TCL Скрипт звонит на внешний номер и должен проиграть сообщение:
Диал-пиры:
dial-peer voice 10 voip
 destination-pattern 05550052хх
 session target ipv4:192.168.201.2
 codec g711ulaw
Скрипт:
proc init { } {
               global param callinfo numExt1
               infotag set med_language_map 0 ru
               infotag set med_location ru 0 tftp://хх.хх.21.173/path/media/
               infotag set med_language 0
               set id "1"
               set callinfo(alertTime) 10
               set callinfo(originationNum) "хх6979"
               set numExt1 "05550052хх"
proc act_MakeCall { } {
               puts "DEBUG: act_MakeCall start"
               leg setup $numExt1 callinfo leg_outgoing
               puts "DEBUG: act_MakeCall stop"
               fsm setstate CHECKCALLSETUP
proc act_CheckCallSetup { } {
               puts "DEBUG: act_CheckCallSetup start"
               global param Status
               set Status [infotag get evt_status]
               switch $Status {
                               "ls_000" {
                                               media play leg_outgoing _welcome.au
                                               puts "DEBUG: CALL ACTIVE true"
                               default {
                                               puts "DEBUG: CALL FAILED, STATUS - $Status"
               puts "DEBUG: act_CheckCallSetup stop"
proc act_AfterMedia { } {
               puts "DEBUG: Media Finished"
               act_Cleanup
proc act_Cleanup { } {
               puts "DEBUG: act_Cleanup start"
               set status [infotag get evt_status]
               puts "DEBUG: STATUS is $status"
               call close
               puts "DEBUG: act_Cleanup stop"
requiredversion 2.0
init
# State Machine
set fsm(any_state,ev_disconnected) "act_Cleanup same_state"
set fsm(CALL_INIT,ev_session_indication) "act_MakeCall CHECKCALLSETUP"
set fsm(CHECKCALLSETUP,ev_setup_done) "act_CheckCallSetup MEDIAPLAY"
set fsm(MEDIAPLAY,ev_media_done) "act_AfterMedia CALLDISCONNECT"
set fsm(CALLDISCONNECT,ev_media_done) "act_Cleanup same_state"
set fsm(CALLDISCONNECT,ev_disconnect_done) "act_Cleanup same_state"
set fsm(CALLDISCONNECT,ev_leg_timer) "act_Cleanup same_state"
fsm define fsm CALL_INIT
Запуск:
Router#call application session start my_balance balance
Router#
May 31 11:07:41.733: //-1//TCL :EEC0EC34BC000:/tcl_PutsObjCmd: DEBUG: act_MakeCall start
May 31 11:07:41.733: //-1//TCL :EEC0EC34BC000:/tcl_PutsObjCmd: DEBUG: act_MakeCall stop
May 31 11:07:47.877: //-1//TCL :EEC0EC34BC000:/tcl_PutsObjCmd: DEBUG: act_CheckCallSetup start
May 31 11:07:47.877: //-1//DPM :DP1295:/pc_mc_createDynamicS: calloc mcDynamicS_t
May 31 11:07:47.877: //-1//DPM :DP1295:/pc_mc_addToDynamicS: (1) _welcome.au
May 31 11:07:47.877: //-1//DPM :DP1295:/pc_mc_addToDynamicS: Doing : _welcome.au
May 31 11:07:47.877: //-1//DPM :/mcTokenizerGetNext: savedcharptr=_ endptrptr=_welcome.au
May 31 11:07:47.877: //-1//DPM :DP1295:/pc_mc_addToDynamicS: Token : _welcome.au status 1
May 31 11:07:47.877: //-1//DPM :DP1295:/pc_mc_addToDynamicS: call dp_mcDQfromFileDynamic() to Handle relative file name
May 31 11:07:47.877: //-1//DPM :DP1295:/dp_mcDQfromFileDynamic: pLanguage=ru FileName=_welcome.au
May 31 11:07:47.877: //-1//DPM :DP1295:/dp_mcDQfromURL: file=tftp://хх.хх.21.173/path/media/ru_welcome.au
