Не корретно распредедляет нагурзку по ядрам. Интересная картина наблюдается с igb0. Привызывал каждый cpu0 к треду igb0.
вот этим скриптом. Посмотрел, привязался . результат один)
Freebsd 9.0 stable. HP proliant GL-160 G7. сетевуха двух портовая.
Скрипт для привязки cpu к тредам
#!/bin/sh
# PROVIDE: cpuset-igb
# REQUIRE: FILESYSTEMS
# BEFORE:  netif
# KEYWORD: nojail
case "$1" in
*start)
 echo "Binding igb(4) IRQs to CPUs"
 cpus=`sysctl -n kern.smp.cpus`
 vmstat -ai | sed -E '/^irq.*que/!d; s/^irq([0-9]+): igb([0-9]+):que ([0-9]+).*/\1 \2 \3/' |\
 while read irq igb que
 do
   cpuset -l $(( ($igb+$que) % $cpus )) -x $irq
 done
esac
last pid: 46908;  load averages:  1.92,  1.71,  1.75                                            up 14+18:11:17  23:13:23
153 processes: 9 running, 97 sleeping, 47 waiting
CPU 0:  0.4% user,  0.0% nice,  0.4% system, 53.9% interrupt, 45.3% idle
CPU 1:  0.4% user,  0.0% nice,  0.0% system, 12.6% interrupt, 87.0% idle
CPU 2:  0.8% user,  0.0% nice,  2.4% system,  4.3% interrupt, 92.5% idle
CPU 3:  0.0% user,  0.0% nice,  0.4% system,  7.9% interrupt, 91.7% idle
CPU 4:  1.2% user,  0.0% nice,  1.6% system,  9.1% interrupt, 88.2% idle
CPU 5:  3.5% user,  0.0% nice,  1.6% system, 11.0% interrupt, 83.9% idle
CPU 6:  0.0% user,  0.0% nice,  0.4% system, 13.4% interrupt, 86.2% idle
CPU 7:  0.4% user,  0.0% nice,  0.4% system, 12.2% interrupt, 87.0% idle
Mem: 90M Active, 3032M Inact, 474M Wired, 133M Cache, 112M Buf, 60M Free
Swap: 4096M Total, 84K Used, 4096M Free
 PID USERNAME PRI NICE   SIZE    RES STATE   C   TIME   WCPU COMMAND
  11 root     155 ki31     0K    64K CPU2    2 331.2H 95.36% idle{idle: cpu2}
  11 root     155 ki31     0K    64K RUN     6 336.6H 94.87% idle{idle: cpu6}
  11 root     155 ki31     0K    64K CPU4    4 333.6H 92.68% idle{idle: cpu4}
  11 root     155 ki31     0K    64K CPU3    3 334.9H 92.58% idle{idle: cpu3}
  11 root     155 ki31     0K    64K CPU7    7 337.4H 90.28% idle{idle: cpu7}
  11 root     155 ki31     0K    64K CPU1    1 334.8H 88.67% idle{idle: cpu1}
  11 root     155 ki31     0K    64K RUN     5 336.0H 88.57% idle{idle: cpu5}
  11 root     155 ki31     0K    64K CPU0    0 246.5H 48.29% idle{idle: cpu0}
  12 root     -92    -     0K   376K WAIT    0  88.4H 46.39% intr{irq256: igb0:que}
  12 root     -92    -     0K   376K WAIT    1  17.0H 12.89% intr{irq265: igb1:que}
  12 root     -92    -     0K   376K WAIT    7 856:53  9.96% intr{irq271: igb1:que}
  12 root     -92    -     0K   376K WAIT    6 874:20  9.28% intr{irq270: igb1:que}
  12 root     -92    -     0K   376K WAIT    4 877:00  8.79% intr{irq268: igb1:que}
  12 root     -92    -     0K   376K WAIT    5 882:08  8.15% intr{irq269: igb1:que}
  12 root     -92    -     0K   376K WAIT    3 885:17  7.76% intr{irq267: igb1:que}
  12 root     -92    -     0K   376K WAIT    2  17.3H  7.28% intr{irq266: igb1:que}
  12 root     -92    -     0K   376K WAIT    0 861:42  6.69% intr{irq272: igb1:que}
1015 root      25    0 15064K  5756K select  3 696:52  5.66% snmpd
1006 root      21    0   183M 44520K select  3 313:18  1.17% mpd5{mpd5}
   0 root     -92    0     0K   232K -       2 152:27  0.68% kernel{igb0 que}
  15 root     -16    -     0K     8K -       5  61:02  0.00% yarrow
 888 root      20    0  9612K  1132K select  4  54:24  0.00% syslogd
