Здравствуйте уважаемые ГУРУ.
Есть сервак:
CPU: Intel(R) Xeon(R) CPU           E5420  @ 2.50GHz (2500.01-MHz K8-class CPU)
 Origin = "GenuineIntel"  Id = 0x1067a  Family = 6  Model = 17  Stepping = 10
 Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
 Features2=0x40ce3bd<SSE3,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,DCA,SSE4.1,XSAVE>
 AMD Features=0x20100800<SYSCALL,NX,LM>
 AMD Features2=0x1<LAHF>
 TSC: P-state invariant
 Cores per package: 4
usable memory = 8580325376 (8182 MB)
avail memory  = 8268234752 (7885 MB)
ACPI APIC Table: <PTLTD          APIC  >
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
cpu0 (BSP): APIC ID:  0
cpu1 (AP): APIC ID:  1
cpu2 (AP): APIC ID:  2
cpu3 (AP): APIC ID:  3
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
acpi0: <SMCI SMCISLP2> on motherboard
acpi0: [iTHREAD]
acpi0: Power Button (fixed)
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1008-0x100b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 2.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> at device 4.0 on pci0
pci2: <ACPI PCI bus> on pcib2
em0: <Intel(R) PRO/1000 Network Connection 7.1.9> port 0x2000-0x201f mem 0xfc120000-0xfc13ffff,0xfc100000-0xfc11ffff irq 16 at device 0.0 on pci2
em0: Using an MSI interrupt
em0: [FILTER]
em0: Ethernet address: 00:15:17:cf:8c:25
pcib3: <ACPI PCI-PCI bridge> at device 6.0 on pci0
pci3: <ACPI PCI bus> on pcib3
pci0: <base peripheral> at device 8.0 (no driver attached)
uhci0: <UHCI (generic) USB controller> port 0x1820-0x183f irq 16 at device 26.0 on pci0
uhci0: [GIANT-LOCKED]
uhci0: [iTHREAD]
usb0: <UHCI (generic) USB controller> on uhci0
usb0: USB revision 1.0
uhub0: <Intel UHCI root hub, class 9/0, rev 1.00/1.00, addr 1> on usb0
uhub0: 2 ports with 2 removable, self powered
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfc600800-0xfc600bff irq 18 at device 26.7 on pci0
ehci0: [GIANT-LOCKED]
ehci0: [iTHREAD]
usb1: EHCI version 1.0
usb1: companion controller, 2 ports each: usb0
usb1: <EHCI (generic) USB 2.0 controller> on ehci0
usb1: USB revision 2.0
uhub1: <Intel EHCI root hub, class 9/0, rev 2.00/1.00, addr 1> on usb1
uhub1: 2 ports with 2 removable, self powered
pcib4: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0
pci5: <ACPI PCI bus> on pcib5
em1: <Intel(R) PRO/1000 Network Connection 7.1.9> port 0x3000-0x301f mem 0xfc200000-0xfc21ffff irq 16 at device 0.0 on pci5
em1: Using an MSI interrupt
em1: [FILTER]
em1: Ethernet address: 00:30:48:d3:04:f0
pcib6: <ACPI PCI-PCI bridge> irq 17 at device 28.5 on pci0
pci6: <ACPI PCI bus> on pcib6
em2: <Intel(R) PRO/1000 Network Connection 7.1.9> port 0x4000-0x401f mem 0xfc300000-0xfc31ffff irq 17 at device 0.0 on pci6
em2: Using an MSI interrupt
em2: [FILTER]
em2: Ethernet address: 00:30:48:d3:04:f1
uhci1: <UHCI (generic) USB controller> port 0x1840-0x185f irq 16 at device 29.0 on pci0
uhci1: [GIANT-LOCKED]
uhci1: [iTHREAD]
usb2: <UHCI (generic) USB controller> on uhci1
usb2: USB revision 1.0
uhub2: <Intel UHCI root hub, class 9/0, rev 1.00/1.00, addr 1> on usb2
uhub2: 2 ports with 2 removable, self powered
uhci2: <UHCI (generic) USB controller> port 0x1860-0x187f irq 17 at device 29.1 on pci0
uhci2: [GIANT-LOCKED]
uhci2: [iTHREAD]
usb3: <UHCI (generic) USB controller> on uhci2
usb3: USB revision 1.0
uhub3: <Intel UHCI root hub, class 9/0, rev 1.00/1.00, addr 1> on usb3
uhub3: 2 ports with 2 removable, self powered
uhci3: <UHCI (generic) USB controller> port 0x1880-0x189f irq 18 at device 29.2 on pci0
uhci3: [GIANT-LOCKED]
uhci3: [iTHREAD]
usb4: <UHCI (generic) USB controller> on uhci3
usb4: USB revision 1.0
uhub4: <Intel UHCI root hub, class 9/0, rev 1.00/1.00, addr 1> on usb4
uhub4: 2 ports with 2 removable, self powered
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfc600c00-0xfc600fff irq 16 at device 29.7 on pci0
ehci1: [GIANT-LOCKED]
ehci1: [iTHREAD]
usb5: EHCI version 1.0
usb5: companion controllers, 2 ports each: usb2 usb3 usb4
usb5: <EHCI (generic) USB 2.0 controller> on ehci1
usb5: USB revision 2.0
uhub5: <Intel EHCI root hub, class 9/0, rev 2.00/1.00, addr 1> on usb5
uhub5: 6 ports with 6 removable, self powered
pcib7: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci7: <ACPI PCI bus> on pcib7
atapci0: <ITE IT8213F UDMA133 controller> port 0x5098-0x509f,0x5090-0x5093,0x5080-0x508f irq 17 at device 0.0 on pci7
atapci0: [iTHREAD]
ata2: <ATA channel 0> on atapci0
ata2: [iTHREAD]
vgapci0: <VGA-compatible display> port 0x5000-0x507f mem 0xfa000000-0xfbffffff,0xfc000000-0xfc03ffff at device 1.0 on pci7
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
atapci1: <Intel ICH8 SATA300 controller> port 0x1c10-0x1c17,0x1c04-0x1c07,0x1c08-0x1c0f,0x1c00-0x1c03,0x18a0-0x18bf mem 0xfc600000-0xfc6007ff irq 17 at device 31.2 on pci0
atapci1: [iTHREAD]
atapci1: AHCI called from vendor specific driver
atapci1: AHCI Version 01.20 controller with 6 ports detected
ata3: <ATA channel 0> on atapci1
ata3: port not implemented
ata3: [iTHREAD]
ata4: <ATA channel 1> on atapci1
ata4: port not implemented
ata4: [iTHREAD]
ata5: <ATA channel 2> on atapci1
ata5: [iTHREAD]
ata6: <ATA channel 3> on atapci1
ata6: [iTHREAD]
ata7: <ATA channel 4> on atapci1
ata7: [iTHREAD]
ata8: <ATA channel 5> on atapci1
ata8: [iTHREAD]
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
acpi_button0: <Power Button> on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [iTHREAD]
psm0: <PS/2 Mouse> irq 12 on atkbdc0
psm0: [GIANT-LOCKED]
psm0: [iTHREAD]
psm0: model Generic PS/2 mouse, device ID 0
sio0: configured irq 4 not in bitmap of probed irqs 0
sio0: port may not be enabled
sio0: <16550A-compatible COM port> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
sio0: type 16550A
sio0: [FILTER]
sio1: configured irq 3 not in bitmap of probed irqs 0
sio1: port may not be enabled
sio1: <16550A-compatible COM port> port 0x2f8-0x2ff irq 3 on acpi0
sio1: type 16550A
sio1: [FILTER]
cpu0: <ACPI CPU> on acpi0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
cpu1: <ACPI CPU> on acpi0
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
cpu2: <ACPI CPU> on acpi0
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
cpu3: <ACPI CPU> on acpi0
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
orm0: <ISA Option ROM> at iomem 0xc0000-0xc7fff on isa0
ppc0: cannot reserve I/O port range
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Timecounters tick every 1.000 msec
ipfw2 initialized, divert enabled, nat loadable, rule-based forwarding enabled, default to accept, logging limited to 500 packets/entry by default
acd0: DVDR <MATSHITADVD-RAM UJ870QJ/1.00> at ata2-slave UDMA33
ad12: 953869MB <WDC WD10EARX-00N0YB0 51.0AB51> at ata6-master SATA300
ad14: 476940MB <WDC WD5002ABYS-01B1B0 02.03B02> at ata7-master SATA300
ad16: 476940MB <WDC WD5002ABYS-01B1B0 02.03B02> at ata8-master SATA300
ar0: 476937MB <Intel MatrixRAID RAID1> status: READY
ar0: disk0 READY (master) using ad14 at ata7-master
ar0: disk1 READY (mirror) using ad16 at ata8-master
SMP: AP CPU #3 Launched!
