ARPING 192.168.1.254
60 bytes from 74:ea:3a:e0:c6:c6 (192.168.1.254): index=0 time=195.026 usec
60 bytes from 00:23:cd:1b:3f:81 (192.168.1.254): index=1 time=1.747 msec
60 bytes from 00:23:cd:1b:3f:81 (192.168.1.254): index=2 time=316.858 usec
60 bytes from 74:ea:3a:e0:c6:c6 (192.168.1.254): index=3 time=377.893 usec
60 bytes from 74:ea:3a:e0:c6:c6 (192.168.1.254): index=4 time=1.155 msec
60 bytes from 00:23:cd:1b:3f:81 (192.168.1.254): index=5 time=1.238 msec
60 bytes from 00:23:cd:1b:3f:81 (192.168.1.254): index=6 time=524.044 usec
60 bytes from 74:ea:3a:e0:c6:c6 (192.168.1.254): index=7 time=207.708 msec
60 bytes from 74:ea:3a:e0:c6:c6 (192.168.1.254): index=8 time=183.105 usec
60 bytes from 00:23:cd:1b:3f:81 (192.168.1.254): index=9 time=356.913 usec
60 bytes from 74:ea:3a:e0:c6:c6 (192.168.1.254): index=10 time=722.885 usec
60 bytes from 00:23:cd:1b:3f:81 (192.168.1.254): index=11 time=794.888 usec
60 bytes from 74:ea:3a:e0:c6:c6 (192.168.1.254): index=12 time=987.053 usec
60 bytes from 00:23:cd:1b:3f:81 (192.168.1.254): index=13 time=1.042 msec
60 bytes from 74:ea:3a:e0:c6:c6 (192.168.1.254): index=14 time=226.974 usec
60 bytes from 00:23:cd:1b:3f:81 (192.168.1.254): index=15 time=283.957 usec
60 bytes from 74:ea:3a:e0:c6:c6 (192.168.1.254): index=16 time=160.933 usec
60 bytes from 00:23:cd:1b:3f:81 (192.168.1.254): index=17 time=287.056 usec
60 bytes from 74:ea:3a:e0:c6:c6 (192.168.1.254): index=18 time=384.808 usec
60 bytes from 00:23:cd:1b:3f:81 (192.168.1.254): index=19 time=440.836 usec
60 bytes from 74:ea:3a:e0:c6:c6 (192.168.1.254): index=20 time=226.021 usec
60 bytes from 00:23:cd:1b:3f:81 (192.168.1.254): index=21 time=277.042 usec
hostname: <unknown>
ip address: 192.168.1.254
interface: eth2
ethernet address: 00:23:cd:1b:3f:81
ethernet vendor: TP-LINK TECHNOLOGIES CO., LTD.
old ethernet address: 74:ea:3a:e0:c6:c6
old ethernet vendor: <unknown>
timestamp: Wednesday, December 28, 2011 20:41:39 +0200
previous timestamp: Wednesday, December 28, 2011 20:41:39 +0200
delta: 0 seconds
На что похоже?
Edited by mrsaygo
На что похоже?
На дублирование адреса в LAN. ACL то походу нет, да и управляемых свитчей тоже.
Дублирование-не уверен .. есть подозрение, что железка тупит.
Свичи почти все управляшки, по поводу ACL - о какого типа ACL Вы говорите?
+ ко всему arpwatch сошел с ума, очень много flip flop о смене мака интерфейса шлюза.
Edited by mrsaygo
О запрете всего, не относящегося к разрешённому IP.
По хорошему - нужен PCF.
Дедовский способ - отключать порты, по очереди и смотреть на каком свистопляска прекратится, дальше - по цепочке.
Тушил все порты кроме аплинка(eth0) на удаленном свиче (DGS-3120-24SC) - не помогло.
