Здравствуйте!
Так уж случилось что через год мне придётся защищать дипломную работу, тема работы - "Wireless Simulator"
За основу взят документ: http://standards.ieee.org/getieee802/download/802.11-2007.pdf
Сейчас я закончил стадию кодирования, сделал всё точь-в-точь как описано в параграфе 17.3.5.5 Convolutional encoder
The DATA field, composed of SERVICE, PSDU, tail, and pad parts, shall be coded with a convolutional
encoder of coding rate R = 1/2, 2/3, or 3/4, corresponding to the desired data rate. The convolutional encoder
shall use the industry-standard generator polynomials, g0 = 1338 and g1 = 1718, of rate R = 1/2, as shown in
Figure 17-8. The bit denoted as “A” shall be output from the encoder before the bit denoted as “B.” Higher
rates are derived from it by employing “puncturing.” Puncturing is a procedure for omitting some of the
encoded bits in the transmitter (thus reducing the number of transmitted bits and increasing the coding rate)
and inserting a dummy “zero” metric into the convolutional decoder on the receive side in place of the
omitted bits. The puncturing patterns are illustrated in Figure 17-9. Decoding by the Viterbi algorithm is
recommended.
На вход кодирующей функции поступает такая последовательность:
101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010
[syntax lang=c]W8 * WSDecodeBits(W8 *bitSeq)
W8 *buf;
W8 reg[] = "1111111";
W8 g1[] = "1011011";
W8 g2[] = "1111001";
W16 i, j = 0;
W16 curBit;
W16 res;
buf = (W8*)malloc(WS_RAW_MSG_SIZE * 2);
if ( NULL == buf )
WSFailureReport_m(OUT_OF_MEMORY);
for (i=0; i<WS_RAW_MSG_SIZE; i++)
curBit = bitSeq-'0';
(void)WSbitDisplase(curBit, (char**)reg);
(void)WSxor(reg, g1, &res);
if (res)
buf[j++] = (char)'1';
else
buf[j++] = (char)'0';
(void)WSxor(reg, g2, &res);
if (res)
buf[j++] = '1';
else
buf[j++] = '0';
buf[WS_RAW_MSG_SIZE * 2] = '\0';
return buf;
}[/syntax]
В итоге на выходе мы имеем:
110010110111110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100
Всё вроде бы хорошо, и замечательно. Было.... пока я не захотел реализовать декодер(Витерби - судя по документации)
Перерыл кучу сайтов, кучу форумов, самый адекватный код видел на сайте http://www.eccpage.com/ Но после пары дней безуспешных попыток к декодированию пришёл к выводу что он байт-ориентированный.. У меня же лимитируется процесс передачи бит. Задачка как мне до сих пор кажется вполне решаемая и не сложная. Но вот охота послушать ваши мнения. Как стоит написать код для декодирования, если такой уже существует пожалуйста делитесь, если есть какая-либо литература по этому вопросу(кроме Скляра) делитесь тоже. Интересует именно программная реализация, как работает в теории ясно.
Дополнение:
Функция: WSbitDisplase
[syntax lang=c]W16 WSbitDisplase(W16 b, W8 **reg)
int i;
for(i=6;i>0;i--)
*((char*)reg+i) = *((char*)reg+i-1);
*((char*)reg) = (char)b + 48;
return 0;
}[/syntax]
Функция: WSxor
[syntax lang=c]int WSxor(char *a, char *mask, int *res)
int i, tmp;
tmp = 0;
for(i=0;i<7;i++)
if (*(mask+i) == (char)'1')
tmp += *(a+i) - '0';
if ( !(tmp%2) )
*res = 0;
else
*res = 1;
return 0;
}[/syntax]
однако для начала неплохо было бы поучить язык С? На котором Вы типа пишете... а уже потом что-то реализовывать. Для реализации обычно достаточно стандарта. Кодер/декодер работает с символьной последовательностью и обычно реализуется аппаратно или на DSP. Если же нужна C-model, есть такая штука - TTCN, сгенерирует что угодно. Ну исходники ей генереные для диплома врядле прокатят :) но проверить работоспособность своего кода по ним можно. Оно как раз для этого.
Спасибо за ответ,
Для начала хотелось бы спросить, что по вашему мнению мне понадобится от СИ что я по вашему мнению не знаю, с удовольствием подучу.
Второй вопрос, в стандартах вроде бы не описывается процесс декодирования... или я что-то путаю?
И третий, TTCN может сгенерировать С-код?
Что Вам понадобится от Си - это я не знаю, но либо займитесь все же изучением, как на нем писать либо пишите на чем-то другом. Знание синтаксиса языка и умение писать на нем ~ знание как в шахматах ходят фигуры и умение играть.
Декодер надо писать красиво и так, чтобы код был нормально читабелен. Тогда возможно появятся конструкции типа
 if ( buf = malloc(sizeof(W8)*SIZE...) ) { ... }
, и указатель на локальную область памяти не будет возвращаться через стек.
http://ieng9.ucsd.edu/~chc019/publication/IEEETWC2006.pdf и там в конце есть список литературы.
C-model - это есть описание процесса на языке С. Для этого TTCN и придуман.
