Сервер.
# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 23
model name : Intel® Celeron® CPU E3400 @ 2.60GHz
stepping : 10
cpu MHz : 2621.586
cache size : 1024 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx lm constant_tsc pni monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr lahf_lm
bogomips : 5243.17
processor : 1
cpu family : 6
model : 23
stepping : 10
cpu MHz : 2621.586
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 5242.91
С картами
02:00.0 Ethernet controller: Intel Corporation 82541PI Gigabit Ethernet Controller (rev 05)
Subsystem: Intel Corporation PRO/1000 GT Desktop Adapter
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 209
Memory at febe0000 (32-bit, non-prefetchable)
Memory at febc0000 (32-bit, non-prefetchable)
I/O ports at ec00
Expansion ROM at 50000000 [disabled]
Capabilities: [dc] Power Management version 2
Capabilities: [e4] PCI-X non-bridge device
Kernel driver in use: e1000
Kernel modules: e1000
02:01.0 Ethernet controller: Intel Corporation 82541PI Gigabit Ethernet Controller (rev 05)
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 169
Memory at feb80000 (32-bit, non-prefetchable)
Memory at feb60000 (32-bit, non-prefetchable)
I/O ports at e880
Expansion ROM at 50020000 [disabled]
ip 192.168.10.254 и алиас 192.168.230.1
# ethtool -S eth1
NIC statistics:
rx_packets: 116327680
tx_packets: 175491901
rx_bytes: 20380783521
tx_bytes: 216747380072
rx_broadcast: 95875
tx_broadcast: 1406182
rx_multicast: 136998
tx_multicast: 30
rx_errors: 0
tx_errors: 0
tx_dropped: 0
multicast: 136998
collisions: 0
rx_length_errors: 0
rx_over_errors: 0
rx_crc_errors: 0
rx_frame_errors: 0
rx_no_buffer_count: 0
rx_missed_errors: 0
tx_aborted_errors: 0
tx_carrier_errors: 0
tx_fifo_errors: 0
tx_heartbeat_errors: 0
tx_window_errors: 0
tx_abort_late_coll: 0
tx_deferred_ok: 0
tx_single_coll_ok: 0
tx_multi_coll_ok: 0
tx_timeout_count: 0
tx_restart_queue: 402
rx_long_length_errors: 0
rx_short_length_errors: 0
rx_align_errors: 0
tx_tcp_seg_good: 0
tx_tcp_seg_failed: 0
rx_flow_control_xon: 0
rx_flow_control_xoff: 0
tx_flow_control_xon: 0
tx_flow_control_xoff: 0
rx_long_byte_count: 20380783521
rx_csum_offload_good: 111696431
rx_csum_offload_errors: 61
rx_header_split: 0
alloc_rx_buff_failed: 0
tx_smbus: 0
rx_smbus: 0
dropped_smbus: 0
Выглядит как:
GW_PROV --- SERVER --- SWITH --- BRIDGE
+--- M5
ping на бридж и m5
64 bytes from 192.168.230.12: icmp_req=11725 ttl=64 time=1.17 ms
64 bytes from 192.168.230.12: icmp_req=11726 ttl=64 time=0.931 ms
64 bytes from 192.168.230.12: icmp_req=11727 ttl=64 time=1.14 ms
64 bytes from 192.168.230.12: icmp_req=11728 ttl=64 time=1.80 ms
64 bytes from 192.168.230.12: icmp_req=11729 ttl=64 time=0.908 ms
64 bytes from 192.168.230.12: icmp_req=11730 ttl=64 time=2.25 ms
64 bytes from 192.168.230.12: icmp_req=11731 ttl=64 time=1.69 ms
64 bytes from 192.168.230.12: icmp_req=11732 ttl=64 time=1.68 ms
64 bytes from 192.168.230.12: icmp_req=11733 ttl=64 time=1.29 ms
64 bytes from 192.168.230.12: icmp_req=11734 ttl=64 time=2.32 ms
64 bytes from 192.168.230.12: icmp_req=11735 ttl=64 time=1.25 ms
64 bytes from 192.168.230.12: icmp_req=11736 ttl=64 time=1.60 ms
64 bytes from 192.168.230.12: icmp_req=11737 ttl=64 time=2.19 ms
Другими словами все отлично.