Dec 28 21:08:43 gw arpwatch: flip flop 10.0.0.1 b0:48:7a:f1:c7:34 (00:1b:21:5b:98:91) eth0
Dec 28 21:08:43 gw arpwatch: flip flop 10.0.0.1 00:1b:21:5b:98:91 (b0:48:7a:f1:c7:34) eth0
Dec 28 21:08:43 gw arpwatch: flip flop 10.0.0.1 b0:48:7a:f1:c7:34 (00:1b:21:5b:98:91) eth2
Dec 28 21:08:44 gw arpwatch: flip flop 10.0.0.1 00:1b:21:5b:98:91 (b0:48:7a:f1:c7:34) eth0
Dec 28 21:08:44 gw arpwatch: flip flop 10.0.0.1 b0:48:7a:f1:c7:34 (00:1b:21:5b:98:91) eth0
(00:1b:21:5b:98:91) - родной мак eth0 10,0,0,1 - родной IP тазика.
не выяснил.. но не шлюза, и не ранее известных юзеров.
Так как он умудряется приходить на eth2? Надо выяснять, по vendor-у - TP-Link.
Вдогонку, а не мог ли кто-то замутить радио, напрямую с кем-то за пределами внутренней сети, но в пределах ближайшей внешней.
Edited by Deac
Выключить 10.0.0.1 и поарпингать без него ? ответы будут ? прапингать ничьи IP? уж коли сеть управляемая, искать по таблицам коммутаторов источник b0:48:7a:f1:c7:34. Может троян сидеть компрометирующий IP шлюза.
ARPING 10.0.0.1 (напоминаю 10.0.0.1- IP интерфейса прибит к тазику для НАТа)
60 bytes from 00:22:15:9a:f1:28 (10.0.0.1): index=0 time=333.786 usec
60 bytes from 1c:af:f7:ae:33:b1 (10.0.0.1): index=1 time=419.855 usec
64 bytes from 14:da:e9:f9:0b:fa (10.0.0.1): index=2 time=429.869 usec
60 bytes from b0:48:7a:f1:c7:34 (10.0.0.1): index=3 time=438.929 usec
60 bytes from f4:6d:04:8d:4a:e0 (10.0.0.1): index=4 time=447.989 usec
60 bytes from e0:cb:4e:ed:88:d4 (10.0.0.1): index=5 time=467.777 usec
60 bytes from 00:19:db:38:80:54 (10.0.0.1): index=6 time=475.883 usec
60 bytes from 00:26:5a:95:ec:2b (10.0.0.1): index=7 time=483.990 usec
60 bytes from e0:cb:4e:dc:e4:cb (10.0.0.1): index=8 time=491.858 usec
Dec 28 21:35:27 gw arpwatch: flip flop 10.0.0.1 b0:48:7a:f1:c7:34 (00:1b:21:5b:98:91) eth2
Dec 28 21:35:28 gw arpwatch: flip flop 10.0.0.1 00:1b:21:5b:98:91 (b0:48:7a:f1:c7:34) eth0
Dec 28 21:25:02 gw arpwatch: flip flop 10.0.0.1 b0:48:7a:f1:c7:34 (00:1b:21:5b:98:91) eth0
Dec 28 21:25:03 gw arpwatch: flip flop хх.хх.хх.хх 00:1b:21:5b:98:91 (00:1b:21:5b:98:90) eth0
Dec 28 21:25:03 gw arpwatch: flip flop хх.хх.хх.хх 00:1b:21:5b:98:91 (00:1b:21:5b:98:90) eth2
xx.xx.xx.xx - вообще реальный IP, который висит на eth3
10.0.0.1 прыгает с eth2 на eth0..
Как то не похоже на подмену. Есть подозрение на глюки тазика (linux debian), но какие - не пойму :(
Насчет радио.. не очень понял..
Мы всем юзерам ставим 741Д ТП-Линки... были уже у них нюансы, но как то прошло, и другого типа глюки, это новое.
А чего тут понимать, кинули клиенты между собой канальчик, типа для резервирования и устроили петлю.
Да ещё прописали на одной из точек 10.0.0.1, точке то всё равно, в режиме бриджа, а тебе геморрой.
  • 2 weeks later...
Разобрались... кинули добрые люди по ошибке шнурок для IPTV не в тот влан.
И действительно получилась петля, о которой даже мысли не было.
