Есть два коммутатора Cisco 3560.
Соединены по соточному медному порту.
Состояние ошибок на порту
SW1#sh int fa0/16 counters errors
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize OutDiscards
Fa0/16 0 0 0 0 0 3572597656
Port Single-Col Multi-Col Late-Col Excess-Col Carri-Sen Runts Giants
Fa0/16 0 0 0 0 0 0 0
SW2#sh int fa0/1 counters errors
Fa0/1 0 0 0 0 0 0
Fa0/1 0 0 0 0 0 0 0
Во второй коммутатор подключены сервера с ПО QNET
Потерь пакетов нет. Порты работают на 100Мбит дуплекс. Пинг не теряется.
На портах серверов тоже ничего криминального.
А вот приложения QNET регулярно отваливаются на 3-5 секунд.
Вот еще с первого коммутатора.
SW1#sh mls qos
QoS is disabled
FastEthernet0/16 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0026.989c.cc92 (bia 0026.989c.cc92)
Description: XXXXXX
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3572597656
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 14000 bits/sec, 24 packets/sec
5 minute output rate 728000 bits/sec, 1159 packets/sec
1142655771 packets input, 317509875218 bytes, 0 no buffer
Received 25771462 broadcasts (8121381 multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 8121381 multicast, 0 pause input
0 input packets with dribble condition detected
18991950750 packets output, 1533769445730 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 PAUSE output
0 output buffer failures, 0 output buffers swapped out
Transmit FastEthernet0/16 Receive
466141684 Bytes 3977262970 Bytes
2028296657 Unicast frames 1116884314 Unicast frames
862864970 Multicast frames 8121381 Multicast frames
3215887490 Broadcast frames 17650081 Broadcast frames
0 Too old frames 383389970 Unicast bytes
0 Deferred frames 1005355007 Multicast bytes
0 MTU exceeded frames 2723337795 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 0 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 13745742 Minimum size frames
0 8 collision frames 882959464 65 to 127 byte frames
0 9 collision frames 64430057 128 to 255 byte frames
0 10 collision frames 11849453 256 to 511 byte frames
0 11 collision frames 30084862 512 to 1023 byte frames
0 12 collision frames 70050428 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 69535770 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
2010397259 64 byte frames 0 Valid frames, too small
3327965299 127 byte frames
520310640 255 byte frames 0 Too old frames
99917456 511 byte frames 0 Valid oversize frames
119493509 1023 byte frames 0 System FCS error frames
18514274 1518 byte frames 0 RxPortFifoFull drop frame
10450680 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
SW1#sh platform port-asic stats drop fa0/16
Interface Fa0/16 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 3572597656
Боремся с загадкой толи сервера глючат то ли коммутатор.
наблюдали проблему у клиента, почему-то на пакетах с сервера стоял запрет на дефрагментацию, в результате часть терялась...
