Cisco Catalyst 6506 проблемы с загрузкой Не удалось обновить прошивку, куда дальше посмотреть?
Доброго времени!
Было закуплено несколько каталистов 6506, конфигурация одинаковая
Cat-CUS#sh ver
Cisco Internetwork Operating System Software
IOS ™ c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(27b)E3, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2007 by cisco Systems, Inc.
Compiled Tue 07-Aug-07 10:01 by hqluong
Image text-base: 0x40008F90, data-base: 0x4185C000
ROM: System Bootstrap, Version 12.2(17r)S5, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(27b)E3, RELEASE SOFTWARE (fc1)
Cat-CUS uptime is 28 weeks, 4 days, 5 hours, 10 minutes
Time since Cat-CUS switched to active is 28 weeks, 4 days, 5 hours, 14 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 08:17:56 msk Mon Apr 4 2011
System image file is "sup-bootflash:c6sup22-psv-mz.121-27b.E3.bin"
cisco WS-C6506 (R7000) processor (revision 3.0) with 458752K/65536K bytes of memory.
Processor board ID TSC070600JA
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
6 Virtual Ethernet/IEEE 802.3 interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
18 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2102
Cat-CUS#sh mod
Mod Ports Card Type Model Serial No.
1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-S2U-MSFC2 SAL0750QP19
3 16 SFM-capable 16 port 1000mb GBIC WS-X6516-GBIC SAD050316TF
5 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45 SAL0739M6ER
Mod MAC addresses Hw Fw Sw Status
1 0006.d65d.b834 to 0006.d65d.b835 5.0 7.1(1) 12.1(27b)E3 Ok
3 00d0.c0d4.3c54 to 00d0.c0d4.3c63 2.0 6.1(3) 8.5(0.23)COS Ok
5 000d.ed8b.4960 to 000d.ed8b.498f 7.4 5.4(2) 8.5(0.23)COS Ok
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 2 WS-F6K-PFC2 SAL0735KUD1 3.4 Ok
1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAL0806U3HU 2.6 Ok
Mod Online Diag Status
1 Pass
3 Pass
5 Pass
Cat-CUS#dir all-filesystems
Directory of sup-bootflash:/
1 -rw- 24997392 Feb 05 2010 00:39:28 +04:00 c6sup22-psv-mz.121-27b.E3.bin
31981568 bytes total (6984048 bytes free)
Directory of bootflash:/
1 -rw- 13575464 Feb 05 2010 00:43:18 +04:00 c6msfc2-psv-mz.121-27b.E3.bin
2 -rw- 1863420 Feb 05 2010 00:44:30 +04:00 c6msfc2-boot-mz.121-27b.E3.bin
31981568 bytes total (16542428 bytes free)
Заменил на sup-bootflash:/ IOS на другой и перезагрузился.
После перезагрузки система грузиться отказалась, можно войти только в ROMMON.
System Bootstrap, Version 7.1(1)
Copyright © 1994-2001 by cisco Systems, Inc.
c6k_sup2 processor with 262144 Kbytes of main memory
Autoboot executing command: "boot bootflash:c6sup22-psv-mz.121-27b.E3.bin"
open(): Open Error = -9
loadprog: error - on file open
boot: cannot load "bootflash:c6sup22-psv-mz.121-27b.E3.bin"
Autoboot executing command: "boot bootflash:c6svc5fmwam-g4js-mz.124-25.bin"
попытки запустить командой тоже к успеху не приводят
rommon 1 > boot bootflash:c6svc5fmwam-g4js-mz.124-25.bin
loadprog: bad file magic number: 0x0
boot: cannot load "bootflash:c6svc5fmwam-g4js-mz.124-25.bin"
Кроме того обратил внимание что пропал sup-bootflash:/, его содержимое
- залитый мною файл лежит в bootflash: а старый bootflash:
отсутствует.
rommon 2 > dev
Devices in device table:
id name
bootflash: boot flash
slot0: PCMCIA slot 0
disk0: PCMCIA slot 0
eprom: eprom
rommon 3 > dir bootflash:
File size Checksum File name
27492704 bytes (0x1a38160) 0xf51de010 c6svc5fmwam-g4js-mz.124-25.bin
Карта памяти маленькая фирменная цисковская на 16М, которая видна на
рабочем каталисте
Cat-CUS#dir slot0:
Directory of slot0:/
1 -rw- 15701088 Aug 19 2011 10:11:56 +04:00 wscmm-i6k9s-mz.124-17.bin
16384000 bytes total (682784 bytes free)
читаться отказывается
rommon 4 > dir disk0:
*** TLB (Store) Exception ***
Access address = 0x10000403
PC = 0x8000e564, Cause = 0xc, Status Reg = 0x30419003
monitor: command "dir" aborted due to exception
rommon 5 > dir slot0:
Нашел рекомендации Cisco по восстановлению
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml
а так же качественный перевод данной статьи от НАГ
http://nag.ru/projects/setup/36498/
там описано так
1. Выясните, в каком режиме ROMmon находится коммутатор.
