postuser Posted July 12, 2011 Posted July 12, 2011 (edited) Подскажите, есть ли конвертер из NetFlow V9 в V5. Нужно для получения статистики с Cisco SCE. Или как можно заставить flow-tools работать с 9-ой версией. Edited July 12, 2011 by postuser Вставить ник Quote
GFORGX Posted July 12, 2011 Posted July 12, 2011 nProbe. It can be a probe, probe+collector, collector, or a proxy. In proxy mode you can convert from/to IPFIX/NetFlow v5/v9 in order to smoothly upgrade to newer netflow protocol versions while capitalizing on previous protocol versions. So you can for instance convert flows coming from your v5 router into IPFIX and vice-versa. Note that with some combinations (e.g. from v9 to v5) you might loose some flow information. Вставить ник Quote
postuser Posted July 12, 2011 Author Posted July 12, 2011 (edited) Его уже смотрели раньше. Он закрытый и платный (: Есть еще этот http://search.cpan.org/~shamrock/RDR-Collector-1.0000/, но это просто коллектор, он не умеет конвертировать в NetFlow V5. И еще не понятно, в каком виде он может выводить данные Edited July 12, 2011 by postuser Вставить ник Quote
shefys Posted July 12, 2011 Posted July 12, 2011 можете посмотреть в сторону nfdump: http://nfdump.sourceforge.net/ NFDUMP tools overview All tools support netflow v5, v7 and v9. nfcapd - netflow capture daemon. Reads the netflow data from the network and stores the data into files. Automatically rotate files every n minutes. ( typically ever 5 min ) nfcapd reads netflow v5, v7 and v9 flows transparently. You need one nfcapd process for each netflow stream. nfdump - netflow dump. Reads the netflow data from the files stored by nfcapd. It's syntax is similar to tcpdump. If you like tcpdump you will like nfdump. Displays netflow data and can create lots of top N statistics of flows IP addresses, ports etc ordered by whatever order you like. nfprofile - netflow profiler. Reads the netflow data from the files stored by nfcapd. Filters the netflow data according to the specified filter sets ( profiles ) and stores the filtered data into files for later use. nfreplay - netflow replay Reads the netflow data from the files stored by nfcapd and sends it over the network to another host. nfclean.pl - cleanup old data Sample script to cleanup old data. You may run this script every hour or so. ft2nfdump - Read and convert flow-tools data. Reads flow-tools data from files or from stdin in a chain of flow-tools commands and converts the data into nfdump format to be processed by nfdump. Вставить ник Quote
nshut Posted September 14, 2012 Posted September 14, 2012 (edited) день добрый. тема конечно устарела, но я также искал данный конвертер, т.к. флоу тулз имеет много полезных утилит. остановился на flowd у него есть также фильтры отсечения ненужного трафика, т.е. например потоки локального трафика. но есть минусы, чтобы отправить в 5 версию надо уже разбирать сформированный файл, т.к. он сам его не ротэйтит, приходиться убивать демон. а версия 9 это всетаки шаблонная, значит идет потеря трафика пока демон шаблонов нацепляет, убивая каджые 5 минут объем множится. главный минус не умеет отправлять не в stdout не в pipe. поковырял исходники и дописал патч к версии flowd-0.9.1_2 теперь с параметром -n программа валит поток в stderr в cvs формате как и flowd-reader, что прекрастно понимают flow-tools, так же с данным параметром не сохраняется дамп на диск, т.к. я его отправляю в другой графический колектор уже удалив ненужные потоки, что ненапрягает диск лишний раз и не забивает место. ну или прячет виайпи :) патч прилагаю, пользуйтесь. ну и запуск уже работающего фильтра для колектора у меня такой flowd -n -f /usr/local/etc/flowd.conf 2>&1|flow-import -V5 -f2|flow-send -V5 127.0.0.1/127.0.0.1/9995 нагрузки на процессоры пока замечено небыло надеюсь flowd всетаки допишет утилиту для онлайн сбора и обработки flowd.c.diff.txt Edited September 14, 2012 by nshut Вставить ник Quote
raveren Posted January 16, 2013 Posted January 16, 2013 nshut flowd понимает статистику в формате NetFlow v9 от Cisco SCE или это описание не для нее? Вставить ник Quote
murzik_one Posted April 15, 2013 Posted April 15, 2013 Кто может подсказать в чем дело. Циска шлет какой то странный аккаунтинг v9. 1366063145,0,7692574,172.23.236.144,0,0,0,0,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063145,0,7692574,172.23.236.144,0,0,0,0,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063145,0,7692574,172.23.236.144,0,0,0,0,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063145,0,7692574,172.23.236.144,0,0,0,0,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063145,0,7692574,172.23.236.144,0,0,0,0,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063145,0,7692574,172.23.236.144,0,0,0,0,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063145,0,7692574,172.23.236.144,0,0,0,0,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063145,0,7692574,172.23.236.144,0,0,0,0,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063145,0,7692574,172.23.236.144,0,0,0,0,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063145,0,7692574,172.23.236.144,0,0,0,0,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063145,0,7692574,172.23.236.144,0,0,0,0,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063146,0,7693445,172.23.236.144,0,0,34359738368,34359738368,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 1366063146,0,7693445,172.23.236.144,0,0,34359738368,34359738368,0,0,(null),(null),(null),0,0,0,0,0,0,0,0,0,0,0 Что и где копнуть? SCE 1010 v3.8.5 Вставить ник Quote