SMP: AP CPU #1 Launched!
SMP: AP CPU #2 Launched!
На нем поднято ng_netflow+ng_car+ng_nat+ng_ipfw
в sysctl.conf
security.bsd.see_other_uids=0
kern.ipc.shmall=32768
kern.ipc.nmbclusters=65536
kern.ipc.maxsockets=204800
kern.random.sys.harvest.ethernet=0
kern.random.sys.harvest.interrupt=0
kern.ipc.somaxconn=16384
kern.ipc.maxsockbuf=2097152
kern.coredump=0
net.graph.maxdgram=20480
net.graph.recvspace=20480
net.inet.ip.forwarding=1
net.inet.ip.fastforwarding=1
net.inet.ip.fw.one_pass=0
net.inet.ip.portrange.first=1024
net.inet.ip.portrange.randomized=0
net.isr.direct=0
net.inet.tcp.delayed_ack=0
net.inet.udp.recvspace=65536
net.inet.udp.maxdgram=57344
net.local.stream.sendspace=32768
net.local.stream.recvspace=32768
net.route.netisr_maxqlen=1024
net.inet.tcp.blackhole=2
net.inet.udp.blackhole=1
net.inet.tcp.drop_synfin=1
net.inet.ip.intr_queue_maxlen=100
dev.em.0.rx_int_delay=250
dev.em.0.tx_int_delay=250
dev.em.0.rx_abs_int_delay=250
dev.em.0.tx_abs_int_delay=250
dev.em.0.rx_processing_limit=400
dev.em.0.flow_control=0
dev.em.1.rx_int_delay=250
dev.em.1.tx_int_delay=250
dev.em.1.rx_abs_int_delay=250
dev.em.1.tx_abs_int_delay=250
dev.em.1.rx_processing_limit=400
dev.em.1.flow_control=0
dev.em.2.rx_int_delay=250
dev.em.2.tx_int_delay=250
dev.em.2.rx_abs_int_delay=250
dev.em.2.tx_abs_int_delay=250
dev.em.2.rx_processing_limit=400
dev.em.2.flow_control=0
в loader.conf
hw.em.rxd=4096
hw.em.txd=4096
hw.em.enable_msi=1
net.graph.maxdata=65536
net.graph.maxalloc=65536
правила ipfw на время тестов:
${fwcmd} add 302 netgraph 60 all from table\(10\) to not x.x.x.x out via em1
${fwcmd} add 303 netgraph 61 all from not x.x.x.x to any in via em1
${fwcmd} add 65500 netgraph tablearg all from table\(12\) to not x.x.x.x in via em2
${fwcmd} add 65501 netgraph tablearg all from not x.x.x.x to table\(14\) out via em2
sysctl dev.em
dev.em.0.%desc: Intel(R) PRO/1000 Network Connection 7.1.9
dev.em.0.%driver: em
dev.em.0.%location: slot=0 function=0
dev.em.0.%pnpinfo: vendor=0x8086 device=0x107d subvendor=0x8086 subdevice=0x1082 class=0x020000
dev.em.0.%parent: pci2
dev.em.0.nvm: -1
dev.em.0.debug: -1
dev.em.0.rx_int_delay: 250
dev.em.0.tx_int_delay: 250
dev.em.0.rx_abs_int_delay: 250
dev.em.0.tx_abs_int_delay: 250
dev.em.0.rx_processing_limit: 400
dev.em.0.flow_control: 0
dev.em.0.link_irq: 0
dev.em.0.mbuf_alloc_fail: 0
dev.em.0.cluster_alloc_fail: 0
dev.em.0.dropped: 0
dev.em.0.tx_dma_fail: 0
dev.em.0.rx_overruns: 0
dev.em.0.watchdog_timeouts: 0
dev.em.0.device_control: 1074534721
dev.em.0.rx_control: 67141634
dev.em.0.fc_high_water: 30720
dev.em.0.fc_low_water: 29220
dev.em.0.queue0.txd_head: 401
dev.em.0.queue0.txd_tail: 405
dev.em.0.queue0.tx_irq: 0
dev.em.0.queue0.no_desc_avail: 0
dev.em.0.queue0.rxd_head: 493
dev.em.0.queue0.rxd_tail: 492
dev.em.0.queue0.rx_irq: 0
dev.em.0.mac_stats.excess_coll: 0
dev.em.0.mac_stats.single_coll: 0
dev.em.0.mac_stats.multiple_coll: 0
dev.em.0.mac_stats.late_coll: 0
dev.em.0.mac_stats.collision_count: 0
dev.em.0.mac_stats.symbol_errors: 0
dev.em.0.mac_stats.sequence_errors: 0
dev.em.0.mac_stats.defer_count: 0
dev.em.0.mac_stats.missed_packets: 0
dev.em.0.mac_stats.recv_no_buff: 0
dev.em.0.mac_stats.recv_undersize: 0
dev.em.0.mac_stats.recv_fragmented: 0
dev.em.0.mac_stats.recv_oversize: 0
dev.em.0.mac_stats.recv_jabber: 0
dev.em.0.mac_stats.recv_errs: 0
dev.em.0.mac_stats.crc_errs: 0
dev.em.0.mac_stats.alignment_errs: 0
dev.em.0.mac_stats.coll_ext_errs: 0
dev.em.0.mac_stats.xon_recvd: 0
dev.em.0.mac_stats.xon_txd: 0
dev.em.0.mac_stats.xoff_recvd: 0
dev.em.0.mac_stats.xoff_txd: 0
dev.em.0.mac_stats.total_pkts_recvd: 2184684
dev.em.0.mac_stats.good_pkts_recvd: 2184684
dev.em.0.mac_stats.bcast_pkts_recvd: 117980
dev.em.0.mac_stats.mcast_pkts_recvd: 0
dev.em.0.mac_stats.rx_frames_64: 648368
dev.em.0.mac_stats.rx_frames_65_127: 1276263
dev.em.0.mac_stats.rx_frames_128_255: 25211
dev.em.0.mac_stats.rx_frames_256_511: 27174
dev.em.0.mac_stats.rx_frames_512_1023: 55642
dev.em.0.mac_stats.rx_frames_1024_1522: 152026
dev.em.0.mac_stats.good_octets_recvd: 408533335
dev.em.0.mac_stats.good_octets_txd: 4621085002
dev.em.0.mac_stats.total_pkts_txd: 3569293
dev.em.0.mac_stats.good_pkts_txd: 3569293
dev.em.0.mac_stats.bcast_pkts_txd: 8
dev.em.0.mac_stats.mcast_pkts_txd: 0
dev.em.0.mac_stats.tx_frames_64: 144433
dev.em.0.mac_stats.tx_frames_65_127: 202341
dev.em.0.mac_stats.tx_frames_128_255: 47470
dev.em.0.mac_stats.tx_frames_256_511: 80673
dev.em.0.mac_stats.tx_frames_512_1023: 42723
dev.em.0.mac_stats.tx_frames_1024_1522: 3051653
dev.em.0.mac_stats.tso_txd: 23176
dev.em.0.mac_stats.tso_ctx_fail: 0
dev.em.0.interrupts.asserts: 3117103
dev.em.0.interrupts.rx_pkt_timer: 269
dev.em.0.interrupts.rx_abs_timer: 2
dev.em.0.interrupts.tx_pkt_timer: 99
dev.em.0.interrupts.tx_abs_timer: 199
dev.em.0.interrupts.tx_queue_empty: 0
dev.em.0.interrupts.tx_queue_min_thresh: 0
dev.em.0.interrupts.rx_desc_min_thresh: 0
dev.em.0.interrupts.rx_overrun: 0
dev.em.1.%desc: Intel(R) PRO/1000 Network Connection 7.1.9
dev.em.1.%driver: em
dev.em.1.%location: slot=0 function=0
dev.em.1.%pnpinfo: vendor=0x8086 device=0x108c subvendor=0x15d9 subdevice=0x108c class=0x020000
dev.em.1.%parent: pci5
dev.em.1.nvm: -1
dev.em.1.debug: -1
dev.em.1.rx_int_delay: 250
dev.em.1.tx_int_delay: 250
dev.em.1.rx_abs_int_delay: 250
dev.em.1.tx_abs_int_delay: 250
dev.em.1.rx_processing_limit: 400
dev.em.1.flow_control: 0
dev.em.1.link_irq: 0
dev.em.1.mbuf_alloc_fail: 0
dev.em.1.cluster_alloc_fail: 0
dev.em.1.dropped: 0
dev.em.1.tx_dma_fail: 0
dev.em.1.rx_overruns: 0
dev.em.1.watchdog_timeouts: 0
dev.em.1.device_control: 1075059017
dev.em.1.rx_control: 67141634
dev.em.1.fc_high_water: 10240
dev.em.1.fc_low_water: 8740