   0 root     -92    0     0K   232K -       4  49:26  0.00% kernel{igb1 que}
   2 root     -16    -     0K     8K pftm    2  36:12  0.00% pfpurge
  13 root     -16    -     0K    64K sleep   2  25:43  0.00% ng_queue{ng_queue7}
  13 root     -16    -     0K    64K sleep   4  25:42  0.00% ng_queue{ng_queue1}
  13 root     -16    -     0K    64K sleep   2  25:41  0.00% ng_queue{ng_queue5}
  13 root     -16    -     0K    64K sleep   2  25:41  0.00% ng_queue{ng_queue6}
  13 root     -16    -     0K    64K sleep   2  25:41  0.00% ng_queue{ng_queue2}
vpn122# netstat -w1 -h
           input        (Total)           output
  packets  errs idrops      bytes    packets  errs      bytes colls
     104k     0     0        71M       113k     0       107M     0
     107k     0     0        74M       115k     0       111M     0
     102k     0     0        71M       109k     0       105M     0
     107k     0     0        74M       117k     0       114M     0
     103k     0     0        69M       111k     0       104M     0
     107k     0     0        73M       115k     0       109M     0
     105k     0     0        71M       112k     0       105M     0
Edited by roysbike
Какой трафик ходит?
Оформляйте PR
Зачем? У человека вполне может быть pppoe брас. А в таком случае:
  • Смотрим datasheet на карту: http://download.intel.com/design/network/datashts/82576_Datasheet.pdf
    Для распределения пакетов по очередям карта использует спецификацию Microsoft Receive-Side Scaling (RSS) и даташит ссылается на неё на странице 274, упоминая реализованную хеш-функцию, которая реализована в чипе аппаратно и результат которой определяет, какой вектор прерывания будет использован для пакета.
  • Смотрим спецификацию RSS от Microsoft: http://download.microsoft.com/download/5/d/6/5d6eaf2b-7ddf-476b-93dc-7cf0072878e6/ndis_rss.doc
    На странице 7 спецификации сказано, от чего может считаться хеш: от IP-адресов (IPv4 или IPv6) и, опционально, портов TCP (но не UDP). Номера тегов 802.1q не используются. На странице 9 сказано, что если пакет не имеет указанных параметров, от которых брать хеш, то он не хешируется.
  • На практике это означает, что все фреймы PPPoE/GRE, приходящие через пучок vlan-ов и карты igb, попадают в одну "очередь" внутри карты и обслуживаются одним вектором прерываний и никакого распределения нагрузки по ядрам не получается.
  • Как следствие, драйвер igb назначает им всем одинаковый (нулевой) "номер потока".
http://dadv.livejournal.com/139170.html
Edited by lagman
Какой трафик ходит?
Оформляйте PR
делал все по статье. У меня брас pppoe+ pptp. Картина таже. Вот картина на втором сервере. igb0 оин тред так же нахально использует CPU0
last pid: 86311;  load averages:  0.85,  0.84,  0.83        up 15+10:06:18  15:08:24
148 processes: 9 running, 92 sleeping, 47 waiting
CPU 0:  0.0% user,  0.0% nice,  0.0% system, 34.8% interrupt, 65.2% idle
CPU 1:  0.0% user,  0.0% nice,  0.0% system,  8.7% interrupt, 91.3% idle
CPU 2:  0.0% user,  0.0% nice,  8.7% system,  0.0% interrupt, 91.3% idle
CPU 3:  0.0% user,  0.0% nice,  0.0% system,  4.3% interrupt, 95.7% idle
CPU 4:  0.0% user,  0.0% nice,  0.0% system,  0.0% interrupt,  100% idle
CPU 5:  0.0% user,  0.0% nice,  0.0% system,  4.3% interrupt, 95.7% idle