А вот пинг на интерфейс сервера выгладит не много удручающе.
1508 bytes from 192.168.10.254: icmp_req=12005 ttl=64 time=10.8 ms
1508 bytes from 192.168.10.254: icmp_req=12006 ttl=64 time=9.69 ms
1508 bytes from 192.168.10.254: icmp_req=12007 ttl=64 time=18.5 ms
1508 bytes from 192.168.10.254: icmp_req=12008 ttl=64 time=8.17 ms
1508 bytes from 192.168.10.254: icmp_req=12009 ttl=64 time=19.2 ms
1508 bytes from 192.168.10.254: icmp_req=12011 ttl=64 time=13.7 ms
1508 bytes from 192.168.10.254: icmp_req=12012 ttl=64 time=16.5 ms
1508 bytes from 192.168.10.254: icmp_req=12013 ttl=64 time=13.6 ms
1508 bytes from 192.168.10.254: icmp_req=12014 ttl=64 time=35.3 ms
1508 bytes from 192.168.10.254: icmp_req=12015 ttl=64 time=10.7 ms
1508 bytes from 192.168.10.254: icmp_req=12016 ttl=64 time=11.6 ms
1508 bytes from 192.168.10.254: icmp_req=12017 ttl=64 time=123 ms
1508 bytes from 192.168.10.254: icmp_req=12018 ttl=64 time=18.2 ms
1508 bytes from 192.168.10.254: icmp_req=12019 ttl=64 time=12.7 ms
1508 bytes from 192.168.10.254: icmp_req=12020 ttl=64 time=21.7 ms
1508 bytes from 192.168.10.254: icmp_req=12021 ttl=64 time=37.6 ms
1508 bytes from 192.168.10.254: icmp_req=12022 ttl=64 time=13.3 ms
1508 bytes from 192.168.10.254: icmp_req=12023 ttl=64 time=27.7 ms
1508 bytes from 192.168.10.254: icmp_req=12024 ttl=64 time=99.0 ms
1508 bytes from 192.168.10.254: icmp_req=12027 ttl=64 time=87.2 ms
1508 bytes from 192.168.10.254: icmp_req=12028 ttl=64 time=10.8 ms
1508 bytes from 192.168.10.254: icmp_req=12029 ttl=64 time=66.9 ms
1508 bytes from 192.168.10.254: icmp_req=12030 ttl=64 time=133 ms
1508 bytes from 192.168.10.254: icmp_req=12031 ttl=64 time=14.6 ms
1508 bytes from 192.168.10.254: icmp_req=12032 ttl=64 time=12.7 ms
1508 bytes from 192.168.10.254: icmp_req=12033 ttl=64 time=17.6 ms
1508 bytes from 192.168.10.254: icmp_req=12034 ttl=64 time=14.8 ms
1508 bytes from 192.168.10.254: icmp_req=12035 ttl=64 time=19.3 ms
1508 bytes from 192.168.10.254: icmp_req=12036 ttl=64 time=69.7 ms
1508 bytes from 192.168.10.254: icmp_req=12037 ttl=64 time=13.4 ms
1508 bytes from 192.168.10.254: icmp_req=12038 ttl=64 time=11.0 ms
1508 bytes from 192.168.10.254: icmp_req=12039 ttl=64 time=13.2 ms
1508 bytes from 192.168.10.254: icmp_req=12040 ttl=64 time=11.2 ms
1508 bytes from 192.168.10.254: icmp_req=12041 ttl=64 time=15.6 ms
1508 bytes from 192.168.10.254: icmp_req=12042 ttl=64 time=32.5 ms
1508 bytes from 192.168.10.254: icmp_req=12043 ttl=64 time=16.2 ms
1508 bytes from 192.168.10.254: icmp_req=12044 ttl=64 time=14.8 ms
1508 bytes from 192.168.10.254: icmp_req=12045 ttl=64 time=17.1 ms
1508 bytes from 192.168.10.254: icmp_req=12046 ttl=64 time=65.1 ms
1508 bytes from 192.168.10.254: icmp_req=12047 ttl=64 time=16.4 ms
1508 bytes from 192.168.10.254: icmp_req=12048 ttl=64 time=15.5 ms
1508 bytes from 192.168.10.254: icmp_req=12049 ttl=64 time=16.9 ms
Появляются кучи непонятных задержек в пакетах, что влияет на общую производительность.
