Davion Posted November 18, 2011 Posted November 18, 2011 Настроил тарелку с помощью ресивера сигнал показывал 100% Повозился с установкой L4v c поддержкой Tevii s480 В конце концов поставил ядро 2.6.39 и в обоих случаях сигнал нелочит? кому нибудь удалось победить? uname -a Linux tv0 2.6.39-02063904-generic #201108040905 SMP Thu Aug 4 11:04:48 UTC 2011 i686 i686 i386 GNU/Linux szap -n 1 -a 1 -H -c /home/davion/channels.conf reading channels from file '/home/davion/channels.conf' zapping to 1 'Raduga': sat 0, frequency = 12670 MHz V, symbolrate 22000000, vpid = 0x1fff, apid = 0x1fff sid = 0x0000 using '/dev/dvb/adapter1/frontend0' and '/dev/dvb/adapter1/demux0' status 00 | signal 64% | snr 23% | ber 0 | unc 0 | status 00 | signal 64% | snr 31% | ber -1 | unc 0 | status 00 | signal 64% | snr 47% | ber -1 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 31% | ber -1 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 31% | ber -1 | unc 0 | status 00 | signal 64% | snr 71% | ber -1 | unc 0 | status 00 | signal 64% | snr 47% | ber -1 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 31% | ber -1 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 47% | ber -1 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 31% | ber -1 | unc 0 | qstatus 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 71% | ber -1 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | Вставить ник Quote
Davion Posted November 18, 2011 Author Posted November 18, 2011 вбил спотолка параметры такаяже фигня... szap -n 1 -a 1 -H -c /home/davion/channels.conf reading channels from file '/home/davion/channels.conf' zapping to 1 'Raduga': sat 0, frequency = 12530 MHz V, symbolrate 22000000, vpid = 0x1fff, apid = 0x1fff sid = 0x0000 using '/dev/dvb/adapter1/frontend0' and '/dev/dvb/adapter1/demux0' status 00 | signal 64% | snr 71% | ber 0 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 87% | ber -1 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 31% | ber -1 | unc 0 | status 00 | signal 64% | snr 23% | ber -1 | unc 0 | status 00 | signal 64% | snr 55% | ber -1 | unc 0 | status 00 | signal 64% | snr 31% | ber -1 | unc 0 | status 00 | signal 64% | snr 87% | ber -1 | unc 0 | Кто нибудь победил эти карты??? Вставить ник Quote
Davion Posted November 18, 2011 Author Posted November 18, 2011 а да linux ubuntu 11.04 Вставить ник Quote
BiWiS Posted November 19, 2011 Posted November 19, 2011 у нас на федоре с ядрами выше 2.6.35 dvb вообще отказывается нормально работать, то понос то золотуха, откатишь до 2.6.35 и все работает как часы. попробуйте ядро сменить, вдруг поможет, правда у нас карточка другая. Вставить ник Quote
Davion Posted November 19, 2011 Author Posted November 19, 2011 вообщем были опробованы следующий ядра 2.6.35-02063513-generic(драйвера собирались) 2.6.38-12-generic-pae (драйвера собирались) 2.6.38-8-generic-pae (драйвера собирались) 2.6.39-02063904-generic (драйвера включены) 3.1.1-030101-generic (драйвера включены) Результат везде одинаковый, отсутствие результата.... Сигнал не лочится, видимо дело в чем то другом. Вставить ник Quote
server801 Posted November 19, 2011 Posted November 19, 2011 (edited) нету логов - нету решения проблем. радуга channels.conf raduga:12670:v:1:22000:0:0:0 вот так выглядет лочка, а0 - номер адаптера root@iptv-radyga:~# szap-s2 -H -a0 -c /root/channels.conf -n 1 reading channels from file '/root/channels.conf' zapping to 1 'raduga': delivery DVB-S, modulation QPSK sat 1, frequency 12670 MHz V, symbolrate 22000000, coderate auto, rolloff 0.35 vpid 0x1fff, apid 0x1fff, sid 0x0000 using '/dev/dvb/adapter0/frontend0' and '/dev/dvb/adapter0/demux0' status 00 | signal 90% | snr 87% | ber 0 | unc 11 | status 1f | signal 71% | snr 87% | ber 0 | unc 15 | FE_HAS_LOCK status 1f | signal 71% | snr 87% | ber 0 | unc 0 | FE_HAS_LOCK status 1f | signal 71% | snr 87% | ber 0 | unc 0 | FE_HAS_LOCK З.Ы Обязательное присутствие в /lib/firmware dvb-fe-ds3000.fw dvb-usb-s660.fw Edited November 19, 2011 by server801 Вставить ник Quote