dev.em.1.queue0.txd_head: 368
dev.em.1.queue0.txd_tail: 368
dev.em.1.queue0.tx_irq: 0
dev.em.1.queue0.no_desc_avail: 0
dev.em.1.queue0.rxd_head: 504
dev.em.1.queue0.rxd_tail: 499
dev.em.1.queue0.rx_irq: 0
dev.em.1.mac_stats.excess_coll: 0
dev.em.1.mac_stats.single_coll: 0
dev.em.1.mac_stats.multiple_coll: 0
dev.em.1.mac_stats.late_coll: 0
dev.em.1.mac_stats.collision_count: 0
dev.em.1.mac_stats.symbol_errors: 0
dev.em.1.mac_stats.sequence_errors: 0
dev.em.1.mac_stats.defer_count: 0
dev.em.1.mac_stats.missed_packets: 0
dev.em.1.mac_stats.recv_no_buff: 0
dev.em.1.mac_stats.recv_undersize: 0
dev.em.1.mac_stats.recv_fragmented: 0
dev.em.1.mac_stats.recv_oversize: 0
dev.em.1.mac_stats.recv_jabber: 0
dev.em.1.mac_stats.recv_errs: 0
dev.em.1.mac_stats.crc_errs: 0
dev.em.1.mac_stats.alignment_errs: 0
dev.em.1.mac_stats.coll_ext_errs: 0
dev.em.1.mac_stats.xon_recvd: 0
dev.em.1.mac_stats.xon_txd: 0
dev.em.1.mac_stats.xoff_recvd: 0
dev.em.1.mac_stats.xoff_txd: 0
dev.em.1.mac_stats.total_pkts_recvd: 257951279
dev.em.1.mac_stats.good_pkts_recvd: 257951279
dev.em.1.mac_stats.bcast_pkts_recvd: 30202
dev.em.1.mac_stats.mcast_pkts_recvd: 0
dev.em.1.mac_stats.rx_frames_64: 13615224
dev.em.1.mac_stats.rx_frames_65_127: 40774521
dev.em.1.mac_stats.rx_frames_128_255: 12547410
dev.em.1.mac_stats.rx_frames_256_511: 5320405
dev.em.1.mac_stats.rx_frames_512_1023: 8611504
dev.em.1.mac_stats.rx_frames_1024_1522: 177082215
dev.em.1.mac_stats.good_octets_recvd: 276237486742
dev.em.1.mac_stats.good_octets_txd: 65188965401
dev.em.1.mac_stats.total_pkts_txd: 200648363
dev.em.1.mac_stats.good_pkts_txd: 200648363
dev.em.1.mac_stats.bcast_pkts_txd: 19
dev.em.1.mac_stats.mcast_pkts_txd: 0
dev.em.1.mac_stats.tx_frames_64: 41788347
dev.em.1.mac_stats.tx_frames_65_127: 109848573
dev.em.1.mac_stats.tx_frames_128_255: 8049782
dev.em.1.mac_stats.tx_frames_256_511: 2409621
dev.em.1.mac_stats.tx_frames_512_1023: 5066717
dev.em.1.mac_stats.tx_frames_1024_1522: 33485323
dev.em.1.mac_stats.tso_txd: 0
dev.em.1.mac_stats.tso_ctx_fail: 0
dev.em.1.interrupts.asserts: 145314904
dev.em.1.interrupts.rx_pkt_timer: 16127
dev.em.1.interrupts.rx_abs_timer: 1441
dev.em.1.interrupts.tx_pkt_timer: 2005
dev.em.1.interrupts.tx_abs_timer: 5233
dev.em.1.interrupts.tx_queue_empty: 0
dev.em.1.interrupts.tx_queue_min_thresh: 0
dev.em.1.interrupts.rx_desc_min_thresh: 0
dev.em.1.interrupts.rx_overrun: 0
dev.em.2.%desc: Intel(R) PRO/1000 Network Connection 7.1.9
dev.em.2.%driver: em
dev.em.2.%location: slot=0 function=0
dev.em.2.%pnpinfo: vendor=0x8086 device=0x109a subvendor=0x15d9 subdevice=0x109a class=0x020000
dev.em.2.%parent: pci6
dev.em.2.nvm: -1
dev.em.2.debug: -1
dev.em.2.rx_int_delay: 250
dev.em.2.tx_int_delay: 250
dev.em.2.rx_abs_int_delay: 250
dev.em.2.tx_abs_int_delay: 250
dev.em.2.rx_processing_limit: 400
dev.em.2.flow_control: 0
dev.em.2.link_irq: 0
dev.em.2.mbuf_alloc_fail: 0
dev.em.2.cluster_alloc_fail: 0
dev.em.2.dropped: 0
dev.em.2.tx_dma_fail: 0
dev.em.2.rx_overruns: 0
dev.em.2.watchdog_timeouts: 0
dev.em.2.device_control: 1075053128
dev.em.2.rx_control: 67141634
dev.em.2.fc_high_water: 10240
dev.em.2.fc_low_water: 8740
dev.em.2.queue0.txd_head: 152
dev.em.2.queue0.txd_tail: 152
dev.em.2.queue0.tx_irq: 0
dev.em.2.queue0.no_desc_avail: 0
dev.em.2.queue0.rxd_head: 349
dev.em.2.queue0.rxd_tail: 348
dev.em.2.queue0.rx_irq: 0
dev.em.2.mac_stats.excess_coll: 0
dev.em.2.mac_stats.single_coll: 0
dev.em.2.mac_stats.multiple_coll: 0
dev.em.2.mac_stats.late_coll: 0
dev.em.2.mac_stats.collision_count: 0
dev.em.2.mac_stats.symbol_errors: 0
dev.em.2.mac_stats.sequence_errors: 0
dev.em.2.mac_stats.defer_count: 0
dev.em.2.mac_stats.missed_packets: 0
dev.em.2.mac_stats.recv_no_buff: 0
dev.em.2.mac_stats.recv_undersize: 0
dev.em.2.mac_stats.recv_fragmented: 0
dev.em.2.mac_stats.recv_oversize: 0
dev.em.2.mac_stats.recv_jabber: 0
dev.em.2.mac_stats.recv_errs: 0
dev.em.2.mac_stats.crc_errs: 0
dev.em.2.mac_stats.alignment_errs: 0
dev.em.2.mac_stats.coll_ext_errs: 0
dev.em.2.mac_stats.xon_recvd: 0
dev.em.2.mac_stats.xon_txd: 0
dev.em.2.mac_stats.xoff_recvd: 0
dev.em.2.mac_stats.xoff_txd: 0
dev.em.2.mac_stats.total_pkts_recvd: 200623799
dev.em.2.mac_stats.good_pkts_recvd: 200623799
dev.em.2.mac_stats.bcast_pkts_recvd: 356613
dev.em.2.mac_stats.mcast_pkts_recvd: 6070
dev.em.2.mac_stats.rx_frames_64: 41794069
dev.em.2.mac_stats.rx_frames_65_127: 109395914
dev.em.2.mac_stats.rx_frames_128_255: 8056313
dev.em.2.mac_stats.rx_frames_256_511: 2395276
dev.em.2.mac_stats.rx_frames_512_1023: 5083123
dev.em.2.mac_stats.rx_frames_1024_1522: 33899104
dev.em.2.mac_stats.good_octets_recvd: 65767383084
dev.em.2.mac_stats.good_octets_txd: 244702622856
dev.em.2.mac_stats.total_pkts_txd: 227123006
dev.em.2.mac_stats.good_pkts_txd: 227123006
dev.em.2.mac_stats.bcast_pkts_txd: 1492
dev.em.2.mac_stats.mcast_pkts_txd: 0
dev.em.2.mac_stats.tx_frames_64: 12853428
dev.em.2.mac_stats.tx_frames_65_127: 33564795
dev.em.2.mac_stats.tx_frames_128_255: 11436499
dev.em.2.mac_stats.tx_frames_256_511: 4992451
dev.em.2.mac_stats.tx_frames_512_1023: 7471672
dev.em.2.mac_stats.tx_frames_1024_1522: 156804161
dev.em.2.mac_stats.tso_txd: 0
dev.em.2.mac_stats.tso_ctx_fail: 0
dev.em.2.interrupts.asserts: 230460812
dev.em.2.interrupts.rx_pkt_timer: 19610
dev.em.2.interrupts.rx_abs_timer: 2889
dev.em.2.interrupts.tx_pkt_timer: 6493
dev.em.2.interrupts.tx_abs_timer: 12034
dev.em.2.interrupts.tx_queue_empty: 0
dev.em.2.interrupts.tx_queue_min_thresh: 0
dev.em.2.interrupts.rx_desc_min_thresh: 0
dev.em.2.interrupts.rx_overrun: 0
К чтению обсуждений на этом форуме не предлагать, все уже 300 раз прочитано, просто не понятно во многих случаях как подбираются значения переменных sysctl. Прошу дельного совета.
