Всем Доброго времени суток.
Имеем в ядре Cisco 7301 48DC.
Переодически сама перезагружается без видимых причин.
Вот логи :
No active filter modules.
Trap logging: level notifications, 28 message lines logged
Logging to xx.xx.xx.xx(global) (udp port 514, audit disabled, link up), 2
8 message lines logged, xml disabled,
filtering disabled
Log Buffer (8192 bytes):
*Feb 8 10:42:41.079: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0
, changed state to up
*Feb 8 10:42:41.079: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed stat
e to up
*Feb 8 10:42:41.079: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed stat
e to up
*Feb 8 10:42:41.079: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed stat
e to up
*Feb 8 10:42:41.279: %SYS-6-CLOCKUPDATE: System clock has been updated from 10:
42:41 UTC Tue Feb 8 2005 to 13:42:41 MSK Tue Feb 8 2005, configured from console
by console.
*Feb 8 10:42:41.279: %SYS-6-CLOCKUPDATE: System clock has been updated from 13:
42:41 MSK Tue Feb 8 2005 to 13:42:41 MSK Tue Feb 8 2005, configured from console
by console.
Feb 8 10:42:42.079: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthe
rnet0/0, changed state to up
rnet0/1, changed state to up
rnet0/2, changed state to up
Feb 8 10:42:42.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback10,
changed state to up
Feb 8 10:42:42.659: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, chang
ed state to up
Feb 8 10:42:45.871: %SYS-5-CONFIG_I: Configured from memory by console
Feb 8 10:42:46.427: %SYS-5-RESTART: System restarted --
Cisco IOS Software, 7301 Software (C7301-IPBASE-M), Version 12.4(9)T1, RELEASE S
OFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2006 by Cisco Systems, Inc.
Compiled Wed 30-Aug-06 21:25 by prod_rel_team
Feb 8 10:42:46.471: %ENTITY_ALARM-6-INFO: ASSERT CRITICAL SFP Slot 0/0 SFP is m
issing
Feb 8 10:42:46.471: %ENTITY_ALARM-6-INFO: ASSERT CRITICAL SFP Slot 0/1 SFP is m
issing
Feb 8 10:42:46.471: %ENTITY_ALARM-6-INFO: ASSERT INFO Gi0/1 Physical Port Admin
istrative State Down
Feb 8 10:42:46.471: %ENTITY_ALARM-6-INFO: ASSERT CRITICAL SFP Slot 0/2 SFP is m
issing
Feb 8 10:42:46.687: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state
to down
Feb 8 10:42:46.687: %ENTITY_ALARM-6-INFO: ASSERT CRITICAL Gi0/0 Physical Port L
ink Down
Feb 8 10:42:46.787: %LINK-3-UPDOWN: Interface Virtual-Access12, changed state t
o up
Feb 8 10:42:46.847: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing
a cold start
Feb 8 10:42:47.916: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed stat
e to administratively down
Feb 8 10:42:47.916: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state
to down
Feb 8 10:42:47.916: %ENTITY_ALARM-6-INFO: ASSERT CRITICAL Gi0/2 Physical Port L
ink Down
Feb 8 10:42:47.916: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthe
rnet0/0, changed state to down
Feb 8 10:42:47.916: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Acc
ess12, changed state to up
Feb 8 10:42:48.260: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.99.0.25 st
arted - CLI initiated
Feb 8 10:42:48.924: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthe
rnet0/1, changed state to down
rnet0/2, changed state to down
Feb 8 10:42:51.120: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state
to up
Feb 8 10:42:51.120: %ENTITY_ALARM-6-INFO: CLEAR CRITICAL Gi0/0 Physical Port Li
nk Down
Feb 8 10:42:52.120: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthe
Feb 8 10:42:56.120: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.99.0.25 st
arted - reconnection
Feb 8 10:46:04.512: %ENVM-4-RPSFAIL: Power Supply may have a failed channel
Feb 8 10:47:45.512: %ENVM-4-RPSFAIL: Power Supply may have a failed channel
У кого какие мысли по этому поводу?
ЗЫ Питание менли.
Edited by NX_BIT
s ver
OFTWARE (fc2)
ROM: System Bootstrap, Version 12.3(4r)T4, RELEASE SOFTWARE (fc1)
Router uptime is 18 hours, 26 minutes
System returned to ROM by power-on
System restarted at 15:48:40 MSK Tue Feb 8 2005
System image file is "disk0:c7301-ipbase-mz.124-9.T1.bin"
Cisco 7301 (NPE) processor (revision E) with 229376K/32768K bytes of memory.
Processor board ID 74836706
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
1 slot midplane, Version 2.0
Last reset from power-on
3 Gigabit Ethernet interfaces
509K bytes of NVRAM.
