Есть подобная проблема с 7606, конфиги четырех одинаковых железок одинаковы, а проблема только с одной... Где-то собака порылась.
Uzel#sho ver
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRC4, RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2009 by Cisco Systems, Inc.
CompiUzel Tue 12-May-09 03:11 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
Uzel uptime is 1 year, 18 weeks, 4 days, 23 hours, 40 minutes
Uptime for this control processor is 1 year, 18 weeks, 4 days, 23 hours, 45 minutes
System returned to ROM by  power cycle (SP by power on)
System restarted at 15:59:36 MSK Tue Mar 2 2010
System image file is "bootdisk:c7600s72033-advipservicesk9-mz.122-33.SRC4.bin"
Last reload type: Normal Reload
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco CISCO7606 (R7000) processor (revision 1.0) with 983008K/65536K bytes of memory.
Processor board ID FOX10450KTB
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
638 Virtual Ethernet interfaces
98 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2102
Uzel#sho bootvar
BOOT variable = sup-bootdisk:c7600s72033-advipservicesk9-mz.122-33.SRC6.bin,1;
CONFIG_FILE variable =
BOOTLDR variable =
Standby is not up.
Uzel#dir
Directory of sup-bootdisk:/
   1  -rw-   123100196   Aug 9 2010 08:53:38 +04:00  c7600s72033-advipservicesk9-mz.122-33.SRC6.bin
   2  -rw-    33554432   Mar 4 2007 23:26:08 +03:00  sea_log.dat
   5  -rw-      223695  Jun 15 2009 23:19:46 +04:00  startup.15.06.09
   6  -rw-        8751  Jun 22 2009 13:00:26 +04:00  Uzel.int.txt
   7  -rw-   111395332   May 2 2009 14:13:50 +04:00  c7600s72033-advipservicesk9-mz.122-33.SRB5.bin
   8  -rw-        8751  Jun 15 2009 16:21:04 +04:00  ports.txt
   9  -rw-       67200  Jun 15 2009 16:22:34 +04:00  udld
  10  -rw-       31626  Jun 15 2009 16:49:48 +04:00  inv
  11  -rw-       31626  Jun 22 2009 13:01:04 +04:00  Uzel.inv.txt
  12  -rw-   123026468  Aug 20 2009 10:49:46 +04:00  c7600s72033-advipservicesk9-mz.122-33.SRC4.bin
512040960 bytes total (120545280 bytes free)
Uzel#
Edited by ilili
У вас 0x2102 - тут вроде всё ок
Ок то оно ок )) Только если будет аварийное отключение, по эл.питанию, придётся ехать, сама она не поднимается, к сожалению... Живем так уже давно *перекрестился*
Uzel#sho bootvar прям буква в букву на всех 4ёх свитчах?
Нет, на одном из маршрутизаторов
sh bootvar
BOOTLDR variable =
Standby BOOT variable = sup-bootdisk:c7600s72033-advipservicesk9-mz.122-33.SRC6.bin,1;
Standby CONFIG_FILE variable =
Standby BOOTLDR variable =
Standby Configuration register is 0x2102
т.е. на остальных трёх Standby опции нет
Edited by ilili
