Есть две цыски 3550 с 24 оптическими портами 100М
и 2950 с двумя оптическими портами 100М
Подключены друг к другу напрямую
На 3550 задействован порт № 5 (FX) вот его статистика:
FastEthernet0/5 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 000d.28ea.b705 (bia 000d.28ea.b705)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 100BaseFX
input flow-control is off, output flow-control is unsupported
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:12, output 00:00:00, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 160000 bits/sec, 47 packets/sec
30 second output rate 223000 bits/sec, 275 packets/sec
650855479 packets input, 4155905165 bytes, 0 no buffer
Received 1602129 broadcasts (0 multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 440580 multicast, 0 pause input
0 input packets with dribble condition detected
2194919939 packets output, 1160960308 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 PAUSE output
0 output buffer failures, 0 output buffers swapped out
Как видно всё ок, ошибок нет
А вот на 2950 другая картина:
FastEthernet0/26 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0005.dcd4.099a (bia 0005.dcd4.099a)
input flow-control is unsupported output flow-control is unsupported
Last input 00:00:00, output 00:00:09, output hang never
5 minute input rate 328000 bits/sec, 259 packets/sec
5 minute output rate 462000 bits/sec, 73 packets/sec
701313519 packets input, 585754451 bytes, 55371228 no buffer
Received 321231257 broadcasts (282120209 multicast)
0 input errors, 0 CRC, 0 frame, 0 overrun, 55371228 ignored
0 watchdog, 282120207 multicast, 0 pause input
368650295 packets output, 1111512760 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
Как видно есть много ноу буффер и игноред пакетов, собственно вопрос в чём может быть дело?
Заранее спасибо.
Заранее спасибо.
собственно несравнимые вещи приведены и Last clearing of "show interface" counters never
смущает. Почистите счетчики и снова посмотрите
А куда оно дальше форвардит пакеты? Не в 10и мегабитные ли порты? или перегруженные, или half-duplex, или с включенным flow control
Дальше клиентские линки.
Нет 10 мегабитных портов нет. Нет не перегружены.
Халфа тоже не виддно, флоу контрол не данной цыске не поддерживается.
C2950C-24TX-GT33P#sh int status
Port Name Status Vlan Duplex Speed Type
Fa0/1 1 connected 257 a-full a-100 10/100BaseTX
Fa0/2 2 connected 252 a-full a-100 10/100BaseTX
Fa0/3 3 connected 129 a-full a-100 10/100BaseTX
Fa0/4 4 connected 38 a-full a-100 10/100BaseTX
Fa0/5 5 connected 138 a-full a-100 10/100BaseTX
Fa0/6 notconnect 1 auto auto 10/100BaseTX
Fa0/7 notconnect 1 auto auto 10/100BaseTX
Fa0/8 notconnect 1 auto auto 10/100BaseTX
Fa0/9 notconnect 1 auto auto 10/100BaseTX
Fa0/10 notconnect 1 auto auto 10/100BaseTX
Fa0/11 notconnect 1 auto auto 10/100BaseTX
Fa0/12 notconnect 1 auto auto 10/100BaseTX
Fa0/13 notconnect 1 auto auto 10/100BaseTX
Fa0/14 notconnect 1 auto auto 10/100BaseTX
Fa0/15 notconnect 1 auto auto 10/100BaseTX
Fa0/16 notconnect 1 auto auto 10/100BaseTX
Fa0/17 notconnect 1 auto auto 10/100BaseTX
Fa0/18 notconnect 1 auto auto 10/100BaseTX
Fa0/19 notconnect 1 auto auto 10/100BaseTX
Fa0/20 notconnect 1 auto auto 10/100BaseTX
Fa0/21 notconnect 1 auto auto 10/100BaseTX
Fa0/22 notconnect 1 auto auto 10/100BaseTX
Fa0/23 notconnect 1 auto auto 10/100BaseTX
Fa0/24 XX connected 5 a-full a-100 10/100BaseTX
Fa0/25 XX connected 153 full 100 100BaseFX
Fa0/26 TRUNK TO CORE connected trunk full 100 100BaseFX
Сделал клеар, завтра видно будет новый результат.
Edited by catalist
а как обстоят дела с настройками vlan. не уверен, что возможно неразрешенные vlan пакеты дропаются и попадают в этот счетчик.
