Всем доброго времени суток.
Есть CCME поднятый на 3745.
CCME#sh ver
Cisco IOS Software, 3700 Software (C3745-ADVENTERPRISEK9-M), Version 12.4(11)XW7, RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
System image file is "flash:c3745-adventerprisek9-mz.124-11.XW7.bin"
Cisco 3745 (R7000) processor (revision 2.0) with 243712K/18432K bytes of memory.
Processor board ID JMX0844L4QT
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
12 Voice FXO interfaces
16 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
500472K bytes of ATA Slot0 CompactFlash (Read/Write)
CCME#sh telephony-service
CONFIG (Version=4.2(0))
Version 4.2(0)
Cisco Unified Communications Manager Express
ip source-address 192.168.1.198 port 2000
load 7912 CP7912080003SCCP070409A.sbin
load 7914 S00105000400
load 7960-7940 P00308010200
max-ephones 40
Вопрос как отучить ССМЕ делать вот такую гадость?
ССМЕ#sh sip-ua register status
Line          peer           expires(sec)  registered
101           20001            153           no
102           20002            153           no
103           20003            153           no
104           104              153           no
121           20004            153           no
122           122              153           no
124           20005            153           no
125           20006            153           no
126           20007            153           no
127           20027            153           no
128           20028            153           no
129           20009            153           no
130           20030            153           no
131           131              153           no
132           20010            153           no
133           20011            153           no
134           20034            153           no
135           20035            153           no
136           20036            153           no
137           20037            153           no
138           20038            153           no
139           20039            153           no
140           20040            151           no
141           20012            151           no
143           143              151           no
144           20013            151           no
145           145              151           no
146           20014            151           no
147           20015            151           no
149           20016            151           no
151           151              151           no
152           20017            150           no
161           20018            150           no
163           20019            150           no
164           20020            150           no
166           20021            150           no
168           168              150           no
169           9169             150           no
171           20024            150           no
172           20025            149           no
71            971              144           no
9             9                143           no
VaTrunk       -1               2843          yes
Вот настройки sip-ua
sip-ua
credentials username VaTrunk password 7 qweqwe realm 10.10.10.10
authentication username VaTrunk password 7 qweqwe
retry invite 5
retry response 5
retry cancel 5
retry register 5
timers trying 1000
timers register 150
registrar ipv4:10.10.10.10 expires 3600
sip-server ipv4:10.10.10.10
вот настройки пиров
dial-peer voice 972 voip
description Incomming Call from SIP Trunk
voice-class codec 1
session protocol sipv2
session target sip-server
incoming called-number .%
dtmf-relay rtp-nte
no vad
dial-peer voice 9972 voip
description Outgoing Call to SIP Trunk
destination-pattern 72
voice-class codec 1
dtmf-relay rtp-nte
no vad
У прова стоит астериск и кроме VaTrunk на астер пытаются заригиться все внутренние voip пиры
Edited by sunrise333
Команда "no-reg" для всех внутренних диал-пиров и экстеншнов
Спасибо.
no sip-register на dial-peer заработала
а вот на ephone-dn ткой команд не нашел.
Итак вопос открыт.
Проще написать no register на sip-ua, а register на нужных пирах. Писанины меньше.
На воисовых, не на потсовых пирах sip-register или register команды нет и на ephone-dn тоже нет.
Вопрос открыт.
Из войсовых пиров пытаются регатся только потсовые:)
Для отключения регистрации:
- ephone-dn: number 123 no-reg [primary|both]
Всем спасибо большое за участие и в особенности [Puno],
а так же [All is not what it seems] за помощь.
Этап пройден эта часть заработала как нужно.
Вопрос закрыт.