Канал приходит 100Мбит/с. В часы пик, абоненты, которые на тестовое время переведены на этот сервак, прокачивают его максимум на 25Мбит/с(пробовали тестировать в обход ng_car). Подскажите пожалуйста в чем может быть проблема, почему не можем прокачать этот канал?
Раньше тюнингом FreeBSD не занимались, все было на аппаратных роутерах.
Поменять прокладку между креслом и монитором не предлагать :-)
ng_car шейпит rate_limit-ом тарифы от 1 до 10 мбит/с
ng_nat пока такой
/usr/sbin/ngctl mkpeer ipfw: nat 60 out
                   /usr/sbin/ngctl name ipfw:60 nat
                   /usr/sbin/ngctl connect ipfw: nat: 61 in
                   /usr/sbin/ngctl msg nat: setaliasaddr x.x.x.x
ядро собранно с этим параметрами, лишние убрано
options         SCHED_ULE               # ULE scheduler
options         PREEMPTION              # Enable kernel thread preemption
options         INET                    # InterNETworking
options         SCTP                    # Stream Control Transmission Protocol
options         FFS                     # Berkeley Fast Filesystem
options         SOFTUPDATES             # Enable FFS soft updates support
options         UFS_ACL                 # Support for access control lists
options         UFS_DIRHASH             # Improve performance on big directories
options         UFS_GJOURNAL            # Enable gjournal-based UFS journaling
options         MD_ROOT                 # MD is a potential root device
options         CD9660                  # ISO 9660 Filesystem
options         PROCFS                  # Process filesystem (requires PSEUDOFS)
options         PSEUDOFS                # Pseudo-filesystem framework
options         GEOM_PART_GPT           # GUID Partition Tables.
options         GEOM_LABEL              # Provides labelization
options         COMPAT_43TTY            # BSD 4.3 TTY compat [KEEP THIS!]
options         COMPAT_IA32             # Compatible with i386 binaries
options         COMPAT_FREEBSD4         # Compatible with FreeBSD4
options         COMPAT_FREEBSD5         # Compatible with FreeBSD5
options         COMPAT_FREEBSD6         # Compatible with FreeBSD6
options         SCSI_DELAY=5000         # Delay (in ms) before probing SCSI
options         KTRACE                  # ktrace(1) support
options         STACK                   # stack(9) support
options         SYSVSHM                 # SYSV-style shared memory
options         SYSVMSG                 # SYSV-style message queues
options         SYSVSEM                 # SYSV-style semaphores
options         P1003_1B_SEMAPHORES     # POSIX-style semaphores
options         _KPOSIX_PRIORITY_SCHEDULING # POSIX P1003_1B real-time extensions
options         KBD_INSTALL_CDEV        # install a CDEV entry in /dev
options         ADAPTIVE_GIANT          # Giant mutex is adaptive.
options         STOP_NMI                # Stop CPUS using NMI instead of IPI
options         AUDIT                   # Security event auditing
#options        KDTRACE_FRAME           # Ensure frames are compiled in
#options        KDTRACE_HOOKS           # Kernel DTrace hooks
options         INCLUDE_CONFIG_FILE     # Include this file in kernel
options         IPFIREWALL
options         IPFIREWALL_FORWARD
options         IPFIREWALL_VERBOSE
options         IPFIREWALL_VERBOSE_LIMIT=500
options         IPFIREWALL_DEFAULT_TO_ACCEPT
options         IPDIVERT
options         NETGRAPH
options         NETGRAPH_IPFW
options         NETGRAPH_NETFLOW
options         NETGRAPH_IFACE
options         NETGRAPH_BPF
options         NETGRAPH_ETHER
options         NETGRAPH_SOCKET
options         NETGRAPH_KSOCKET
options         NETGRAPH_CAR
options         NETGRAPH_TEE
options         NETGRAPH_NAT
options         NETGRAPH_CISCO
options         NETGRAPH_ONE2MANY
options         LIBALIAS
options         HZ=1000
options         SMP
дрова на сетевках FreeBSD-шные
vmstat -zm | grep 0$
UMA Kegs:                 216,        0,       87,       15,       88,        0
UMA Zones:                280,        0,       87,        4,       88,        0
UMA Slabs:                128,        0,    13513,       30,    17028,        0
UMA RCntSlabs:            128,        0,     2603,        7,     2603,        0
UMA Hash:                 256,        0,        3,       12,        7,        0
16 Bucket:                152,        0,      149,        1,      149,        0
32 Bucket:                280,        0,      174,        8,      174,        0
VM OBJECT:                216,        0,    46675,      683,  1107049,        0
MAP:                      256,        0,        7,       23,        7,        0
KMAP ENTRY:               112,   278322,       45,      153,    24738,        0
MAP ENTRY:                112,        0,     7063,     4058,  2626853,        0
DP fakepg:                120,        0,        0,      155,     4277,        0
SG fakepg:                120,        0,        0,        0,        0,        0
mt_zone:                 1032,        0,      215,       13,      215,        0
16:                        16,        0,     2703,      825,  8488741,        0
32:                        32,        0,     3213,     1433,   903828,        0
64:                        64,        0,    10042,      878, 1988889906,        0
128:                      128,        0,    23558,    16984, 20989168,        0
256:                      256,        0,     1208,      562,   390788,        0
512:                      512,        0,      982,      306,   131275,        0
1024:                    1024,        0,       75,      221,   520649,        0
2048:                    2048,        0,       68,      130,     2444,        0
4096:                    4096,        0,      430,      224,    67391,        0
Files:                    128,        0,      217,      392,  8389210,        0
TURNSTILE:                152,        0,      425,       79,      425,        0
umtx pi:                   96,        0,        0,        0,        0,        0
PROC:                    1160,        0,      120,      111,    26209,        0
THREAD:                   920,        0,      281,      143,     6386,        0
UPCALL:                    88,        0,        0,        0,        0,        0
SLEEPQUEUE:                64,        0,      425,      135,      425,        0
VMSPACE:                  432,        0,       67,      104,    26008,        0
cpuset:                    72,        0,        2,       98,        2,        0
audit_record:             992,        0,        0,        0,        0,        0
mbuf_packet:              256,        0,        1,      767, 37388456,        0
mbuf:                     256,        0,     3074,      898, 1040675044,        0
mbuf_cluster:            2048,    65536,     3840,      904, 463340674,        0
mbuf_jumbo_pagesize:     4096,    12800,        0,      231,   501004,        0
mbuf_jumbo_9k:           9216,     6400,        0,        0,        0,        0
mbuf_jumbo_16k:         16384,     3200,        0,        0,        0,        0
mbuf_ext_refcnt:            4,        0,        0,      672,     2313,        0
ACL UMA zone:             388,        0,        0,        0,        0,        0
NetGraph items:            72,    65565,        0,      405,  7616075,        0
NetGraph data items:       72,    65565,        1,      539, 1992397884,        0
g_bio:                    216,        0,        0,    13680,  6028756,        0
ata_request:              312,        0,        0,     7116,  1603249,        0
ata_composite:            352,        0,        0,     3806,    94580,        0
VNODE:                    504,        0,    96387,      333,   820223,        0
VNODEPOLL:                128,        0,        0,        0,        0,        0
S VFS Cache:              104,        0,    73780,    28532,   766410,        0
L VFS Cache:              327,        0,    23381,      631,    81453,        0
NAMEI:                   1024,        0,        0,       96, 16626511,        0
DIRHASH:                 1024,        0,     1926,      142,     2235,        0
pipe:                     744,        0,        4,       86,     9476,        0
ksiginfo:                 112,        0,      185,      871,      185,        0
itimer:                   360,        0,        0,       30,        3,        0
KNOTE:                    120,        0,       19,      353,  6462591,        0
socket:                   720,   204800,       71,      229,   764419,        0
ipq:                       56,     2079,        0,      378,      244,        0
udp_inpcb:                288,   204802,        6,      202,   467549,        0
udpcb:                     16,   204960,        6,      834,   467549,        0
inpcb:                    288,   204802,       51,     1392,   263420,        0
tcpcb:                    728,   204800,       20,      215,   263420,        0
tcptw:                     88,     8232,       31,     1439,   135009,        0
syncache:                 128,    15370,        0,      261,   137291,        0
hostcache:                136,    15372,        2,      110,        7,        0
tcpreass:                  40,     4116,        0,      168,        3,        0
sackhole:                  32,        0,        0,        0,        0,        0
sctp_ep:                 1232,    25602,        0,        0,        0,        0
sctp_asoc:               2208,    40000,        0,        0,        0,        0
sctp_laddr:                48,    80064,        0,      216,        3,        0
sctp_raddr:               568,    80003,        0,        0,        0,        0
sctp_chunk:               144,   400010,        0,        0,        0,        0
sctp_readq:               104,   400032,        0,        0,        0,        0
sctp_stream_msg_out:       96,   400026,        0,        0,        0,        0
sctp_asconf:               40,   400008,        0,        0,        0,        0
sctp_asconf_ack:           48,   400032,        0,        0,        0,        0
ripcb:                    288,   204802,        0,       78,     2288,        0
unpcb:                    248,   204810,       45,      165,    23293,        0
rtentry:                  248,        0,       34,      191,     1390,        0
IPFW dynamic rule:        120,        0,        0,        0,        0,        0
divcb:                    288,   204802,        0,        0,        0,        0
SWAPMETA:                 288,   116519,        0,        0,        0,        0
Mountpoints:              896,        0,        6,        6,        6,        0
FFS inode:                184,        0,    96349,      230,   820148,        0
FFS1 dinode:              128,        0,        0,        0,        0,        0
FFS2 dinode:              256,        0,    96349,      251,   820148,        0
NetFlow cache:             80,   262170,    15785,    42940, 24964755,        0
ошибок на интерфейсах нет вроде, но эти данные то что сейчас происходит, в часы пик тоже вроде нет
netstat -I em1 -w1
          input          (em1)           output
  packets  errs      bytes    packets  errs      bytes colls
      679     0     750983        570     0     139213     0
      834     0     921383        632     0     117226     0
      707     0     817043        544     0     105088     0
      607     0     681962        477     0      79808     0
      700     0     753942        569     0     133476     0
      900     0    1074913        648     0      87090     0
      709     0     821235        531     0      81108     0
      725     0     850834        531     0      66624     0
      814     0     953851        597     0      82143     0
      795     0     943367        615     0     164796     0
      753     0     819954        601     0     143301     0
      705     0     713005        574     0     119593     0
      702     0     789153        533     0     128496     0
=0, для начала.