Igor Diakonov Posted April 15, 2013 Posted April 15, 2013 nshut flowd понимает статистику в формате NetFlow v9 от Cisco SCE или это описание не для нее? Для SCE можно вот эту софтинку посмотреть: https://github.com/littlesavage/rdr2netflow Вставить ник Quote
murzik_one Posted April 15, 2013 Posted April 15, 2013 (edited) Для SCE можно вот эту софтинку посмотреть: https://github.com/l...age/rdr2netflow уже смотрю при запуске с -V 1 все пусто... при -V 10 и -V 100 активно данные сыпятся в консоль. но на выходе ничего нет. где еще копать? RDR FLOW_START_RDR(0xf0f0f016) .144:4544 -> .53:80, PPC: 3, FC_ID: 149220, size: 150, fields: 17 RDR UNKNOWN(0xf0f0f546) .17:19740 -> .66:80, PPC: 1, FC_ID: 185058, size: 369, fields: 29 RDR FLOW_START_RDR(0xf0f0f016) .3:2927 -> .2:80, PPC: 2, FC_ID: 39534, size: 154, fields: 17 RDR UNKNOWN(0xf0f0f546) .28:52802 -> .188:10095, PPC: 2, FC_ID: 57868, size: 258, fields: 29 RDR FLOW_END_RDR(0xf0f0f018) .187:1178 -> .209:80, PPC: 3, FC_ID: 198996, size: 149, fields: 17 RDR UNKNOWN(0xf0f0f546) .203:59301 -> .119:25, PPC: 3, FC_ID: 218114, size: 258, fields: 29 RDR FLOW_START_RDR(0xf0f0f016) .101:4113 -> .203:1080, PPC: 3, FC_ID: 210744, size: 149, fields: 17 RDR UNKNOWN(0xf0f0f546) .16:62612 -> .36:63808, PPC: 3, FC_ID: 194092, size: 258, fields: 29 RDR FLOW_START_RDR(0xf0f0f016) .175:59843 -> .53:80, PPC: 1, FC_ID: 160531, size: 148, fields: 17 RDR ANONYMIZED_HTTP_TRANSACTION_USAGE_RDR(0xf0f0f53c) .2:59916 -> .215:80, PPC: 3, FC_ID: 213666, size: 455, fields: 33 RDR FLOW_END_RDR(0xf0f0f018) .111:2296 -> .197:28000, PPC: 1, FC_ID: 171618, size: 154, fields: 17 Field 01 STRING(41), 19 bytes: perekreshenko_17_70 Field 02 INT16(12), 02 bytes: 4 Field 03 INT32(13), 04 bytes: 63 Field 04 UINT8(14), 01 bytes: 17 Field 05 UINT32(16), 04 bytes: 3256667845 Field 06 UINT16(15), 02 bytes: 28000 Field 07 UINT32(16), 04 bytes: 3658870895 Field 08 UINT16(15), 02 bytes: 2296 Field 09 UINT8(14), 01 bytes: 1 Field 10 UINT32(16), 04 bytes: 1366086956 Field 11 UINT32(16), 04 bytes: 1366086978 Field 12 INT8(11), 01 bytes: 0 Field 13 UINT32(16), 04 bytes: 171618 Field 14 INT8(11), 01 bytes: 1 Field 15 UINT8(14), 01 bytes: 0 Field 16 STRING(41), 00 bytes: Field 17 STRING(41), 00 bytes: RDR UNKNOWN(0xf0f0f020) .0:0 -> .0:0, PPC: 3, FC_ID: 0, size: 119, fields: 12 Field 01 STRING(41), 15 bytes: kolhoznaja_45_1 Field 02 UINT16(15), 02 bytes: 1 Field 03 INT32(13), 04 bytes: 16732 Field 04 INT32(13), 04 bytes: 163718 Field 05 UINT16(15), 02 bytes: 4615 Field 06 UINT16(15), 02 bytes: 37328 Field 07 UINT8(14), 01 bytes: 0 Field 08 BOOLEAN(31), 01 bytes: ... Field 09 BOOLEAN(31), 01 bytes: ... Field 10 UINT32(16), 04 bytes: 1366087031 Field 11 UINT32(16), 04 bytes: 87102 Field 12 UINT32(16), 04 bytes: 148938 Edited April 16, 2013 by murzik_one Вставить ник Quote
Дятел Posted April 16, 2013 Posted April 16, 2013 Если я правильно понял, то начиная с 3.8.0 нефло уже нет и не будет, так что, наверное, не нужно ковырять умирающую сущность, проще научиться работать с RDR. Вставить ник Quote
murzik_one Posted April 16, 2013 Posted April 16, 2013 Если я правильно понял, то начиная с 3.8.0 нефло уже нет и не будет, так что, наверное, не нужно ковырять умирающую сущность, проще научиться работать с RDR. Дак сконвертить то как то надо. Биллинг не понимает RDR он понимает скотина только netflow v5. Что-ж нам делать ущербным нищебродам? Вставить ник Quote
littlesavage Posted April 16, 2013 Posted April 16, 2013 murzik_one, на SCE нужно включить TRANSACTION_USAGE_RDR, используются только они. Вставить ник Quote
raveren Posted April 18, 2013 Posted April 18, 2013 Если я правильно понял, то начиная с 3.8.0 нефло уже нет и не будет, так что, наверное, не нужно ковырять умирающую сущность, проще научиться работать с RDR. Откуда такая информация насчёт "нефло уже нет и не будет"? Вставить ник Quote
raveren Posted April 22, 2013 Posted April 22, 2013 Кто использует rdr2netflow, обновитесь. Fix критичен, если есть subscriber'ы за PAT'ом. Вставить ник Quote
raveren Posted October 26, 2014 Posted October 26, 2014 RDR UNKNOWN(0xf0f0f546) возникает, если в настройках RDR, включен Extended TURs (include protocol specific information). Вставить ник Quote