На сервере работает
Linux prov.local 2.6.18-238.12.1.el5.028stab091.1 #1 SMP Wed Jun 1 13:55:18 MSD 2011 i686 i686 i386 GNU/Linux
# cat /etc/redhat-release
CentOS release 5.6 (Final)
Сделал:
# cat /proc/interrupts
CPU0 CPU1
0: 174332251 30145 IO-APIC-edge timer
1: 2 6 IO-APIC-edge i8042
7: 1 1 IO-APIC-edge parport0
8: 2 1 IO-APIC-edge rtc
9: 0 0 IO-APIC-level acpi
12: 2 2 IO-APIC-edge i8042
169: 15694932 122872645 IO-APIC-level eth1
201: 2206 6975472 IO-APIC-level ata_piix
209: 1484 163388038 IO-APIC-level eth0
NMI: 0 0
LOC: 175393403 175393402
RES: 12289823 983840
ERR: 0
MIS: 0
Не много помогло, но все равно ерунда полная.
Куда еще можно посмотреть и на что глянуть?
Скоро надо разворачивать еще ppptp и pppoe, но эта машинка явно не потянет это дело.
# ethtool -k eth1
Offload parameters for eth1:
Cannot get device udp large send offload settings: Operation not supported
rx-checksumming: on
tx-checksumming: on
scatter-gather: on
tcp segmentation offload: on
udp fragmentation offload: off
generic segmentation offload: off
generic-receive-offload: off
# ethtool -g eth1
Ring parameters for eth1:
Pre-set maximums:
RX: 4096
RX Mini: 0
RX Jumbo: 0
TX: 4096
Current hardware settings:
RX: 256
RX Mini: 0
RX Jumbo: 0
TX: 256
# modinfo igb
filename: /lib/modules/2.6.18-238.12.1.el5.028stab091.1/kernel/drivers/net/igb/igb.ko
version: 2.1.0-k2-1
license: GPL
description: Intel® Gigabit Ethernet Network Driver
author: Intel Corporation, <e1000-devel@lists.sourceforge.net>
srcversion: 53DE31944CEBA8B3896B7E8
alias: pci:v00008086d000010D6sv*sd*bc*sc*i*
alias: pci:v00008086d000010A9sv*sd*bc*sc*i*
alias: pci:v00008086d000010A7sv*sd*bc*sc*i*
alias: pci:v00008086d000010E8sv*sd*bc*sc*i*
alias: pci:v00008086d00001526sv*sd*bc*sc*i*
alias: pci:v00008086d0000150Dsv*sd*bc*sc*i*
alias: pci:v00008086d000010E7sv*sd*bc*sc*i*
alias: pci:v00008086d000010E6sv*sd*bc*sc*i*
alias: pci:v00008086d00001518sv*sd*bc*sc*i*
alias: pci:v00008086d0000150Asv*sd*bc*sc*i*
alias: pci:v00008086d000010C9sv*sd*bc*sc*i*
alias: pci:v00008086d00001516sv*sd*bc*sc*i*
alias: pci:v00008086d00001511sv*sd*bc*sc*i*
alias: pci:v00008086d00001510sv*sd*bc*sc*i*
alias: pci:v00008086d0000150Fsv*sd*bc*sc*i*
alias: pci:v00008086d0000150Esv*sd*bc*sc*i*
alias: pci:v00008086d00001524sv*sd*bc*sc*i*
alias: pci:v00008086d00001523sv*sd*bc*sc*i*
alias: pci:v00008086d00001522sv*sd*bc*sc*i*
alias: pci:v00008086d00001521sv*sd*bc*sc*i*
depends: dca,8021q
vermagic: 2.6.18-238.12.1.el5.028stab091.1 SMP mod_unload 686 REGPARM gcc-4.1
parm: max_vfs:Maximum number of virtual functions to allocate per physical function (uint)
Собственно вот все что есть.
