Подключение происходит, интернет раздается, но в мониторинге нет статистики получено/отправлено и
если клиент отключается, сессия все равно висит в билинге.
freeradius -X
FreeRADIUS Version 2.1.10, for host i486-pc-linux-gnu, built on Nov 14 2010 at 20:41:03
Copyright © 1999-2009 The FreeRADIUS server project and contributors.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
You may redistribute copies of FreeRADIUS under the terms of the
GNU General Public License v2.
Starting - reading configuration files ...
including configuration file /etc/freeradius/radiusd.conf
including configuration file /etc/freeradius/proxy.conf
including configuration file /etc/freeradius/clients.conf
including configuration file /etc/freeradius/snmp.conf
including configuration file /etc/freeradius/policy.conf
including files in directory /etc/freeradius/sites-enabled/
including configuration file /etc/freeradius/sites-enabled/default
main {
user = "freerad"
group = "freerad"
allow_core_dumps = no
including dictionary file /etc/freeradius/dictionary
main {
prefix = "/usr"
localstatedir = "/var"
logdir = "/var/log/freeradius"
libdir = "/usr/lib/freeradius"
radacctdir = "/var/log/freeradius/radacct"
hostname_lookups = no
max_request_time = 30
cleanup_delay = 5
max_requests = 1024
pidfile = "/var/run/freeradius/freeradius.pid"
checkrad = "/usr/sbin/checkrad"
debug_level = 0
proxy_requests = yes
log {
stripped_names = no
auth = no
auth_badpass = no
auth_goodpass = no
security {
max_attributes = 200
reject_delay = 1
status_server = yes
radiusd: #### Loading Realms and Home Servers ####
proxy server {
retry_delay = 5
retry_count = 3
default_fallback = no
dead_time = 120
wake_all_if_all_dead = no
home_server localhost {
ipaddr = 127.0.0.1
port = 1812
type = "auth"
secret = "testing123"
response_window = 20
max_outstanding = 65536
require_message_authenticator = yes
zombie_period = 40
status_check = "status-server"
ping_interval = 30
check_interval = 30
num_answers_to_alive = 3
num_pings_to_alive = 3
revive_interval = 120
status_check_timeout = 4
irt = 2
mrt = 16
mrc = 5
mrd = 30
home_server_pool my_auth_failover {
type = fail-over
home_server = localhost
realm example.com {
auth_pool = my_auth_failover
realm LOCAL {
radiusd: #### Loading Clients ####
client localhost {
require_message_authenticator = no
secret = "radsecret"
shortname = "shortname"
radiusd: #### Instantiating modules ####
instantiate {
Module: Linked to module rlm_exec
Module: Instantiating module "exec" from file /etc/freeradius/radiusd.conf
exec {
wait = yes
input_pairs = "request"
output_pairs = "reply"
shell_escape = yes
Module: Linked to module rlm_expr
Module: Instantiating module "expr" from file /etc/freeradius/radiusd.conf
Module: Linked to module rlm_expiration
Module: Instantiating module "expiration" from file /etc/freeradius/radiusd.conf
expiration {
reply-message = "Password Has Expired "
Module: Linked to module rlm_logintime
Module: Instantiating module "logintime" from file /etc/freeradius/radiusd.conf
logintime {
reply-message = "You are calling outside your allowed timespan "
minimum-timeout = 60
radiusd: #### Loading Virtual Servers ####
server { # from file /etc/freeradius/radiusd.conf
modules {
Module: Checking authorize {...} for more modules to load
Module: Linked to module rlm_preprocess
Module: Instantiating module "preprocess" from file /etc/freeradius/radiusd.conf
preprocess {
huntgroups = "/etc/freeradius/huntgroups"
hints = "/etc/freeradius/hints"
with_ascend_hack = no
ascend_channels_per_line = 23
with_ntdomain_hack = no
with_specialix_jetstream_hack = no
with_cisco_vsa_hack = no
with_alvarion_vsa_hack = no
Module: Instantiating module "abills_preauth" from file /etc/freeradius/radiusd.conf
exec abills_preauth {
wait = yes
program = "/usr/abills/libexec/rauth.pl pre_auth"
output_pairs = "config"
shell_escape = yes
Module: Instantiating module "abills_auth" from file /etc/freeradius/radiusd.conf
exec abills_auth {
wait = yes
program = "/usr/abills/libexec/rauth.pl"
shell_escape = yes
Module: Checking preacct {...} for more modules to load
Module: Instantiating module "abills_acc" from file /etc/freeradius/radiusd.conf
exec abills_acc {
wait = yes
program = "/usr/abills/libexec/racct.pl"
shell_escape = yes
Module: Checking post-auth {...} for more modules to load
Module: Instantiating module "abills_postauth" from file /etc/freeradius/radiusd.conf
exec abills_postauth {
wait = yes
program = "/usr/abills/libexec/rauth.pl post_auth"
shell_escape = yes
} # modules
} # server
radiusd: #### Opening IP addresses and Ports ####
listen {
type = "auth"
ipaddr = *
port = 0
listen {
type = "acct"
ipaddr = *
port = 0
Listening on authentication address * port 1812
Listening on accounting address * port 1813
Listening on proxy address * port 1814
Ready to process requests.