Там ещё 2/3 из ядра можно выкинуть спокойно, тк модулями прекрасно работает.
И данные нужно было показывать в момент когда упёрлись в 25мегабит, а не после перезагрузки - у меня дома пакетрейт выше, и по памяти статистика совсем скромная.
options IPFIREWALL
options IPDIVERT
options NETGRAPH
options LIBALIAS
options HZ=1000
options SMP
Там ещё и устройства далеко не все нужны, и почти все из них можно модулями грузить.
Фаервол проде тоже можно выкинуть, я не помню опция с форвардом что именно делает. Нетграф прекрасно грузится модулями сам. Диверт нужен для натд или очень редкого софта.
А кто нибудь может подсказать что с памятью? Как узнать на что она тратиться, т.е. как это посмотреть?
top
last pid: 30941;  load averages:  0.55,  0.63,  0.48        up 3+07:28:49  17:13:35
113 processes: 1 running, 112 sleeping
CPU:  1.8% user,  0.0% nice,  2.6% system,  0.8% interrupt, 94.8% idle
Mem: 603M Active, 4331M Inact, 1096M Wired, 916K Cache, 828M Buf, 1896M Free
Swap: 16G Total, 16G Free
 PID USERNAME  THR PRI NICE   SIZE    RES STATE   C   TIME   WCPU COMMAND
1179 mysql      35  44    0   696M   501M ucond   2   0:00  1.07% mysqld
1236 zabbix      1   8    5 59916K  4560K nanslp  0   0:46  0.00% zabbix_server
 838 bind        7   4    0 62436K 49560K kqread  2   0:37  0.00% named
1200 zabbix      1   8    5 10712K  2048K nanslp  0   0:20  0.00% zabbix_agentd
1248 root        1   4    0   185M 18876K select  1   0:13  0.00% httpd
1244 zabbix      1   8    5 59916K  4144K nanslp  2   0:11  0.00% zabbix_server
1238 zabbix      1   8    5 59916K  4144K nanslp  1   0:11  0.00% zabbix_server
1227 zabbix      1   8    5 60172K  5852K nanslp  1   0:08  0.00% zabbix_server
1204 zabbix      1   8    5 10712K  1968K nanslp  2   0:08  0.00% zabbix_agentd
1226 zabbix      1   8    5 60172K  5840K nanslp  1   0:08  0.00% zabbix_server
1224 zabbix      1   8    5 60172K  5840K nanslp  0   0:08  0.00% zabbix_server
1225 zabbix      1   8    5 60172K  5840K nanslp  1   0:08  0.00% zabbix_server
1223 zabbix      1   8    5 60172K  5852K nanslp  3   0:08  0.00% zabbix_server
1201 zabbix      1   4    5 10712K  2120K select  0   0:07  0.00% zabbix_agentd
1202 zabbix      1   4    5 10712K  2120K select  0   0:07  0.00% zabbix_agentd
1203 zabbix      1  49    5 10712K  2120K select  1   0:07  0.00% zabbix_agentd
1242 zabbix      1   8    5 59916K  4392K nanslp  1   0:07  0.00% zabbix_server
1243 zabbix      1   8    5 59916K  4424K nanslp  3   0:07  0.00% zabbix_server
1240 zabbix      1   8    5 59916K  4316K nanslp  0   0:07  0.00% zabbix_server
1222 zabbix      1   8    5 59916K  4144K nanslp  2   0:07  0.00% zabbix_server
1241 zabbix      1   8    5 59916K  4384K nanslp  0   0:07  0.00% zabbix_server
1237 zabbix      1   8    5 59916K  4188K nanslp  2   0:07  0.00% zabbix_server
1221 zabbix      1   8    5 59916K  4416K nanslp  3   0:06  0.00% zabbix_server
1239 zabbix      1   8    5 59916K  5556K nanslp  0   0:06  0.00% zabbix_server
1235 zabbix      1   8    5 59916K  4144K nanslp  1   0:06  0.00% zabbix_server
1228 zabbix      1   8    5 60172K  5816K nanslp  2   0:05  0.00% zabbix_server
1245 zabbix      1   8    5 59916K  4148K nanslp  1   0:05  0.00% zabbix_server
1234 zabbix      1   8    5 60428K  4180K nanslp  0   0:05  0.00% zabbix_server
1576 root        7   8    0 48772K 31004K nanslp  3   0:04  0.00% LBcore
1246 zabbix      1   8    5 59916K  4144K nanslp  3   0:03  0.00% zabbix_server
 734 root        1   4    0  5860K  1468K select  0   0:02  0.00% syslogd
 605 root        1   4    0  2180K   656K select  0   0:01  0.00% devd
28706 www         1   4    0   190M 45960K accept  2   0:01  0.00% httpd
28735 www         1   4    0   191M 42396K accept  2   0:01  0.00% httpd
1621 root        1   4    0 23104K  3984K select  0   0:01  0.00% sshd
25247 root        1   4    0 33960K  4664K select  0   0:01  0.00% sshd
28747 www         1   4    0   188M 29952K accept  0   0:01  0.00% httpd
28734 www         1   4    0   189M 40180K accept  0   0:01  0.00% httpd
28744 www         1   4    0   190M 41952K accept  0   0:01  0.00% httpd
1232 zabbix      1   4    5 59916K  4216K select  0   0:01  0.00% zabbix_server
1231 zabbix      1   4    5 59916K  4216K accept  3   0:01  0.00% zabbix_server
1630 root        1   8    0  6788K  1504K nanslp  0   0:00  0.00% cron
1233 zabbix      1   4    5 59916K  4216K accept  3   0:00  0.00% zabbix_server
1229 zabbix      1   4    5 59916K  4216K select  0   0:00  0.00% zabbix_server
28740 www         1   4    0   190M 41288K accept  1   0:00  0.00% httpd
1230 zabbix      1   4    5 59916K  4216K accept  3   0:00  0.00% zabbix_server
29196 www         1   4    0   188M 28908K accept  0   0:00  0.00% httpd
25251 root        1  20    0 10148K  3584K pause   1   0:00  0.00% csh
29235 www         1   4    0   188M 27316K accept  3   0:00  0.00% httpd
29265 root        3   8    0 10632K  6516K nanslp  3   0:00  0.00% LBucd
29240 www         1   4    0   187M 25504K accept  3   0:00  0.00% httpd
30928 root        1  44    0  8156K  2284K CPU3    3   0:00  0.00% top
29239 www         1   4    0   188M 26972K accept  0   0:00  0.00% httpd
Сори, затупил. Появляется вопрос, почему так много приложения съедают.