Davion Posted November 19, 2011 Author Posted November 19, 2011 Вот аналогичное выполнение szap-s2 ./szap-s2 -H -a0 -c /home/davion/channels.conf -n 1 reading channels from file '/home/davion/channels.conf' zapping to 1 'Raduga': delivery DVB-S, modulation QPSK sat 1, frequency 12670 MHz V, symbolrate 22000000, coderate auto, rolloff 0.35 vpid 0x1fff, apid 0x1fff, sid 0x0000 using '/dev/dvb/adapter0/frontend0' and '/dev/dvb/adapter0/demux0' status 00 | signal 68% | snr 47% | ber 0 | unc 0 | status 00 | signal 68% | snr 47% | ber -1 | unc 0 | status 00 | signal 68% | snr 47% | ber -1 | unc 0 | status 00 | signal 68% | snr 47% | ber -1 | unc 0 | status 00 | signal 68% | snr 23% | ber -1 | unc 0 | status 00 | signal 68% | snr 31% | ber -1 | unc 0 | status 00 | signal 68% | snr 87% | ber -1 | unc 0 | status 00 | signal 68% | snr 47% | ber -1 | unc 0 | status 00 | signal 68% | snr 47% | ber -1 | unc 0 | status 00 | signal 68% | snr 23% | ber -1 | unc 0 | status 00 | signal 68% | snr 23% | ber -1 | unc 0 | status 00 | signal 68% | snr 23% | ber -1 | unc 0 | Вот /lib/firmware find /lib/firmware/dvb* /lib/firmware/dvb-fe-ds3000.fw /lib/firmware/dvb-fe-xc5000-1.6.114.fw /lib/firmware/dvb-usb-dib0700-1.20.fw /lib/firmware/dvb-usb-s660.fw Вывод dmesg [ 7.802080] dvb-usb: found a 'TeVii S660 USB' in cold state, will try to load a firmware [ 7.837658] Linux agpgart interface v0.103 [ 7.847848] e1000e 0000:05:00.0: irq 43 for MSI/MSI-X [ 7.848323] ADDRCONF(NETDEV_UP): eth1: link is not ready [ 7.849601] dvb-usb: downloading firmware from file 'dvb-usb-s660.fw' [ 7.849603] dw2102: start downloading DW210X firmware [ 7.856794] lp: driver loaded but no devices found [ 7.860121] s3fb 0000:04:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19 [ 7.860125] s3fb 0000:04:00.0: BAR 0: can't reserve [mem 0xf0000000-0xf3ffffff] [ 7.860127] s3fb 0000:04:00.0: cannot reserve framebuffer region [ 7.862546] s3fb: probe of 0000:04:00.0 failed with error -16 [ 7.867673] parport_pc 00:08: reported by Plug and Play ACPI [ 7.867739] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE] [ 7.898750] ppdev: user-space parallel port driver [ 7.920771] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 7.967460] lp0: using parport0 (interrupt-driven). [ 8.007328] dvb-usb: found a 'TeVii S660 USB' in warm state. [ 8.007363] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer. [ 8.007724] DVB: registering new adapter (TeVii S660 USB) [ 8.270592] dvb-usb: MAC address: 00:18:bd:5b:57:6e [ 10.649678] e1000e: eth1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None [ 10.649852] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready [ 11.191640] DS3000 chip version: 0.192 attached. [ 11.191991] dw2102: Attached ds3000+ds2020! [ 11.191992] [ 11.191996] DVB: registering adapter 0 frontend 0 (Montage Technology DS3000/TS2020)... [ 11.192814] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1c.0/0000:01:00.1/usb3/3-1/input/input2 [ 11.192834] dvb-usb: schedule remote query interval to 150 msecs. [ 11.192836] dvb-usb: TeVii S660 USB successfully initialized and connected. [ 11.192845] dvb-usb: found a 'TeVii S660 USB' in cold state, will try to load a firmware [ 11.194040] dvb-usb: downloading firmware from file 'dvb-usb-s660.fw' [ 11.194042] dw2102: start downloading DW210X firmware [ 11.351896] dvb-usb: found a 'TeVii S660 USB' in warm state. [ 11.351944] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer. [ 11.352358] DVB: registering new adapter (TeVii S660 USB) [ 11.612700] dvb-usb: MAC address: 00:18:bd:5b:57:6f [ 11.616174] DS3000 chip version: 0.192 attached. [ 11.616546] dw2102: Attached ds3000+ds2020! [ 11.616548] [ 11.616551] DVB: registering adapter 1 frontend 0 (Montage Technology DS3000/TS2020)... [ 11.617238] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1c.0/0000:01:00.3/usb4/4-1/input/input3 [ 11.617268] dvb-usb: schedule remote query interval to 150 msecs. [ 11.617270] dvb-usb: TeVii S660 USB successfully initialized and connected. [ 11.617281] usbcore: registered new interface driver dw2102 Вывод lsmod lsmod Module Size Used by ds3000 13227 2 ppdev 5471 0 parport_pc 27878 1 s3fb 14556 0 svgalib 8130 1 s3fb lp 7469 0 intel_agp 26903 0 agpgart 33230 1 intel_agp vgastate 9260 1 s3fb dvb_usb_dw2102 32753 0 dvb_usb 17704 1 dvb_usb_dw2102 dvb_core 86658 1 dvb_usb serio_raw 4094 0 parport 32432 3 ppdev,parport_pc,lp usb_storage 40513 2 r8169 40019 0 mii 4169 1 r8169 e1000e 134389 0 Какие еще логи могут понадобиться? Вставить ник Quote
server801 Posted November 19, 2011 Posted November 19, 2011 (edited) или карта брак или тарель не настроена.начни с дебы. ядро рабочее дам , но только х64 сделай лочку как я показал. Edited November 19, 2011 by server801 Вставить ник Quote
Davion Posted November 19, 2011 Author Posted November 19, 2011 да сейчас для начала воткну скайстарку гляну какой на ней уровень сигнала, покручу тарель а дальше мучать дебиан Вставить ник Quote
Guest novysf Posted October 17, 2012 Posted October 17, 2012 есть сдвиги в этой ветке? Вставить ник Quote
BSI_KSK Posted October 22, 2012 Posted October 22, 2012 А у меня с 460-й такой же результат. Скажите у кого работает такая карточка. И еще мпег4 она умеет? Вставить ник Quote
server801 Posted October 23, 2012 Posted October 23, 2012 Умеет она все , в том числе и HD . Но карты по качеству гуано , каждая вторая брак. Ищите альтернативу . Вставить ник Quote