rad_recv: Access-Request packet from host 127.0.0.1 port 59196, id=185, length=92
Service-Type = Framed-User
Framed-Protocol = PPP
User-Name = "biz001"
CHAP-Challenge = 0x4e733de5c1436da43e681e07df2a39b490a415
CHAP-Password = 0x0a19606a09160e065b5029e082edcdb71c
NAS-IP-Address = 127.0.0.1
NAS-Port = 0
# Executing section authorize from file /etc/freeradius/sites-enabled/default
+- entering group authorize {...}
++[preprocess] returns ok
Exec-Program output: Auth-Type := Accept
Exec-Program-Wait: value-pairs: Auth-Type := Accept
Exec-Program: returned: 0
++[abills_preauth] returns ok
Exec-Program output: Session-Timeout = 1202725, Session-Octets-Limit = 2146435072, PPPD-Downstream-Speed-Limit = 256, Acct-Interim-Interval = 120, User-Name = biz001, PPPD-Upstream-Speed-Limit = 256, Octets-Direction = 0, Framed-IP-Address = 172.16.0.51, Framed-IP-Netmask = 255.255.255.255,
Exec-Program-Wait: value-pairs: Session-Timeout = 1202725, Session-Octets-Limit = 2146435072, PPPD-Downstream-Speed-Limit = 256, Acct-Interim-Interval = 120, User-Name = biz001, PPPD-Upstream-Speed-Limit = 256, Octets-Direction = 0, Framed-IP-Address = 172.16.0.51, Framed-IP-Netmask = 255.255.255.255,
++[abills_auth] returns ok
Found Auth-Type = Accept
Auth-Type = Accept, accepting the user
WARNING: Empty post-auth section. Using default return values.
# Executing section post-auth from file /etc/freeradius/sites-enabled/default
Sending Access-Accept of id 185 to 127.0.0.1 port 59196
Octets-Direction = Route-IP-No
Finished request 0.
Going to the next request
Waking up in 4.9 seconds.
rad_recv: Accounting-Request packet from host 127.0.0.1 port 53022, id=186, length=98
Acct-Session-Id = "4DD2FCAB0A0100"
Acct-Status-Type = Start
Acct-Authentic = RADIUS
NAS-Port-Type = Virtual
NAS-Port = 0
Acct-Delay-Time = 0
# Executing section preacct from file /etc/freeradius/sites-enabled/default
+- entering group preacct {...}
++[abills_acc] returns ok
WARNING: Empty accounting section. Using default return values.
Finished request 1.
Cleaning up request 1 ID 186 with timestamp +30
Waking up in 4.7 seconds.
Смотрите, что по interim и stop пакетам будет. start аккаунтнг то как раз приходит и обрабатывается (иначе сессия в мониторинг бы не попала).
Какая логика сбора статистики получено/отправлено?
ориентируетесь только на Stop-овый пакет от BRAS?
alive не ловите?
Stop пакет может и потеряться.
Значит останавливаете сервер radius, запускаете его с ключен -x для вывода отладки, подключаетесь клиентом и смотрите, где у Вас бока. А еще проверьте права на все папки с Abills, были такие грабли просто небыло прав на папку :) Удачи!
  • 9 months later...
пытаюсь настроить ABillS + Ubuntu + FreeRadius2 + RLMPerl инструкция тут
запускаю в режиме отладки:
root@tv:/usr# /usr/local/freeradius/sbin/radiusd -X
FreeRADIUS Version 2.1.12, for host i686-pc-linux-gnu, built on Mar  2 2012 at 19:31:47
Copyright (C) 1999-2009 The FreeRADIUS server project and contributors.
