нужна помощь Проблема Большой Ping до сервера
дро dpkg -l | grep linux-image
ii linux-image-2.6-amd64 2.6.32+29 Linux 2.6 for 64-bit PCs (meta-package)
ii linux-image-2.6.32-5-amd64 2.6.32-38 Linux 2.6.32 for 64-bit PCs
ii linux-image-2.6.32-5-xen-amd64 2.6.32-35 Linux 2.6.32 for 64-bit PCs, Xen dom0 support
# ethtool -i peth0
driver: e1000e
version: 1.0.2-k2
firmware-version: 0.10-2
bus-info: 0000:00:19.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
ethtool peth0
Settings for peth0:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: Not reported
Advertised pause frame use: No
Advertised auto-negotiation: No
Speed: 10Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: off
MDI-X: on
Supports Wake-on: pumbag
Wake-on: g
Current message level: 0x00000001 (1)
drv
Link detected: yes
ethtool -S peth0
NIC statistics:
rx_packets: 39035247
tx_packets: 61974367
rx_bytes: 4103323249
tx_bytes: 88611677952
rx_broadcast: 532433
tx_broadcast: 5207
rx_multicast: 602622
tx_multicast: 105088
rx_errors: 0
tx_errors: 170554
tx_dropped: 0
multicast: 602622
collisions: 361245
rx_length_errors: 0
rx_over_errors: 0
rx_crc_errors: 0
rx_frame_errors: 0
rx_no_buffer_count: 2
rx_missed_errors: 1011
tx_aborted_errors: 0
tx_carrier_errors: 0
tx_fifo_errors: 0
tx_heartbeat_errors: 0
tx_window_errors: 170554
tx_abort_late_coll: 170554
tx_deferred_ok: 342437
tx_single_coll_ok: 186091
tx_multi_coll_ok: 1092
tx_timeout_count: 1
tx_restart_queue: 3620400
rx_long_length_errors: 0
rx_short_length_errors: 0
rx_align_errors: 0
tx_tcp_seg_good: 0
tx_tcp_seg_failed: 0
rx_flow_control_xon: 0
rx_flow_control_xoff: 0
tx_flow_control_xon: 0
tx_flow_control_xoff: 0
rx_long_byte_count: 4103323249
rx_csum_offload_good: 38539814
rx_csum_offload_errors: 46
rx_header_split: 0
alloc_rx_buff_failed: 0
tx_smbus: 0
rx_smbus: 0
dropped_smbus: 0
rx_dma_failed: 0
tx_dma_failed: 0
файлы копируются и заливаются на сервер нормально! но пинг скачет . от 30 мсек до 500-600 мсек
10 мегабит стоит потому-то провайдер режет :) ограничением скорости на порту.
Вовремя загрузки сетевуха не видит full dгplex при загрузке. приходится руками выставлять full
от сервера пинг до яндекса пляшет от 3 мсек до 200 мсек.
попробовал увеличить буфер ethtool -G peth0 rx 1024 tx 1024
эффекта не дало ...
что делать ? уговариваю провайдера резать скорость не железно а acl, может, поможет.
может можно что-то сделать на самом сервере?
Сделайте, чтобы collisions: 361245 было 0, похоже с ответной стороны half
счетчик не меняется .. можно считать что 0. с ответной стороны было auto. сейчас стоит full