старое:
# modinfo e1000
filename: /lib/modules/2.6.18-238.12.1.el5.028stab091.1/kernel/drivers/net/e1000/e1000.ko
version: 7.3.21-k4-3-NAPI
license: GPL
description: Intel® PRO/1000 Network Driver
author: Intel Corporation, <linux.nics@intel.com>
srcversion: 2B6567746A6C60FF5C50F4D
alias: pci:v00008086d000010B5sv*sd*bc*sc*i*
alias: pci:v00008086d00001099sv*sd*bc*sc*i*
alias: pci:v00008086d0000108Asv*sd*bc*sc*i*
alias: pci:v00008086d0000107Csv*sd*bc*sc*i*
alias: pci:v00008086d0000107Bsv*sd*bc*sc*i*
alias: pci:v00008086d0000107Asv*sd*bc*sc*i*
alias: pci:v00008086d00001079sv*sd*bc*sc*i*
alias: pci:v00008086d00001078sv*sd*bc*sc*i*
alias: pci:v00008086d00001077sv*sd*bc*sc*i*
alias: pci:v00008086d00001076sv*sd*bc*sc*i*
alias: pci:v00008086d00001075sv*sd*bc*sc*i*
alias: pci:v00008086d00001028sv*sd*bc*sc*i*
alias: pci:v00008086d00001027sv*sd*bc*sc*i*
alias: pci:v00008086d00001026sv*sd*bc*sc*i*
alias: pci:v00008086d0000101Esv*sd*bc*sc*i*
alias: pci:v00008086d0000101Dsv*sd*bc*sc*i*
alias: pci:v00008086d0000101Asv*sd*bc*sc*i*
alias: pci:v00008086d00001019sv*sd*bc*sc*i*
alias: pci:v00008086d00001018sv*sd*bc*sc*i*
alias: pci:v00008086d00001017sv*sd*bc*sc*i*
alias: pci:v00008086d00001016sv*sd*bc*sc*i*
alias: pci:v00008086d00001015sv*sd*bc*sc*i*
alias: pci:v00008086d00001014sv*sd*bc*sc*i*
alias: pci:v00008086d00001013sv*sd*bc*sc*i*
alias: pci:v00008086d00001012sv*sd*bc*sc*i*
alias: pci:v00008086d00001011sv*sd*bc*sc*i*
alias: pci:v00008086d00001010sv*sd*bc*sc*i*
alias: pci:v00008086d0000100Fsv*sd*bc*sc*i*
alias: pci:v00008086d0000100Esv*sd*bc*sc*i*
alias: pci:v00008086d0000100Dsv*sd*bc*sc*i*
alias: pci:v00008086d0000100Csv*sd*bc*sc*i*
alias: pci:v00008086d00001009sv*sd*bc*sc*i*
alias: pci:v00008086d00001008sv*sd*bc*sc*i*
alias: pci:v00008086d00001004sv*sd*bc*sc*i*
alias: pci:v00008086d00001001sv*sd*bc*sc*i*
alias: pci:v00008086d00001000sv*sd*bc*sc*i*
depends: e1000e
parm: TxDescriptors:Number of transmit descriptors (array of int)
parm: TxDescPower:Binary exponential size (2^X) of each transmit descriptor (array of int)
parm: RxDescriptors:Number of receive descriptors (array of int)
parm: Speed:Speed setting (array of int)
parm: Duplex:Duplex setting (array of int)
parm: AutoNeg:Advertised auto-negotiation setting (array of int)
parm: FlowControl:Flow Control setting (array of int)
parm: XsumRX:Disable or enable Receive Checksum offload (array of int)
parm: TxIntDelay:Transmit Interrupt Delay (array of int)
parm: TxAbsIntDelay:Transmit Absolute Interrupt Delay (array of int)
parm: RxIntDelay:Receive Interrupt Delay (array of int)
parm: RxAbsIntDelay:Receive Absolute Interrupt Delay (array of int)
parm: InterruptThrottleRate:Interrupt Throttling Rate (array of int)