PARTICULAR PURPOSE.
including configuration file /usr/local/freeradius/etc/raddb/radiusd.conf
including configuration file /usr/local/freeradius/etc/raddb/clients.conf
including files in directory /usr/local/freeradius/etc/raddb/modules/
including configuration file /usr/local/freeradius/etc/raddb/modules/perl
including configuration file /usr/local/freeradius/etc/raddb/modules/digest
including configuration file /usr/local/freeradius/etc/raddb/modules/inner-eap
including configuration file /usr/local/freeradius/etc/raddb/modules/detail.log
including configuration file /usr/local/freeradius/etc/raddb/modules/preprocess
including configuration file /usr/local/freeradius/etc/raddb/modules/exec
including configuration file /usr/local/freeradius/etc/raddb/modules/krb5
including configuration file /usr/local/freeradius/etc/raddb/modules/sradutmp
including configuration file /usr/local/freeradius/etc/raddb/modules/counter
including configuration file /usr/local/freeradius/etc/raddb/modules/pam
including configuration file /usr/local/freeradius/etc/raddb/modules/linelog
including configuration file /usr/local/freeradius/etc/raddb/modules/smsotp
including configuration file /usr/local/freeradius/etc/raddb/modules/passwd
including configuration file /usr/local/freeradius/etc/raddb/modules/attr_filter
including configuration file /usr/local/freeradius/etc/raddb/modules/rediswho
including configuration file /usr/local/freeradius/etc/raddb/modules/sqlcounter_expire_on_login
including configuration file /usr/local/freeradius/etc/raddb/modules/ippool
including configuration file /usr/local/freeradius/etc/raddb/modules/unix
including configuration file /usr/local/freeradius/etc/raddb/modules/smbpasswd
including configuration file /usr/local/freeradius/etc/raddb/modules/etc_group
including configuration file /usr/local/freeradius/etc/raddb/modules/echo
including configuration file /usr/local/freeradius/etc/raddb/modules/attr_rewrite
including configuration file /usr/local/freeradius/etc/raddb/modules/ldap
including configuration file /usr/local/freeradius/etc/raddb/modules/pap
including configuration file /usr/local/freeradius/etc/raddb/modules/radutmp
including configuration file /usr/local/freeradius/etc/raddb/modules/cui
including configuration file /usr/local/freeradius/etc/raddb/modules/realm
including configuration file /usr/local/freeradius/etc/raddb/modules/mac2ip
including configuration file /usr/local/freeradius/etc/raddb/modules/wimax
including configuration file /usr/local/freeradius/etc/raddb/modules/sql_log
including configuration file /usr/local/freeradius/etc/raddb/modules/logintime
including configuration file /usr/local/freeradius/etc/raddb/modules/opendirectory
including configuration file /usr/local/freeradius/etc/raddb/modules/ntlm_auth
including configuration file /usr/local/freeradius/etc/raddb/modules/acct_unique
including configuration file /usr/local/freeradius/etc/raddb/modules/files
including configuration file /usr/local/freeradius/etc/raddb/modules/policy
including configuration file /usr/local/freeradius/etc/raddb/modules/always
including configuration file /usr/local/freeradius/etc/raddb/modules/checkval
including configuration file /usr/local/freeradius/etc/raddb/modules/expiration
including configuration file /usr/local/freeradius/etc/raddb/modules/replicate
including configuration file /usr/local/freeradius/etc/raddb/modules/expr
including configuration file /usr/local/freeradius/etc/raddb/modules/otp
including configuration file /usr/local/freeradius/etc/raddb/modules/soh
including configuration file /usr/local/freeradius/etc/raddb/modules/dynamic_clients
including configuration file /usr/local/freeradius/etc/raddb/modules/detail.example.com
including configuration file /usr/local/freeradius/etc/raddb/modules/mschap
including configuration file /usr/local/freeradius/etc/raddb/modules/chap
including configuration file /usr/local/freeradius/etc/raddb/modules/mac2vlan
including configuration file /usr/local/freeradius/etc/raddb/policy.conf
including configuration file /usr/local/freeradius/etc/raddb/sites-enabled/abills_default
