 ebgp-multihop 255
neighbor yyy.yyy.yyy.46 weight 1000
neighbor yyy.yyy.yyy.46 soft-reconfiguration inbound
neighbor yyy.yyy.yyy.46 route-map ISP2-in in
neighbor yyy.yyy.yyy.46 route-map ISP2-out out
ip prefix-list bogons description bogus nets
ip prefix-list bogons description seq 15 permit 0.0.0.0/8 le 32
ip prefix-list bogons seq 20 permit 127.0.0.0/8 le 32
ip prefix-list bogons seq 30 permit 10.0.0.0/8 le 32
ip prefix-list bogons seq 35 permit 172.16.0.0/12 le 32
ip prefix-list bogons seq 40 permit 192.168.0.0/16 le 32
ip prefix-list bogons seq 45 permit 169.254.0.0/16 le 32
ip prefix-list bogons seq 50 permit 224.0.0.0/4 le 32
ip prefix-list bogons seq 55 permit 240.0.0.0/4 le 32
ip prefix-list default description default route
ip prefix-list default seq 10 permit 0.0.0.0/0
ip prefix-list our-CIDR-blocks seq 5 permit xxx.xxx.xxx.0/24 le 32
ip prefix-list upstream-out seq 10 permit xxx.xxx.xxx.0/24
ip as-path access-list 1 permit _6451[2-9]_
ip as-path access-list 1 permit _645[2-9][0-9]_
ip as-path access-list 1 permit _64[6-9][0-9][0-9]_
ip as-path access-list 1 permit _65[0-9][0-9][0-9]_
route-map ISP1-in deny 100
match as-path 1
route-map ISP1-in deny 110
match ip address prefix-list bogons
route-map ISP1-in deny 120
match ip address prefix-list our-CIDR-blocks
route-map ISP1-in permit 200
set local-preference 200
route-map ISP1-out permit 100
match ip address prefix-list upstream-out
route-map ISP1-out deny 200
route-map ISP2-in deny 100
match as-path 1
route-map ISP2-in deny 110
route-map ISP2-in deny 120
route-map ISP2-in permit 200
set local-preference 100
route-map ISP2-out permit 100
set as-path prepend OURAS OURAS OURAS OURAS OURAS
!route-map ISP2-out deny 200
line vty
У меня получается вообще непонятно что, вобщем я совсем запутался, хотелось бы чтоб 80% узеров ходило через ISP1, а 20% - через ISP2.
Похоже что у меня трафик разделился на два интерфейса, входящий по одному каналу идёт, исходящий по другому.
Edited by llaann
У каждого аплинка свои приколы с маршрутизацией.
Да и внутри сети иногда бывает ассиметрия исхода.
Обращайтесь в личку за помощью, небезкорыстно помогу настроить BGP и внешний роутинг.
Edited by vlad11
что значит
у Вас блок всего /24, Вы его анонсите всем провам одинаково.префиксами Вы только маршруты выбираете и все .
что значит
Деже если блок /24, всегда можно разделить равномерно исход на 2 и более аплинков.
Главное, чтоб аплинки отдавали FV.
Edited by vlad11
Исходящий - без проблем. Статические маршруты + fallback-gw.
Дополнительный плюс - не надо возиться с fullview.
Чтобы балансировать входящий, надо иметь блок больше /24,
регистрировать в RIPE route object'ы для подсетей
и анонсировать их разным аплинкам с разными препендами.
зачем фуллвью ? это ж только исходячка. исходячка как правило в разы меньше => похрен куда она пойдет. чтобы ровно разделить, хватит и ecmp на дефолтах от каждого из аплинков.
надо тчобы маршруты создавались в зависимости от состояния бгп сессии, чтобы при ее падении они удалялись. на квагге такое реализуется лишь скриптами из палок и кабаньего говна. sad but true.
все не совсем так. если у вас есть большой блок который можно порезать на специфики до /24, то можно балансить спецификами. например есть /23, то одну /24 анонсим в один апстрим, другую /24 в другой, а /23 в оба. бида в том что не всегда трафик раскладывается по ровну между блоками сетей и вообще трафик никак не связан с адресами. это скорее такой деревянный вариант от безисходности. препенды на анонсы тоже деревянный вариант, т.к. влияют глобально на всё и сразу и управлять тем как разложится трафик будет получаться очень грубо: то весь трафик едет в один аплинк, то в другой.
