Привет!
хелп плиз!
Вчера кончилась вся память на каталисте 3560G, выполняющая роль BGP роутера (на дефаултах):
Sep 22 23:00:45 1.1.1.1 182: Sep 22 23:14:24: %SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed from 0x1457418, alignme
Sep 22 23:00:45 1.1.1.1 183: Pool: Processor Free: 40232 Cause: Not enough free memory
Sep 22 23:00:45 1.1.1.1 184: Alternate Pool: None Free: 0 Cause: No Alternate pool
Sep 22 23:00:45 1.1.1.1 185: -Process= "BGP I/O", ipl= 0, pid= 81
Sep 22 23:00:45 1.1.1.1 186: -Traceback= C56458 C56B6C 14285A8 142CCA0 145741C A62C8C A2F298 A33274 A34584 A34A00 90AB90 901858
Sep 22 23:00:45 1.1.1.1 187: Sep 22 23:14:24: %BGP-5-ADJCHANGE: neighbor A Down No memory
Sep 22 23:00:45 1.1.1.1 188: Sep 22 23:14:24: %BGP-5-ADJCHANGE: neighbor B Down No memory
Sep 22 23:00:45 1.1.1.1 189: Sep 22 23:14:24: %BGP-5-ADJCHANGE: neighbor C Down No memory
Sep 22 23:00:45 1.1.1.1 190: Sep 22 23:14:24: %BGP-5-ADJCHANGE: neighbor D Down No memory
Sep 22 23:00:45 1.1.1.1 191: Sep 22 23:14:24: %BGP-5-ADJCHANGE: neighbor E Down No memory
помогла только перезагрузка
ИОС: Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(44)SE1, RELEASE SOFTWARE (fc1)
вот как расходуется память:
sh mem free: free 55217200
через 10 сек: free 55215612
#sh proc memory sorted allocated
Processor Pool Total: 84504788 Used: 29278836 Free: 55225952
I/O Pool Total: 8380416 Used: 3597620 Free: 4782796
Driver te Pool Total: 1048576 Used: 40 Free: 1048536
PID TTY Allocated Freed Holding Getbufs Retbufs Process
124 0 341633480 340093480 24996 0 0 HQM Stack Proces
280 0 244807052 385958268 12924 0 0 SNMP ENGINE
125 0 177024056 177024056 60924 0 0 HRPC qos request
278 0 173528644 173527728 13840 0 0 IP SNMP
279 0 141151216 0 12924 0 0 PDU DISPATCHER
0 0 82635168 80210616 4128108 5369644 2002472 *Dead*
0 0 38102352 13532380 22025304 0 0 *Init*
50 0 24234364 34915784 6924 0 0 RedEarth Tx Mana
222 0 21231976 0 6924 0 0 MDFS RP process
81 0 18911276 65580 9924 0 0 BGP I/O
242 0 13698856 19163740 342216 0 0 BGP Router
116 0 10455132 180 6924 0 0 Hulc LED Process
194 0 9978964 15652 16532 0 0 TCP Protocols
каковы могут быть причины утечки памяти, и чем можно это вылечить? может обновить ios?
(посоветовали ребутнуться с иосом c3560-advipservicesk9-mz.122-46.SE.bin)
есть еще идеи?
спасибо.
Edited by dbask
vurd
софт реконфиг отключен только на одного аплинка (который вовремя на давал только default)
на втором аплинке (две параллельные BGP сессии - софт реконфиг включен, но там точно прилетает только default)
Много лет стоит на бордере каталист с ipservices.12-2-50.SE2, десяток bgp-пиров, везде включен soft-reconfig и все ок. Попробуйте эту версию залить для начала.