parm: SmartPowerDownEnable:Enable PHY smart power down (array of int)
parm: KumeranLockLoss:Enable Kumeran lock loss workaround (array of int)
parm: copybreak:Maximum size of packet that is copied to a new buffer on receive (uint)
parm: debug:Debug level (0=none,...,16=all) (int)
новое:
# modinfo e1000
filename: /lib/modules/2.6.18-238.19.1.el5/kernel/drivers/net/e1000/e1000.ko
version: 8.0.30-NAPI
license: GPL
srcversion: 1D436A0D02B18BE145D2AE1
depends: 8021q
vermagic: 2.6.18-238.19.1.el5 SMP mod_unload 686 REGPARM 4KSTACKS gcc-4.1
parm: TxDescriptorStep:Transmit Descriptor Step (array of int)
parm: ignore_64bit_dma:Ignore 64-bit DMA (DAC) capability (int)
Сейчас правда загрузки всего 11-15мегабит и порядка 5к pps, но пока вот такие результаты:
1508 bytes from 192.168.10.254: icmp_req=327 ttl=64 time=6.82 ms
1508 bytes from 192.168.10.254: icmp_req=328 ttl=64 time=16.7 ms
1508 bytes from 192.168.10.254: icmp_req=329 ttl=64 time=8.46 ms
1508 bytes from 192.168.10.254: icmp_req=330 ttl=64 time=12.1 ms
1508 bytes from 192.168.10.254: icmp_req=331 ttl=64 time=8.40 ms
1508 bytes from 192.168.10.254: icmp_req=332 ttl=64 time=18.2 ms
1508 bytes from 192.168.10.254: icmp_req=333 ttl=64 time=6.65 ms
1508 bytes from 192.168.10.254: icmp_req=334 ttl=64 time=9.34 ms
1508 bytes from 192.168.10.254: icmp_req=335 ttl=64 time=18.9 ms
1508 bytes from 192.168.10.254: icmp_req=336 ttl=64 time=12.5 ms
1508 bytes from 192.168.10.254: icmp_req=337 ttl=64 time=11.5 ms
1508 bytes from 192.168.10.254: icmp_req=338 ttl=64 time=14.3 ms
1508 bytes from 192.168.10.254: icmp_req=339 ttl=64 time=7.25 ms
1508 bytes from 192.168.10.254: icmp_req=340 ttl=64 time=8.55 ms
1508 bytes from 192.168.10.254: icmp_req=341 ttl=64 time=9.07 ms
1508 bytes from 192.168.10.254: icmp_req=342 ttl=64 time=9.94 ms
1508 bytes from 192.168.10.254: icmp_req=343 ttl=64 time=11.6 ms
1508 bytes from 192.168.10.254: icmp_req=344 ttl=64 time=18.4 ms
1508 bytes from 192.168.10.254: icmp_req=345 ttl=64 time=15.9 ms
1508 bytes from 192.168.10.254: icmp_req=346 ttl=64 time=8.83 ms
1508 bytes from 192.168.10.254: icmp_req=347 ttl=64 time=8.11 ms
1508 bytes from 192.168.10.254: icmp_req=348 ttl=64 time=11.0 ms
1508 bytes from 192.168.10.254: icmp_req=349 ttl=64 time=10.7 ms
1508 bytes from 192.168.10.254: icmp_req=350 ttl=64 time=8.24 ms
1508 bytes from 192.168.10.254: icmp_req=351 ttl=64 time=10.7 ms
1508 bytes from 192.168.10.254: icmp_req=352 ttl=64 time=12.2 ms
1508 bytes from 192.168.10.254: icmp_req=353 ttl=64 time=11.5 ms
Вроде как частично в чем-то помогло, нету заржек более 100ms, но как говориться еще не вечер, скоро нагрузка будет подниматся и тогда будет видно
Но покажите-ка еще ... и modinfo igb.