выяснил, в режиме SP ROMmon.
2. В режиме SP ROMmon выполните команду boot.
Эта команда переводит коммутатор в режим RP ROMmon:
rommon 1 >boot
Self decompressing the image : #################################################
однако у меня после команды boot выдает так
rommon 1 > boot
boot: cannot load "bootflash:"
rommon 2 >
и никакого перехода в RP ROMmon не происходит...
rommon 2 > set
PS1=rommon ! >
CONFIG_FILE=
BOOTLDR=
SLOTCACHE=cards;
RET_2_RUTC=1088075455
BSI=0
RANDOM_NUM=1940481761
BOOT=bootflash:c6sup22-psv-mz.121-27b.E3.bin,1;bootflash:c6svc5fmwam-g4js-mz.124-25.bin,1
RET_2_RTS=13:51:59 msk Thu Aug 18 2011
RET_2_RCALTS=1313661119
?=1
прописывал BOOTLDR= , пытался залить через xmodem - безрезультатно.
Подскажите куда копать дальше?
Я понимаю, что чего-то не понимаю но вот чего не понимаю я не понимаю ;)
Заранее благодарю за любую помощь!
Share this post
Link to post
Share on other sites
Поменяйте флешку, купите несколько на 128 или 256 - какая нибудь да заработает.
Share this post
Link to post
RussTlt, а есть уверенность, что в файлике c6svc5fmwam-g4js-mz.124-25.bin софт, подходящий для Вашего Sup2? Судя по имени он для другой железки.
Share this post
Link to post
Да, я понимаю что IOS не тот (не подходит, бито залился и пр.)
Вопрос - что делать дальше???
Флешку попробую другую взять но имеющаяся цисковская фирменная флешка на другом таком же каталисте работает а в rommon не видна....
Share this post
Link to post
Для начала я попробовал-бы залить правильный IOS через xmodem.
Share this post
Link to post
или отформатировать флешку в другом роутере и в нём же залить правильный иос
так быстрее получится
Share this post
Link to post
Не проверял, что это за версии, но если у Вас раньше был CatOS и он заменен на IOS, то IOS не читает флешы отформатированные в CatOS.
Share this post
Link to post
Благодарю всех отозвавшихся, проблема решилась!
Примерно так и поступил - хороший человек дал другую флешку, которая прочиталась из rommon
Дальше дело техники, загрузился с нее и переписал в sup-bootflash:/ нужный IOS
Осталось загадкой почему не читалась цисковская карточка в rommon, которая читается под IOS но это похоже так и останется загадкой Cisco.
Никакого CatOS не было, флеш форматировалась под IOS на рабочей киске, там же на нее и заливался IOS.
Share this post
Link to post
И после заливки софта Вы ее "на горячую" выдернули?
Share this post
Link to post
А что в этом такого ? Я так не делал, но слышал, что давно так можно у цыски делать. В USB кардридер же можно CF втыкать и вытыкать без перезагрузки компа, значит в принципе такое возможно :-). Вопрос в реализации, вроде должно работать. Главное ничего не писать и не читать в момент перетыкания флеша.
Share this post
Link to post
Вобще да, может конечно в этом проблема но когда она помещалась назад, еще раз переформатировалась и заливался другой иос она была видна с файлом.
Для проверки вставлял в рабочий, читал - читается, из rommon - нет
Share this post
Link to post
Судя по
Флешка явно не класс С :) Выдергивать ее, это в лучшем случае 50/50.
Share this post
Link to post
Судя по
Да примерно та же ситуация была и с еще 2 картами за исключением того, что их не форматировали. В рабочем под ИОС файлы видны а под rommon нет. Насчет класса не скажу, шли в комплекте с 7204 и с ними проблем не было. После выдергивания и экспериментов были помещены назад - все читается без проблем...
А насчет slot0: и disk0: - та флешка, с которой удалось загрузиться определилась как slot0:, после загрузки ИОСа она же стала видится как disk0: Я приводил просто список видимых девайсов под rommon, к конкретной флешке отношения не имеют...
rommon 2 > dev
id name
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Sign in to follow this
