В одной сети имеем FTP сервер на Gene6 FTP Server вход клиентов осуществляется по анонимной учетной записи, то есть без логина и пароля, на сетевой карте сервера прописано два IP 192.168.54.200/24 и 10.17.9.200/24 пару дней в логах сервера стал замечать:
11/12/30 02:02:24, 151, 192.168.5.5, , 220 Gene6 FTP Server v3.10.0 (Build 2) ready...
11/12/30 02:02:25, 151, 192.168.5.5, , USER anonymous
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, 331 Password required for anonymous.
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, PASS ****
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, logged in as "Anonymous".
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, 230 User anonymous logged in.
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, CLNT FileZilla
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, 200 Noted.
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, OPTS UTF8 ON
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, 200 UTF8 OPTS ON
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, CWD /Video/Films/Russian films/Otstavnik
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, change directory '/Video/Films/Russian films/Otstavnik' -> 'merge://d:\FTP DATA\Video\Films\Russian films\Otstavnik,e:\Video\Films\Russian films\Otstavnik,f:\Video\Films\Russian films\Otstavnik' --> Access allowed.
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, 250 CWD command successful. "/Video/Films/Russian films/Otstavnik" is current directory.
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, PWD
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, 257 "/Video/Films/Russian films/Otstavnik" is current directory.
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, TYPE I
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, 200 Type set to I.
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, PASV
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, 227 Entering Passive Mode (192,168,54,200,63,50)
11/12/30 02:02:25, 151, 192.168.5.5, anonymous, RETR otstavnik.2011.DivX.SATRip.avi
после чего добавили этот IP в бан и получили это:
11/12/30 04:49:05, 162, 192.168.5.5, , new connection from 192.168.5.5 on 192.168.54.200:21
11/12/30 04:49:09, 162, 192.168.5.5, , sending welcome message.
11/12/30 04:49:09, 162, 192.168.5.5, , 220 Gene6 FTP Server v3.10.0 (Build 2) ready...
11/12/30 04:49:09, 162, 192.168.5.5, , USER anonymous
11/12/30 04:49:09, 162, 192.168.5.5, anonymous, 331 Password required for anonymous.
11/12/30 04:49:09, 162, 192.168.5.5, anonymous, PASS ****
11/12/30 04:49:09, 162, 192.168.5.5, anonymous, login failed.
11/12/30 04:49:12, 162, 192.168.5.5, anonymous, 530 Not logged in, access denied.
11/12/30 04:49:12, 162, 192.168.5.5, anonymous, will be disconnected : IP is banned.
понятно что IP стал блокироваться, не понятно как IP 192.168.5.5 смог приконектится к 192.168.54.200/24 даже если он себе поставил маску 21 и ниже, сервер то имеет 24.
Очевидно через маршрутизатор.
то есть вы хотите сказать плохо отработал NAT? и в логах сервера появилась эта запись, но если у пакета который пришел с маршрутизатора IP 192.168.5.5 то как сервер смог отправить ему пакет, то есть пакет то придти может если клиент у себя поставит маску 21, но вот сервер то куда будет отправлять?
Нет. Я имел ввиду, что есть шлюз, а не НАТ, через который эти сетки маршрутизируются и видят друг друга.
понял, спасибо, как то сразу не уловил, что кто то в сети поставил шлюз на котором смаршрутизировал обе сети. сеть маленькая на мыльницах, не где блокировать все лишнее. значит заблокируем все лишние сети на самом сервере.
По идее Ваш сервер должен тоже знать маршрут в эту сеть. Попробуйте трейсроут сделать и посмотреть куда оно пойдет.
Конечно может и НАТ быть, как частный случай роутинга.
Edited by Hawk128