Вот что было 10 минут назад, ограничение по тарифам отключал, т.е. в обход ng_car. swi1:net загружен был максимум 1%, загрузка ядер нулевая.
Не можем понять. либо сервер затюнили, либо провайдер не дадает причем дофига.
netstat -I em1 -w1
           input          (em1)           output
     2325     0    2623187       1958     0     664530     0
     2449     0    2713733       1849     0     572369     0
     2151     0    2529045       1629     0     377148     0
     2194     0    2469153       1626     0     422753     0
     2262     0    2610128       1642     0     346249     0
     2231     0    2673264       1641     0     308453     0
     2313     0    2673103       1730     0     410427     0
     2370     0    2683042       1795     0     402418     0
     2392     0    2715361       1814     0     477197     0
     2294     0    2717186       1820     0     466723     0
     2234     0    2622533       1671     0     344120     0
     2166     0    2629086       1647     0     338447     0
     2589     0    3196777       1943     0     404459     0
     2221     0    2515070       1829     0     462593     0
     2054     0    2450235       1595     0     375814     0
     2269     0    2704257       1804     0     460130     0
     2441     0    2956612       1872     0     424891     0
     2053     0    2299462       1736     0     537207     0
     2135     0    2580908       1634     0     387016     0
     1912     0    2344185       1562     0     340170     0
           input          (em1)           output
     1868     0    2245287       1573     0     439280     0
     2291     0    2737506       1749     0     415231     0
     2153     0    2573904       1647     0     431760     0
^C
mediainform# netstat -I em1 -w1
           input          (em1)           output
     2380     0    2812117       1781     0     403309     0
     2588     0    3175676       1808     0     355840     0
     2203     0    2670034       1722     0     365578     0
     1975     0    2342080       1650     0     417594     0
     2035     0    2410606       1636     0     426075     0
     2076     0    2497387       1680     0     393480     0
     1887     0    2087977       1619     0     454713     0
     1986     0    2256297       1550     0     373158     0
     1906     0    2248918       1492     0     359513     0
     2208     0    2558345       1557     0     256280     0
     2132     0    2516050       1545     0     375429     0
     1837     0    2214390       1407     0     303367     0
     2349     0    2758801       1653     0     497163     0
     2176     0    2505755       1422     0     313063     0
     1936     0    2220511       1507     0     436836     0
     2125     0    2376566       1465     0     399827     0
     2443     0    2744205       1502     0     329662     0
     2256     0    2586585       1488     0     369537     0
     2184     0    2417713       1636     0     442806     0
     2046     0    2309428       1604     0     399463     0
vmstat -zm
Type InUse MemUse HighUse Requests  Size(s)
    acpitask     0     0K       -        5  64
     ithread    73    13K       -       73  32,128,256
CAM dev queue     1     1K       -        1  128
   CAM queue     3     1K       -        3  16
      KTRACE   100    13K       -      100  128
 ata_generic     4     4K       -        4  1024
      linker    57     4K       -       75  16,32,64,512
       lockf    24     3K       -  2341609  64,128
   ad_driver     3     1K       -        3  32
        temp    35   230K       -   837853  16,32,64,128,256,512,1024,2048,4096
      devbuf 16809 34839K       -    16970  16,32,64,128,256,512,1024,2048,4096
      module   248    31K       -      248  128
      kbdmux     6     9K       -        6  16,256,512,2048,4096
    mtx_pool     1     8K       -        1
         LED     3     1K       -        3  128
     subproc   353   600K       -    39291  512,4096
        proc     2    16K       -        2
     session    23     3K       -     2023  128
        pgrp    25     4K       -     2959  128
        cred    32     8K       -   263917  256
     uidinfo     6     3K       -     1857  64,2048
      plimit    15     4K       -    21674  256
     ata_dma     7     2K       -        7  256
   sysctltmp     0     0K       -     2878  16,32,64,128,4096
   sysctloid  4585   228K       -     4697  16,32,64,128
      sysctl     0     0K       -   794820  16,32,64
        umtx   424    53K       -      424  128
    p1003.1b     1     1K       -        1  16
        SWAP     2  2189K       -        2  64
      bus-sc    94   128K       -     1965  16,32,64,128,256,512,1024,2048,4096
         bus   779    72K       -     5285  16,32,64,128,256,1024
     devstat    26    53K       -       26  32,4096
eventhandler    69     6K       -       69  64,128
   ar_driver     1     1K       -        9  512,1024,2048
        kobj   145   580K       -      205  4096
  acd_driver     1     2K       -        1  2048
        rman   193    24K       -      616  16,64,128
     acpisem    16     2K       -       16  128
        sbuf     0     0K       -     1674  16,32,64,128,256,512,1024,2048,4096
     CAM SIM     1     1K       -        1  256
       stack     0     0K       -        4  256
   taskqueue    17     3K       -       17  16,32,256
      Unitno    13     1K       -    16391  32,64
         iov     0     0K       -  6057865  16,64,128,256,512
    ioctlops     0     0K       -    51840  16,32,64,128,256,512,1024,4096
         msg     4    30K       -        4  2048,4096
         sem     4    11K       -        4  512,1024
         shm    34    86K       -      153  2048
        ttys  1167   166K       -     6617  128,1024
        ptys     3     1K       -        3  256
    mbuf_tag     0     0K       - 2631652815  32,64
        ksem     1     8K       -        1
         pcb    31   157K       -   834882  16,32,64,128,1024,2048,4096
      soname    19     2K       -  5452233  16,32,128
      biobuf     0     0K       -       11  2048
    vfscache     1  2048K       -        1
  cl_savebuf     0     0K       -     2031  64,128
    vfs_hash     1  1024K       -        1
      vnodes     1     1K       -       24  32,256
  CAM periph     2     1K       -        9  16,32,64,128,256
 vnodemarker     0     0K       -   105103  512
       mount    82     4K       -      164  16,32,64,128,256
     acpidev    71     5K       -       71  64
         BPF     4     1K       -       29  16,32,128,512
 ether_multi    17     1K       -       20  16,64
      ifaddr    32     9K       -       44  32,64,512,4096
       ifnet     5     9K       -        5  256,2048
       clone     6    24K       -        6  4096
      arpcom     3     1K       -        3  16
          lo     1     1K       -        1  32
     entropy  1024    64K       -     1024  64
    routetbl   244    79K       -     5726  32,64,128,256,512
netflow_hash     1  4096K       -        2
      USBdev    26    10K       -       26  16,128,256,512
         USB   118    25K       -      136  16,32,64,128,256,1024
      DEVFS1   119    60K       -      125  512
netgraph_msg     0     0K       -     8707  64,128,256,512,1024,4096
netgraph_node   129    33K       -     6812  256
netgraph_hook   496    62K       -      534  128
    netgraph   373  2541K       -     1125  16,64,4096
netgraph_bpf     2     1K       -        9  128,256
netgraph_ksock     1     1K       -        2  128
netgraph_parse     0     0K       -     6038  16,32,64,512
netgraph_sock     0     0K       -     5942  128
netgraph_path     0     0K       -     6714  16
    in_multi     4     1K       -        4  64
      DEVFS3   276    69K       -      553  256
    ipfw_tbl   380    95K       -     2661  256
 IpFw/IpAcct    24     3K       -      154  64,128
   sctp_iter     0     0K       -        9  256
    sctp_ifn     4     1K       -        7  128
    sctp_ifa     4     1K       -        7  128
    sctp_vrf     1     1K       -        1  64
   sctp_a_it     0     0K       -        9  16
   hostcache     1    36K       -        1
      DEVFS2   119     2K       -      119  16
    syncache     1   100K       -        1
    libalias 19912  2553K       - 23094897  128
audit_evclass   151     5K       -      188  32
    savedino     0     0K       -    13222  256
   newdirblk     0     0K       -        1  64
      dirrem     0     0K       -    46078  64
       mkdir     0     0K       -       22  64
      diradd     1     1K       -    46195  64
    freefile     1     1K       -    41627  64
    freeblks     1     1K       -    41501  256
    freefrag     0     0K       -    48253  64
  allocindir     0     0K       -   318635  128
    indirdep     0     0K       -    11946  64
 allocdirect     1     1K       -   133320  256
   bmsafemap     1     1K       -    24025  128
      newblk     1     1K       -   451956  64,512