main {
       user = "freerad"
       group = "freerad"
including dictionary file /usr/local/freeradius/etc/raddb/dictionary
main {
       name = "radiusd"
       prefix = "/usr/local/freeradius"
       sbindir = "/usr/local/freeradius/sbin"
       logdir = "/var/log"
       run_dir = "/var/run/radiusd"
       libdir = "/usr/local/lib/freeradius-2.1.6"
       radacctdir = "/var/log/radacct"
       cleanup_delay = 5
       max_requests = 80960
       pidfile = "/var/run/radiusd/radiusd.pid"
       checkrad = "/usr/local/freeradius/sbin/checkrad"
       debug_level = 0
       proxy_requests = no
log {
       stripped_names = no
       auth = no
       auth_badpass = no
       auth_goodpass = no
security {
       reject_delay = 1
       status_server = yes
client 127.0.0.1 {
       shortname = "shorrname"
instantiate {
Module: Instantiating module "exec" from file /usr/local/freeradius/etc/raddb/modules/exec
 exec {
       wait = no
       shell_escape = yes
Module: Instantiating module "expiration" from file /usr/local/freeradius/etc/raddb/modules/expiration
 expiration {
Module: Instantiating module "logintime" from file /usr/local/freeradius/etc/raddb/modules/logintime
 logintime {
server { # from file /usr/local/freeradius/etc/raddb/radiusd.conf
modules {
 Module: Creating Auth-Type = Perl
 Module: Creating Post-Auth-Type = REJECT
Module: Checking authenticate {...} for more modules to load
Module: Linked to module rlm_pap
Module: Instantiating module "pap" from file /usr/local/freeradius/etc/raddb/modules/pap
 pap {
       encryption_scheme = "auto"
       auto_header = no
Module: Linked to module rlm_mschap
Module: Instantiating module "mschap" from file /usr/local/freeradius/etc/raddb/modules/mschap
 mschap {
       use_mppe = yes
       require_encryption = no
       require_strong = no
       allow_retry = yes
/usr/local/freeradius/etc/raddb/modules/perl[1]: Failed to link to module 'rlm_perl': rlm_perl.so: cannot open shared object file: No such file or directory
/usr/local/freeradius/etc/raddb/sites-enabled/abills_default[10]: Failed to load module "perl".
/usr/local/freeradius/etc/raddb/sites-enabled/abills_default[10]: Failed to parse "perl" entry.
понял, что нет rlm_perl.so, где его взять так и не понял. Помогите сдвинуться с места.
P.S. Cмутило в raduisd.conf
libdir = /usr/local/lib/freeradius-2.1.6
такой папки нет, откуда библиотеки берутся - не понятно...
Радиус версии 2.1.12, abills 0.53, убунту 11.10. Остальные конфиги также могу предоставить
PARTICULAR PURPOSE.
main {
       user = "freerad"
       group = "freerad"
main {
       name = "radiusd"
       logdir = "/var/log"
       cleanup_delay = 5
       debug_level = 0
       proxy_requests = no
log {
       stripped_names = no
       auth = no
       auth_badpass = no
       auth_goodpass = no
security {
       reject_delay = 1
       status_server = yes
client 127.0.0.1 {
instantiate {
 exec {
       wait = no
       shell_escape = yes
 expiration {
 logintime {
modules {
 pap {
       auto_header = no
 mschap {
       use_mppe = yes
       require_strong = no
       allow_retry = yes
Мои страдания с абиллсом на линукс закончились после установки его на FreeBSD.
Edited by lllsergeyv
Вряха самое-то для бывших виндузятников... крестики поставил где надо и жди.. деградация рулит среди населения...
Потому как менять ось из-за того, что что-то не получилось - бред. так до смешного можно дойти...
Edited by zakachkin
Данный продукт под фрей работает на много лучше. А на счет крестиков Вы что-то путаете. И чем Вам винда не угодила. Каждая ось решает свою задачу, а тупо пихать везде линкс вот это и есть бред.
еммм..
ну расскажите тогда, что там есть в нём такого-этакого ос-ориентированного (именно в биллинге который написан на перл и юзает мускул с радиусом) ЧТО ВО ФРЕ работает лучше ?....
работает оно одинаково как во фре так и в linux.
Если в кого то руки не оттуда ростут и есть проблема в установке-настройке - то это их личные проблемы
еммм..
думаю руки тут ни причём люди ленятся даже мануал по установке прочитать до конца
еммм..