CPU 6:  0.0% user,  0.0% nice,  0.0% system,  4.3% interrupt, 95.7% idle
CPU 7:  0.0% user,  0.0% nice,  0.0% system,  4.3% interrupt, 95.7% idle
Mem: 84M Active, 3115M Inact, 447M Wired, 63M Cache, 112M Buf, 80M Free
  11 root     155 ki31     0K    64K CPU5    5 351.1H 100.00% idle{idle: cpu5}
  11 root     155 ki31     0K    64K CPU4    4 348.8H 99.85% idle{idle: cpu4}
  11 root     155 ki31     0K    64K CPU3    3 350.1H 99.17% idle{idle: cpu3}
  11 root     155 ki31     0K    64K CPU6    6 352.0H 97.66% idle{idle: cpu6}
  11 root     155 ki31     0K    64K CPU7    7 352.8H 95.36% idle{idle: cpu7}
  11 root     155 ki31     0K    64K CPU1    1 349.8H 95.07% idle{idle: cpu1}
  11 root     155 ki31     0K    64K CPU2    2 346.3H 92.97% idle{idle: cpu2}
  11 root     155 ki31     0K    64K RUN     0 258.8H 67.09% idle{idle: cpu0}
  12 root     -92    -     0K   376K WAIT    0  91.4H 29.30% intr{irq256: igb0:que}
  12 root     -92    -     0K   376K WAIT    1  17.8H  7.37% intr{irq265: igb1:que}
  12 root     -92    -     0K   376K WAIT    6 902:38  5.18% intr{irq270: igb1:que}
  12 root     -92    -     0K   376K WAIT    3 912:32  4.59% intr{irq267: igb1:que}
1015 root      23    0 15064K  5820K select  1 729:58  4.59% snmpd
  12 root     -92    -     0K   376K WAIT    7 883:19  3.76% intr{irq271: igb1:que}
  12 root     -92    -     0K   376K WAIT    0 888:44  3.66% intr{irq272: igb1:que}
  12 root     -92    -     0K   376K WAIT    5 921:39  3.47% intr{irq269: igb1:que}
  12 root     -92    -     0K   376K WAIT    2  17.7H  3.37% intr{irq266: igb1:que}
  12 root     -92    -     0K   376K WAIT    4 903:39  3.17% intr{irq268: igb1:que}
1006 root      21    0   171M 44992K select  2 328:30  0.98% mpd5{mpd5}
   0 root     -92    0     0K   232K -       2 157:04  0.00% kernel{igb0 que}
  15 root     -16    -     0K     8K -       4  63:47  0.00% yarrow
 888 root      20    0  9612K  1136K select  4  57:21  0.00% syslogd
   0 root     -92    0     0K   232K -       4  50:10  0.00% kernel{igb1 que}
   2 root     -16    -     0K     8K pftm    2  37:26  0.00% pfpurge
  13 root     -16    -     0K    64K sleep   1  26:21  0.00% ng_queue{ng_queue7}
  13 root     -16    -     0K    64K sleep   2  26:20  0.00% ng_queue{ng_queue1}
  13 root     -16    -     0K    64K sleep   0  26:19  0.00% ng_queue{ng_queue5}
  13 root     -16    -     0K    64K sleep   2  26:19  0.00% ng_queue{ng_queue6}
  13 root     -16    -     0K    64K sleep   0  26:19  0.00% ng_queue{ng_queue2}
  13 root     -16    -     0K    64K sleep   0  26:19  0.00% ng_queue{ng_queue3}
  13 root     -16    -     0K    64K sleep   0  26:18  0.00% ng_queue{ng_queue0}
  13 root     -16    -     0K    64K sleep   2  26:18  0.00% ng_queue{ng_queue4}
  12 root     -60    -     0K   376K WAIT    0  24:43  0.00% intr{swi4: clock}
Edited by roysbike
Дык написали же, PPPoE не распараллеливается драйвером. Все pppoe клиенты висят у вас на 1 ядре, pptp - размазаны по разным.
и что же делать? нет совсем решений? если только купить 4 портовую и с агрегировать с коммутатором?
Можно и без агрегации 4 порта завести в один сегмент и вынудить мпд на них слушать.
Либо net.isr.direct=0 и параллелить через несколько isr :)
Edited by lagman
если 8 ядер ,значит 8 портов:) Завтра попробую через isr, ночью ребут.