62720K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
32768K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x21020
s fla
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- n
ame
1 .. image 4BD6CD7B 80A610 25 8168848 Jan 1 2000 05:15:24 +03:00 c7
301-boot-mz.124-9.T.bin
2 .D crashinfo 83E63EC6 8466C8 25 245814 Feb 27 2010 19:17:29 +03:00 c
rashinfo_20100227-161729
3 .D crashinfo 9D92C942 881454 25 240906 Apr 15 2010 15:04:13 +04:00 c
rashinfo_20100415-110413
4 .D crashinfo 3E9919B1 8BECF0 25 251932 Apr 15 2010 15:10:46 +04:00 c
rashinfo_20100415-111046
5 .. crashinfo 61E2D459 8F333C 25 214474 Feb 20 2011 21:49:45 +03:00 c
rashinfo_20110220-184945
6 .. crashinfo 0527FEDE 9318E8 25 255273 Mar 3 2011 11:08:52 +03:00 cr
ashinfo_20110303-080852
23389976 bytes available (9378024 bytes used)
Sh Stack
Router#sh stack
Minimum process stacks:
Free/Size Name
4944/6000 CEF process
5020/6000 CEF Scanner
59124/60000 script background loader
5276/6000 CDP Protocol
5332/6000 SASL MAIN
2300/3000 allegro libretto init
4188/6000 Update prst
4436/6000 DIB error message
3216/12000 Init
5144/6000 RADIUS INITCONFIG
2264/3000 Rom Random Update Process
34260/36000 TCP Command
8600/12000 Virtual Exec
2948/6000 radius nvwrite
Interrupt level stacks:
Level Called Unused/Size Name
1 253702371 6528/9000 Network interfaces
2 0 9000/9000 DMA/Timer Interrupt
3 15 7888/9000 PA Management Int Handler
4 46104 8608/9000 Console Uart
5 0 9000/9000 OIR/Error Interrupt
7 16665825 8568/9000 NMI Interrupt Handler
Edited by NX_BIT
Вот логи со свитча подключенного к ней
58 2011/12/xx 13:55:05 Port 27 link up, 1000Mbps FULL duplex
57 2011/12/xx 13:55:01 Port 27 link down
56 2011/12/xx 13:55:00 Port 27 link up, 1000Mbps FULL duplex
55 2011/12/xx 13:54:57 Port 27 link down
54 2011/12/xx 13:54:55 Port 27 link up, 1000Mbps FULL duplex
53 2011/12/xx 13:54:29 Port 27 link down
52 2011/12/xx 13:54:03 Port 27 link up, 1000Mbps FULL duplex
51 2011/12/xx 13:53:59 Port 27 link down
Зы Порт и кабель меняли
Router#sh env power all
% Invalid input detected at '^' marker.
Говорит не понимает.
Извиняюсь если что.
Циску "первый раз в глаза вижу"
Ну и еще show power status all . Второй питатель подключен ? Или только один ?
Edited by ilili
sh run | i kron
ВВел эту команду и ничего не произошло.
Router#show power status all
Питальник подключен один.
eltex УЕП 1-1
И сразу после ребута покажите вывод команды show version, там будет строка System restarted by %значение%
Ок,дождусь ребута и зделаю.
выкладывайте весь конфиг
Могу выложить конфиг без IP интерфейсов и прочих интимных моментов.
Edited by NX_BIT
Без Ip интрфейсов и ACL Есть необходимость выкладывать?
Да я вот это сразу не увидел... Так что, видимо, нету :)
Как я понял он ругается на неправельно указанный канал питания.
Меняли ничего не изменилось.
Кстати Циска это писала чуть ли не с покупки.
Может быть есть способ это поправить?
Второй шланг с питанием подключите, а потом гляньте, есть ли изменения
Edited by ilili
Второй шланг ничего к сожалению не изменил(
Принимаются предложения по продаже циски (В смысле купить хотим)
Меняйте ios, мониторьте загрузку. Таблица маршрутизации случайно не ест 100% ОЗУ? Очень вряд ли что трабл аппаратный
Edited by denis_vid
А как можно посмотреть загузку ОЗУ?
ЗЫ ЦПУ В пике 82 %
Нарисовал следующее
Router#sh memory sta his
------------------ History of Processor Mempool ------------------
Router 06:38:27 PM Thursday Feb 10 2005 MSK
6666666666666666666666666666666666666666666666666666666666
9999999999999999999999999999999999999999999999999999999999
100
90
80
70 ************************************************************
60 ************************************************************
50 ************************************************************
40 ************************************************************
30 ************************************************************
20 ************************************************************
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
Free memory per second (last 60 seconds)
9999999999999999999999999999999999999999999998888888888888
100
90
80
70 ############################################################
60 ############################################################
50 ############################################################
40 ############################################################
30 ############################################################
20 ############################################################
10 ############################################################
0 5 0 5 0 5 0 5 0 5
Free memory per minute (last 60 minutes)
* = maximum # = average
66777777777777776666666776777777777777777666667778
88000122333333218667799009000123333333210777890010
100
90
80 *
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
Free memory per hour (last 72 hours)
------------------ History of I/O Mempool ------------------
Router 06:38:31 PM Thursday Feb 10 2005 MSK
8888888888888888888888888888888888888888888888888888888888
100
90 ************************************************************
80 ************************************************************
0 5 0 5 0 5 0 5 0 5
100
90 ############################################################
80 ############################################################
0 5 0 5 0 5 0 5 0 5
88889999999999887777888888888899999999777777888899
100
Вот SHOW VERSION
Router#show version
OFTWARE (fc2)
Router uptime is 17 minutes
System restarted at 16:11:38 MSK Mon Feb 14 2005
Сразу после ребута
Как Я понимаю пришёл конец блоку питания самой циски....
