Сабж.
Не получается настроить звонки между телефонами SCCP и SIP на CCME. Cisco 2921 c2900-universalk9_npe-mz.SPA.151-2.T4.bin
Все телефоны регистрируются, звонки между SCCP проходят нормально, а вот с вот на sip или с sip короткий гудок номера не существует.
грешил на кодеки оставлял только g711alaw g711ulaw проблема сохранялась.
ip dhcp excluded-address 10.200.53.254
ip dhcp pool TEST1
  network 10.200.53.128 255.255.255.128
  dns-server 10.200.53.254
  default-router 10.200.53.254
  option 150 ip 10.200.53.254
  lease 0 0 30
ip domain name yourdomain.com
ip dhcp-server 10.200.53.254
voice-card 0
voice service voip
allow-connections h323 to h323
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
 no call service stop
sip
 registrar server expires max 1800 min 180
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g726r32
codec preference 4 g726r24
codec preference 5 g726r16
codec preference 6 g723r53
codec preference 7 g723ar53
codec preference 8 g723ar63
codec preference 9 g711alaw
codec preference 10 g711ulaw
voice register global
mode cme
source-address 10.200.53.254 port 5060
max-dn 10
max-pool 10
create profile sync 0174222212574026
voice register dn  1
number 305
voice register pool  1
id mac 705A.B659.C126
number 1 dn 1
voice-class codec 1
username 111 password 111
tftp-server flash:locale/tc-sccp.jar alias Russian_Russia/tc-sccp.jar
tftp-server flash:locale/gd-sip.jar alias Russian_Russia/gd-sip.jar
tftp-server flash:locale/mk-sccp.jar alias Russian_Russia/mk-sccp.jar
tftp-server flash:locale/ipc-sccp.jar alias Russian_Russia/ipc-sccp.jar
tftp-server flash:locale/gp-sccp.jar alias Russian_Russia/gp-sccp.jar
tftp-server flash:locale/g3-tones.xml alias Russian_Russia/g3-tones.xml
tftp-server flash:locale/be-sccp.jar alias Russian_Russia/be-sccp.jar
tftp-server flash:locale/7921-kate.xml alias Russian_Russia/7921-kate.xml
tftp-server flash:locale/7921-kate.utf-8.xml alias Russian_Russia/7921-kate.utf-8.xml
tftp-server flash:locale/7921-font.dat alias Russian_Russia/7921-font.dat
tftp-server flash:locale/7921-dictionary.xml alias Russian_Russia/7921-dictionary.xml
tftp-server flash:locale/td-sccp.jar alias Russian_Russia/td-sccp.jar
tftp-server flash:locale/rp-sccp.jar alias Russian_Russia/rp-sccp.jar
tftp-server flash:locale/tags_file alias Russian_Russia/tags_file
tftp-server flash:locale/utf8_tags_file alias Russian_Russia/utf8_tags_file
tftp-server flash:locale/rtl-sccp.jar alias Russian_Russia/rtl-sccp.jar
tftp-server flash:locale/g4-tones.xml alias Russian_Russia/g4-tones.xml
tftp-server flash:locale/CME-locale-ru_RU-Russian-8.6.2.4.tar.cfg alias Russian_Russia/CME-locale-ru_RU-Russian-8.6.2.4.tar.cfg
dial-peer voice 101 voip
destination-pattern 8T
session target ipv4:10.200.53.253
voice-class codec 1
dial-peer voice 2 voip
destination-pattern 2..
session target ipv4:172.20.201.2
telephony-service
max-ephones 35
max-dn 35
ip source-address 10.200.53.254 port 2000
user-locale RU
network-locale RU
time-zone 32
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Dec 16 2011 12:01:20
ephone-dn  1
number 301
description SC 301
name SC 301
ephone-dn  2
number 302
description Vologda SC 302
name SC 302
ephone-dn  3
number 303
description Vologda SC 303
name SC 303
ephone  1
mac-address 0008.3031.B531
button  1:1
ephone  2
mac-address 68BC.0C81.5E9B
button  1:2
ephone  3
mac-address 68BC.0C81.55E5
button  1:3
зы если память не изменяет с такимже конфигом на 2851 работает без проблем
зы телефоны 7911g + eyeBeam (пробовал другие софтофоны неработают)