Канечно мне лень на Ubuntu(Debian) ставить радиус такми способом:
cd freeradius-server-2.1.11
./configure --prefix=/usr/local/freeradius --with-rlm-perl-lib-dir=/usr/lib/
make && make install
ln -s /usr/local/freeradius/sbin/radiusd /usr/sbin/radiusd
Ну да ладно... Когда я пытался перейти на линукс и такой доки не было. По фре все замечательно было описано.
Почему ввиду "безразличности" к платформе разработчики хотят за установку на FreeBSD 800$, а за установку на Linux 1000$? от чего такая несправедливость? или фрей пользуются нищеброды, а линуксом крутые перцы, с которых и две штуки сбить можно? Когда вы снезойдете до того, чтоб сделать установочный пакет для своего продукта(хотябы для платной версии.. и не нужно мне говорить что сами все усатновят.. на свой сервер я никого не пущу)?
Я выбрал более легкий путь и поделился своим субъективным мнением. Чем мой выбор не правильный?
Ваш выбор правильный, несомненно. Но не стоит советовать человеку дробовик, если он со своей проблемой справился при помощи вальтера.
нда .... как всё запущено... видно, что человек не в курсе о системе пакетов. Как научили под фрями компилить всё по надобности и без - так и едет. Вы так и во фре всё компилите ? там есть порты говоря, пекеджи там всякие тоже есть ....
ПС. Хотелось бы всё таки услышать ответ о "Данный продукт под фрей работает на много лучше" и что там есть в нём такого-этакого ос-ориентированного (именно в биллинге который написан на перл и юзает мускул с радиусом) ЧТО ВО ФРЕ работает лучше ?
Edited by Lynx10
"Все запущено" у тех, кто постит такое на официальном сайте проекта в документации ссылка
На фре я все ставил из портов, а на debian из пакетов, не нужно мне об этом напоминать.
По поводу работы: На debian etch freeradius из включеным rlm_perl выжирал всю память, приходилось раз в неделю перезагружать процесс. На фре такого прикола замечено не было. Когда появилась надобность дергать радис раз в день, то решили вернуться назад на фрю и всем довольны.
Я бы наоборот поблагодарил автора на вашем месте за то, что вы можете, я так понимаю, безвозмездно юзать его продукт и строить на нём бизнес.
не всё так плохо оказывается
а вот это странно... работает радиус под линуксом (правда не на дебиане) годами без перезагрузки.
Edited by Lynx10
Может щас и лучше стало.. но лень пробовать.. без rlm_perl все было отлично
после того как в линуксе в одних дистрибутивах начали собирать радиус с потоками а модуль rlm_perl без (соответвенно ничгео не работало) мы отказались собирать радиус с пакетов под линукс, а только с исходников
в комерческой версии есть автоконфигуратор так что сбор пакетов и их конфигурация происходит автоматически
еммм..
Ну да.. Очередная басня о Кулике и его Болоте :)
А если я, например, решаю одни задачи на Linux, а другие на FreeBSD и при этом считаю, что задача "А" решается проще-лучше-удобнее на Linux, а задача "В" соответственно на FreeBSD, то тут как?
Хто я есть такой, и из откуда произрастают мои руки? ;)
P.S. Для примера - 3 года "сидел" на Linux pptp с биллингом FreeNibs, если кто-то еще помнит такой :). Кстати, ну очень похоже на ABills. ;) Проблематично было, если не сказать хуже. Затем по совету коллеги скомпилил это же "изделие" на FreeBSD+mpd, и... Был неожиданно приятно удивлен, как тут (на FreeBSD) все получилось просто/удобно/понятно. НО!!!
Роутеры, фаервол и НАТ до сих пор юзаю на Linux и считаю, что он (Linux) более приспособлен и удобен для решения этих задач.
P.P.S. Может быть я и ошибаюсь, но все же считаю, что шуруп (саморез) необходимо заворачивать отверткой, а не забивать молотком, хотя и результат вроде бы одинаков - держится! :).
Это я про "инструмент", если кому-то непонятно.. ;)
Да, и еще про ABills и FreeBSD - первый есть в портах второго, и без проблем устанавливается (проверено), а вот на Linux его ни в yum, ни в rpm нет, и без configure/make/make install + танцы с бубном на раз-два не соберёшь..
Тут конечно, можно снова поспорить насчёт наличия "прямого /dev/hands", но.. Как говориться, кесарю кесарево, а слесарю слесарево! :) В любой дом приличные люди входят через дверь..
Edited by AlKov
Щас Вам раскажут как нужно строить нат на фре :)