с net.isr. облом. в freebsd 9.0 уже устарела. Так что, все у кого MPD5 PPPoE Брасы, на одном ядре вертят?
http://www.opennet.ru/openforum/vsluhforumID1/92848.html ?
vpn119# sysctl net.isr.direct_dispatch=direct
sysctl: unknown oid 'net.isr.direct_dispatch'
vpn119# sysctl net.isr.direct_dispatch=hybrid
vpn119# sysctl net.isr.direct_dispatch=deferred
vpn119# uname -a
FreeBSD vpn119.1111ru 9.0-STABLE FreeBSD 9.0-STABLE #0 r231963: Tue Feb 21 13:08:33 KRAT 2012     root@vpn119.elf.ru:/usr/obj/usr/src/sys/GENERIC.custom  i386
vpn119#
Может я плохо прочитал статейку. Но в sysctl нет таких oid
Edited by roysbike
В релизе все есть:
vps1# sysctl net.isr
net.isr.numthreads: 1
net.isr.maxprot: 16
net.isr.defaultqlimit: 256
net.isr.maxqlimit: 10240
net.isr.bindthreads: 0
net.isr.maxthreads: 1
net.isr.direct: 1
net.isr.direct_force: 1
net.isr.dispatch: direct
vps1# uname -r
9.0-RELEASE
В релизе все есть:
net.isr.maxprot: 16
net.isr.direct: 1
vps1# uname -r
9.0-RELEASE
динамически не изменить? только в loader.conf?
В релизе все есть:
net.isr.maxprot: 16
net.isr.direct: 1
vps1# uname -r
9.0-RELEASE
я лапать) все работает) спасибо) Кака измменить net.isr.numthreads: 1 ? на 8 тредов
Edited by roysbike
net.isr.bindthreads надо потыкать еще
это уже завтра. Ночью ребутну.
Картина не изменилась. также igb0 жрет cpu0.
net.isr.numthreads: 8
net.isr.maxprot: 16
net.isr.defaultqlimit: 4096
net.isr.maxthreads: 8
net.isr.direct: 1
net.isr.direct_force: 0
net.isr.dispatch: hybrid
last pid:  2406;  load averages:  0.57,  0.61,  0.43        up 0+00:26:57  12:04:49
168 processes: 12 running, 108 sleeping, 48 waiting
CPU 0:  0.0% user,  0.0% nice,  3.1% system,  9.8% interrupt, 87.0% idle
CPU 1:  0.8% user,  0.0% nice,  3.1% system,  2.8% interrupt, 93.3% idle
CPU 2:  0.4% user,  0.0% nice,  4.7% system,  3.5% interrupt, 91.3% idle
CPU 3:  0.0% user,  0.0% nice,  2.0% system,  3.9% interrupt, 94.1% idle
CPU 4:  1.2% user,  0.0% nice,  1.6% system,  3.5% interrupt, 93.7% idle
CPU 5:  0.8% user,  0.0% nice,  2.4% system,  3.1% interrupt, 93.7% idle
CPU 6:  0.0% user,  0.0% nice,  1.6% system,  1.6% interrupt, 96.9% idle
CPU 7:  0.0% user,  0.0% nice,  0.0% system, 29.1% interrupt, 70.9% idle
Mem: 18M Active, 32M Inact, 275M Wired, 88K Cache, 32M Buf, 3302M Free
Swap: 4096M Total, 4096M Free
  11 root     155 ki31     0K    64K CPU6    6  26:30 100.00% idle{idle: cpu6}
  11 root     155 ki31     0K    64K CPU1    1  26:09 100.00% idle{idle: cpu1}
  11 root     155 ki31     0K    64K CPU4    4  26:00 100.00% idle{idle: cpu4}
  11 root     155 ki31     0K    64K RUN     5  26:19 97.46% idle{idle: cpu5}
  11 root     155 ki31     0K    64K CPU2    2  25:40 96.19% idle{idle: cpu2}
  11 root     155 ki31     0K    64K CPU3    3  26:08 94.97% idle{idle: cpu3}
  11 root     155 ki31     0K    64K RUN     0  24:53 92.09% idle{idle: cpu0}
  11 root     155 ki31     0K    64K CPU7    7  23:18 81.79% idle{idle: cpu7}
  12 root     -92    -     0K   392K WAIT    0   1:19  7.08% intr{irq256: igb0:que}
  12 root     -72    -     0K   392K WAIT    7   0:33  4.39% intr{swi1: netisr 2}
  12 root     -72    -     0K   392K WAIT    4   0:38  3.56% intr{swi1: netisr 0}
  12 root     -72    -     0K   392K WAIT    7   0:32  3.08% intr{swi1: netisr 7}