    inodedep     3  1025K       -    47657  256
     pagedep     2   257K       -     1394  128
 ufs_dirhash   709   153K       -     5724  16,32,64,128,256,512
   ufs_mount    12   178K       -       12  512,2048,4096
     UMAHash     4   170K       -       24  512,1024,2048,4096
  DEVFS_RULE    52    25K       -      150  64,512
       DEVFS    24     1K       -       47  16,128
   vm_pgdata     2   129K       -        2  128
   pfs_nodes    20     5K       -       20  256
        GEOM   225    41K       -     1831  16,32,64,128,256,512,1024,2048
     CAM XPT    10     2K       -       25  32,64,128,1024
     io_apic     1     2K       -        1  2048
      isadev     7     1K       -        7  128
     memdesc     1     4K       -        1  4096
         msi     3     1K       -        3  128
    nexusdev     4     1K       -        4  16
    pci_link    16     2K       -       16  32,64,128
   acpi_perf     4     1K       -        4  64
        cdev    21     6K       -       21  256
    atkbddev     2     1K       -        2  64
       sigio     1     1K       -        1  64
    filedesc   126    76K       -    39512  16,32,64,128,512,1024,2048,4096
        kenv    79    11K       -       81  16,32,64,128
      kqueue    22    31K       -     6277  256,2048
      acpica  2127   187K       -    56828  16,32,64,128,256,512,1024,2048
   proc-args    56     4K       - 10688875  16,32,64,128,256
ITEM                     SIZE     LIMIT      USED      FREE  REQUESTS  FAILURES
UMA Slabs:                128,        0,    13531,       12,    18835,        0
UMA RCntSlabs:            128,        0,     3043,        2,     3043,        0
16 Bucket:                152,        0,      153,       22,      153,        0
32 Bucket:                280,        0,      182,        0,      182,        0
64 Bucket:                536,        0,      226,        5,      234,        8
128 Bucket:              1048,        0,     1559,        1,     1606,      343
VM OBJECT:                216,        0,    46784,      628,  1544557,        0
KMAP ENTRY:               112,   278322,       37,      260,    32087,        0
MAP ENTRY:                112,        0,     7039,     4082,  3777629,        0
DP fakepg:                120,        0,        0,      155,     4694,        0
16:                        16,        0,     2712,      816, 11789810,        0
32:                        32,        0,     3215,     1431,  1274706,        0
64:                        64,        0,    10041,      879, 2640161619,        0
128:                      128,        0,    25542,    17030, 28897826,        0
256:                      256,        0,     1227,      633,   548980,        0
512:                      512,        0,      984,      304,   185378,        0
1024:                    1024,        0,       77,      219,   718276,        0
2048:                    2048,        0,       67,      131,     3557,        0
4096:                    4096,        0,      433,      221,    94883,        0
Files:                    128,        0,      207,      402, 11745102,        0
PROC:                    1160,        0,      120,      111,    39053,        0
THREAD:                   920,        0,      273,      151,     8439,        0
VMSPACE:                  432,        0,       67,      122,    38820,        0
mbuf_packet:              256,        0,       20,      748, 48836206,        0
mbuf:                     256,        0,     3078,     1794, 1394254712,        0
mbuf_cluster:            2048,    65536,     3843,     1781, 622414824,        0
mbuf_jumbo_pagesize:     4096,    12800,        0,      231,   666115,        0
mbuf_ext_refcnt:            4,        0,        0,      672,     4330,        0
NetGraph items:            72,    65565,        0,      405,  7664476,        0
NetGraph data items:       72,    65565,        3,      537, 2641739414,        0
g_bio:                    216,        0,        0,    13680,  8025248,        0
ata_request:              312,        0,        0,     7116,  2140162,        0
ata_composite:            352,        0,        0,     3927,   132322,        0
VNODE:                    504,        0,    96468,      396,  1079479,        0
S VFS Cache:              104,        0,    74159,    28729,  1007213,        0
L VFS Cache:              327,        0,    23383,      629,   108532,        0
NAMEI:                   1024,        0,        0,       96, 23275325,        0
DIRHASH:                 1024,        0,     1928,      140,     2237,        0
pipe:                     744,        0,        3,      102,    13815,        0
itimer:                   360,        0,        0,       40,        5,        0
KNOTE:                    120,        0,       19,      353,  9033897,        0
socket:                   720,   204800,       81,      219,  1050147,        0
ipq:                       56,     2079,        0,      378,      343,        0
udp_inpcb:                288,   204802,        6,      202,   660623,        0
udpcb:                     16,   204960,        6,      834,   660623,        0
inpcb:                    288,   204802,       58,     1385,   341198,        0
tcpcb:                    728,   204800,       20,      215,   341198,        0
tcptw:                     88,     8232,       38,     1432,   175258,        0
syncache:                 128,    15370,        0,      261,   178477,        0
hostcache:                136,    15372,        2,      138,       12,        0
tcpreass:                  40,     4116,        0,      420,      132,        0
sctp_laddr:                48,    80064,        0,      288,        9,        0
ripcb:                    288,   204802,        0,       78,     4087,        0
unpcb:                    248,   204810,       44,      166,    32354,        0
rtentry:                  248,        0,       55,      170,     2634,        0
Mountpoints:              896,        0,        6,        6,        8,        0
FFS inode:                184,        0,    96428,      214,  1079379,        0
FFS2 dinode:              256,        0,    96428,      337,  1079379,        0
NetFlow cache:             80,   262170,    24726,    33999, 33783988,        0
это канал по полной прогружен.
netstat -I em1 -w1
input (em1) output
2861 0 3506716 1659 0 210344 0
3092 0 4051663 1765 0 259584 0
2034 0 2332860 1262 0 173909 0
2790 0 3537453 1682 0 196807 0
3182 0 4076520 1938 0 236210 0
2020 0 2174656 1314 0 260428 0
2964 0 3629966 1809 0 248098 0
3351 0 4162074 2081 0 331310 0
2507 0 2985563 1593 0 216373 0
2555 0 3095900 1551 0 253051 0
3092 0 3977951 1849 0 260002 0
2724 0 3355809 1543 0 217758 0
1741 0 2014796 1168 0 199831 0
2695 0 3333048 1683 0 263366 0
3085 0 3994664 1815 0 248295 0
1703 0 2013297 1111 0 204184 0
2449 0 3143419 1501 0 248847 0
3071 0 3896997 1960 0 262917 0
2638 0 3298299 1664 0 325534 0
2133 0 2599278 1319 0 269442 0
input (em1) output
2851 0 3614260 1712 0 287288 0
2749 0 3417571 1628 0 304076 0
2094 0 2500934 1315 0 213920 0
2660 0 3234196 1612 0 267075 0
Edited by ArminBah
netstat -m
3075/2565/5640 mbufs in use (current/cache/total)
3073/2551/5624/65536 mbuf clusters in use (current/cache/total/max)
1/767 mbuf+clusters out of packet secondary zone in use (current/cache)
0/231/231/12800 4k (page size) jumbo clusters in use (current/cache/total/max)
0/0/0/6400 9k jumbo clusters in use (current/cache/total/max)
0/0/0/3200 16k jumbo clusters in use (current/cache/total/max)
6914K/6667K/13582K bytes allocated to network (current/cache/total)
0/0/0 requests for mbufs denied (mbufs/clusters/mbuf+clusters)
0/0/0 requests for jumbo clusters denied (4k/9k/16k)
0/0/0 sfbufs in use (current/peak/max)
0 requests for sfbufs denied
0 requests for sfbufs delayed
212 requests for I/O initiated by sendfile
0 calls to protocol drain routines
vmstat -i
interrupt                          total       rate
irq1: atkbd0                       13614          0
irq17: uhci2++                   4161889         11
cpu0: timer                    733216012       2000
irq256: em0                      5466649         14
irq257: em1                    195514128        533
irq258: em2                    300002127        818
cpu3: timer                    733215818       2000
cpu1: timer                    733215818       2000
cpu2: timer                    733215817       2000
Total                         3438021872       9377
top
жесть!
первое правило, убрать мух от котлет. что тут делает мускл, с апачами и забиксами?? какой тут может быть тюненг.
разумнее и проще использовать ipfw nat.
включить direct isr, fastforwarding включить обратно. ядро оставить как в первом посте.
для вывода всех процессов "покурить" man top.
дуал*P3 c двумя em вольготно себя чувствовать на таком трафике будет
Edited by shelma
Вобщем выяснилось, почему не могли прокачать 100Мбитный канал, оказалось что у прова на порту стояло автоопределение скорости. Вот отсюда и все пироги.
