31337Ghost Posted February 20, 2012 Posted February 20, 2012 На свиче конфиг такой: SNR-S2950-24G#sh running-config ! no service password-encryption ! hostname SNR-S2950-24G sysLocation Ak.Vonsovskogo str. 1-118, Ekaterinburg, Russia sysContact support@nag.ru ! username admin privilege 15 password 0 admin ! ! ! web language english ! service dhcp ! ip forward-protocol udp bootps ip dhcp relay share-vlan 101 sub-vlan 1 ! ip dhcp snooping enable ip dhcp snooping vlan 1 ip dhcp snooping binding enable ! ip dhcp snooping information enable ip dhcp snooping information option subscriber-id format hex ip dhcp snooping broadcast suppress ! ! ! ! ! ! sflow version 0 ! ! vlan 1 ! vlan 101 name management ! Interface Ethernet1/1 ! Interface Ethernet1/2 ! Interface Ethernet1/3 ! Interface Ethernet1/4 ! Interface Ethernet1/5 ! Interface Ethernet1/6 ! Interface Ethernet1/7 ! Interface Ethernet1/8 ! Interface Ethernet1/9 ! Interface Ethernet1/10 ! Interface Ethernet1/11 ! Interface Ethernet1/12 ! Interface Ethernet1/13 ! Interface Ethernet1/14 ! Interface Ethernet1/15 ! Interface Ethernet1/16 ! Interface Ethernet1/17 ! Interface Ethernet1/18 ! Interface Ethernet1/19 ! Interface Ethernet1/20 ! Interface Ethernet1/21 ! Interface Ethernet1/22 ! Interface Ethernet1/23 ! Interface Ethernet1/24 ! Interface Ethernet1/25 ! Interface Ethernet1/26 description Uplink switchport mode trunk ! interface Vlan101 description management ip address 10.35.255.13 255.255.255.0 !forward protocol udp 67(active)! ip helper-address 192.168.0.100 ! ip default-gateway 10.35.255.1 ! ! no login ! ! end 192.168.0.100 это DHCP-сервер Клиент подключен в первый порт и пытается получить IP-адрес 10.36.5.10, но не получает. В логах сервера следующие: Feb 20 18:22:32 billing dhcpd: DHCPDISCOVER from 00:26:22:a4:81:16 via 10.35.255.13 Feb 20 18:22:32 billing dhcpd: DHCPOFFER on 10.36.5.10 to 00:26:22:a4:81:16 via 10.35.255.13 Свич пишет следующее: SNR-S2950-24G#sh ip dhcp snooping interface ethernet 1/1 interface Ethernet1/1 user config: trust attribute: untrust action: none binding dot1x: disabled binding user: disabled recovery interval:0(s) Driver user number 0 : Max user number 1024 Alarm info: 0 Binding info: 0 Static Binding info: 0 Static Binding info from shell: 0 Static Binding info from server: 0 flag: D - Dynamic ; U - already upload server ; S - static binding info from shell; R - static binding info from server; O - dhcp ack has option82; X - notify dot1x ok; L - notify driver ok; E - notify dot1x error P - binding protect; Expired Binding: 0 Request Binding: 1 -------------------------------------------------------- DHCP Snooping Binding built at SUN JAN 01 00:03:02 2006 Time Stamp: 187 Ref Count: 1 VID 1, Port: Ethernet1/1 Client MAC: 00-26-22-a4-81-16 Client IP: 0.0.0.0 0.0.0.0 Gateway: 0.0.0.0 Lease: 30(s) Flag: 0 Т.е. сервер получает запрос, отправляет ответ, а свич его игнорирует. Что я не так настроил? Вставить ник Quote
tunny Posted February 21, 2012 Posted February 21, 2012 а через 10.35.255.1 dhcp-ответ проходит? Вставить ник Quote
tunny Posted February 21, 2012 Posted February 21, 2012 ip dhcp snooping trust нету Вставить ник Quote
31337Ghost Posted February 21, 2012 Author Posted February 21, 2012 а через 10.35.255.1 dhcp-ответ проходит? Сниффером не проверял, но проходить должен 10.35.255.1 - это обычный L3, длинки через него замечательно работают. И tcpdump на сервере показыает фактическую отправку пакетов. ip dhcp snooping trust На 26 порту - аплинке? Почему-то мне козалось, что данная опция влияет на Opt82. Видимо это заблуждение, которое взялось не пойми откуда. Спасибо. Попробую. Вставить ник Quote
31337Ghost Posted February 21, 2012 Author Posted February 21, 2012 Попробовал прописать - не заработало. У меня в качестве сервера isc-dhcp, заметил интересный момент, что пакеты, которые он отправляет в ответ - с нулевой контрольной суммой (смотрел по выводу tcpdump). Следовательно возможно, что данный свич может их отбрасывать, как "битые". Господа, у кого работает данный функционал этих комутаторов в связке с isc-dhcp, можете посмотреть есть ли косяк с нулевой контрольной суммой пакетов, отправляемых в ответ сервером? Вставить ник Quote
s.lobanov Posted February 21, 2012 Posted February 21, 2012 Попробовал прописать - не заработало. У меня в качестве сервера isc-dhcp, заметил интересный момент, что пакеты, которые он отправляет в ответ - с нулевой контрольной суммой (смотрел по выводу tcpdump). Следовательно возможно, что данный свич может их отбрасывать, как "битые". Господа, у кого работает данный функционал этих комутаторов в связке с isc-dhcp, можете посмотреть есть ли косяк с нулевой контрольной суммой пакетов, отправляемых в ответ сервером? Контрольная сумма == 0 на 3ем или 4ом уровне? Если на третьем, то это нормально, просто она считается сетевой картой и tcpdump видет 0. Если на 4ом, то да, некоторые свитчи дропают такие pdu. Вставить ник Quote
31337Ghost Posted February 21, 2012 Author Posted February 21, 2012 Т.е. надо отснифать этот пакет за сетевой картой сервера и поглядеть на него? Вставить ник Quote
passer Posted March 23, 2012 Posted March 23, 2012 Учитывая, что на свитче строится dhcp relay - добавить команды ip dhcp relay information option ip dhcp relay information option subscriber-id format hex и убедиться что 192.168.0.100 знает где искать 10.35.255.13 (ошибка весьма распространена) Вставить ник Quote
f.dorokhov Posted April 10, 2013 Posted April 10, 2013 Вопрос к автору темы. Нельзя ли написать решение этой проблемы, я так понимаю она разрешилась. Вставить ник Quote