Да при чем тут igb, если там древнючие сетевухи стоят?
2 Megas - попробуйте для начала собрать последние драйвера для этих адаптеров.
Пардон, не заметил. Я думал, таких уже не бывает.
Megas,
И да - попробуйте драйвера с сайта Интела.
Еще попробуйте увеличить ring buffer до 4096 (это где-то в районе ethtool -g).
ethtool -G eth1 rx 4096 tx 4096
# ethtool -g eth1
Pre-set maximums:
RX: 4096
RX Mini: 0
RX Jumbo: 0
TX: 4096
RX: 4096
RX Mini: 0
RX Jumbo: 0
TX: 4096
1508 bytes from 192.168.10.254: icmp_req=3339 ttl=64 time=25.5 ms
1508 bytes from 192.168.10.254: icmp_req=3340 ttl=64 time=79.4 ms
1508 bytes from 192.168.10.254: icmp_req=3341 ttl=64 time=10.9 ms
1508 bytes from 192.168.10.254: icmp_req=3342 ttl=64 time=12.7 ms
1508 bytes from 192.168.10.254: icmp_req=3343 ttl=64 time=13.1 ms
1508 bytes from 192.168.10.254: icmp_req=3344 ttl=64 time=114 ms
1508 bytes from 192.168.10.254: icmp_req=3346 ttl=64 time=56.1 ms
1508 bytes from 192.168.10.254: icmp_req=3347 ttl=64 time=8.27 ms
1508 bytes from 192.168.10.254: icmp_req=3348 ttl=64 time=115 ms
1508 bytes from 192.168.10.254: icmp_req=3349 ttl=64 time=83.3 ms
1508 bytes from 192.168.10.254: icmp_req=3350 ttl=64 time=66.4 ms
1508 bytes from 192.168.10.254: icmp_req=3351 ttl=64 time=12.2 ms
1508 bytes from 192.168.10.254: icmp_req=3352 ttl=64 time=10.8 ms
1508 bytes from 192.168.10.254: icmp_req=3353 ttl=64 time=12.0 ms
1508 bytes from 192.168.10.254: icmp_req=3354 ttl=64 time=94.7 ms
один черт, на соседнее устройство рядом с этим сервом пинг 2-3мс, а на сервер прыгает что подорванный.
Дрова обовил, количество буферов поменял.
martini, спасибо, уже увидел, лажанулся, но зато сейчас смотрю что при пике в 30мегабит как раз 1508 байт проходят на ура.
  • 2 months later...
В общем снова полезли какие-то траблы, только вот теперь ширина канала по более, порядка 200мегабит.
А вот выжать максимум что-то не получается.
И как правильно диагностировать производительность канала тоже не совсем понятно.
К стати, чтиво:
http://www.redbooks.ibm.com/redpapers/pdfs/redp4285.pdf
кто нибудь осиливал?
