Askel Posted November 13, 2011 Posted November 13, 2011 Подскажи есть ли нюансы работы route-map (next-hop) при ip cef? А то 6 часовое выявление проблемы не дали результаты ! interface Vlan68 ip address xxx.yyy.190.1 255.255.255.0 ip policy route-map MOSCOW ! access-list 102 permit ip xxx.yyy.190.0 0.0.0.255 any ! route-map MOSCOW permit 10 match ip address 102 set global set ip next-hop xxx.yyy.28.17 ! Самое странное что route-map срабатывает route-map MOSCOW, permit, sequence 10 Match clauses: ip address (access-lists): 102 Set clauses: global ip next-hop xxx.yyy.28.17 Policy routing matches: 40 packets, 4312 bytes Extended IP access list 102 10 permit ip xxx.yyy.190.0 0.0.0.255 any (11 match) И дебаг показывает Nov 11 10:22:13 192.168.100.1 1708: .Nov 11 00:22:14.111: IP: s=xxx.yyy.190.190 (Vlan68), d=aaa.bbb.146.233, len 92, policy match Nov 11 10:22:13 192.168.100.1 1709: .Nov 11 00:22:14.111: IP: route map MOSCOW, item 10, permit Nov 11 10:22:13 192.168.100.1 1710: .Nov 11 00:22:14.111: IP: s=xxx.yyy.190.190 (Vlan68), d=aaa.bbb.146.233, len 92, set global Nov 11 10:22:13 192.168.100.1 1711: .Nov 11 00:22:14.111: IP: set global to outidb 0x14840190 Nov 11 10:22:13 192.168.100.1 1712: .Nov 11 00:22:14.111: IP: s=xxx.yyy.190.190 (Vlan68), d=aaa.bbb.146.233 (GigabitEthernet5/1), len 92, policy routed Nov 11 10:22:13 192.168.100.1 1713: .Nov 11 00:22:14.115: IP: Vlan68 to GigabitEthernet5/1 aaa.bbb.146.233 Вставить ник Quote
vurd Posted November 13, 2011 Posted November 13, 2011 Да поди ограничения какие-нибудь с vrf связанные, что будет если убрать "set global"? Вставить ник Quote
Askel Posted November 13, 2011 Author Posted November 13, 2011 Не помогает, set global - это уже последние опыты Вставить ник Quote
