Купил multimouse, пытаюсь расшарить карту на компе с линуксом, но
что то NewCS не может прочитать карту до конца, эта же карта
в дримбоксе работает.
Инструкция на ридер - инструкция.
Ридер в режиме mouse 6Mhz.
Вот часть конфига NewCS:
<device>
           <name>mouse</name>
           <type>mouse</type>
                          <mhz>600</mhz>
           <node>/dev/ttyS0</node>
                       <parity>odd</parity>
                       <reset>inverse</reset>
                       <infinity_number>0</infinity_number>
                       <slot>0</slot>
                       <export>yes</export>
                       <enabled>yes</enabled>
                       <blocksa>no</blocksa>
                       <blockua>no</blockua>
                       <blockga>no</blockga>
                       <boxid>1</boxid>
                       <PTShandshake>no</PTShandshake>
                       <Seca>no</Seca>
                       <crypto>no</crypto>
                       <carddetect>yes</carddetect>
        <newcamd_port>34000</newcamd_port>
        <priority>round</priority>
        <autosid>yes</autosid>
     </device>
Вот что в логе:
[ 08:19:50 ] [ Phoenix ] Opening device /dev/ttyS0
[ 08:19:50 ] [ Phoenix ] Setting Parity to: ODD
[ 08:19:50 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyS0
[ 08:19:50 ] [ Phoenix ] Setting Baud to standard 9600
[ 08:19:51 ] [ Phoenix ] Inverse RESET on node /dev/ttyS0
[ 08:19:53 ] [ ATR ] T=14  1etu=104.17us  Guardtime:17etu  WWT:9600etu
[ 08:19:53 ] [ ATR ] Historical bytes: I R D E T O   A [FF] [00] [00] [00] [00] [00] [00]
[ 08:19:53 ] [ Loader ] Init Irdeto card
[ 08:19:53 ] [ Phoenix ] Setting Parity to: NONE
[ 08:19:53 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyS0
[ 08:19:53 ] [ Phoenix ] Setting Baud to standard 9600
[ 08:19:59 ] [ Loader ] Card 0600 on port /dev/ttyS0 failed
[ 08:19:59 ] [ Loader ] Starting Newcamd Server on port 34000
[ 08:19:59 ] [ Newcamd ] Newcamd thread Server started on port 34000