Кто нибудь может объяснить что за ошибки 32 Bucket, 64 Bucket и 128 Bucket?
vmstat -zm
       lockf    24     3K       -    96021  64,128
        temp    35   230K       -    84407  16,32,64,128,256,512,1024,2048,4096
      devbuf 16809 34839K       -    16968  16,32,64,128,256,512,1024,2048,4096
    mtx_pool     1     8K       -        1
         LED     3     1K       -        3  128
     subproc   349   595K       -    19493  512,4096
        proc     2    16K       -        2
     session    23     3K       -      540  128
        pgrp    24     3K       -      648  128
        cred    28     7K       -    95721  256
     uidinfo     6     3K       -      483  64,2048
      plimit    15     4K       -     5608  256
   sysctltmp     0     0K       -      630  16,32,64,128,4096
      sysctl     0     0K       -   191973  16,32,64
        umtx   404    51K       -      404  128
        SWAP     2  2189K       -        2  64
         bus   779    72K       -     4677  16,32,64,128,256,1024
     devstat    24    49K       -       24  32,4096
        kobj   145   580K       -      203  4096
        sbuf     0     0K       -     1106  16,32,64,128,256,512,1024,2048,4096
       stack     0     0K       -        2  256
      Unitno    13     1K       -     8439  32,64
         iov     0     0K       -  1427834  16,64,128,256,512
    ioctlops     0     0K       -    16684  16,32,64,128,256,512,1024,4096
         shm    34    86K       -       34  2048
        ttys  1166   165K       -     4545  128,1024
        ptys     2     1K       -        2  256
    mbuf_tag     0     0K       - 780888370  32,64
        ksem     1     8K       -        1
         pcb    30   157K       -   194770  16,32,64,128,1024,2048,4096
      soname    21     3K       -  1281476  16,32,128
      biobuf     0     0K       -        8  2048
  cl_savebuf     0     0K       -      296  64,128
      vnodes     1     1K       -        8  32,256
 vnodemarker     0     0K       -    26436  512
       mount    82     4K       -      138  16,32,64,128,256
         BPF     4     1K       -        9  16,128,512
      ifaddr    32     9K       -       32  32,64,512,4096
      arpcom     3     1K       -        3  16
          lo     1     1K       -        1  32
    routetbl   208    75K       -     1698  32,64,128,256,512
netflow_hash     1  4096K       -        1
      DEVFS1   115    58K       -      121  512
netgraph_msg     0     0K       -     6404  64,128,256,512,1024,4096
netgraph_node   130    33K       -     5190  256
netgraph_hook   498    63K       -      508  128
    netgraph   375  2545K       -     1133  16,64,4096
netgraph_bpf     2     1K       -        3  128,256
netgraph_ksock     1     1K       -        1  128
netgraph_parse     0     0K       -     3713  16,32,64,512
netgraph_sock     0     0K       -     4307  128
netgraph_path     0     0K       -     5167  16
      DEVFS3   262    66K       -      269  256
    ipfw_tbl   384    96K       -     2670  256
 IpFw/IpAcct    30     4K       -       30  64,128
   sctp_iter     0     0K       -        3  256
    sctp_ifn     4     1K       -        4  128
    sctp_ifa     4     1K       -        4  128
   sctp_a_it     0     0K       -        3  16
   hostcache     1    36K       -        1
      DEVFS2   115     2K       -      115  16
    syncache     1   100K       -        1
    libalias  7755  1034K       -  4975842  128
    savedino     0     0K       -     3365  256
      dirrem     0     0K       -    10910  64
       mkdir     0     0K       -       16  64
      diradd     1     1K       -    10952  64
    freefile     1     1K       -     9731  64
    freeblks     1     1K       -     9672  256
    freefrag     0     0K       -    10425  64
  allocindir    65     9K       -    43913  128
    indirdep     3     1K       -      854  64
 allocdirect     1     1K       -    28622  256
   bmsafemap     4     1K       -     4138  128
      newblk     1     1K       -    72536  64,512
    inodedep     3  1025K       -    11356  256
     pagedep     2   257K       -      392  128
 ufs_dirhash   703   152K       -     5714  16,32,64,128,256,512
  DEVFS_RULE    52    25K       -       52  64,512
       DEVFS    24     1K       -       25  16,128
        GEOM   212    39K       -     1747  16,32,64,128,256,512,1024,2048
      isadev     7     1K       -        7  128
         msi     3     1K       -        3  128
        cdev    21     6K       -       21  256
       sigio     1     1K       -        1  64
    filedesc   133    86K       -    19331  16,32,64,128,512,1024,2048,4096
      kqueue    22    31K       -      297  256,2048
      acpica  2127   187K       -    55908  16,32,64,128,256,512,1024,2048
   proc-args    56     5K       -  2733871  16,32,64,128,256
UMA Kegs:                 216,        0,       87,       15,       87,        0
UMA Zones:                280,        0,       87,        4,       87,        0
UMA Slabs:                128,        0,    13822,       11,    14404,        0
UMA RCntSlabs:            128,        0,     2578,        3,     2578,        0
16 Bucket:                152,        0,      146,        4,      146,        0
32 Bucket:                280,        0,      167,        1,      167,        1
64 Bucket:                536,        0,      179,        3,      179,       65
128 Bucket:              1048,        0,     1858,        2,     1858,      516
VM OBJECT:                216,        0,    51738,      300,   507135,        0
KMAP ENTRY:               112,   278322,       40,      356,    15225,        0
MAP ENTRY:                112,        0,     7033,     1679,  1068651,        0
DP fakepg:                120,        0,        0,      155,     1500,        0
16:                        16,        0,     2701,      659,  2831967,        0
32:                        32,        0,     3211,     1435,   300989,        0
64:                        64,        0,    10042,      822, 782917023,        0
128:                      128,        0,    13404,    17307,  6046415,        0
256:                      256,        0,     1209,      396,   170595,        0
512:                      512,        0,      976,      277,    71096,        0
1024:                    1024,        0,       82,      214,    43290,        0
2048:                    2048,        0,       67,       67,      400,        0
4096:                    4096,        0,      433,      264,    27988,        0
Files:                    128,        0,      225,      413,  2957945,        0
TURNSTILE:                152,        0,      405,       51,      405,        0
PROC:                    1160,        0,      119,      109,    19262,        0
THREAD:                   920,        0,      274,      130,     4476,        0
SLEEPQUEUE:                64,        0,      405,      155,      405,        0
VMSPACE:                  432,        0,       66,      123,    19207,        0
mbuf_packet:              256,        0,       18,      750, 10043013,        0
mbuf:                     256,        0,     3077,      895, 425226603,        0
mbuf_cluster:            2048,    65536,     3840,      854, 197036656,        0
mbuf_jumbo_pagesize:     4096,    12800,        0,      231,   134394,        0
mbuf_ext_refcnt:            4,        0,        0,      672,      685,        0
NetGraph items:            72,    65565,        0,      405,  2243708,        0
NetGraph data items:       72,    65565,        1,      404, 783697069,        0
g_bio:                    216,        0,        0,    13824,  1718186,        0
ata_request:              312,        0,        0,     6840,   463402,        0
ata_composite:            352,        0,        0,     3586,    32284,        0
VNODE:                    504,        0,    98930,      150,   530220,        0
S VFS Cache:              104,        0,   104626,      278,   515945,        0
L VFS Cache:              327,        0,      697,    22991,    31337,        0
NAMEI:                   1024,        0,        0,       96,  5993740,        0
DIRHASH:                 1024,        0,     1921,      159,     2228,        0
pipe:                     744,        0,        3,       87,     6934,        0
ksiginfo:                 112,        0,      180,      876,      180,        0
itimer:                   360,        0,        0,       20,        1,        0
KNOTE:                    120,        0,       19,      322,  2109646,        0
socket:                   720,   204800,       71,      259,   244245,        0
ipq:                       56,     2079,        0,      252,       43,        0
udp_inpcb:                288,   204802,        6,      176,   145216,        0
udpcb:                     16,   204960,        6,      834,   145216,        0
inpcb:                    288,   204802,       39,     1729,    82757,        0
tcpcb:                    728,   204800,       20,      215,    82757,        0
tcptw:                     88,     8232,       19,     1577,    41350,        0
syncache:                 128,    15370,        0,      174,    41659,        0
tcpreass:                  40,     4116,        0,        0,        0,        0
ripcb:                    288,   204802,        0,       65,     3739,        0
unpcb:                    248,   204810,       45,      135,     3918,        0
rtentry:                  248,        0,       37,      173,      731,        0
FFS inode:                184,        0,    98897,      181,   530162,        0
FFS2 dinode:              256,        0,    98897,      118,   530162,        0
NetFlow cache:             80,   262170,    22808,    97162,  7430099,        0
