Созданы политики в зависимости от времени
 policy access-list Pol-in
 condition 1 time-range
  periodic weekend weekdays 00:00 to 01:59 class UDay
  periodic weekend weekdays 14:00 to 23:59 class UDay
seq 900 permit ip any any class UNight condition 1
policy access-list Pol-out
! subscriber profile Pol
  qos policy policing Pol-in
  qos policy metering Pol-out
radius service profile Pol8_24
 parameter value RateDay 8192
 parameter value BurstDay 1048576
 parameter value RateNight 24576
 parameter value BurstNight 3145728
 accounting in qos "UDay UNight"
 accounting out qos "UDay UNight"
 seq 10 attribute Dynamic-Policy-Filter "ip in forward class UDay qos"
 seq 20 attribute Dynamic-Policy-Filter "ip out forward class UDay qos"
 seq 50 attribute Dynamic-Policy-Filter "ip in forward class UNight qos"
 seq 60 attribute Dynamic-Policy-Filter "ip out forward class UNight qos"
 seq 90 attribute Dynamic-Qos-Parameter "meter-class-rate UDay rate-absolute $RateDay"
 seq 100 attribute Dynamic-Qos-Parameter "meter-class-burst UDay $BurstDay"
 seq 110 attribute Dynamic-Qos-Parameter "police-class-rate UDay rate-absolute $RateDay"
 seq 120 attribute Dynamic-Qos-Parameter "police-class-burst UDay $BurstDay"
 seq 170 attribute Dynamic-Qos-Parameter "meter-class-rate UNight rate-absolute $RateNight"
 seq 180 attribute Dynamic-Qos-Parameter "meter-class-burst UNight $BurstNight"
 seq 190 attribute Dynamic-Qos-Parameter "police-class-rate UNight rate-absolute $RateNight"
 seq 200 attribute Dynamic-Qos-Parameter "police-class-burst UNight $BurstNight"
 seq 250 attribute Service-Interim-Accounting 1200
По логике в 14-00 скорость у клиента должна менятся с 24Мб/с до 8Мб/с, но по графику на интерфейсе в этом время происходит резкий рост трафика.
Чем это может быть вызвано?
qos policy Pol-in policing radius-guided
access-group Pol-in local
 class UDay
  rate 2048 burst 262144
 class UNight
  rate 4096 burst 524288
qos policy Pol-out metering radius-guided
access-group Pol-out local
 class UDay
 class UNight
Они все однотипные, отличаются только названиями и значениями параметров RateDay/BurstDay и RateNight/BurstNight.
У всех RateDay < RateNight.
Вот вывод команды. Просто перечисление классов и их параметров. Какой из них используется не понятно.
В случае с Cisco по команде sh access-list видно какая часть в данный момент active.
Есть в SE600 аналог?
Circuit: 1/3 vlan-id 4011 pppoe 4396
Policy Name       : Marathon-in
Policy Type       : policing
Hierarchical Type : None
Rate              :                   Rate Source       :
Burst             :                   Excess Burst      :
Dynamic Parameters
Class 0:
Rate              : 51200             Burst             : 6553600
Excess Burst      :
Mark              :                   Value             :
Conform           :                   Value             :
Exceed            :                   Value             :
Violate           :                   Value             :
Class 1:
Rate              : 2048              Burst             : 262144
Excess Burst      :
Mark              :                   Value             :
Conform           :                   Value             :
Exceed            :                   Value             :
Violate           :                   Value             :
Class 2:
Rate              : 5120              Burst             : 655360
Excess Burst      :
Mark              :                   Value             :
Conform           :                   Value             :
Exceed            :                   Value             :
Violate           :                   Value             :
Class mapping     : 1-->0, 2-->0, 3-->0, 4-->0, 5-->0, 6-->0, 7-->0, 8-->0
Замерил изменения на одной из политик. Параметры с 2-00 до 13-59 - 5Мб/с после 14-00 - 2Мб/с.
Фактические значения: до 14-00 скорость соответствовала заявленной - 5Мб/с. В момент наступления 14-00 скорость не ограничивается. Если разорвать РРРоЕ соединение и подключится заново, то скорость соответствует - 2Мб/с. Если не разрывать соединение скорость остается без ограничений.
Прикладываю общий график.
>[local]se2#sh card 1 qos policing circuit 1/3:1023:63/6/2/107272
Slot 1 Ingress:
 Circuit 1/3:1023:63/6/2/107272, policy Marathon-in, id 42361b80/3000002d
  Class ID 1:
   Rate 51200 kbps, burst 6553600 bytes
   Max burst 460390400 clocks, duration 460390400 clocks
     last packet 112092425:782104 clocks/seconds
     left shift 0, right shift 2, multiplier 281
  Class ID 2:
   Rate 2048 kbps, burst 262144 bytes
   Max burst 460587008 clocks, duration 460587008 clocks
     last packet 596720750:777151 clocks/seconds
     left shift 0, right shift 0, multiplier 1757
  Class ID 3:
   Rate 5120 kbps, burst 655360 bytes
   Max burst 460718080 clocks, duration 460718080 clocks
     last packet 2147432757:778892 clocks/seconds
     left shift 0, right shift 0, multiplier 703
Тест показывает 17Мб/с
Slot 1 Ingress:
  Class ID 1:
  Class ID 2:
  Class ID 3:
У вас рост трафика в каком направлении происходит ? в metering наверное но не в policing
Выглядит точно так же
[local]se2#sh card 1 qos met circuit 1/3:1023:63/6/2/107272
Slot 1 Egress:
 Circuit 1/3:1023:63/6/2/107272, policy Marathon-out, id 627364c0/3000002d
  Class ID 1:
     last packet 1546846974:785104 clocks/seconds
  Class ID 2:
     last packet 660706080:777151 clocks/seconds
  Class ID 3:
     last packet 2024777249:778891 clocks/seconds
Число в last packet для class ID 2: меняется, остальные числа не меняются. Эффекта на ограничение скорости это не прибавляет.
просто посмотрите что qos изменялся с соответсвующими параметрами
245 1 1 112 circuit update policy 0/2 default-out
queue 0, up id 0 H-n flags 0
2/1:1023:63/7/2/117 mode 0x1 type 0x100
channel 0
Remap parent class array { 8, 8, 8, 8, 8, 8, 8, 8 }
246 19 1 60 Params update circuit parameters for 2/1:1023:63/7/2/117
Dynamic param rate - size 20
classid 0, rate 1024, burst 192000, excess_burst 0, % 0
set/reset 0x60/0
classid 0x1, rate 100000, burst 18750000, excess_burst 0, % 0
