Вот конфиг:
inactive: helpers {
traceoptions {
file helpers.log;
flag bootp;
bootp {
server 10.63.0.4 routing-instance vrf-oeirs;
interface {
xe-0/1/0.62 {
xe-0/1/0.63;
dhcp-relay {
traceoptions {
file dhcp-relay.log;
flag all;
server-group {
sip-dhcp {
10.63.0.4;
active-server-group sip-dhcp;
group sip-dhcp {
interface xe-0/1/0.62 {
overrides {
allow-snooped-clients;
По описанию из данной ссылки http://k4route.blogspot.com/2011/06/dhcp-helper.html обе конфигурации равнозначны, но на сервере ничего не вижу, на клиентском интерфейсе запросы приходят:
monitor traffic interface xe-0/1/0.62
verbose output suppressed, use <detail> or <extensive> for full protocol decode
Address resolution is ON. Use <no-resolve> to avoid any reverse lookup delay.
Address resolution timeout is 4s.
Listening on xe-0/1/0.62, capture size 96 bytes
Reverse lookup for 255.255.255.255 failed (check DNS reachability).
Other reverse lookup failures will not be reported.
Use <no-resolve> to avoid reverse lookups on IP addresses.
15:55:14.890122 In IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 00:1c:10:c3:39:6d, length 318
15:55:18.795586 In IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 00:1c:10:c3:39:6d, length 318
15:55:27.110195 In IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 00:1c:10:c3:39:6d, length 318
15:55:43.750230 In IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 00:1c:10:c3:39:6d, length 318
15:56:16.560418 In IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 00:1c:10:c3:39:6d, length 318
^C
5 packets received by filter
0 packets dropped by kernel
Если такие запросы обрабатываются через Re, так на lo добавил правило:
term DHCP {
from {
source-address {
0.0.0.0/32;
destination-address {
255.255.255.255/32;
protocol udp;
then accept;
Edited by bmp82
Используйте helper , проверь попадают ли запросы на RE ( не фильтруются ли они где-нибудь ) Аккуратнее с экспериментами в некоторых версиях Junos данные манипуляции приводят к ЗАВИСАНИЮ RE. Commit confirm не спасает =(
show firewall log ничего не показывает, по udp ничего не фильтруется.
Версия ПО:
Model: mx480
JUNOS Base OS boot [10.4R7.5]
unit 62 {
description "'dhcp-relay-test'";
vlan-id 62;
family inet {
address 10.62.0.1/27;
unit 63 {
description dhcp-server;
vlan-id 63;
family inet {
address 10.63.0.1/29;
Обратного ответа от сервера нет, он скорее всего где-то у вас за фильтрован . Есть возможность проверить работу без фильтров ?
Отключите флирты полностью на lo и на возможных входящих и исходящих интерфес, которые смотрят в сторону DHCPD.
Просто на стройте bootp helper
http://www.juniper.net/techpubs/software/junos/junos94/swconfig-policy/interface.html#id-11414411
Edited by triam
запросы dhcp есть, ответов от сервера нет. А там маршруты видно, пинги ходят между сетками. Сижу со снифером на dhcp сервере, кроме арп запросов от джунипера ничего.
Edited by bmp82
Точно такая же ситуация была =) У нас это поличилось исправлением filter'а =) Правда тогда софт был 9.6
Могу посмотреть RSI, если в личку пришлёте.
  • 1 month later...
все заработало, как то так
helpers {
bootp {
dhcp-option82 {
circuit-id;
remote-id;
vendor-id;
interface {
xe-0/1/0.62 {
description client;
server 10.63.0.4 routing-instance vrf-test;
server 10.63.0.3 routing-instance vrf-test;
maximum-hop-count 8;
minimum-wait-time 3;
dhcp-option82 {
circuit-id {
use-vlan-id;
remote-id {
prefix mac;
vendor-id;
xe-0/1/0.198 {
no-listen;
  • 5 months later...