May 31 11:07:47.877: //-1//MCM :/mc_createFromFileUrl: Getting a media content: name=ru_welcome.au
       url=tftp://xx.xx.21.173/path/media/ru_welcome.au
       load fast, fetchtimeout=-1
May 31 11:07:47.877: //-1//MCM :MC8:/mc_getFromUrlName: ru_welcome.au on ram
May 31 11:07:47.877: //-1//MCM :MC8:/mc_waitq_unlink: elm=73DA58C4
May 31 11:07:47.877: //-1//MCM :MC8:/mc_waitq_unlink: prompt_wait=C0F88 prompt_active=0
May 31 11:07:47.877: //-1//MCM :MC8:/mc_waitq_delete: prompt_wait=C0F88 prompt_active=22D12
May 31 11:07:47.877: //-1//MCM :/mc_createFromFileUrl: Found a good mc (0x64E0C834), RefCount(1)
May 31 11:07:47.877: //-1//DPM :DP1295:/dp_mcDQfromURL: mc_createFromFileUrl OK
May 31 11:07:47.877: //-1//DPM :LP:DP1295:MC8:/dp_mcDQfromURL:
May 31 11:07:47.877: dp_mcDQfromURL enqueuing ru_welcome.au OK###
May 31 11:07:47.877: //-1//DPM :/mcTokenizerGetNext: savedcharptr= endptrptr=
May 31 11:07:47.877: //3303//MSW :/msw_create: cbf=0x6213F128
May 31 11:07:47.877: //-1//MSM :MS1313:/ms_create: Iniz ply_timer
May 31 11:07:47.877: //3303//MSW :/msw_synth_open: mediaStream 0x73697E30 created
May 31 11:07:47.877: //3303//MSW :/msw_synth_open: rtspStream 0x6734BE3C created,
                       status=RTSP_STATUS_SUCCESS, session_id=0x521 (1313)
May 31 11:07:47.877: //3303//MSW :/msw_synth_open: AIS : Creating TTS AIS Backend record
May 31 11:07:47.877: //-1//MSM :MS1314:/ms_create: Iniz ply_timer
May 31 11:07:47.877: //3303//MSW :/msw_recrd_open:
May 31 11:07:47.877: :msw_recrd_open mediaStream 0x65589ED8 created
May 31 11:07:47.877: //3303//MSW :/msw_recrd_open: rtspStream 0x6734BE44 created,
                       status=RTSP_STATUS_SUCCESS, session_id=0x522 (1314)
May 31 11:07:47.877: //3303//MSW :/msw_recog_open: AIS : Creating ASR AIS Backend record
May 31 11:07:47.877: //-1//MSW :/msw_associate_call:
May 31 11:07:47.877: msw_associate_call: callID=0xCE7(3303),
                                         genericStream=0xC0E99804
May 31 11:07:47.877: //3303//MSW :/msw_synth_get_stream_state: genericStream 0xC0E99804 is in state MSW_S_IDLE
May 31 11:07:47.877: //-1//MSW :/msw_synth_start:
May 31 11:07:47.877: msw_synth_start: Enter...
May 31 11:07:47.877: //3303//MSW :/msw_synth_start: current_stream_id=1, content 0x0, dynamicS 0x73D990F0, current_state=MSW_S_IDLE
May 31 11:07:47.877: //-1//MSW :/msw_synth_start: msw_synth_start: p_mcDynamicS, We've been given a list of URLs to play.
May 31 11:07:47.877: //-1//MSW :/msw_synth_start: p_mcDynamicQ is NOT empty
May 31 11:07:47.877: //3303//MSW :/msu_synth_partial_play: Media Stream URL
May 31 11:07:47.877: //-1//MCM :MR1289:/mc_createDynamicReader:
May 31 11:07:47.877: //3303//MSM :/ms_get_packet_size:
May 31 11:07:47.877: ms_get_packet_size NO Voice Class codec
May 31 11:07:47.877: //3303//MSM :/ms_associate: packet_size = 160 timestamp increment = 160 packet_duration = 20 Coder = 5 vad = 0 SampleRate = 8000
May 31 11:07:47.877: //3303//MSM :/ms_associate: >>ccAssociateStream()
May 31 11:07:47.877: //-1//TCL :EEC0EC34BC000:/tcl_PutsObjCmd: DEBUG: CALL ACTIVE true
May 31 11:07:47.877: //-1//TCL :EEC0EC34BC000:/tcl_PutsObjCmd: DEBUG: act_CheckCallSetup stop
Звонок приходит на 05550052хх, поднимаю трубку и тишина.
Смущает ошибка:
Во входящий лег промт проигрывается. С исходящим проблема.
Edited by Macro