  12 root     -72    -     0K   392K WAIT    7   0:29  2.59% intr{swi1: netisr 3}
  12 root     -72    -     0K   392K CPU7    7   0:28  2.49% intr{swi1: netisr 4}
  12 root     -72    -     0K   392K WAIT    7   0:28  2.39% intr{swi1: netisr 1}
  12 root     -72    -     0K   392K WAIT    7   0:24  2.29% intr{swi1: netisr 6}
  12 root     -72    -     0K   392K WAIT    7   0:28  1.86% intr{swi1: netisr 5}
  13 root     -16    -     0K    64K sleep   2   0:14  1.27% ng_queue{ng_queue2}
  13 root     -16    -     0K    64K sleep   5   0:14  1.17% ng_queue{ng_queue6}
  13 root     -16    -     0K    64K RUN     5   0:14  1.17% ng_queue{ng_queue0}
  13 root     -16    -     0K    64K sleep   1   0:14  1.07% ng_queue{ng_queue5}
  13 root     -16    -     0K    64K sleep   5   0:14  0.98% ng_queue{ng_queue3}
  13 root     -16    -     0K    64K CPU0    0   0:14  0.98% ng_queue{ng_queue7}
  13 root     -16    -     0K    64K sleep   1   0:14  0.88% ng_queue{ng_queue4}
  13 root     -16    -     0K    64K sleep   2   0:14  0.78% ng_queue{ng_queue1}
  12 root     -92    -     0K   392K WAIT    7   0:08  0.78% intr{irq263: igb0:que}
  12 root     -92    -     0K   392K WAIT    1   0:11  0.68% intr{irq265: igb1:que}
  12 root     -92    -     0K   392K WAIT    2   0:06  0.49% intr{irq258: igb0:que}
  12 root     -92    -     0K   392K WAIT    3   0:05  0.49% intr{irq267: igb1:que}
  12 root     -92    -     0K   392K WAIT    1   0:05  0.49% intr{irq257: igb0:que}
  12 root     -92    -     0K   392K WAIT    5   0:08  0.39% intr{irq261: igb0:que}
1034 root      21    0 15200K  6352K select  1   0:09  0.29% snmpd
  12 root     -92    -     0K   392K WAIT    6   0:06  0.29% intr{irq262: igb0:que}
  12 root     -92    -     0K   392K WAIT    6   0:05  0.29% intr{irq270: igb1:que}
  12 root     -92    -     0K   392K WAIT    0   0:05  0.29% intr{irq272: igb1:que}
  12 root     -92    -     0K   392K WAIT    4   0:04  0.29% intr{irq260: igb0:que}
  12 root     -92    -     0K   392K WAIT    5   0:05  0.20% intr{irq269: igb1:que}
1025 root      21    0   141M 31720K select  2   0:15  0.10% mpd5{mpd5}
  12 root     -92    -     0K   392K WAIT    3   0:06  0.10% intr{irq259: igb0:que}
  12 root     -92    -     0K   392K WAIT    2   0:05  0.10% intr{irq266: igb1:que}
  12 root     -92    -     0K   392K WAIT    4   0:05  0.10% intr{irq268: igb1:que}
Device igb1~P�� (4/448):
Incoming:
        ###  Curr: 155.92 MBit/s
        ###  Avg: 164.92 MBit/s
        ###  Min: 151.97 MBit/s
        ###  Max: 179.89 MBit/s
        ###  Ttl: 2.17 GByte
Outgoing:
        ###  Curr: 24.99 MBit/s
        ###  Avg: 23.19 MBit/s
        ###  Min: 20.64 MBit/s
        ###  Max: 26.32 MBit/s
        ###  Ttl: 2.45 GByte
Edited by roysbike
Почти все netisr на 7-м ядре, неудивительно.
Надо прибивать гвоздями. тогда должно стать ок.
и спадет загрузка с
12 root     -92    -     0K   392K WAIT    0   1:38  9.38% intr{irq256: igb0:que}
напомню. У меня PPPoE bras. freebsd 9.0 mpd5.6 pf nat. сетевука Intel 82576 2- портовая. Один порт в EXT , на другом pppoe слушает.
9.38% intr{irq256: igb0:que} это жж эксплуатационные расходы по выгребанию в очереди. Параллелиться будет уже в netisr-ах.
получается , что все учереди прут на cpu0? а есть возможность распараллелить ?
Edited by roysbike