правильный путь - использовать апстримов с развитыми комунитями (благо любой современый магисрал имеет какие-никакие комунити), снимая анонсы, вешая препенды на разные пиры у апстрима можно довольно тонко размазать трафик поровну.
Если адреса используются для NAT, то можно назначать для разных приватных подсетей публичные адреса из разных блоков,
и таким образом балансировать входящую нагрузку с большой точностью.
Если адреса выдаются клиентам напрямую, то принцип тот же - адреса из разных блоков распределяются равномерно.
Не везде есть даже возможность подключения второго аплинка, не говоря уже о том,
что сначала принято смотреть на цену, а в последнюю очередь на поддержку community.
Любой????
Пока это скорее исключение, чем правило.
Тогда подскажите как правильно выбирать маршрут, у меня все уходят в ISP2, нужно чтобы все ходили через ISP1.
1) фильтруйте все префиксы, которые приходят от аплинков.
2) вся маршрутизация наружу - статическая.
3) переключение с упавшего аплинка - через fallback-gw.
4) при использовании bgp маршрут входящего трафика не зависит от маршрута исходящего.
натить просто в несколько адресов из разных блоков, это не проблема. а адреса выдавать клиентам из разных блоков может стать проблемой в последствии, потому что внезапно окажется что все сети /24 утилизированы на 89% и не откуда дать доброму клиенту /26 для счастья.
принято смотреть на совокупность вещей, в которые конешно включается и цена, но цена не может являться определяющим фактором. любой дурак готов продать интернетов в разы дешевле какого магисрала, но далеко не каждый может предоставить адекватное качество. ну а если качество не нужно, то да, можно взять интернетов у любого хомяка.
Любой????
эээ.. да магисралов то раз два и обчелся ж: ттк, рт, совинтел (белайн), синтерра (мегафон), - у всех есть комунити.
никак не пойму что такое фолбак-гв ? и зачем статическая маршрутизация, если есть бгп.
use google, luke!
https://www.google.com/search?q=fallback-gw
1) через статические маршруты проще балансировать исходящую нагрузку,
2) если аплинки шлют fullview, можно фильтровать их и этим прилично снизить нагрузку на бордер.
Что лучше - пять маршрутов или 370k?
Не факт. Вы придумываете свой демон маршрутизации.
Если у вас бюджетный киско-роутер, то он от FV загнется.
А если РС-роутер, то лучше брать максимум, легче балансировать.
A script to activate backup routing on gateway failure.
пинцет. это типа "true"-решение ? закопайте обратно.
и как вы будете удалять статические маршруты при падении одного из пиров ? говноскриптом вышеупомянутым ? а может еще свой демон маршрутизации напишем ? зачем это всё, когда можно принять два дефолта и сделать ecmp. ну или если fv то по as-path'у раскидать префиксы туда-сюда. количество трафика то не зависит от количества префиксов. у вас легко может быть на какой не большой блок адресов трафика быть в разы больше чем на все остальные адреса вместе взятые.
зачем их фильтровать ? не проще аплинк попросить тогда уж слать дефолт ? а что лучше fv или дефолт решает не количество префиксов, а решаемые задачи. под которые вобщем-то и покупается оборудование.
не, ну не включать soft-inbound configuration и будет ок. просто зачем использовать "бюджетный киско-роутер" там где нужен нормальный роутер. из-за нищеты ?
ну и я не знаю, есть далеко не бюджетные роутеры неумеющие fv в fib'е. 76+rsp720-c хороший пример - стоит гору денег, а ничо не может. такие дела.
рекомендую для начала прочитать книжку про bgp (например Хелеби от цископресса) и чего еще, поделать лабы про бгп и осознать принципы работы протокола. а потом уже с шашкой на гало побеждать циски и квагги.
вот тут чаще всего и проблема - что надо нормальные а не "какиеникакие".... а "какиеникакие" - тоже часто только очень грубо могут регулировать
Похоже никто из ответивших даже не смотрел приложенный конфиг...
При ваших настройках трафик и так должен идти через ISP1. У вас сессии то поднялись на обоих ISP ? Проблема может быть в том, что ISP1 - это multihop. Т.е. для маршрутов от него будет приниматься атрибут "Next Hop", и для адресов в нем может не оказаться нужных маршрутов через нужный интерфейс. Попробуйте сделать так:
set ip next-hop xxx.xxx.xxx.109
еще я бы рекомендовал статический маршрут добавить
ip route xxx.xxx.xxx.72/32 xxx.xxx.xxx.109
Также непонятно зачем вот эти маршруты
ЗЫ: И еще уберите weight с обоих пиров и никогда не пользуйтесь этим атрибутом - его придумала cisco, в стандарте BGP про него ничего нет.
бывает, да. ну лучше "какие-нибудь", чем никаких вообще.
чо к чему? в один аплинк входячка может литься банально потому что оба апстрима своим аплинком имеют одного магисрала. это ж легко выяснить в ripe.net/ris и пробежавшись по лукенг глассам.
про исходячку, зачем делать некстхоп ? что вообще тут имеется ввиду. пусть топикстартер прочитает книжку (вам тоже советую) и осознает что да как. это будет гораздо полезнее и ценнее чем тысячи недосоветов на форуме хоменетов.
и что такого ? волков боятся - в лес не ходить. если знаешь как он работает, почему им не пользоваться ?
ну значит позовите одмина, он вам настроит. ну а если вы и есть тот одмин, то надо открывать книжку. такие дела.
у вас вес 4000 на одном пире и 1000 на другом, соответственно активным маршрутами с одинаковыми префиксами с обоих апстримов назначены те что с 4000.
Я ж говорю, что некоторые даже не читают перед тем как ответить.
Если бы прочитали конфиг, то увидели, что weight 4000 стоит на ISP1, а если бы прочитали вот это сообщение
то поняли, что вопреки weight трафик ходит через другого аплинка.
Если бы сами почитали книжку, то наверно знали бы чем отличается обработка анонсов от ebgp-multihop пиров. Например, что от multihop пира принимается "Next Hop", и если маршрут к этому некстхопу будет виден через другого аплинка, то и трафик пойдет через другого аплинка.
pfexec, я делаю вывод, что вы - обычный болтун, тролль и невежда.
у топикстартера представлне недостаточно информации для того чтобы однозначно понять что у него происходит. разница между нами в том что я не пытаюсь пальцем в небо тыкать и играть в телепата. да, прочитал по диагонали.
тащем-то нет, не так. начнем с того что от безисходности кто-то налепил в конфиг ebgp-multihop с ттл аж 255. очевидно же что никто даже не поинтересовался зачем. во-вторых, опять же не представлено достаточно информации чтобы понять нужен там этот мультихоп или нет. ну и в-третьих, квагга не умеет работать мультихопом, если до мультихоп пира маршрут изучен через бгп. об этом даже есть PR столетеней давности: https://bugzilla.quagga.net/show_bug.cgi?id=377
в данном сценарии правильно решение - выбросить кваггу уже на свалку истории и использовать bird. если очень хочется кваггу, то опять же, правильный вариант прописать статик маршрут до пира, что вы вобщем-то и предложили. но это всё не "особенности" работы бгп в мультихопе, это особенности квагге которая работает как ей хочется.
можете делать выводы сколько влезет, но книжку Вам прочитать таке не помешает. теперь я в этом уверен. ну а воспользоваться этим советом или нет, конечно, дело ваше.
возможно немного офтоп, но продолжу мысль по коммюнити, может поможет ТС - хорошо когда провайдер-апстрим разрешает (пропускает, не фильтрует) коммюнити - которые работают у его апстримов - иногда оооочень помогает....
Многие апстримы их режут, "якобы, они память отжирают у маршрутизаторов".
и это справедливо, отжирают, только, по уму, срезать надо мусор который приходит от их апстрима, и не мешать клиентам устанавливать с их помощью политики для своей сети
Покажите пример мусора?
Лично я хочу видеть сети с комьюнити аплинков моего аплинка.
а вы хотите видеть комьюнити аплинков аплинков аплинков... в общем можно долго продолжать
интернет большой, десятки тысяч автономных систем, кто там где там начнут по своим причинам вешать комьнити да еще и не поодному, и все это надо хранить в памяти
сподвигли меня посмотреть, что делает наш аплинк, и он как раз присылает маршруты с комьюнити которые установил он сам и их аплинк, как раз то о чем говорим
PS. спасибо за идею, у нас BPG policy полгода назад я только реализовал, посрезать лишние комьнити - хорошая идея для развития, займусь на недельке
Нет. Мне достаточно коммьюнити от аплинка 2-го уровня.
Остальное нужное я посмотрю на LG.
P.S. а почему нельзя продавать роутеры с парой гигов памяти? флеш дорогая? маркетинговая защита?
